    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      A Former User last edited by
      Hi @ciddi89 ,
      ich würde auch gern noch die Geräte zweier Adapter in Deinem tollen Adapter sehen 🙂
      1. handelt es sich um den Meross Adapter, ich habe dort Thermostate:
      Batterie Json:
        "type": "state",
        "common": {
          "type": "number",
          "read": true,
          "write": false,
          "name": "battery",
          "role": "value",
          "unit": "%"
        "native": {},
        "from": "system.adapter.meross.0",
        "user": "system.user.admin",
        "ts": 1664192417695,
        "_id": "meross.0.1911084120365426280348e1e91141bc.01009381.battery",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Online Json:
        "type": "state",
        "common": {
          "type": "boolean",
          "read": true,
          "write": false,
          "name": "online",
          "role": "indicator.reachable"
        "native": {},
        "ts": 1664192417654,
        "_id": "meross.0.1911084120365426280348e1e91141bc.01009381.online",
        "acl": {
          "object": 1636,
          "state": 1636,
      1. Um die Batterie der USV "NUT":
      Charge Jason:
        "type": "state",
        "common": {
          "name": "battery.charge",
          "type": "number",
          "role": "value.battery",
          "read": true,
          "write": false,
          "unit": "%"
        "native": {
          "id": "battery.charge"
        "from": "system.adapter.nut.0",
        "ts": 1621489976980,
        "_id": "nut.0.battery.charge",
        "acl": {
          "object": 1636,
          "state": 1636,
      Charge-Low Json:
        "type": "state",
        "common": {
          "name": "battery.charge-low",
          "type": "string",
          "read": true,
          "write": false
        "native": {
          "id": "battery.charge-low"
        "ts": 1621489976987,
        "_id": "nut.0.battery.charge-low",
        "acl": {
          "object": 1636,
          "state": 1636,
      Charge-Warning Json:
        "type": "state",
        "common": {
          "name": "battery.charge-warning",
          "type": "string",
          "read": true,
          "write": false
        "native": {
          "id": "battery.charge-warning"
        "ts": 1621489976998,
        "_id": "nut.0.battery.charge-warning",
        "acl": {
          "object": 1636,
          "state": 1636,
      VG
      Bernd
      • da_Woody
        da_Woody @JB_Sullivan last edited by
        @jb_sullivan sagte in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
        die Eier legenden Wollmichsau
        da fängt für mich das problem an, was soll drinnen sein, was nicht. jeder mag was anderes. die config wird immer komplizierter. ich lass mir jetzt schon bei jeder liste was ausblenden und unterschiedlich sortieren.
        deine idea in ehren, aber wäre das nicht besser mit influxDB und Grafana?
          A Former User @JB_Sullivan last edited by
          @jb_sullivan Hi 🙋🏼‍♂️
          Also erst mal vielen Dank an dir und auch an all den anderen Usern für euer Feedback, Ideen und auch Hilfen. Auch das ihr soviel Nachsicht habt, wenn mal etwas nicht funktioniert. Das zeigt mal wieder was das für eine nette Community hier doch ist. 🙂
          Leider ist es manchmal echt nicht einfach Adapter zu implementieren weil jeder in der Adapter Erstellung sein eigenes Süppchen kocht und diverse states anders benennt oder die Struktur komplett aus der Reihe tanzt. Ich versuche wenn möglich das immer alles nachzubauen und zu testen. Aber manchmal raubt es einen den letzten Nerv und man muss jeder Situation im Code anders behandeln und bedenken. 😬
          Aber nun zu deiner Idee, an sich finde ich es klasse und würde bestimmt ein paar Leuten die Gier an Informationen auf einem Haufen befriedigen 😬
          Aber um es kurz und knapp zu sagen: Dies geht leider am grundsätzlichen Thema des Device-Watcher vorbei. Denn die Hauptaufgabe ist und soll sein: Geräte auf Erreichbarkeit und Batteriestand zu überprüfen und wenn dem nicht so ist eine Meldung / Eintrag in die Tabellen vorzunehmen. Mehr nicht.
          Leider will auch der Großteil es so einfach haben wie möglich ohne groß rum suchen zu müssen und auswählen zu müssen.
          Ich will deine Idee aber nicht ganz abweisen da es schon paar Anfragen über Tabellen mit states Inhalt . Ich muss mich aber erstmal um die großen Baustellen von diesem Adapter kümmern. Wenn alles so läuft, werde ich vielleicht in Erwägung ziehen einen ähnlichen Adapter zu kreieren der sowas erfasst. Das Grundgerüst wäre dann ja schon vorhanden.
          Ich danke schon mal für dein Verständnis 🙂
          D3ltoroxp 1 Reply Last reply Reply Quote 1
          • D3ltoroxp
            D3ltoroxp @Guest last edited by
            @ciddi89 So, der Adapter hat sich beruhigt. Ich bekomme jetzt nur noch 1x mindestens am Tag eine Liste mit Offline Geräten. Ich habe nun überall 300 drin stehen. Denke, da dort sich immer wieder die Werte geändert haben, wird das eben mit -1 so übernommen.
            Ich lass das nun mal so das reicht mir ja.
            Hätte noch eine Frage, WLAN Kameras, wie könnte ich die denn mit überwachen, wenn da mal eine Offline geht. Hatte ich jetzt ist mir dann nur aufgefallen, als ich mal reingeschnuppert hatte, da war kein Bild da. Wenn ich da sowas noch mit abfangen könnte wäre super.
              A Former User @D3ltoroxp last edited by A Former User
              @d3ltoroxp danke für die Rückmeldung! So bestätigt das nur wieder das es mit den Erreichbarkeitsstates sehr unzuverlässig läuft in einigen Adaptern. Musste es bei mir teilweise auch wieder auf Zeit umstellen da einige States garnicht umgesprungen sind auf false/true obwohl das Gerät 100% nicht erreichbar war, weil Stecker gezogen.
              Hast du die denn über ein Adapter eingebunden? Ansonsten mit den Adapter Ping. Dieser Pingt dann immer die IP Adresse an, und wenn da nichts zurück kommt ist das Netzwerkgerät offline/nicht erreichbar.
              • Negalein
                Negalein Global Moderator @Guest last edited by
                @ciddi89
                Hallo
                Habe heute den Adapter installiert.
                Funktioniert eigentlich wie gewünscht.
                Bei den Emails hab ich leider ein Problem.
                So waren sie am Anfang (wie gewollt):
                Folgende 18 Geräte sind seit einiger Zeit nicht erreichbar:
                Hue ambiance lamp 1 (297 Tagen)
                Hue ambiance lamp 2 (297 Tagen)
                Hue ambiance lamp 3 (297 Tagen)
                Hue ambiance lamp 4 (297 Tagen)
                Laura 1 (8 Stunden)
                Wintergarten Tisch 1 (13 Stunden)
                Wintergarten Tisch 2 (13 Stunden)
                Wintergarten Tisch 3 (13 Stunden)
                Wintergarten Tisch 4 (13 Stunden)
                Schlafzimmer-Fenster (13:56 Uhr)
                Küche-Fenster (13:22 Uhr)
                Postkasten (13:55 Uhr)
                Kinderzimmer-Fenster (13:50 Uhr)
                Wintergarten-Schiebe (13:35 Uhr)
                Haustür (13:08 Uhr)
                Wintergarten-Fenster (14:06 Uhr)
                Temperatur-Bad (308 Tagen)
                Aquarium-Wassersensor (13:48 Uhr)
                Und plötzlich kommen sie nur noch so an:
                Folgende 20 Geräte sind seit einiger Zeit nicht erreichbar:
                Christian's Alexa Apps (VOGLxxxxxxxxxx) (14:10 Uhr) Christian's Alexa Apps (VOGLxxxxxxxxxx) (14:10 Uhr) Hue ambiance lamp 1 (297 Tagen) Hue ambiance lamp 2 (297 Tagen) Hue ambiance lamp 3 (297 Tagen) Hue ambiance lamp 4 (297 Tagen) Laura 1 (8 Stunden) Wintergarten Tisch 1 (13 Stunden) Wintergarten Tisch 2 (13 Stunden) Wintergarten Tisch 3 (13 Stunden) Wintergarten Tisch 4 (13 Stunden) Schlafzimmer-Fenster (13:56 Uhr) Küche-Fenster (13:22 Uhr) Postkasten (13:55 Uhr) Kinderzimmer-Fenster (13:50 Uhr) Wintergarten-Schiebe (13:35 Uhr) Haustür (13:08 Uhr) Wintergarten-Fenster (14:06 Uhr) Temperatur-Bad (308 Tagen) Aquarium-Wassersensor (13:48 Uhr)
                  A Former User @Negalein last edited by
                  @negalein Du meinst weil diese nicht mehr untereinander stehen? Habe gerade eben versucht das zu reproduzieren. Aber bei mir kommt es immer so an wie es soll. Hast du zufällig unterschiedliche Programme genutzt um diese zu öffnen?
                  • Negalein
                    @ciddi89 sagte in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
                    genau
                    Nein, immer nur Outlook am PC. War/ist durchgehend offen.
                      A Former User @Guest last edited by
                      @dp20eic Hallo Bernd,
                      habe beide Sachen mit eingepflegt. Einmal neu drüber installieren dann sollten diese bei dir in der Auswahl mit auftauchen.
                      @Negalein hmm okay. War das bis jetzt nur eine Nachricht oder kam da schon mehrere die so aussahen? Kann sein das es an Outlook liegt und er das '/n' für eine neue Zeile nicht richtig interpretiert. Wobei er es ja in der ersten Mail getan hat.
                      Negalein ? 4 Replies Last reply Reply Quote 0
                      • Negalein
                        4x kam es richtig.
                        seit der 5. Mail immer falsch
                          A Former User @Guest last edited by A Former User
                          @ciddi89 👍
                          Sind da und läuft, danke.
                          • Negalein
                            hmm okay
                            seit Mitternacht funktioniert die Liste wieder 🙂
                            • Negalein
                              @ciddi89
                              Frage zu den Mi-Home Geräten.
                              Ich bekomme jedesmal in der Liste alle Mi-Home Fensterkontakte als offline gemeldet.
                              Aber diese Geräte haben keinen DP dafür.
                              Nur das Gateway hat einen.
                              Folgende 10 Geräte sind seit einiger Zeit nicht erreichbar:
                              Laura 1 (2 Stunden)
                              Schlafzimmer-Fenster (07:40 Uhr)
                              Küche-Fenster (07:47 Uhr)
                              Postkasten (07:29 Uhr)
                              Kinderzimmer-Fenster (07:24 Uhr)
                              Wintergarten-Schiebe (2 Stunden)
                              Haustür (07:56 Uhr)
                              Wintergarten-Fenster (07:41 Uhr)
                              Temperatur-Bad (309 Tagen)
                              Aquarium-Wassersensor (07:22 Uhr)
                                @negalein danke für die Info. Ist in den expert Einstellung bei mihome ‚-1‘ oder eine Zeit eingetragen? Werde das später aber noch mal überarbeiten.
                                • Negalein
                                  eine Zeit
                                    A Former User @Negalein last edited by A Former User
                                    @negalein ok danke für die Info. Normalerweise soll das so sein das wenn kein Datenpunkt für connected da ist, dann soll er den aktualisierten Zeitstempel nehmen vom Datenpunkt ‚percent‘. Eventuell reicht das schon wenn du die Zeit bei dir höher stellst zb. 180. Aber wenn ich das richtige sehe melden die sich schon unter zwei Stunden als offline obwohl du 120 eingetragen. Werde das nachher eben bei mir testen und evtl korrigieren. 🙂
                                    // Edit: Okay habs geprüft. Soweit sollte alles in Ordnung sein. Ich hatte nur ein Fehler gefunden das er ein rssi wert aus dem Battery wert genommen hatte obwohl nichts angegeben ist. Das habe ich gefixt. Ansonsten denke ich das du einfach nur die Zeit höher schrauben musst, da 120min leider zu kurz sind. Vielleicht mal rantasten welcher ein guter Durchschnittswert ist den würde ich dann für die Zukunft auch als default wert setzen wenn du mir das dann berichten magst.
                                    • Negalein
                                      werd ich machen 👍
                                      noch was hätte ich.
                                      Kann es sein, dass nur alexa2.0 berücksichtigt wird, obwohl 2 Alexa-Instanzen laufen?
                                        @negalein Super danke!
                                        Öhm ne eigentlich sollten alle Instanzen beachtet werden:
                                        alexa2: {
                                        	'Selektor': 'alexa2.*.online',
                                        • Negalein
                                          Ok, das hat heute nicht funktioniert.
                                          Meine Kleine hat heute in der Früh ihre Alexa Instanz .1 ausgesteckt.
                                          Diese war bis 16:30 stromlos.
                                          Es is aber den ganzen Tag keine Meldung gekommen.
                                            @negalein werde ich mir morgen in ruhe anschauen. Bin gerade meine Benachrichtigungen durch gegangen und hab gesehen das mein firetv das letzte mal auch nicht offline gemeldet wurde obwohl ich 100% weiss das der offline war.
                                            1461
                                            498524
