    3. Einsteigerfragen
    4. Installation
    5. Installation echt nicht möglich...
      Thomas Braun Most Active @Hammer Klaus last edited by
      @hammer-klaus
      Das schaut erstmal gesund aus.
      Ist da der ioBroker drauf?
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      iobroker status
      iobroker update
      anschauen.
      Hammer Klaus 1 Reply Last reply Reply Quote 0
      • Hammer Klaus
        Hammer Klaus @Thomas Braun last edited by
        pi@iobroker-pi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.20.0
        v14.20.0
        6.14.17
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        /home/pi
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
        Reading package lists... Done
        Building dependency tree
        111 packages can be upgraded. Run 'apt list --upgradable' to see them.
        nodejs:
          Installed: 14.20.0-deb-1nodesource1
          Candidate: 14.20.1-deb-1nodesource1
          Version table:
             14.20.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         *** 14.20.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
        pi@iobroker-pi:~ $ iobroker status
        Objects type: jsonl
        States  type: jsonl
        pi@iobroker-pi:~ $ iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.22
        Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          @hammer-klaus sagte in Installation echt nicht möglich...:
          Dann mach das mal zuerst.
          • Hammer Klaus
            Das wird was dauern. Weil ich vorher ein Image der installation mache.
              @hammer-klaus
              Mach was du willst. Aber halte die Kiste auf Stand.
                crunchip Forum Testing Most Active @Hammer Klaus last edited by
                Genervt davon, dass meine Automation nicht läuft, habe ich iobroker neu auf dem Raspi4 installiert, alles neu gemacht.
                Prima. --- für 2 tage. iobroker bleibt einfach hängen. Nix mehr. Raspi reagiert auf nix.
                und was zeigt z.b. das log, irgendwo muss es ja dann klemmen
                • da_Woody
                  da_Woody @Hammer Klaus last edited by
                  also separaten PC aufgesetzt mit Linux Mint21
                  Das Docker image installiert und konfiguriert.
                  warum? entweder direkt unter debian ioB insten, oder proxmox und dann eine VM drauf.
                  was soll das docker dingens?
                  • Hammer Klaus
                    Hammer Klaus @da_Woody last edited by
                    @da_woody
                    Weil das Docker Ding als offizielle Version angegeben ist:
                    https://www.iobroker.net/#de/download
                    Und das Installationsscript:
                    curl -sLf https://iobroker.net/install.sh | bash -
                    Vor die Wand fährt.
                    Wenn ich eine fertige VM hätte, wäre ich froh.
                    • da_Woody
                      @hammer-klaus darum frag ich ja. du hast einen rechner.
                      inste dort debian, https://www.debian.org/releases/bullseye/installmanual und dann ioB mit der zeile.
                      das hat doch nix mit docker zu tun! docker hat nichts mit linux zu tun.
                      • Hammer Klaus
                        @da_woody
                        Sag mal, Du hast schon gelesen, das das Script nicht läuft, oder?
                        Siehe Post von @Jey-Cee
                        https://forum.iobroker.net/topic/58380/installation-echt-nicht-möglich/11?_=1664282299559
                        Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                          Versuch mal die 64bit-Version vom Raspberry OS.
                          • Hammer Klaus
                            Wir hatten heute Morgen festgestellt, dass mein Raspi 3 zu schwach ist. Also: Warum soll ich jetzt da ein anderes RaspiOS drauf tun?
                            Das IOBroker Image läuft, hängt nur alle 48h
                            Für den Preis eines Raspi 4 kann ich aktuell jemanden einstellen, der durchs Haus läuft und Schalter drückt.
                            Auf einem echten Rechner mit Linux xyz läuft das Installscript vor die Wand.
                            Der Docker Container ist nutzlos.
                            Also warte ich, bis irgendwann der Fehler mit NPM behoben ist (siehe post von @Jey-Cee ) und dann installiere ich das auf einem Rechner.
                              @hammer-klaus
                              Ich kann dir nicht folgen, mit welchem System du da gerade zugange bist.
                              Rpi... Docker... Native Installation...
                              Den 'Fehler' mit dem Zugriff auf das /tmp-Verzeichnis kenne ich nur aus einem anderen Zusammenhang. Da lief es mit dem 64bit RPI-OS, mit der 32bit-Version klemmte es.
                              • da_Woody
                                @hammer-klaus so, hab mir den spaß angetan. neue VM in proxmox geschnitzt, debian. danach deine, die richtige zeile eingegeben in putty.
                                was funktioniert da nicht?
                                • Hammer Klaus
                                  @da_woody
                                  Ich verwende ein Linux Mint. und bekomme die Fehlermeldung:
                                  Installing ioBroker (3/4)
                                  npm ERR! code 1
                                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                  npm ERR! command failed
                                  npm ERR! command sh /tmp/install-0b2854f4.sh
                                  npm ERR! node:internal/modules/cjs/loader:959
                                  npm ERR! throw err;
                                  npm ERR! ^
                                  npm ERR!
                                  npm ERR! Error: Cannot find module 'winston'
                                  npm ERR! Require stack:
                                  npm ERR! - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                  npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                  npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                  npm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                  npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                  npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19)
                                  npm ERR! at require (node:internal/modules/cjs/helpers:102:18)
                                  npm ERR! at Object.<anonymous> (/opt/iobroker/node_modules/winston-daily-rotate-file/index.js:3:15)
                                  npm ERR! at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                  npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                  npm ERR! at Module.load (node:internal/modules/cjs/loader:1004:32)
                                  npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                  npm ERR! at Module.require (node:internal/modules/cjs/loader:1028:19) {
                                  npm ERR! code: 'MODULE_NOT_FOUND',
                                  npm ERR! requireStack: [
                                  npm ERR! '/opt/iobroker/node_modules/winston-daily-rotate-file/index.js',
                                  npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js',
                                  npm ERR! '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                  npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                  npm ERR! '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  npm ERR! ]
                                  npm ERR! }
                                  npm ERR! /home/iobroker/.npm/_logs/2022-09-27T07_30_51_414Z-debug-0.log
                                  Finalizing installation (4/4)
                                  Enabling autostart...
                                  Autostart enabled!
                                  Fixing directory permissions...
                                  ioBroker was installed successfully
                                  Open http://172.xx.xxx.xx:8081 in a browser and start configuring!
                                  O.K. allso mache ich das System platt und probiere es mit Debian erneut... 😕
                                  da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • Hammer Klaus
                                    Ich habe alles drei ausprobiert.
                                    Noch bevor ich den ersten Post abgeschickt habe.
                                    • da_Woody
                                      da_Woody @Hammer Klaus last edited by da_Woody
                                      @hammer-klaus könntest du dein log in 6c8d18e7-93c5-44dc-b545-b0cfbaa752e8-grafik.png stellen, so ist das unleserlich... 😉
                                      und was sagt dein browser nach dem aufruf?
                                      nebenbei, lass das xxxen. mit deiner internen IP kann keiner was anfangen.
                                      • Hammer Klaus
                                        @da_woody
                                        Der Browser sagt: Da läuft nix.
                                        • da_Woody
                                          @hammer-klaus wie schon geschrieben, wenn dein rechner power hat, du noch mehr VMs haben möchtest, dann hau proxmox drauf und dann eben VMs. wenn nicht debian und dann mit dem einzeiler ioB.
                                            Dann verwende das 'Original', Debian Bullseye (die Version ohne Desktop natürlich).
                                            Hammer Klaus 1 Reply Last reply Reply Quote 1
                                            4682
