Visualisierung mit Node Red erstellen
@damrak2022 Hmm - stand irgendwas im Log?
@mickym Danke
@damrak2022 Na normal ist das nicht - schau mal im Log, ob was abgestürzt war.
@mickym Hier ein Auszug aus dem Lg:
node-red.0 2022-09-28 16:43:50.294 info b875c1a1cb845312: Automatic objects creation is not enabled. You can enable it in the node configuration node-red.0 2022-09-28 16:43:50.292 info b875c1a1cb845312: "ioBroker in" Cannot set state of non-existing object "hue.0.Dimmschalter.battery". node-red.0 2022-09-28 16:43:48.130 warn 28 Sep 16:43:48 - [warn] Projects disabled : editorTheme.projects.enabled=false node-red.0 2022-09-28 16:43:39.437 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2022-09-28 16:43:38.167 warn Cannot enable the dynamic object read as admin has authentication node-red.0 2022-09-28 16:43:38.039 info starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v16.17.0, js-controller: 4.0.23 host.homebridge 2022-09-28 16:43:35.706 info instance system.adapter.node-red.0 started with pid 276468 host.homebridge 2022-09-28 16:43:33.709 info instance system.adapter.node-red.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) node-red.0 2022-09-28 16:43:33.078 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason host.homebridge 2022-09-28 16:43:32.570 info stopInstance timeout 5000 system.adapter.node-red.0 killing pid 107629 node-red.0 2022-09-28 16:43:27.881 info node-red exited with 0 node-red.0 2022-09-28 16:43:27.578 info kill node-red task host.homebridge 2022-09-28 16:43:27.568 info stopInstance system.adapter.node-red.0 (force=false, process=true) node-red.0 2022-09-28 16:41:34.517 info b875c1a1cb845312: Automatic objects creation is not enabled. You can enable it in the node configuration node-red.0 2022-09-28 16:41:34.514 info b875c1a1cb845312: "ioBroker in" Cannot set state of non-existing object "hue.0.Dimmschalter.battery". host.homebridge 2022-09-28 16:40:30.952 info instance system.adapter.ical.0 terminated with code 0 (NO_ERROR) ical.0 2022-09-28 16:40:30.413 info Terminated (NO_ERROR): With -
@damrak2022 Na Du hast halt doch wieder irgendwas mit Authentifizierung gemacht . da kann ich Dir nicht helfen, weil bei mir ist das alles immer ausgeschaltet.
Und in einer iobroker-IN Node hast Du einen Topic angegeben, den es anscheinend nicht gibt:
hue.0.Dimmschalter.batteryDu kannst bei den Flows mal
b875c1a1cb845312
suchen - dann sollte es Dir die betreffende node anzeigen.
@mickym Ja, das ist der wo ich die Batterie austauschen muss.
@damrak2022 Ja aber den State/Datenpunkt scheint es nicht zu geben.
@mickym Nein, im Moment nicht.
@damrak2022 dann deaktiviere diese Nodes - macht doch keinen Sinn - wenn Du Nodes ohne Funktion aktiv hast.
@mickym Okay, ich dachte halt das kann ich auch lassen, weil es morgen ja wieder eingebunden wird
@damrak2022 Na ja bricht nichts zusammen - aber wenn Du die Node deaktiviert hast dann siehst ja auch gleich, wo noch was zu tun ist.
@mickym Zu tun und lernen habe ich genug
warn Cannot enable the dynamic object read as admin has authenticationSo was habe ich halt nicht - weil ich keine Anmeldung benutze - keine Ahnung - aber das würde für mich bedeuten, wenn ich das richtig interpretiere, dass Du keine Wildcards nutzen kannst - und das wäre für mich ein absolutes NoGo.
@mickym Das ist jetzt weg, da ich diesen Google Mist wieder entfernt habe.
@mickym Guten Morgen, eine Frage Micky:
Die openwethermap node gibt mir folgende Daten aus:
Die 4 Markierten Werte möchte ich jeweils in einer Gauge Node darstellen.
Also habe ich hinter die openweathermap node eine Switch Node gehängt, aber irgendwie klappt das noch nicht.In der Vorlage die ich habe sieht die Payload auch etwas anders aus, da hier der DWD verwendet wird - siehe hier:
Bei mir sieht der Flow momentan so aus:
Ich habe es auch mit der Change node versucht, aber da habe ich wohl noch dickeFehler drin.
Kannst Du mir einen Denkanstoß geben? -
@damrak2022 Ja in diesem Fall ist die switch Node falsch. Besser wäre Du hättest 4 Change Nodes verwendet und die payload auf den Pfad von der Nachrichteneigenschaft gesetzt, die Dich interessiert. Das Pfad kopieren aus dem Debug Fenster haben wir schon gemacht.
Aber das ist wieder in Beispiel, dass Dir noch etwas Verständnis für die Nodes fehlt.
@mickym Okay, danke, ich biege das nachher hin. Momentan bin ich im Stress - siehe Chat
@mickym Genau mit dem Verständnis tue ich mich schwer.
Was muss ich jetzt in de Change Node eintragen um den ersten Wert "weather" anzuzeigen.
Habe schon einiges versucht, bekomme im Dashboard aber keinen Wert, bzw. keine Meldung angezeigt
@damrak2022 Nun wie gesagt Du setzt die neue payload auf die Eigenschaft der alten payload. Dafür kopierst Du den Pfad aus der Debug Node.
und natürlich mit einer debug Node prüfen, ob was rauskommt.
Theoretisch brauchst Du nicht mal eine Change Node - Du kannst auch in der Textnode - den vollständigen Pfad zur Eigenschaft eingeben - dann ist es noch einfacher.
Machs einfach mal MIT Change Node und einmal OHNE Change Node - damit Du auch verstehst - was passiert.
Bei der gauge Node - musst eh in eine payload wandeln - da diese nur die payload untersucht.
@mickym Ja, das geht alles, wie nicht anders zu erwarte war bei Erklärungen von Dir
Wenn ich mich recht erinnere ist Deine Wetter Ansicht viel schöner
