    4. JavaScript
    5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
      Wurzelfuchs last edited by
      ich bekomme folgende Fehlermeldung ausm Log:
      javascript.0
      2022-08-26 13:15:58.514 info script.js.common.Wetterwarnung: debug: Alert States wurden gesetzt
      javascript.0
      2022-08-26 13:15:43.627 error at changeMode (script.js.common.Wetterwarnung:887:9)
      javascript.0
      2022-08-26 13:15:43.627 error at InitDatabase (script.js.common.Wetterwarnung:2380:53)
      javascript.0
      2022-08-26 13:15:43.627 error at getDataFromServer (script.js.common.Wetterwarnung:2442:51)
      javascript.0
      2022-08-26 13:15:43.627 error at _getDataFromServer (script.js.common.Wetterwarnung:2503:37)
      javascript.0
      2022-08-26 13:15:43.627 error at processData (script.js.common.Wetterwarnung:2652:21)
      javascript.0
      2022-08-26 13:15:43.627 error at writeResultEntry (script.js.common.Wetterwarnung:2755:16)
      javascript.0
      2022-08-26 13:15:43.626 error at addDatabaseData (script.js.common.Wetterwarnung:3405:20)
      javascript.0
      2022-08-26 13:15:43.626 error at getDatabaseData (script.js.common.Wetterwarnung:3637:124)
      javascript.0
      2022-08-26 13:15:43.626 error script.js.common.Wetterwarnung: TypeError: Cannot read properties of undefined (reading '0')
      javascript.0
      2022-08-26 13:15:43.621 warn script.js.common.Wetterwarnung: info: [object Object]
      javascript.0
      2022-08-26 13:15:43.621 warn script.js.common.Wetterwarnung: info: Bitte das Json im Forum posten: EC: undefined
      javascript.0
      2022-08-26 13:15:43.621 info script.js.common.Wetterwarnung: debug: 1. addDatabaseData() ID + JSON:0_userdata.0.wetterwarnung.data.dwd.809275145.warning1.object - {"AREADESC":"Ruhstorf","NAME":"Gemeinde Ruhstorf a.d. Rott","WARNCELLID":809275145,"IDENTIFIER":"2.49.0.0.276.0.DWD.PVW.1661510700000.18b35d4b-40e8-4d91-a43f-04fe4bc5b07b.DEU","SENDER":"opendata@dwd.de","SENT":"2022-08-26T10:45:00Z","STATUS":"Actual","MSGTYPE":"Alert","SOURCE":"PVW","SCOPE":"Public","CODE":"id:2.49.0.0.276.0.DWD.PVW.1661510700000.18b35d4b-40e8-4d91-a43f-04fe4bc5b07b","LANGUAGE":"de-DE","CATEGORY":"Met","EVENT":"SCHWERES GEWITTER mit HEFTIGEM STARKREGEN und HAGEL","RESPONSETYPE":"Prepare","URGENCY":"Immediate","SEVERITY":"Severe","CERTAINTY":"Likely","EC_PROFILE":"2.1.12","EC_LICENSE":"© GeoBasis-DE / BKG 2021 (Daten modifiziert)","EC_II":"46","EC_GROUP":"THUNDERSTORM;RAIN;HAIL;WIND","EC_AREA_COLOR":"229 57 53","EFFECTIVE":"2022-08-26T10:45:00Z","ONSET":"2022-08-26T10:45:00Z","EXPIRES":"2022-08-26T12:00:00Z","SENDERNAME":"Deutscher Wetterdienst","HEADLINE":"Amtliche UNWETTERWARNUNG vor SCHWEREM GEWITTER mit HEFTIGEM STARKREGEN und HAGEL","DESCRIPTION":"Es treten Gewitter auf. Dabei gibt es heftigen Starkregen mit Niederschlagsmengen zwischen 30 l/m² und 40 l/m² pro Stunde sowie schwere Sturmböen mit Geschwindigkeiten bis 100 km/h (28m/s, 55kn, Bft 10) und Hagel.","INSTRUCTION":"ACHTUNG! Hinweis auf mögliche Gefahren: Bei Blitzschlag besteht Lebensgefahr! Vereinzelt können zum Beispiel Bäume entwurzelt und Dächer beschädigt werden. Achten Sie auf herabstürzende Äste, Dachziegel oder Gegenstände. Überflutungen von Kellern und Straßen sowie örtliche Überschwemmungen an Bächen und kleinen Flüssen sind möglich (Details: www.hochwasserzentralen.de). Es können zum Beispiel Erdrutsche auftreten. Schließen Sie alle Fenster und Türen! Sichern Sie Gegenstände im Freien! Halten Sie insbesondere Abstand von Gebäuden, Bäumen, Gerüsten und Hochspannungsleitungen! Vermeiden Sie möglichst den Aufenthalt im Freien!","WEB":"https://www.wettergefahren.de","CONTACT":"Deutscher Wetterdienst","PARAMETERNAME":"gusts;precipitation;hail","PARAMETERVALUE":"<100 [km/h];30-40 [l/m² in 1h];>0 [cm]","ALTITUDE":0,"CEILING":9842.5197,"warncellObj":{"8":true,"id":"809275145","text":"Ruhstorf","area":"Ruhstorf","favorit":true}}
      kann mir jemand weiterhelfen?
        Wurzelfuchs @Wurzelfuchs last edited by
        Ich hab jetzt einfach in Zeile 485 die "46" mit eingefügt.
        jetzt gehts ohne Fehlermeldung.
          MartyBr @Wurzelfuchs last edited by
          @wurzelfuchs Kannst du deine Version bitte posten? Ich bekomme den Fehler nicht weg. Bitte deine Anmeldedaten löschen.
            Wurzelfuchs @MartyBr last edited by
            @martybr
            Zeile 485 ff sieht bei mir jetzt so aus:
            let tempwarningTypesString = [
            ['Gewitter', 31,32,33,34,35,36,37,38,39,40,41,46,91,92,93,94,95,96],//31-49, 91-96
            ['Sturm', 51,52,53,54,55,56,57,58],//51-58
            ['Regen', 61,62,63,64,65,66],//61-66
            ['Schnee', 70,71,72,73,74,75,76,77,78],//71 - 78
            ['Nebel', 59],//59
            ['Frost', 22,82], //22, 82
            ['Glatteis', 24,84,85,86,87],//24, 84-87
            ['Tauwetter', 88,89,],
            ['Hitzewarnungen',247,248],
            ['UV_Warnungen', 246]
            ['Kuestenwarnungen', ''],
            ['Binnenseewarnungen', '']
            du musst einfach "nur" nur die Zahl aus der Fehlermeldung mit eintragen.
              @wurzelfuchs
              Danke, habe ich eingetragen. Dann schau ich mal, ob wieder Fehlermeldungen kommen.
              Danke dir. 👍
                Masl last edited by Masl
                Hallo.
                Ich habe das Script mal zum testen installiert und eingerichtet.
                Mich würde nur gern folgendes interessieren:
                Im Log fehlt der Eintrag der NINA Area:
                21:30:49.093	info	javascript.0 (264009) script.js.Warnungen: advance: Rufe Daten vom Server ab - DWD2 Area: 808216002
                21:30:49.148	info	javascript.0 (264009) script.js.Warnungen: advance: Rufe Daten vom Server ab - DWD Area: 108216000
                21:30:49.204	info	javascript.0 (264009) script.js.Warnungen: advance: Rufe Daten vom Server ab - DWD2 Area: 108216000
                21:30:49.255	info	javascript.0 (264009) script.js.Warnungen: advance: Rufe Daten vom Server ab - UWZ Area: UWZDE76474
                21:30:49.362	info	javascript.0 (264009) script.js.Warnungen: advance: Rufe Daten vom Server ab - NINA Area:
                Ich habe folgende Eingaben gemacht:
                /* für UWZ Regionnamen eingeben "Warnung der Unwetterzentrale für XXXX" */
                /* Durch das auffüllen wird der Datenabruf der UWZ aktiviert*/
                /* Textbeispiel anstatt Entenhausen: 'Stadt / Dorfname' 'Berlin' oder 'den Regionsbezeichnung' 'den Schwarzwald' ''*/
                /* UWZ - Für Deutschland: UWZDE + PLZ (UWZDE12345) */
                /* var regionName = ['UWZDE13245', 'Entenhausen'] */
                /* zum Deaktivieren [[]] oder [['','']]*/
                var regionName          = ['UWZDE76474', 'Au am Rhein'];
                // Standalone Datenquelle
                // entnehme ZAHL aus CSV
                /* nur Gemeinde/Landkreis/Großstädte werden verwendet: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3 */
                var dwdWarncellId = ['808216002','108216000']; // Deaktivieren mit '' einzel: '2334535354' mehrere: ['23423424','23423423']
                // Koordinaten [{laengen:13.05501,breiten:47.80949},{breiten:46.6247200, laengen:14.3052800},{breiten:48.332741,laengen:14.62274}];.
                var zamgCoordinates = []; // [] ist deaktiviert
                var uZAMGMitMeteoinformationen = true; // gibt die Wetterinformationen mit der Beschreibung aus: z.B Eine Kaltfront und ein Italientief sorgen im Warnzeitraum...
                // für Nina gebt die Koordinaten für euren Ort ein.
                ninaCoordinates = [{breiten:48.9516939, laengen:8.2380728, text:'Au am Rhein'}] //   ninaCoordinates = [{breiten:51.2277, laengen:6.7735, text:'dadrüben'}, {breiten:53.0511000, laengen:8.6309100, text:'Delmenhorst'}];
                /*         Datenabruf über Adapter oder externes Skript                      */
                // für Nina wird die Gemeinde und der Landkreis benötigt. Am besten von hier kopieren: https://warnung.bund.de/assets/json/suche_channel.json
                // ohne die kryptischen Zeichen. Das ersetzt nicht den NINA-Adapter
                var uGemeinde = 'Au am Rhein'; // hier steht zum Beispiel, Hamburg, Unterdorf
                var uLandkreis = 'Rastatt'; // hier Kreis Bitburg, Landkreis Fürth
                Zudem bekomme ich leider auch die Fehlermeldung:
                21:35:42.304	warn	javascript.0 (264009) script.js.Warnungen: info: getDataFromServer() 3. Error: read ECONNRESET Maybe internet is down!
                  Thomas Braun Most Active @Masl last edited by Thomas Braun
                  Die Meldung
                  script.js.common.dwd_uwz_nina_warnungen: info: getDataFromServer() 3. Error: error request aborted Maybe internet is down!
                  hing bei mir mit einem PiHole zusammen. Hab bund.de auf die Whitelist gepackt, jetzt geht es wieder.
                  Edit: Nee, geht doch nicht. Aber irgendwie hängt es mit pihole zusammen. Sobald das aus ist funktioniert alles.
                    MartyBr @Thomas Braun last edited by
                    Die 1.0.10 läuft bei mir auch nicht. Pihole ist nicht verantwortlich, habe es testweise ausgeschaltet.
                    Die version 1.0.9 läuft ohne Fehlermeldung zusammen mit Pihole.
                      Masl @MartyBr last edited by
                      @martybr Die Version 1.0.10 nervt mich... UWZ kommen gar nicht durch. Erst nach einem Neustart des Script. Die Fehlermeldung ist weiterhin da...
                      Woher bekomme ich die Vorgängerversion?
                      crunchip T 2 Replies Last reply Reply Quote 0
                        MartyBr last edited by MartyBr
                        @masl Ich lasse die Vorgängerversionen immer bestehen, deaktiviere sie nur.
                        Wenn @ticaki nichts dagegen hat, dann poste ich sie hier. Meine persönlichen Angaben habe ich anonymisiert.
                        Das Script muss ich als TXT anhängen, da es für den Code-Teil zu groß ist.
                        Unwetter-1-09.txt
                          crunchip Forum Testing Most Active @Masl last edited by
                          @masl sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                          https://github.com/ticaki/DWD-UWZ-NINA-Pushwarnungen-iobroker/commits/master
                            Masl @crunchip last edited by
                            @crunchip Ich finde da recht viel, aber nicht den Code der 1.09.... ? auch nicht im archiv...
                              @masl wenn du da drauf klickst siehst du die Änderungen und da ist auch der Wechsel der Version mit hinterlegt
                                ticaki @MartyBr last edited by ticaki
                                @martybr sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                Unwetter-1-09.txt
                                Hallo, hab ich absolut nichts dagegen.
                                War durch eine Augenoperation 2,5 Monate und Corona 2 Wochen ausser Gefecht und es ist noch immer nicht ohne Probleme wenn ich länger am Computer arbeite. Hinzukommt da mir natürlich auch das Geld (Selbstständig) dieser 3 Monate fehlt und ich aktuell kaum Zeit habe für mein Hobby.
                                Die Augenop war wegen einer Netzhautablösung im linken Auge und der Arzt hat auch gleich die künstliche Linse getauscht, was darin geendet hat das ich von 30% Sehschärfe auf etwas unter 5% (blind) gefallen bin und extrem Lichtempfindlich (Monitor) auf dem Auge bin.
                                Gruß Tim
                                M 1 Reply Last reply Reply Quote 3
                                  MartyBr @ticaki last edited by
                                  @ticaki
                                  Ich wünsche dir dann alles Gute und eine gute Besserung. Das ist ja schon eine happige Operation. Mein Schwager hat aufgrund einer Krebserkrankung und der dazu eingeleiteten Bestrahlung ähnliches erlebt. Ich kann das daher gut (soweit es geht) nachvollziehen.
                                  Nochmals auch hier ein Riesen Lob für das Script. Auch wenn es nicht weiter gepflegt wird, die Welt geht dadurch nicht unter. Vorrang sollte deine Gesundheit haben.
                                  Viele liebe Grüße, auch für deine Offenheit.
                                    Hat sich erledigt... Script läuft problemlos
                                    • bergjet
                                      bergjet last edited by
                                      Meine Einstellung:
                                      //Version 1.0.10
                                      // Erläuterung Update:
                                      // Suche im Script nach 123456 und kopiere/ersetze ab diesem Punkt. So braucht ihr die Konfiguration nicht zu erneuern.
                                      // Link: https://forum.iobroker.net/topic/30616/script-dwd-uwz-nina-warnungen-als-push-sprachnachrichten/
                                      /*             Script zum Übertragen der DWD/UWZ-Wetterwarnungen über        */
                                      /*             Telegram, Pushover, Home24-Mediaplayer, SayIt, Alexa          */
                                      /*             Datenpunkt, eMail oder ioGo                                   */
                                      /*             Pushnachrichten können manuell ausgelöst werden               */
                                      /*             höchstes Warnlevel pro Warnungstyp is als State vorhanden     */
                                      /*     mit freundlicher Unterstützung von Paul53 (Tausend Dank nochmals)     */
                                      /*                    Stand: 13022017    PrinzEisenherz1                     */
                                      /*                    Stand: 08032020    ticaki                              */
                                      Unterstützt:
                                      - Telegram, Pushover, Home24-Mediaplayer, SayIt, Alexa, Datenpunkt, eMail oder ioGo
                                      - DWD-Adapter & Unwetterzentrale-Script & NINA-Adapter ab V0.0.22
                                      - Eigener Datenabruf für DWD Kreiswarnungen (wie Adapter), DWD Gemeindeegene, UWZ, Nina (ausgenommen Hochwasser), Zamg
                                      - Wetterwarnung
                                      - Wetterentwarnung
                                      Funktionen:
                                      - Filter die Warnungen nach doppelt, Gefahr(level) und Höhe
                                      - Umschalten über iobroker zwischen DWD/UWZ/NINA
                                      - Automatischer Versand und/oder manueller Nachrichtenversand
                                      - Zeitschaltuhr für Sprachausgabe
                                      - Datenpunkte mit der Startzeit, Endzeit, Type, Schlagzeile, Beschreibung, Farbe für Level(bgcolor) und höchstem Warnlevel dieses Typs
                                      - Unterstützung für 0_userdata
                                      - Datenpunkthauptpfade sind konfigurierbar incl. 0_userdata
                                      - Konfigurationsprüfung soweit möglich
                                      - Automodus und einzelne Pushdienste über iobroker schaltbar, sowohl für Automodus als auch Manuell
                                      - Optimierte Sprachausgabe
                                      Kleinkram:
                                      - Sprachausgabe: Sturmdetails werden ausgefiltert oder korrekt ausgesprochen (konfigurierbar)
                                      - Sprachausgabe: Pause zwischen dem Absenden der einzelnen Warnungen an die Wiedergabeeinheit konfigurierbar.
                                      - Manuelle Sprachnachrichten können die Zeitschaltuhr missachten. (konfigurierbar)
                                      - Multi-User/Device bei fast allen Pushdiensten verfügbar (außer Datenpunkt & pushover)
                                      - Alexa und SayIt mit Lautstärkeeinstellung. Alexagruppen unterstützen keine Lautstärke trotzdem konfigurieren.
                                      - Zusätzliche Hervorhebung konfigurierbar über attentionWarningLevel (im Betreff/Ansage)
                                      - Filter für Nina-sender
                                      - Namesbezeichner für Nina verfügbar, diese werden benötigt, falls in der Warnung Ort genannt wird, das auszugeben und damit die Bedeutung der Warnung hervorzuheben.
                                      Farben-Bedeutung:
                                      0 - Grün // sollte es nicht geben
                                      1 - Dunkelgrün
                                      2 - Gelb Wetterwarnungen (Stufe 2)
                                      3 - Orange Warnungen vor markantem Wetter (Stufe 3)
                                      4 - Rot Unwetterwarnungen (Stufe 4) // im Grunde höchste Stufe in diesem Skript.
                                      5 - Violett Warnungen vor extremem Unwetter (sollte es nicht geben)
                                      Dank an:
                                      - crunchip, sigi234, Latzi, CruziX fürs Testen und Ideen
                                      - die ursprünglichen Authoren s.o.
                                      /*            Datenpfad konfigurieren                                       */
                                      /*            0_userdata. möglich                                           */
                                      var mainStatePath = '0_userdata.0.wetterwarnung.';
                                      /*            Datenpfad konfigurieren ENDE                                  */
                                      /* NICHT EDITIEREN */
                                      var konstanten = [
                                          {'name':'telegram','value':1,count:0, delay:200, maxChar: 4000 },
                                          {"name":'pushover',"value":2, count:0, delay:1000, maxChar: 1000},
                                          {"name":'email',"value":4},
                                          {"name":'sayit',"value":8, count:0, delay:0, maxChar: 940},
                                          {"name":'home24',"value":16, count:0, delay:0},
                                          {"name":'alexa',"value":32, count:0, delay:0, maxChar: 940},
                                          {"name":'state',"value":64},
                                          {"name":'iogo',"value":128, maxChar: 940, count: 0, delay: 300},
                                          {"name":'state_html',"value":256}
                                      const TELEGRAM = konstanten[0].value;
                                      const PUSHOVER = konstanten[1].value;
                                      const EMAIL = konstanten[2].value;
                                      const SAYIT = konstanten[3].value;
                                      const HOMETWO = konstanten[4].value;
                                      const ALEXA = konstanten[5].value;
                                      const STATE = konstanten[6].value;
                                      const IOGO = konstanten[7].value;
                                      const STATE_HTML = konstanten[8].value;
                                      var uPushdienst = 0;
                                      const DWD = 1;
                                      const UWZ = 2;
                                      const NINA = 4;
                                      const DWD2 = 8; // only for request
                                      const ZAMG = 16;
                                      const MODES = [{mode:DWD, text:'DWD'},{mode:UWZ, text:'UWZ'},{mode:NINA, text:'NINA'}, {mode: ZAMG, text:'ZAMG'}];
                                      if(mainStatePath[mainStatePath.length - 1] != '.') mainStatePath += '.';
                                      const aliveState = mainStatePath+'alive';
                                      if (extendedExists(aliveState)) {
                                          setState(aliveState, true, true);
                                      /*                       Konfiguration ab hier                               */
                                      /* Konfiguration der zu nutzenden Ausgabe um //uPushdienst+= PUSHOVER; zu aktivieren, bitte die // enfernen, also uPushdienst+= PUSHOVER; */
                                      uPushdienst+= TELEGRAM;          // Auskommentieren zum aktivieren
                                      //uPushdienst+= PUSHOVER;          // Auskommentieren zum aktivieren
                                      //uPushdienst+= EMAIL;             // Auskommentieren zum aktivieren. Einstellungen nicht vergessen
                                      //uPushdienst+= SAYIT;             // Auskommentieren zum aktivieren. Einstellungen nicht vergessen
                                      //uPushdienst+= HOMETWO;           // Auskommentieren zum aktivieren. Einstellungen nicht vergessen
                                      uPushdienst+= ALEXA;             // Auskommentieren zum aktivieren. Einstellungen nicht vergessen
                                      //uPushdienst+= STATE;             // Auskommentieren zum aktivieren. State befindet sich unter mainStatePath.message
                                      //uPushdienst+= IOGO;              // Auskommentieren zum aktivieren. Einstellungen nicht vergessen
                                      //uPushdienst+= STATE_HTML;        // Auskommentieren zum aktivieren. State_html befindet sich unter mainStatePath.messageHtml als Tabelle
                                      /*                 Beispiele zur weiteren Konfiguration                      */
                                      /* kein oder einen Eintrag möglich:
                                      /* var senderEmailID = ["max@mustermann.de"];
                                      /* kein oder mehrfach nach gleichem Muster [1, 2, 3] bzw. ['1', '2', '3'] Einträge
                                      /* '' ist das selbe wie "", jedoch nicht mischen.
                                      /* var empfaengerEmailID = ["max@musterman.de","max2@musterman.de"];
                                      /* var telegramUser = []; // leer
                                      /* var telegramUser = ['']; // leer
                                      /* var telegramUser = ['Hans']; // User mit Namen Hans
                                      /* var telegramUser = ['Hans', 'Gretel']; // User mit Namen Hans und User mit Namen Gretel
                                      /* var idSayIt = ["sayit.0.tts.text"];
                                      /* var sayItVolumen = [60]; // Zahl ohne ''
                                      /* var idSayIt = ["sayit.0.tts.text","sayit.1.tts.text"];
                                      /* var sayItVolumen = [60, 30]; // mehrfach Zahl ohne ''
                                      /* var ioGoUser = ['max@musterman.de'];
                                      /* var idAlexaSerial =['G090RV32984110Y', 'G090RZ3345643XR'];
                                      /* var alexaVolumen = [40, 30]; // Lautstärke die gleiche Anzahl an Einträgen wie bei idAlexaSerial
                                      /*                          weitere Konfiguration                            */
                                      /*                                Datenabruf intern                          */
                                      var regionName          = [['','']];
                                      var dwdWarncellId = ''; // Deaktivieren mit '' einzel: '2334535354' mehrere: ['23423424','23423423']
                                      var zamgCoordinates = [{laengen: 15.156741515414303,breiten: 48.018632603793776}]; // [] ist deaktiviert
                                      ninaCoordinates = [] //   ninaCoordinates = [{breiten:51.2277, laengen:6.7735, text:'dadrüben'}, {breiten:53.0511000, laengen:8.6309100, text:'Delmenhorst'}];
                                      var uGemeinde = ''; // hier steht zum Beispiel, Hamburg, Unterdorf
                                      var uLandkreis = ''; // hier Kreis Bitburg, Landkreis Fürth
                                      /*                                Sonstige                                   */
                                      /* Einstellungen zur Emailbenachrichtigung*/
                                      var senderEmailID       = [""]; // mit Sender Emailadresse füllen. email Adapter muß installiert sein. 1 Eintrag erlaubt [] oder ["email1"]
                                      var empfaengerEmailID   = [""]; // mit Empfänger Emailadresse füllen. Mehrere Empfänger möglich. [] oder ["email1"] oder ["email1","email2"]
                                      /* Konfiguration Sprachausgabe über Home24 - Mediaplayer */
                                      //var idMediaplayer = ["192.168.178.x:Port"];
                                      var idMediaplayer       = [""]; // Eingabe IP-Adresse incl. Port für Home24-Mediaplayer mehrere Möglich - ungetestet
                                      /* Konfiguration Telegram */
                                      var telegramUser                = []; // Einzelnutzer ['Hans']; Multinutzer ['Hans, Gretel']; Nutzer vom Adapter übernehmen [];
                                      var telegramChatId              = ['']; // Mehrfach Einträge möglich ['Gruppe1','Gruppe2']
                                      var uTelegramReplyMarkup        = null; // Falls ihr ein Telegrammmenü verwendet, könnt ihr hier einen Weg zurück definieren z.B.: {keyboard: [['Zurück']], resize_keyboard: true};
                                      var uTelegramAllowNotification  = true; // Erlaube Telegramnotification (Benachrichtigungston/Hinweise auf dem Empfangsgerät)
                                      var uTelegramUseStdUser         = false; // Verwende immer auch die im Adapter gespeicherten Benutzer.
                                      uTelegramReplyMarkupInline      = true   // Bei Nachrichten die nicht mit volle Länge angefragt wurde, gibt es eine Schalfläche in der man die Langversion anfordern kann.
                                      /* Konfiguration Pushover */
                                      var uPushoverDeviceName     = ''; // ein bestimmtes Gerät z.B: ['droid4'];
                                      var uPushoverSound          = ''; // Sounds siehe: https://pushover.net/api#sounds
                                      //Konfiguration von ioGo
                                      var ioGoUser = ['']; // // Einzelnutzer ['Hans']; Multinutzer ['Hans', 'Gretel']; Nutzer vom Adapter übernehmen [];
                                      var ioGoExpiry = 0;     // Nachricht wird nach Sekunden entfernt. 0: aus
                                      /* Konfiguration Sprachausgabe über SayIt */
                                      var idSayIt             = ["sayit.0.tts.text"]; // mehrfach Einträge möglich
                                      var sayItVolumen        = [30]; // gleiche Anzahl wie idSayIt
                                      /* Konfiguration Sprachausgabe über Alexa
                                      /* mehrere Einträge möglich, bei mir ging nur der Echo, 2 dots 2.Gen reagieren nicht auf announcement. */
                                      var idAlexaSerial       = ['G090LV0365250072','G090VC09915705D3']; // die reine Seriennummer des Echos z.B.: var idAlexaSerial =['G090RV32984110Y', 'G090RV32984110Y']
                                      var alexaVolumen        = [30]; // Lautstärke die gleiche Anzahl an Einträgen wie bei idAlexaSerial
                                      alexaMultiroomParentsOff = false; // pausiere alle mit den IDs verknüpfte Multiroomgruppen
                                      // Filtereinstellungen über Objekte einstellen
                                      var minlevel                      =    1 // Warnungen unterhalb dieses Levels nicht senden; (DWD und Nina level 1-4  / UWZ 0-5)
                                      var attentionWarningLevel         =    3 // Warnung gleich oder oberhalb dieses Levels mit zusätzlichen Hinweisen versehen
                                      var minhoehe                      =    0 // Warnung für eine Höhe unterhalb dieses Wertes nicht senden
                                      var maxhoehe                      =    5000 // Warnung für eine Höhe oberhalb dieses Wertes nicht senden
                                      // Sprachausgabe Zeiten
                                      // Für durchgehende Sprachausgabe die Einstellung der Zeiten auf '' setzen. z.B. var startTimeSpeak = '';
                                      var startTimeSpeak =        '6:45';// Zeiten mo - fr ab der Sprachausgaben ok sind. Nicht unter 6 Uhr gehen oder den Schedule ändern
                                      var startTimeSpeakWeekend = '9:00';// sa + so Bemerkung siehe oben
                                      var endTimeSpeak =          '22:30'; // ab diesem Zeitpunkt gibt es keine Sprachausgabe
                                      // Ein manuellen Auslösen von Sprachnachrichten, löscht alle noch nicht ausgegebenen Sprachnachrichten aus der Liste.
                                      var uManuellClickClearSpeakMessageList = true;
                                      //Auslösen der Pushnachricht über States ignoriert Sprachausgabezeiten
                                      var forcedSpeak             = true;
                                      // keine Ansage über m/s Knoten und Windstärke. Die Angabe mit Kilometer pro Stunde wird angesagt
                                      var windForceDetailsSpeak   = false;
                                      // Über Objekte einzustellen
                                      uLogLevel = 1 // 0:OFF, 1:INFO, 2:ADVANCE, 4:DEBUG
                                      /*                       Nur Anpassen wenn nötig                             */
                                      //Formatierungsstring für Datum / Zeit Alternative "TT.MM.YYYY SS:mm" KEINE Anpassung nötig
                                      const formatierungString =  "TT.MM.YY SS:mm";
                                      var scriptOverrides = false; // Die Einstellung im Skript überschreiben bei jedem Start die Einstellungen in den Objekten (punkte unter Basiskonfiguration außer warnzelle.
                                      // Die Geschwindigkeit gibt an wie lange das Skript wartet bevor es eine neue Nachricht an die Sprachausgabe sendet.
                                      konstanten[3].delay /*SayIt*/       = 86; // Vorlese Geschwindigkeit pro Zeichen in ms
                                      konstanten[4].delay /*Home24*/      = 90; // Vorlese Geschwindigkeit pro Zeichen in ms
                                      konstanten[5].delay /*Alexa*/       = 88; // Vorlese Geschwindigkeit pro Zeichen in ms
                                      // Mit diesen Optionen verringert man die Nachrichtenlänge in dem Beschreibung oder Handlungsanweisungen
                                      // nicht der Nachricht hinzugefügt werden.
                                      // über Objekte einzustellen
                                      var uHtmlMitBeschreibung            = true; // gilt für Email
                                      var uHtmlMitAnweisungen             = true; // uHtmlMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
                                      var uTextMitBeschreibung            = true; // gilt nicht für Email, aber für alle anderen Textnachrichten
                                      var uTextMitAnweisungen             = true; // uTextMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
                                      var uSpracheMitBeschreibung         = true; // gilt für alle Sprachnachrichten
                                      var uSpracheMitAnweisungen          = true; // uSpracheMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
                                      var uSpracheMitOhneAlles            = true; // super kurz überschreibt die anderen Einstellungen
                                      uTextHtmlMitOhneAlles               = false // super kurz für Text und Html
                                      // Obergrenze an Zeichen die über Sprachausgabe ausgegeben werden, bei überschreitung wird nur die Schlagzeile ausgegebenen
                                      var uMaxCharToSpeak = 0; // 0 = aus - Zahl größer als 0 = maximal Zeichenanzahl (1000 sind rund 86 Sekunden bla bla)
                                      // Automodus Filter um Warnungen unterhalb attentionWarningLevel von DWD, UWZ oder NINA zu unterdrücken
                                      // Sprachausgabe bei auto und manuell unterdrückt.
                                      // Diese Warnungen sind vorhanden, sie werden nur in den benannten Fällen ausgeblendet.
                                      // Ist eine feste Vorgabe überschreibt alles andere
                                      var uFilterList               = 0;   // generelles Filter für den AutoModus ( = DWD + UWZ; oder = NINA; oder = 0;), außer Warnungslevel ist gleich/über attentionWarningLevel
                                      var uAutoNinaFilterList       = ['CAP@hochwasserzentralen.de']; //Nina only. Filter diesen Sender raus s.o. - mehrere ['abc','cde'];
                                      var uwzPath=            'javascript.0.UWZ';
                                      var dwdPath=            'dwd.0';
                                      var ninaPath=           'nina.0'
                                      var intervalMinutes = 5; // die Daten bei DWD werden alle 10 Minuten aktualisiert.
                                      // Instanzen im ioBroker
                                      var telegramInstanz=    'telegram.0';
                                      var pushoverInstanz=    'pushover.0';
                                      var ioGoInstanz=        'iogo.0';
                                      var alexaInstanz=       'alexa2.0';
                                      var emailInstanz=       'email.0';
                                      /*                       Konfiguration Ende                                  */
                                      /*        Keine Anpassungen ab hier, außer du weißt was du tuest             */
                                      Meine Warnmeldungmeldung:
                                      javascript.0 (764) script.js.Test.Unwetterwarnung: info: Alle Benachrichtigungen ausgeschaltet, bitte unter ioBroker - Objektansicht - 0_userdata.0.wetterwarnung..config - UWZ und/oder DWD und/oder NINA auf true stellen.
                                      25.11.2022, 10:34:34.440	[info ]: javascript.0 (764) Start javascript script.js.Test.Unwetterwarnung
                                      25.11.2022, 10:34:34.474	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Skripts gestartet: ID:5624.068911063456
                                      25.11.2022, 10:34:34.475	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info:  var regionName:  Eintrag 1 ist teilweise oder ganz leer, wird entfernt
                                      25.11.2022, 10:34:34.481	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Warte 15 Sekunden das bei einem eventuellen Restart alles beendet wurde!
                                      25.11.2022, 10:34:34.482	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      25.11.2022, 10:34:49.486	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Starte Initialisierung! - Bitte warten. Das dauert beim ersten Start etwas länger. - Das Skript in dieser Phase nicht Neustarten, wenn doch bitte Javascript Instanz ebenfalls neustarten
                                      25.11.2022, 10:34:49.487	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Datenpunkte werden überprüft
                                      25.11.2022, 10:34:50.539	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Abonniere Konfigurationsdatenpunkte
                                      25.11.2022, 10:34:50.544	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Setzte Modus, Inialisiere Datenbank, starte Datenabruf(asynchron)
                                      25.11.2022, 10:34:50.544	[warn ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Alle Benachrichtigungen ausgeschaltet, bitte unter ioBroker - Objektansicht - 0_userdata.0.wetterwarnung..config - UWZ und/oder DWD und/oder NINA auf true stellen.
                                      25.11.2022, 10:34:50.545	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: InitDatabase() - first run: false
                                      25.11.2022, 10:34:50.545	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Standalone ZAMG Datenabruf aktiviert
                                      25.11.2022, 10:34:50.549	[info ]: javascript.0 (764) script.js.Test.Unwetterwarnung: info: Initialisierung abgeschlossen
                                      Ich verwende die Warnmeldung von ZAMG
                                      Die Ausgabe sollte auf Telegramm und Alexa erfolgen.
                                      Wie kann ich das dann testen?
                                        sigi234 Forum Testing Most Active @bergjet last edited by
                                        @bergjet
                                        Was hast du da eingestellt?
                                        bergjet 1 Reply Last reply Reply Quote 0
                                        • bergjet
                                          bergjet @sigi234 last edited by
                                          @sigi234 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                          @bergjet
                                          Der Datenpunkt ist leer.
                                            @bergjet sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                            Alle? Screenshot bitte
                                            1521
                                            564368
