    4. iobroker start - No connection to databases possible
      Thomas Braun Most Active @Rene 2 last edited by
      @rene-2
      Bitte vollständige Ein- und Ausgaben zeigen.
      sudo systemctl stop iobroker
      iobroker status
      Rene 2 1 Reply Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @Rene 2 last edited by
        @rene-2
        ls -lh /opt/iobroker/iobroker-data/
        • Rene 2
          Rene 2 @Thomas Braun last edited by
          pi@raspberrypi:/opt/iobroker $ sudo systemctl stop iobroker
          pi@raspberrypi:/opt/iobroker $ iobroker status
          No connection to databases possible ...
          @Glasfaser
          pi@raspberrypi:/opt/iobroker $ ls -lh /opt/iobroker/iobroker-data/
          insgesamt 476M
          drwxrwxr-x+  2 iobroker iobroker 4,0K Mär 30 21:43 backitup
          drwxrwxr-x+  2 iobroker iobroker  12K Sep 28 10:09 backup-objects
          drwxrwxr-x+ 18 iobroker iobroker 4,0K Sep 27 17:14 files
          drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 31  2021 history
          -rw-rwxr--+  1 iobroker iobroker 4,7K Mär 30 21:42 iobroker.json
          drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 31  2021 lgtv_0
          -rw-rwxr--+  1 iobroker iobroker    3 Sep 28 11:51 notifications.json
          -rw-rwxr--+  1 iobroker iobroker 3,3M Mär 30 21:39 objects.json.bak.migrated
          -rw-rwxr--+  1 iobroker iobroker 462M Sep 28 11:51 objects.jsonl
          -rw-rwxr--+  1 iobroker iobroker 3,3M Mär 30 21:42 objects.json.migrated
          -rw-rwxr--+  1 iobroker iobroker 2,5K Nov  4  2021 objects.json.old
          -rw-rwxr--+  1 iobroker iobroker 326K Mär 30 21:40 states.json.bak.migrated
          -rw-rwxr--+  1 iobroker iobroker    0 Nov 10  2021 states.json.broken
          -rw-rwxr--+  1 iobroker iobroker 6,7M Sep 28 11:51 states.jsonl
          -rw-rwxr--+  1 iobroker iobroker 327K Mär 30 21:42 states.json.migrated
          -rw-rwxr--+  1 iobroker iobroker 335K Nov  4  2021 states.json.old
          drwxrwxr-x+  4 iobroker iobroker 4,0K Feb  2  2022 tuya_0
          drwxrwxr-x+  2 iobroker iobroker 4,0K Jul 31  2021 yahka.0.hapdata
          • Rene 2
            Rene 2 @Rene 2 last edited by
            Ich habe nochmal versucht einige Befehle die so genannt wurden auszuführen um evtl. noch mehr Infos zu ergattern, eventuell hilft das ja auch noch.
            Mir fehlt gerade einfach das Wissen um einen Ansatz für eine Lösung herauszukriegen.
            pi@raspberrypi:/opt/iobroker $ iobroker restart
            Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
            pi@raspberrypi:/opt/iobroker $ iobroker update
             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            ^C
            pi@raspberrypi:/opt/iobroker $ lsof /opt/iobroker/iobroker-data/objects.jsonl
              @rene-2
              sudo apt install lsof
              sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
              • Rene 2
                pi@raspberrypi:/opt/iobroker $ sudo apt install lsof
                lsof ist schon die neueste Version (4.91+dfsg-1).
                Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                  ax25-node libax25 openbsd-inetd python-colorzero tcpd update-inetd
                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                pi@raspberrypi:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                  @rene-2
                  Komisch...
                  getfacl /opt/iobroker/iobroker-data/objects.jsonl
                  • Rene 2
                    Das klappt anscheinend
                    pi@raspberrypi:/opt/iobroker $ getfacl /opt/iobroker/iobroker-data/objects.jsonl
                    getfacl: Entferne führende '/' von absoluten Pfadnamen
                    # file: opt/iobroker/iobroker-data/objects.jsonl
                    # owner: iobroker
                    # group: iobroker
                    user::rw-
                    group::r-x
                    group:iobroker:rwx
                    mask::rwx
                    other::r--
                      @rene-2
                      Die Rechte sehen bei mir leicht anders aus.
                      sudo ln -s /usr/bin/node /usr/bin/nodejs
                      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      iobroker stop
                      iobroker fix
                      iobroker start
                      • Rene 2
                        Okay, laufen tut es jetzt aus irgendeinem Grund.
                        Nur die Adapter updaten möchte er noch nicht
                        $ iobroker upgrade javascript@6.0.3
                        Update javascript from @5.7.0 to @6.0.3
                        NPM version: 8.15.0
                        Installing iobroker.javascript@6.0.3... (System call)
                        host.raspberrypi Cannot install iobroker.javascript@6.0.3: 217
                        ERROR: Process exited with code 25
                          Homoran Global Moderator Administrators @Rene 2 last edited by
                          @rene-2 sagte in iobroker start - No connection to databases possible:
                          code 25
                          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                            Thomas Braun Most Active @Rene 2 last edited by Thomas Braun
                            @rene-2
                            Was kam auf die Befehle zurück?
                            Insbesondere auf den langen aus Zeile 2?
                            • Rene 2
                              Der Link von @Homoran konnte mir weiterhelfen.
                              Es läuft wieder alles und updates gingen auch alle durch.
                              Vielen lieben Dank für die Hilfe!
                              Falls das dennoch von Bedeutung ist, um noch weitere Fehler zu erkennen:
                              pi@raspberrypi:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.1
                              v16.17.1
                              8.15.0
                              4.0.23
                              pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                              /opt/iobroker
                              OK:1 http://archive.raspberrypi.org/debian buster InRelease
                              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                              OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                              Alle Pakete sind aktuell.
                              nodejs:
                                Installiert:           16.17.1-deb-1nodesource1
                                Installationskandidat: 16.17.1-deb-1nodesource1
                                Versionstabelle:
                               *** 16.17.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   14.20.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                   10.24.0~dfsg-1~deb10u1 500
                                Alles gut, keine Fehler zu sehen.
                                740
