    4. [How-to] Node.js für ioBroker richtig updaten
    • Glasfaser
      Glasfaser @bergjet last edited by
      @bergjet
      sudo reboot
      bergjet 1 Reply Last reply Reply Quote 0
      • bergjet
        bergjet @Glasfaser last edited by
        @glasfaser sagte in [How-to] Node.js für ioBroker richtig updaten:
        @bergjet
        sudo reboot
        pi@pi4:~ $ sudo reboot now
        Connection to 192.168.1.61 closed by remote host.
        Connection to 192.168.1.61 closed.
        Martins-iMac:~ Martin$ ssh pi@192.168.1.61
        pi@192.168.1.61's password:
        Linux pi4 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Thu Sep 29 10:32:34 2022 from 192.168.1.9
        pi@pi4:~ $ node -v
        v16.17.0
        Keine Änderung
        • Glasfaser
          @bergjet
          Eventuell quer installiert.
          Zeige mal im ganzen
           sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          • bergjet
            @glasfaser
            armv7l
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v16.17.1
            v16.17.0
            8.15.0
            pi
            /home/pi
            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
            Paketlisten werden gelesen… Fertig
            Abhängigkeitsbaum wird aufgebaut… Fertig
            Statusinformationen werden eingelesen… Fertig
            Alle Pakete sind aktuell.
            nodejs:
              Installiert:           16.17.1-deb-1nodesource1
              Installationskandidat: 16.17.1-deb-1nodesource1
              Versionstabelle:
             *** 16.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u1 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              Thomas Braun Most Active @bergjet last edited by Thomas Braun
              @bergjet sagte in [How-to] Node.js für ioBroker richtig updaten:
              /usr/local/bin/node
              Falsche Pfade.
              In meiner Signatur steht wie es richtig gemacht wird und wie man das behebt.
              Meine obligatorische Frage: Wie bist du beim Update von nodejs auf 16.17.0 vorgegangen?
              Das Paket raspberrypi-sys-mods darf eigentlich auch keine Probleme machen, denn bei einem Server-Setup (ohne Desktop!!!) ist das gar nicht installiert.
              • bergjet
                bergjet @Thomas Braun last edited by bergjet
                @thomas-braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                pi@pi4:~ $ iob stop
                pi@pi4:~ $ sudo apt update && sudo apt upgrade
                pi@pi4:~ $ iob start
                Und was sollte ich nun genau machen?
                In der Signatur steht unheimlich viel.
                Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @bergjet last edited by Glasfaser
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                  ab Punkt : Teil 1.1 Node-Upgrade/ Wechsel der nodejs-Version:
                  Unterpunkt ab Check ....
                  sudo rm .......
                    Das kann für nodejs v16.17.0 nicht sein, die nodejs-Versionen aus dem nodesource-Repo installieren sich nicht in /user/local/bin.
                    Da muss noch was anderes gemacht worden sein.
                    • bergjet
                      Ich habe nachgeschaut:
                      sudo apt-get update
                      sudo apt-get upgrade
                      iobroker fix
                      war der Befehl.
                      • Glasfaser
                        Ich habe node.js 16.17.0 installiert.
                        Darauf möchte @Thomas-Braun eine Antwort haben , wie du es installiert hast , nach welcher Anleitung !
                          @bergjet
                          Wie gesagt, das kann nicht sein. Die nodejs 16.17.0 ist im falschen Pfad gelandet, das passiert aber nie bei den nodesource-Versionen aus den Repos/aus apt.
                          Deswegen muss da irgendwas anders gemacht worden sein.
                          Die v16.17.1 ist offenbar korrekt installiert worden.
                          • bergjet
                            Vor einiger Zeit wurde installiert
                            Mit dem Raspberry Pi Imager App das Raspberry Pi OS 32bit
                            und dann
                            curl -sLf https://iobroker.net/install.sh | bash -
                            Seit dieser Zeit erfolgten alle Updates mit
                            sudo apt-get update
                            iobroker fix
                            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                              @bergjet
                              Wie bereits gesagt: Kann nicht sein.
                              Dann hätte nodesource die Art das Paket zu packen geändert, das wäre aber aufgefallen.
                              • bergjet
                                Bis zum 16.17.0 hat aber alles auf diese Art funktioniert.
                                • Glasfaser
                                  Was heißt ... vor einieger Zeit ...
                                  denn du schreibst :
                                  dann war vorher Nodejs 12 oder 14 vorhanden !?
                                  Edit :
                                  Laut Log von dir
                                    Bis zum 16.17.0
                                    Ja, und die 16.17.0 MUSS auf einem anderen Weg in /usr/local/bin gelandet sein.
                                    • bergjet
                                      Am 24.2.2022 habe ich neu installiert.
                                      • Glasfaser
                                        Ja , und wie mit welcher Anleitung ... das fragen wir schon die ganze Zeit !
                                          @bergjet
                                          Die 16.17.0 kann das aber nicht gewesen sein, die ist nämlich erst im August 2022 released worden:
                                          2022-08-16, Version 16.17.0 'Gallium' (LTS)
                                          • bergjet
                                            Also ausser dem habe ich nicht s gemacht.
                                            und dann
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            733703
