    3. Einsteigerfragen
    4. Installation
    5. Installation echt nicht möglich...
      Thomas Braun Most Active @Hammer Klaus last edited by
      @hammer-klaus
      Bitte in CodeTags. Danke.
      Hammer Klaus 1 Reply Last reply Reply Quote 0
      • Hammer Klaus
        Hammer Klaus @Thomas Braun last edited by
        pi@iobroker-pi:~ $ free -ht --mega
        Mem:           972M        533M        135M        6.0M        303M        447M
        Swap:           99M          0B         99M
        Total:         1.1G        533M        235M
          @hammer-klaus
          Das schaut erstmal gesund aus.
          Ist da der ioBroker drauf?
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          iobroker status
          iobroker update
          anschauen.
          • Hammer Klaus
            pi@iobroker-pi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.20.0
            v14.20.0
            6.14.17
            4.0.23
            pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
            /home/pi
            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
            Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
            Reading package lists... Done
            Building dependency tree
            111 packages can be upgraded. Run 'apt list --upgradable' to see them.
            nodejs:
              Installed: 14.20.0-deb-1nodesource1
              Candidate: 14.20.1-deb-1nodesource1
              Version table:
                 14.20.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
             *** 14.20.0-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
            pi@iobroker-pi:~ $ iobroker status
            Objects type: jsonl
            States  type: jsonl
            pi@iobroker-pi:~ $ iobroker update
            Used repository: stable
            Adapter    "admin"        : 6.2.22   , installed 6.2.22
            Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
            Adapter    "history"      : 2.2.0    , installed 2.2.0
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
            Adapter    "javascript"   : 6.0.3    , installed 6.0.3
            Adapter    "shelly"       : 6.0.0    , installed 6.0.0
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
              @hammer-klaus sagte in Installation echt nicht möglich...:
              Dann mach das mal zuerst.
              • Hammer Klaus
                Das wird was dauern. Weil ich vorher ein Image der installation mache.
                  @hammer-klaus
                  Mach was du willst. Aber halte die Kiste auf Stand.
                    crunchip Forum Testing Most Active @Hammer Klaus last edited by
                    Genervt davon, dass meine Automation nicht läuft, habe ich iobroker neu auf dem Raspi4 installiert, alles neu gemacht.
                    Prima. --- für 2 tage. iobroker bleibt einfach hängen. Nix mehr. Raspi reagiert auf nix.
                    und was zeigt z.b. das log, irgendwo muss es ja dann klemmen
                    • da_Woody
                      da_Woody @Hammer Klaus last edited by
                      also separaten PC aufgesetzt mit Linux Mint21
                      Das Docker image installiert und konfiguriert.
                      warum? entweder direkt unter debian ioB insten, oder proxmox und dann eine VM drauf.
                      was soll das docker dingens?
                      • Hammer Klaus
                        Hammer Klaus @da_Woody last edited by
                        @da_woody
                        Weil das Docker Ding als offizielle Version angegeben ist:
                        https://www.iobroker.net/#de/download
                        Und das Installationsscript:
                        curl -sLf https://iobroker.net/install.sh | bash -
                        Vor die Wand fährt.
                        Wenn ich eine fertige VM hätte, wäre ich froh.
                        • da_Woody
                          @hammer-klaus darum frag ich ja. du hast einen rechner.
                          inste dort debian, https://www.debian.org/releases/bullseye/installmanual und dann ioB mit der zeile.
                          das hat doch nix mit docker zu tun! docker hat nichts mit linux zu tun.
                          • Hammer Klaus
                            @da_woody
                            Sag mal, Du hast schon gelesen, das das Script nicht läuft, oder?
                            Siehe Post von @Jey-Cee
                            https://forum.iobroker.net/topic/58380/installation-echt-nicht-möglich/11?_=1664282299559
                            Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                              Versuch mal die 64bit-Version vom Raspberry OS.
                              • Hammer Klaus
                                Wir hatten heute Morgen festgestellt, dass mein Raspi 3 zu schwach ist. Also: Warum soll ich jetzt da ein anderes RaspiOS drauf tun?
                                Das IOBroker Image läuft, hängt nur alle 48h
                                Für den Preis eines Raspi 4 kann ich aktuell jemanden einstellen, der durchs Haus läuft und Schalter drückt.
                                Auf einem echten Rechner mit Linux xyz läuft das Installscript vor die Wand.
                                Der Docker Container ist nutzlos.
                                Also warte ich, bis irgendwann der Fehler mit NPM behoben ist (siehe post von @Jey-Cee ) und dann installiere ich das auf einem Rechner.
                                  @hammer-klaus
                                  Ich kann dir nicht folgen, mit welchem System du da gerade zugange bist.
                                  Rpi... Docker... Native Installation...
                                  Den 'Fehler' mit dem Zugriff auf das /tmp-Verzeichnis kenne ich nur aus einem anderen Zusammenhang. Da lief es mit dem 64bit RPI-OS, mit der 32bit-Version klemmte es.
                                  • da_Woody
                                    @hammer-klaus so, hab mir den spaß angetan. neue VM in proxmox geschnitzt, debian. danach deine, die richtige zeile eingegeben in putty.
                                    was funktioniert da nicht?
                                    • Hammer Klaus
                                      @da_woody
                                      Ich verwende ein Linux Mint. und bekomme die Fehlermeldung:
                                      Installing ioBroker (3/4)
                                      npm ERR! code 1
                                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                      npm ERR! command failed
                                      npm ERR! command sh /tmp/install-0b2854f4.sh
                                      npm ERR! node:internal/modules/cjs/loader:959
                                      npm ERR! throw err;
                                      npm ERR! ^
                                      npm ERR!
                                      npm ERR! Error: Cannot find module 'winston'
                                      npm ERR! Require stack:
                                      npm ERR! - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
                                      npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
                                      npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                      npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                      npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                      npm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                      npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                      npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19)
                                      npm ERR! at require (node:internal/modules/cjs/helpers:102:18)
                                      npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:3:15)
                                      npm ERR! at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                      npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                      npm ERR! at Module.load (node:internal/modules/cjs/loader:1004:32)
                                      npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                      npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19) {
                                      npm ERR! code: 'MODULE_NOT_FOUND',
                                      npm ERR! requireStack: [
                                      npm ERR! '/opt/iobroker/node_modules/winston-daily-rotate-file/index.js',
                                      npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js',
                                      npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                      npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                      npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      npm ERR! ]
                                      npm ERR! }
                                      npm ERR! /home/iobroker/.npm/_logs/2022-09-27T07_30_51_414Z-debug-0.log
                                      Finalizing installation (4/4)
                                      Enabling autostart...
                                      Autostart enabled!
                                      Fixing directory permissions...
                                      ioBroker was installed successfully
                                      Open http://172.xx.xxx.xx:8081 in a browser and start configuring!
                                      O.K. allso mache ich das System platt und probiere es mit Debian erneut... 😕
                                      da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • Hammer Klaus
                                        Ich habe alles drei ausprobiert.
                                        Noch bevor ich den ersten Post abgeschickt habe.
                                        • da_Woody
                                          da_Woody @Hammer Klaus last edited by da_Woody
                                          @hammer-klaus könntest du dein log in 6c8d18e7-93c5-44dc-b545-b0cfbaa752e8-grafik.png stellen, so ist das unleserlich... 😉
                                          und was sagt dein browser nach dem aufruf?
                                          nebenbei, lass das xxxen. mit deiner internen IP kann keiner was anfangen.
                                          • Hammer Klaus
                                            @da_woody
                                            Der Browser sagt: Da läuft nix.
                                            4682
