    4. iobroker start - No connection to databases possible
      Thomas Braun Most Active @Rene 2 last edited by
      @rene-2
      iobroker restart
      iobroker status
      iobroker update
      Rene 2 1 Reply Last reply Reply Quote 0
      • Rene 2
        Rene 2 @Thomas Braun last edited by
        iobroker status
         Objects database error: connect ECONNREFUSED 127.0.0.1:9001
        iobroker update
        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          @rene-2 sagte in iobroker start - No connection to databases possible:
          lsof /opt/iobroker/iobroker-data/objects.jsonl
          • Rene 2
            Da gibt er mir leider gar keine Rückmeldung
            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
              @rene-2
              Bitte vollständige Ein- und Ausgaben zeigen.
              sudo systemctl stop iobroker
              iobroker status
              • Glasfaser
                Glasfaser @Rene 2 last edited by
                @rene-2
                ls -lh /opt/iobroker/iobroker-data/
                • Rene 2
                  pi@raspberrypi:/opt/iobroker $ sudo systemctl stop iobroker
                  pi@raspberrypi:/opt/iobroker $ iobroker status
                  No connection to databases possible ...
                  @Glasfaser
                  pi@raspberrypi:/opt/iobroker $ ls -lh /opt/iobroker/iobroker-data/
                  insgesamt 476M
                  drwxrwxr-x+  2 iobroker iobroker 4,0K Mär 30 21:43 backitup
                  drwxrwxr-x+  2 iobroker iobroker  12K Sep 28 10:09 backup-objects
                  drwxrwxr-x+ 18 iobroker iobroker 4,0K Sep 27 17:14 files
                  drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 31  2021 history
                  -rw-rwxr--+  1 iobroker iobroker 4,7K Mär 30 21:42 iobroker.json
                  drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 31  2021 lgtv_0
                  -rw-rwxr--+  1 iobroker iobroker    3 Sep 28 11:51 notifications.json
                  -rw-rwxr--+  1 iobroker iobroker 3,3M Mär 30 21:39 objects.json.bak.migrated
                  -rw-rwxr--+  1 iobroker iobroker 462M Sep 28 11:51 objects.jsonl
                  -rw-rwxr--+  1 iobroker iobroker 3,3M Mär 30 21:42 objects.json.migrated
                  -rw-rwxr--+  1 iobroker iobroker 2,5K Nov  4  2021 objects.json.old
                  -rw-rwxr--+  1 iobroker iobroker 326K Mär 30 21:40 states.json.bak.migrated
                  -rw-rwxr--+  1 iobroker iobroker    0 Nov 10  2021 states.json.broken
                  -rw-rwxr--+  1 iobroker iobroker 6,7M Sep 28 11:51 states.jsonl
                  -rw-rwxr--+  1 iobroker iobroker 327K Mär 30 21:42 states.json.migrated
                  -rw-rwxr--+  1 iobroker iobroker 335K Nov  4  2021 states.json.old
                  drwxrwxr-x+  4 iobroker iobroker 4,0K Feb  2  2022 tuya_0
                  drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 31  2021 yahka.0.hapdata
                  • Rene 2
                    Rene 2 @Rene 2 last edited by
                    Ich habe nochmal versucht einige Befehle die so genannt wurden auszuführen um evtl. noch mehr Infos zu ergattern, eventuell hilft das ja auch noch.
                    Mir fehlt gerade einfach das Wissen um einen Ansatz für eine Lösung herauszukriegen.
                    pi@raspberrypi:/opt/iobroker $ iobroker restart
                    pi@raspberrypi:/opt/iobroker $ iobroker update
                    ^C
                    pi@raspberrypi:/opt/iobroker $ lsof /opt/iobroker/iobroker-data/objects.jsonl
                      @rene-2
                      sudo apt install lsof
                      sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                      • Rene 2
                        pi@raspberrypi:/opt/iobroker $ sudo apt install lsof
                        lsof ist schon die neueste Version (4.91+dfsg-1).
                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                          ax25-node libax25 openbsd-inetd python-colorzero tcpd update-inetd
                        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        pi@raspberrypi:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                          @rene-2
                          Komisch...
                          getfacl /opt/iobroker/iobroker-data/objects.jsonl
                          • Rene 2
                            Das klappt anscheinend
                            pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                            getfacl: Entferne führende '/' von absoluten Pfadnamen
                            # file: opt/iobroker/iobroker-data/objects.jsonl
                            # owner: iobroker
                            # group: iobroker
                            user::rw-
                            group::r-x
                            group:iobroker:rwx
                            mask::rwx
                            other::r--
                              @rene-2
                              Die Rechte sehen bei mir leicht anders aus.
                              sudo ln -s /usr/bin/node /usr/bin/nodejs
                              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              iobroker stop
                              iobroker fix
                              iobroker start
                              • Rene 2
                                Okay, laufen tut es jetzt aus irgendeinem Grund.
                                Nur die Adapter updaten möchte er noch nicht
                                $ iobroker upgrade javascript@6.0.3
                                Update javascript from @5.7.0 to @6.0.3
                                NPM version: 8.15.0
                                Installing iobroker.javascript@6.0.3... (System call)
                                host.raspberrypi Cannot install iobroker.javascript@6.0.3: 217
                                ERROR: Process exited with code 25
                                  Homoran Global Moderator Administrators @Rene 2 last edited by
                                  code 25
                                  https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                                    Thomas Braun Most Active @Rene 2 last edited by Thomas Braun
                                    @rene-2
                                    Was kam auf die Befehle zurück?
                                    Insbesondere auf den langen aus Zeile 2?
                                    • Rene 2
                                      Der Link von @Homoran konnte mir weiterhelfen.
                                      Es läuft wieder alles und updates gingen auch alle durch.
                                      Vielen lieben Dank für die Hilfe!
                                      Falls das dennoch von Bedeutung ist, um noch weitere Fehler zu erkennen:
                                      pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.17.1
                                      v16.17.1
                                      8.15.0
                                      4.0.23
                                      pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                      /opt/iobroker
                                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                      OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                                      Alle Pakete sind aktuell.
                                      nodejs:
                                        Installiert:           16.17.1-deb-1nodesource1
                                        Installationskandidat: 16.17.1-deb-1nodesource1
                                        Versionstabelle:
                                       *** 16.17.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                              100 /var/lib/dpkg/status
                                           14.20.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                           10.24.0~dfsg-1~deb10u1 500
                                        Alles gut, keine Fehler zu sehen.
                                        735
