    4. MQTT Adapter - verliert Verbindung - MQTT und VIS?
    • N
      noxx last edited by
      Moin
      da ja leider mein ESP ohne MQTT nicht funktioniert, habe ich nun diesen
      installiert, dazu auch den MQTT Adapter. Aber ich verliere ständig die Verbindung,
      mehrmals pro Sekunde wird verbunden/verloren.
      Die Lampe unter Instanzen ist nur Grün/Gelb am flackern.
      mqtt.0	2017-07-03 13:45:44.908	info	Adapter is disabled => stop
      mqtt.0	2017-07-03 13:45:44.853	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.754	info	All states published
      mqtt.0	2017-07-03 13:45:43.655	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.637	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.618	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.601	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.592	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.575	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.567	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.550	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.542	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.524	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.515	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.493	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.486	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.468	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.462	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.443	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.437	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.420	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.411	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.390	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.382	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.364	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.358	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.338	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:43.332	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:43.317	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:42.506	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:42.482	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:41.516	info	All states published
      mqtt.0	2017-07-03 13:45:41.424	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:41.406	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:41.392	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:41.374	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:41.365	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:41.348	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:41.341	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:41.323	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:41.316	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:41.299	info	Disconnected from localhost
      mqtt.0	2017-07-03 13:45:41.293	info	Connected to localhost
      mqtt.0	2017-07-03 13:45:41.276	info	Disconnected from localhost
      • Thisoft
        Thisoft last edited by
        Macht dein MQTT-Adapter das "Geflackere" auch wenn der ESP nicht an ist, also quasi "von sich aus" oder passiert das nur wenn sich der ESP-Client versucht zu verbinden?
        Im zweiten Fall wäre es interessant wenn Du das ESP-Script posten könntest…
        Achja - zum Testen vielleicht die beiden Haken in den Adaptereinstellungen mal rausnehmen. Ich hab die jedenfalls bei mir nicht drin.
        • N
          noxx last edited by
          Teste ich, es läuft ESPeasy, letzte Version, auf dem ESP.
          Gesendet von meinem GT-I9195 mit Tapatalk
          • Dutchman
            @noxx:
            Gesendet von meinem GT-I9195 mit Tapatalk `
            du probierst einen MQTT client auf localhost zu connecten, hast du den einen MQTT server laufen oder moechtest du iObroker als server benutzen ?
            (dan stimmen deine settings nicht)
            Das geflakkeren kommt weil er probiert verbindung zu machen aber keinen response bekommt.
            ~Dutch
            • Thisoft
              Ja - natürlich. Dutchman hat Recht! Als erstes musst Du natürlich den MQTT-Adapter als Server konfigurieren wenn der ESP der Client ist (wovon ich mal ausgehe..)
                Guest last edited by
                Also brauche ich mosquitto nicht?
                • N
                  noxx last edited by
                  mosquitto habe ich wie folgt installiert:
                  sudo /etc/init.d/mosquitto stop
                  sudo apt-get --purge remove mosquitto mosquitto-clients python-mosquitto
                  wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                  sudo apt-key add mosquitto-repo.gpg.key
                  cd /etc/apt/sources.list.d/
                  sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
                  sudo apt-get update
                  sudo apt-cache search mosquitto
                  sudo apt-get install mosquitto
                  sudo apt-get install mosquitto-clients
                  sudo apt-get install phyton-mosquitto
                  Verbindung kann ich testen mit
                  mosquitto_sub -v -t \#
                  /ESP04/Gaszaehler/Count 0.00
                  Nun möchte ich die Werte auch im ioBroker.
                  Stelle ich auf Server um, geht der Adapter nicht mehr auf Grün.
                  mqtt.0	2017-07-03 18:10:26.750	error	exception by stop: server.destroy is not a function
                  mqtt.0	2017-07-03 18:10:26.744	error	at Adapter. (/opt/iobroker/node_modules/iobroker.mqtt/main.js:50:24)
                  mqtt.0	2017-07-03 18:10:26.744	error	at MQTTServer.destroy (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:25:20)
                  mqtt.0	2017-07-03 18:10:26.744	error	at Object.destroy (/opt/iobroker/node_modules/iobroker.mqtt/lib/streamServer.js:141:19)
                  mqtt.0	2017-07-03 18:10:26.744	error	at Object.mapSeries (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:980:16)
                  mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:1153:16
                  mqtt.0	2017-07-03 18:10:26.744	error	at _asyncMap (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:1067:5)
                  mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:950:9
                  mqtt.0	2017-07-03 18:10:26.744	error	at replenish (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:946:17)
                  mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/node_modules/async/dist/async.js:1069:9
                  mqtt.0	2017-07-03 18:10:26.744	error	at /opt/iobroker/node_modules/iobroker.mqtt/lib/streamServer.js:146:24
                  mqtt.0	2017-07-03 18:10:26.744	error	TypeError: server.destroy is not a function
                  mqtt.0	2017-07-03 18:10:26.718	error	uncaught exception: server.destroy is not a function
                  Gibt für denn Adapter eine Anleitung?
                  • Dutchman
                    Nein du brauchst kein mosquitto dafür haben wir ja iobroker, der kan als MQTT Client und Server fungieren.
                    Ich stellen in 5 nin mal einen Screenshot nach wie mein MQTT Server in ioBroker eingerichtet ist.
                    Eventuell bei dir mal die MQTT Instanze löschen und neu installieren.
                    Also Basis ist:
                    • ioBroker ist der MQTT Server
                    • der muss richtig eingerichtet und freigegeben sein
                    • die Clients verbinden sich mit dem ioBroker MQTT Server und publishen da ihre stats
                    Bei mir so ähnlich gelöst
                    iObroker <> domoticz, ioBroker ist der Server und domoticz ein client
                    edit: ok hier die screens, einziger underschied ist das ich wohl einen username/pass verwende.
                    ergebnis, domoticz pusht seine werte in seinen eigenen channel:
                    ich empfehle dir sowieso die instanz mal zu loeschen und neu installieren deine fehlermeldung kommt mir komisch vor (eventueel bereits belegter port ?)
                    Den userguide findest du auf git (in iobroker auf das fragezeichen druecken bei dem adapter: https://github.com/ioBroker/ioBroker.mqtt
                    Send from mobile device
                    • N
                      noxx last edited by
                      danke, geht nun. Frage, warum werden die mqtt-IDs nicht unter VIS angezeigt?
                      Kannt leider keine Relais schalten.
                      • N
                        noxx last edited by
                        Habe mal ein paar Sachen probiert, aber irgendwie will er nicht
                        • Dutchman
                          Das mit vis lan sein bei neuen Werten eventuell Adapter Mal bei starten aber das hast du ja bereits selber gedixt 🙂
                          Stimmen die URL? Gehen diese wen du sie außerhalb vis im Browser probierst ?
                          • N
                            noxx last edited by
                            Im Browser gehen sie. Verstehe die Logik noch nicht so ganz
                              ccc.ggg73 last edited by
                              @noxx:
                              Habe mal ein paar Sachen probiert, aber irgendwie will er nicht `
                              Hallo noxx,
                              Siehe dir dieser thread an:
                              http://forum.iobroker.net/viewtopic.php?t=6655
                              Gesendet von meinem SM-G950F mit Tapatalk
                              • N
                                noxx last edited by
                                danke, den hatte ich schon gefunden, bin aber nicht weitergekommen.
                                Habe schon diverse Sachen in vis probiert, aber leider schaltet der ESP nicht.
                                • Thisoft
                                  um erstmal einzugrenzen ob die Ursache im VIS liegt oder schon vorher:
                                  Kannst du denn den ESP schalten wenn du den entsprechenden Zustand direkt in der Adminoberfläche (Reiter "Objekte" oder "Zustände") änderst?
                                  • N
                                    noxx last edited by
                                    @Thisoft:
                                    MQTT1.jpg `
                                    Nein, geht nicht. Wert wird erst Grün, dann Rot, dann springt er auf den alten Wert zurück
                                    • Thisoft
                                      Da fällt mir auf, dass es bei dir einen "Get"- und einen "Set"-Zweig im MQTT-Ordner gibt. Ich befürchte, da liegt der Haken… wo wir gerade beim Haken sind - probiere mal ob's hilft wenn du in den Adaptereinstellungen den Haken bei "Unterschiedliche Namen für setzen und lesen" reinmachst.
                                      Ist aber nur eine Vermutung. Ich hab das noch nie probiert und ich kenne auch ESPEasy überhaupt nicht - ich programmiere meine ESP's und Arduinos selber...
                                      • N
                                        noxx last edited by
                                        @Thisoft:
                                        Ist aber nur eine Vermutung. Ich hab das noch nie probiert und ich kenne auch ESPEasy überhaupt nicht - ich programmiere meine ESP's und Arduinos selber... `
                                        Hatte mich etwas an den Sonoff Thread gehalten, da wurden SET und GET definiert.
                                        Habe nun den MQTT nochmal neu aufgesetzt und auch ESPeasy neu installiert (ältere FW R147)
                                        Laufen tuts aber noch immer nicht, kann manuell nicht schalten. Setze ich auf 1 springt er zurück auf 0.
                                        EDIT
                                        Hier nochmal ne Liste von Fehler, betreffen aber nun den Sonoff. Mal geht der, dann wieder nicht.
                                        ESPClient13 = ESP03 (Screenshots)
                                        ESPClient1 = Sonoff
                                        mqtt.0	2017-07-04 14:09:10.298	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                        mqtt.0	2017-07-04 14:09:10.297	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                        mqtt.0	2017-07-04 14:09:10.289	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                        mqtt.0	2017-07-04 14:09:08.987	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                        mqtt.0	2017-07-04 14:09:08.986	warn	Cannot resolve topic name for ID: web.0.connected (object not found)
                                        mqtt.0	2017-07-04 14:08:36.231	info	publishOnSubscribe send all known states
                                        mqtt.0	2017-07-04 14:08:36.231	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
                                        mqtt.0	2017-07-04 14:08:36.230	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
                                        mqtt.0	2017-07-04 14:08:36.202	info	Client [ESPClient13] connected
                                        mqtt.0	2017-07-04 14:08:35.575	warn	Cannot resolve topic name for ID: null (object not found)
                                        mqtt.0	2017-07-04 14:08:35.574	info	publishOnSubscribe
                                        mqtt.0	2017-07-04 14:08:35.574	info	Client [ESPClient0] subscribes on "null"
                                        mqtt.0	2017-07-04 14:08:35.552	info	Client [ESPClient0] connected
                                        mqtt.0	2017-07-04 14:08:20.191	warn	Cannot resolve topic name for ID: null (object not found)
                                        mqtt.0	2017-07-04 14:08:20.165	info	publishOnSubscribe
                                        mqtt.0	2017-07-04 14:08:20.164	info	Client [ESPClient1] subscribes on "null"
                                        mqtt.0	2017-07-04 14:08:19.761	info	Client [ESPClient1] connected
                                        mqtt.0	2017-07-04 14:08:09.244	info	Starting MQTT server on port 1883
                                        mqtt.0	2017-07-04 14:08:08.439	info	starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.11.0
                                        mqtt.0	2017-07-04 14:08:08.268	info	States connected to redis 127.0.0.1:6379
                                        mqtt.0	2017-07-04 14:08:03.244	info	terminating
                                        mqtt.0	2017-07-04 14:08:02.769	info	Client [ESPClient0] closed
                                        mqtt.0	2017-07-04 14:08:02.765	info	Client [ESPClient13] closed
                                        mqtt.0	2017-07-04 14:08:02.762	info	Client [ESPClient1] closed
                                        mqtt.0	2017-07-04 14:04:51.117	info	Client [ESPClient1] closed
                                        mqtt.0	2017-07-04 14:04:51.079	info	Client [ESPClient1] connected
                                        mqtt.0	2017-07-04 14:04:40.158	info	publishOnSubscribe
                                        mqtt.0	2017-07-04 14:04:40.157	info	Client [ESPClient1] subscribes on "mqtt.0.Sonoff1.Set.GPIO.12"
                                        mqtt.0	2017-07-04 14:04:40.140	info	Client [ESPClient1] connected
                                        mqtt.0	2017-07-04 14:04:36.147	info	publishOnSubscribe send all known states
                                        mqtt.0	2017-07-04 14:04:36.147	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^mqtt\.0\.ESP03\..*/
                                        mqtt.0	2017-07-04 14:04:36.144	info	Client [ESPClient13] subscribes on "ESP03.#" with regex /^ESP03\..*/
                                        mqtt.0	2017-07-04 14:04:36.122	info	Client [ESPClient13] connected
                                        mqtt.0	2017-07-04 14:04:35.877	warn	Cannot resolve topic name for ID: null (object not found)
                                        • Dutchman
                                          Der MQTT hat einen get und einen Set.
                                          Get = was reinkommt
                                          Set = schalten
                                          Also Variable ändern in den hetbobject wird nicht bringen, überschreibt MQTT logischer Weise.
                                          Die musst den richtigen Wert bei Set übermitteln
                                          2978
