    4. ioBroker startet nicht mehr
      Thomas Braun Most Active @Magnus 0 last edited by
      @magnus-0
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Magnus 0 @Thomas Braun last edited by
        pi@DELO0150:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        pi@DELO0150:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.1
        v16.17.1
        8.15.0
        4.0.23
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        /home/pi
        OK:1 http://archive.raspberrypi.org/debian buster InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:3 https://deb.nodesource.com/node_16.x buster InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           16.17.1-deb-1nodesource1
          Installationskandidat: 16.17.1-deb-1nodesource1
          Versionstabelle:
         *** 16.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
          @magnus-0
          Starte die Kiste mal sauber durch.
            also "sudo reboot"?
              @magnus-0
              Ja.
                Gleiches Problem immer noch.
                  @magnus-0
                  iobroker status
                  iobroker update -i
                    pi@DELO0150:~ $ iobroker status
                    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                      pi@DELO0150:~ $ iobroker update -i
                        @magnus-0
                        systemctl status iobroker.service
                        iobroker status
                        sudo systemctl stop iobroker.service
                        iobroker start
                          @thomas-braun sagte in ioBroker startet nicht mehr:
                          iobroker start
                          pi@DELO0150:~ $ systemctl status iobroker.service
                          ● iobroker.service - ioBroker Server
                             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                             Active: active (running) since Fri 2022-09-30 20:56:19 CEST; 28s ago
                               Docs: http://iobroker.net
                           Main PID: 882 (iobroker.js-con)
                              Tasks: 11 (limit: 4915)
                             CGroup: /system.slice/iobroker.service
                                     └─882 iobroker.js-controller
                          Sep 30 20:56:19 DELO0150 systemd[1]: Started ioBroker Server.
                          pi@DELO0150:~ $ sudo systemctl stop iobroker.service
                          pi@DELO0150:~ $ iobroker start
                            @magnus-0 sagte in ioBroker startet nicht mehr:
                            sudo apt install lsof
                            sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                              Magnus 0 @Thomas Braun last edited by Magnus 0
                              pi@DELO0150:~ $ sudo apt install lsof
                              Die folgenden NEUEN Pakete werden installiert:
                                lsof
                              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 307 kB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 447 kB Plattenplatz zusätzlich benutzt.
                              Holen:1 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf lsof armhf 4.91+dfsg-1 [307 kB]
                              Es wurden 307 kB in 2 s geholt (196 kB/s).
                              Vormals nicht ausgewähltes Paket lsof wird gewählt.
                              (Lese Datenbank ... 53671 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../lsof_4.91+dfsg-1_armhf.deb ...
                              Entpacken von lsof (4.91+dfsg-1) ...
                              lsof (4.91+dfsg-1) wird eingerichtet ...
                              Trigger für man-db (2.8.5-2) werden verarbeitet ...
                              pi@DELO0150:~ $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                              COMMAND    PID     USER   FD   TYPE DEVICE  SIZE/OFF   NODE NAME
                              iobroker. 1226 iobroker   19u   REG  179,2 972533859 261398 /opt/iobroker/iobroker-data/objects.jsonl
                                sudo kill 1226
                                  sudo kill 1226
                                  pi@DELO0150:~ $ sudo kill 1226
                                  kill: (1226): Kein passender Prozess gefunden
                                    Da ja der ioBroker dauert neustartet, ändert sich glaub die PID.
                                    Ich habe jetzt mal sekündlich folgenden Befehl eingegeben:
                                    iobroker. 1952 iobroker   19u   REG  179,2 972533859 261398 /opt/iobroker/iobroker-data/objects.jsonl
                                    Wenn ich den Befehl ein paar Sekunden später wieder eingebe, steht wieder eine andere PID dabei.
                                      Ja, natürlich. Mir fällt nur im Moment nix dazu ein warum der ioBroker dauernd neustartet.
                                        Achso ok, ist das vielleicht normal, dass er sich 30 Sekunden mit der Datenbank verbinden möchte und wenn das nicht klappt einen Neustart durchführt?
                                        Folgend ein Log-Auszug:
                                        2022-09-30 21:15:05.006  - error: host.DELO0150 No connection to databases possible, restart
                                        2022-09-30 21:15:05.016  - info: host.DELO0150 iobroker _restart
                                        2022-09-30 21:15:05.525  - info: host.DELO0150 connected to Objects and States
                                        2022-09-30 21:15:05.555  - info: host.DELO0150 added notifications configuration of host
                                        2022-09-30 21:15:05.563  - info: host.DELO0150 Node.js version has changed from 16.16.0 to 16.17.1
                                        2022-09-30 21:15:05.632  - info: host.DELO0150 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                        2022-09-30 21:15:05.717  - info: host.DELO0150 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        2022-09-30 21:15:05.786  - info: host.DELO0150 7 instances found
                                        2022-09-30 21:15:05.812  - info: host.DELO0150 starting 7 instances
                                        2022-09-30 21:15:05.909  - info: host.DELO0150 instance system.adapter.admin.0 started with pid 2060
                                        2022-09-30 21:15:10.520  - info: host.DELO0150 iobroker.js-controller version 4.0.23 js-controller starting
                                        2022-09-30 21:15:10.527  - info: host.DELO0150 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                        2022-09-30 21:15:10.528  - info: host.DELO0150 hostname: DELO0150, node: v16.17.1
                                        2022-09-30 21:15:10.529  - info: host.DELO0150 ip addresses: 192.168.178.150 fe80::5068:6694:ad08:cc79
                                        2022-09-30 21:15:40.549  - error: host.DELO0150 No connection to databases possible, restart
                                        2022-09-30 21:15:40.558  - info: host.DELO0150 iobroker _restart
                                        2022-09-30 21:15:41.154  - info: host.DELO0150 connected to Objects and States
                                        2022-09-30 21:15:41.184  - info: host.DELO0150 added notifications configuration of host
                                        2022-09-30 21:15:41.193  - info: host.DELO0150 Node.js version has changed from 16.16.0 to 16.17.1
                                        2022-09-30 21:15:41.261  - info: host.DELO0150 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                        2022-09-30 21:15:41.352  - info: host.DELO0150 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        2022-09-30 21:15:41.408  - info: host.DELO0150 7 instances found
                                        2022-09-30 21:15:41.434  - info: host.DELO0150 starting 7 instances
                                        2022-09-30 21:15:41.539  - info: host.DELO0150 instance system.adapter.admin.0 started with pid 2095
                                        2022-09-30 21:15:46.246  - info: host.DELO0150 iobroker.js-controller version 4.0.23 js-controller starting
                                        2022-09-30 21:15:46.252  - info: host.DELO0150 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                        2022-09-30 21:15:46.253  - info: host.DELO0150 hostname: DELO0150, node: v16.17.1
                                        2022-09-30 21:15:46.254  - info: host.DELO0150 ip addresses: 192.168.178.150 fe80::5068:6694:ad08:cc79
                                          Denkst du, wir bekommen das heute irgendwie hin?
                                            Thomas Braun Most Active @Magnus 0 last edited by Thomas Braun
                                            @magnus-0
                                            sudo systemctl disable iobroker.service
                                            Sollte den restart loop unterbrechen.
                                            1671
