    • mickym
      mickym Most Active @Damrak2022 last edited by
      @damrak2022 Schau mal ob im Log was angezeigt wird - aber eigentlich glaub ich das alles nicht. Ausser Du hast wieder irgendwas installiert. 😉
      • Damrak2022
        @mickym Okay, nach dem Adapter Neustart geht es wieder.
        • mickym
          @damrak2022 Hmm - stand irgendwas im Log?
          • Damrak2022
            @mickym Danke
            • mickym
              @damrak2022 Na normal ist das nicht - schau mal im Log, ob was abgestürzt war.
              • Damrak2022
                @mickym Hier ein Auszug aus dem Lg:
                node-red.0
                2022-09-28 16:43:50.294	info	b875c1a1cb845312: Automatic objects creation is not enabled. You can enable it in the node configuration
                node-red.0
                2022-09-28 16:43:50.292	info	b875c1a1cb845312: "ioBroker in" Cannot set state of non-existing object "hue.0.Dimmschalter.battery".
                node-red.0
                2022-09-28 16:43:48.130	warn	28 Sep 16:43:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
                node-red.0
                2022-09-28 16:43:39.437	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                node-red.0
                2022-09-28 16:43:38.167	warn	Cannot enable the dynamic object read as admin has authentication
                node-red.0
                2022-09-28 16:43:38.039	info	starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v16.17.0, js-controller: 4.0.23
                host.homebridge
                2022-09-28 16:43:35.706	info	instance system.adapter.node-red.0 started with pid 276468
                host.homebridge
                2022-09-28 16:43:33.709	info	instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                node-red.0
                2022-09-28 16:43:33.078	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                host.homebridge
                2022-09-28 16:43:32.570	info	stopInstance timeout 5000 system.adapter.node-red.0 killing pid 107629
                node-red.0
                2022-09-28 16:43:27.881	info	node-red exited with 0
                node-red.0
                2022-09-28 16:43:27.578	info	kill node-red task
                host.homebridge
                2022-09-28 16:43:27.568	info	stopInstance system.adapter.node-red.0 (force=false, process=true)
                node-red.0
                2022-09-28 16:41:34.517	info	b875c1a1cb845312: Automatic objects creation is not enabled. You can enable it in the node configuration
                node-red.0
                2022-09-28 16:41:34.514	info	b875c1a1cb845312: "ioBroker in" Cannot set state of non-existing object "hue.0.Dimmschalter.battery".
                host.homebridge
                2022-09-28 16:40:30.952	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                ical.0
                2022-09-28 16:40:30.413	info	Terminated (NO_ERROR): With
                • mickym
                  @damrak2022 Na Du hast halt doch wieder irgendwas mit Authentifizierung gemacht . da kann ich Dir nicht helfen, weil bei mir ist das alles immer ausgeschaltet.
                  Und in einer iobroker-IN Node hast Du einen Topic angegeben, den es anscheinend nicht gibt:
                  Du kannst bei den Flows mal
                  b875c1a1cb845312
                  suchen - dann sollte es Dir die betreffende node anzeigen.
                  • Damrak2022
                    @mickym Ja, das ist der wo ich die Batterie austauschen muss.
                    • mickym
                      @damrak2022 Ja aber den State/Datenpunkt scheint es nicht zu geben.
                      • Damrak2022
                        @mickym Nein, im Moment nicht.
                        • mickym
                          @damrak2022 dann deaktiviere diese Nodes - macht doch keinen Sinn - wenn Du Nodes ohne Funktion aktiv hast.
                          • Damrak2022
                            @mickym Okay, ich dachte halt das kann ich auch lassen, weil es morgen ja wieder eingebunden wird
                            • mickym
                              @damrak2022 Na ja bricht nichts zusammen - aber wenn Du die Node deaktiviert hast dann siehst ja auch gleich, wo noch was zu tun ist.
                              • Damrak2022
                                @mickym Zu tun und lernen habe ich genug🙂
                                • mickym
                                  @damrak2022
                                  So was habe ich halt nicht - weil ich keine Anmeldung benutze - keine Ahnung - aber das würde für mich bedeuten, wenn ich das richtig interpretiere, dass Du keine Wildcards nutzen kannst - und das wäre für mich ein absolutes NoGo.
                                  • Damrak2022
                                    @mickym Das ist jetzt weg, da ich diesen Google Mist wieder entfernt habe.
                                    • Damrak2022
                                      @mickym Guten Morgen, eine Frage Micky:
                                      Die openwethermap node gibt mir folgende Daten aus:
                                      Die 4 Markierten Werte möchte ich jeweils in einer Gauge Node darstellen.
                                      Also habe ich hinter die openweathermap node eine Switch Node gehängt, aber irgendwie klappt das noch nicht.
                                      In der Vorlage die ich habe sieht die Payload auch etwas anders aus, da hier der DWD verwendet wird - siehe hier:
                                      Bei mir sieht der Flow momentan so aus:
                                      Ich habe es auch mit der Change node versucht, aber da habe ich wohl noch dickeFehler drin.
                                      Kannst Du mir einen Denkanstoß geben?
                                      • mickym
                                        @damrak2022 Ja in diesem Fall ist die switch Node falsch. Besser wäre Du hättest 4 Change Nodes verwendet und die payload auf den Pfad von der Nachrichteneigenschaft gesetzt, die Dich interessiert. Das Pfad kopieren aus dem Debug Fenster haben wir schon gemacht. 😉
                                        Aber das ist wieder in Beispiel, dass Dir noch etwas Verständnis für die Nodes fehlt. 😉
                                        • Damrak2022
                                          @mickym Okay, danke, ich biege das nachher hin. Momentan bin ich im Stress - siehe Chat
                                          • Damrak2022
                                            @mickym Genau mit dem Verständnis tue ich mich schwer.
                                            Was muss ich jetzt in de Change Node eintragen um den ersten Wert "weather" anzuzeigen.
                                            Habe schon einiges versucht, bekomme im Dashboard aber keinen Wert, bzw. keine Meldung angezeigt
                                            2333466
