    3. Off Topic
    4. Zählerstände visualisieren
      liv-in-sky @Wszene last edited by
      @wszene
      denkst du an sowas?
        @wszene
        hier das script dazu - die 3 datenpunkte musst du im script einstellen - die sind ja bei dir wo anders (rote pfeile)
         <variables>
           <variable id="C|7Hvj}4:d28m!2G/^3_">JsonData</variable>
           <variable id=",V0`HHOB)Lc;lP).fRvo">myValue</variable>
           <variable id="g.W8ouD}/|D}4#_A{x(u">myDifferenz</variable>
           <variable id="C`+9GusIciON]M$;#$#_">myDate</variable>
           <variable id="vjsaCA?A5Qwtuv(pC^sq">differenceLastMonth</variable>
           <variable id="PrPY;|4]dTeDTohPAkR{">myStromJSON</variable>
         </variables>
         <block type="on" id="rcACyBS(G!|NdQNWe)C;" x="162" y="87">
           <field name="OID">0_userdata.0.CONTROL-OWN.STROMZÄHLER.INPUTStromDaten</field>
             <block type="controls_if" id="3=3*TU+K_,REP^M(Vl3U">
                 <block type="logic_compare" id="$fsm/=HJxlO*-9=.E5hb">
                   <field name="OP">GT</field>
                     <block type="math_arithmetic" id="v7D2tTTRF*Cu$AwpoQtw">
                         <shadow type="math_number">
                           <field name="NUM">1</field>
                         <block type="on_source" id="3?+n^Ih.`{E_t+R3-BDJ">
                         <block type="on_source" id="9W/8?:n3GI(zWUY^dSwe">
                           <field name="ATTR">oldState.val</field>
                     <block type="math_number" id="TYoviIg254:jv-n2bx3R">
                       <field name="NUM">0</field>
                 <block type="variables_set" id="ViW]2wGopV0g[^gG4TMN">
                   <field name="VAR" id="vjsaCA?A5Qwtuv(pC^sq">differenceLastMonth</field>
                     <block type="math_arithmetic" id="5zSzHd)5^+}L5eDEjyb;">
                         <shadow type="math_number" id="[cO`N[AJMN,6T5j)aU~/">
                         <block type="on_source" id="S3IqN1?B-Z]}E}xQO;;d">
                         <shadow type="math_number" id="+n6r+4w8O*B}BL`-@[`G">
                         <block type="on_source" id="Q{Q**6d|LZ!rhA0T4n[T">
                     <block type="control" id="/(lOdH2ztOzoS=*_{+Xq">
                       <field name="OID">0_userdata.0.CONTROL-OWN.STROMZÄHLER.MONATDIFFERENZStromDaten</field>
                         <block type="variables_get" id="1ilSv(6Ah[W}E{X3Qipn">
                         <block type="controls_if" id="EigRd/}$;oZLSw]nCX]#">
                           <mutation elseif="1" else="1"></mutation>
                             <block type="logic_compare" id="}Ujo_hAP=uA`}Bu@`$q-">
                               <field name="OP">EQ</field>
                                 <block type="get_value" id="#FUW9p(htE[3@kv0tEHP">
                                   <field name="OID">0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONStromDaten</field>
                                 <block type="text" id="Wga1jL[#zr1u2.k|Xd)6">
                                   <field name="TEXT"></field>
                             <block type="variables_set" id="wEMzZ3{_2yo[u0TWOt^^">
                               <field name="VAR" id="PrPY;|4]dTeDTohPAkR{">myStromJSON</field>
                                 <block type="lists_create_with" id="[dAAJhx~-q(EW1.bE?I6">
                                 <block type="procedures_callnoreturn" id="uR=ST{sOX9ubJ_zkM0~U">
                                   <mutation name="jsonFunc"></mutation>
                           <value name="IF1">
                             <block type="logic_compare" id="K9{n^%.8ZjuL7$U0BkI*">
                                 <block type="lists_length" id="=7AG(6y*9GZ;TGxk=GT+">
                                     <block type="convert_json2object" id="uue^mgV@O{SxLzXk4R={">
                                         <block type="get_value" id="bL0lFl6bBF*w40a90ax:">
                                 <block type="math_number" id="QtlW?tFQjkYKN{zIwwKH">
                           <statement name="DO1">
                             <block type="variables_set" id="L.Ivc)I@m*}Ym)ib3^+(">
                                 <block type="convert_json2object" id="1RN3o-a`SZ_C(Ne0}qe,">
                                     <block type="get_value" id="P#f%bsw^49^d}{.l1o]d">
                                 <block type="procedures_callnoreturn" id="{,Z8M]n@%QKABA^$Vh|w">
                           <statement name="ELSE">
                             <block type="debug" id="##63#tSuc%.cxkYGQ0Pn">
                               <field name="Severity">warn</field>
                               <value name="TEXT">
                                 <shadow type="text" id="$@=T!+1Jt|^M9p^}Le}5">
                                   <field name="TEXT">beim Stromzähler stimmt was nicht</field>
         <block type="procedures_defcustomreturn" id="-dj~-jKd1)aXigrUB7Nn" x="687" y="113">
           <mutation statements="false">
             <arg name="JsonData" varid="C|7Hvj}4:d28m!2G/^3_"></arg>
             <arg name="myValue" varid=",V0`HHOB)Lc;lP).fRvo"></arg>
             <arg name="myDifferenz" varid="g.W8ouD}/|D}4#_A{x(u"></arg>
             <arg name="myDate" varid="C`+9GusIciON]M$;#$#_"></arg>
           </mutation>
           <field name="NAME">makeJSON</field>
           <field name="SCRIPT">DQoNCkpzb25EYXRhLnB1c2goew0KICAgICJEYXR1bSI6bXlEYXRlLA0KICAgICJWZXJicmF1Y2hNb25hdCI6bXlEaWZmZXJlbnosDQogICAgIkFiZ2VsZXNlbmVyV2VydCI6bXlWYWx1ZSwNCiAgICAiVGltZXN0YW1wIjogRGF0ZS5ub3coKQ0KfSkNCg0KcmV0dXJuIEpzb25EYXRhOw==</field>
         <block type="procedures_defnoreturn" id="4!+9YQ-Yv-QN$!yE=,7A" x="438" y="588">
           <field name="NAME">jsonFunc</field>
           <statement name="STACK">
             <block type="control" id="=:2:b@-tOR+A#7V*Fyr(">
                 <block type="convert_object2json" id="l$_p|jf-I=k!`m$Qs0`i">
                   <field name="PRETTIFY">FALSE</field>
                     <block type="procedures_callcustomreturn" id="uEYJ_Wd^X3r5BSd;@[y8">
                       <mutation name="makeJSON">
                         <arg name="JsonData"></arg>
                         <arg name="myValue"></arg>
                         <arg name="myDifferenz"></arg>
                         <arg name="myDate"></arg>
                       </mutation>
                       <value name="ARG0">
                         <block type="variables_get" id="hti91V)gqt|DGi|Bc1x0">
                       <value name="ARG1">
                         <block type="get_value" id="eJWw#gmXkOXg($O2xgN1">
                       <value name="ARG2">
                         <block type="variables_get" id="E%aqp.%6.G@u7p8%M`IY">
                       <value name="ARG3">
                         <block type="convert_from_date" id="aT54!grlK95Q3-xCm@Dh">
                           <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                           <field name="OPTION">custom</field>
                           <field name="FORMAT">JJJJ.MM.TT SS:mm</field>
                             <block type="time_get" id="9I2c^oos%BBJ2J(KK4lj">
                               <field name="OPTION">object</field>
          liv-in-sky @Wszene last edited by liv-in-sky
          @wszene
          und das input und json widget - das json ist von inventwo widgets - das muss du installiert haben - auch hier die dp angleichen
          [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"10","iTableRefreshRate":"0","iTblSortOrder":"desc","iColCount":"3","iColShow1":"true","iTblHeadTextAlign1":"center","iTblTextAlign1":"center","iTblCellFormat1":"normal","iTblCellImageSize1":"200","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellThresholdsDp1":"","iTblCellThresholdsText1":"","iOpacityAll":"1","iTblRowEvenColor":"#333333","iTblRowUnevenColor":"#343829","iTblHeaderColor":"#333333","iRowSpacing":"10","iTblRowEvenTextColor":"#ffffff","iTblRowUnevenTextColor":"#ffffff","iTblHeaderTextColor":"#ffffff","iBorderSize":"0","iBorderStyleLeft":"none","iBorderStyleRight":"none","iBorderStyleUp":"none","iBorderStyleDown":"none","iBorderColor":"#ffffff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONStromDaten","iTblShowHead":true,"iColShow2":"true","iTblHeadTextAlign2":"center","iTblTextAlign2":"center","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellThresholdsDp2":"","iTblCellThresholdsText2":"","iColShow3":"true","iTblHeadTextAlign3":"center","iTblTextAlign3":"center","iTblCellFormat3":"normal","iTblCellImageSize3":"200","iTblCellBooleanCheckbox3":"false","iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellThresholdsDp3":"","iTblCellThresholdsText3":"","iTblSortAttr":"Timestamp","iHorScroll":false,"iVertScroll":true},"style":{"left":"948px","top":"636px","width":"593px","height":"220px","border-width":"1px","border-style":"solid","border-color":"#20f824","border-radius":"15px"},"widgetSet":"vis-inventwo"},{"tpl":"tplJquiInput","data":{"oid":"0_userdata.0.CONTROL-OWN.STROMZÄHLER.INPUTStromDaten","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","label":"Input","digits":"0","size":"10","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"919px","top":"558px"},"widgetSet":"jqui"}]
          Wszene 1 Reply Last reply Reply Quote 1
          • Wszene
            Wszene @liv-in-sky last edited by
            @liv-in-sky
            Vielen Dank für deine Mühe
            Das Input über die VIS funktioniert auch perfekt
            Auch das eintragen der Differenz in den DP klappt
            Aber dann beim JSON bringt er mir einen Fehler
            Fehler:
            javascript.0
            2022-09-30 06:16:17.983	error	at processImmediate (node:internal/timers:466:21)
            javascript.0
            2022-09-30 06:16:17.982	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
            javascript.0
            2022-09-30 06:16:17.982	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
            javascript.0
            2022-09-30 06:16:17.982	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
            javascript.0
            2022-09-30 06:16:17.982	error	at Object.<anonymous> (script.js.030-Allgemeines.Zählerstände.Zählerstand_-_Strom:32:149)
            javascript.0
            2022-09-30 06:16:17.982	error	script.js.030-Allgemeines.Zählerstände.Zählerstand_-_Strom: TypeError: Cannot read properties of null (reading 'length')
            Mein DP für das JSON sieht so aus
              "common": {
                "name": "JSONStromDaten",
                "type": "string",
                "read": true,
                "write": true,
                "role": "state",
                "smartName": false
              "native": {},
              "type": "state",
              "user": "system.user.admin",
              "ts": 1664509310320,
              "_id": "0_userdata.0.07_Zaehlerstände.Strom.JSONStromDaten",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
            Ich lege den DP mit diesem Skript an
            // DP Strom
            createState('0_userdata.0.07_Zaehlerstände.Strom.Input', {'name':'InputStromDaten', 'type':'number', 'read':true, 'write':true, 'role':'state', "smartName": false });
            createState('0_userdata.0.07_Zaehlerstände.Strom.DifferenzLastMonth', {'name':'Differenz zum letzten monat', 'type':'number', 'read':true, 'write':true, 'role':'state', "smartName": false });
            createState('0_userdata.0.07_Zaehlerstände.Strom.JSONStromDaten', {'name':'JSONStromDaten', 'type':'string', 'read':true, 'write':true, 'role':'state', "smartName": false });
            Siehst du da einen Fehler?
            Danke für deine Hilfe
              @wszene nur kurz - muss leider gleich los
              stelle sicher - also das script kurz pausieren - dass in den nummern-datenpunkte eine 0 steht und im string-datenpunkt kein string drin ist - auch kein leerzeichen
              dann script starten und einmal einen wert eingeben
              Wszene 1 Reply Last reply Reply Quote 0
              • Wszene
                @liv-in-sky
                Ich habe mal das Skript gestopt
                Dann in alle DPs 0 eingetragen
                dann das Skript gestartet
                einen Wert eingegeben
                Nun kommt
                06:28:25.351	warn	javascript.0 (434) script.js.030-Allgemeines.Zählerstände.Zählerstand_-_Strom: beim Stromzähler stimmt was nicht
                Es muss auch nicht jetzt sein
                Ich muss auch gleich los
                  @wszene übers wochenende bekommen wir das zum laufen 🙂
                    @wszene
                    die warnung kommt eigentlich, wenn im json-datenpunkt (string-dp) - beim ersten mal eingeben - etwas steht- nur wenn da nichts drinsteht, funktioniert das erste mal
                    ab dann wird dort ein json gesichert und das script weiß was zu tun ist
                    also bitte nochmal script stoppen /pausieren - zahlen-datenpunkte mit 0 beschreiben und im string-datenpunkt reinklicken und alles löschen
                    • Dr.Pie
                      Dr.Pie last edited by
                      @liv-in-sky
                      Moin
                      ich hänge mich mal hier mit dran da ich genau das selbe vor habe.
                      Die Datenpunkte wurde durch das Skript erstellt.
                      In dem Skript selber habe ich die Anpassungen vorgenommen.
                      Aber in dem Widget wird nichts angezeigt.
                      Ich habe da nicht wirklich die Ahnung von ... ich habe mehr Ahnung von Copy/Paste 😳
                      Wo hängt es denn bei mir ?
                      Irgendwo müssen die Werte ja in eine Tabelle rein ... oder ???
                        liv-in-sky @Dr.Pie last edited by
                        @dr-pie
                        hast du das gemacht - sonst geht es nicht beim ersten mal
                        https://forum.iobroker.net/post/865722
                        Dr.Pie 1 Reply Last reply Reply Quote 0
                        • Dr.Pie
                          Dr.Pie @liv-in-sky last edited by
                          @liv-in-sky
                          ja das hatte ich.
                            @dr-pie
                            lust auf anydesk session ?
                              @dr-pie
                              ich würde es gerne sehen, da ich mein script schon x-mal resettet habe und es immer funktioniert - nur bei euch beiden klappt es nicht
                              • Dr.Pie
                                @liv-in-sky sagte in Zählerstände visualisieren:
                                @dr-pie
                                Auf waaaaas ?.?
                                  @dr-pie
                                  schau mal in den chat
                                    ich überarbeite das script nochmal - beim ersten wert ist immer die referenz falsch, daher ist der erste wert zu groß
                                    wird so aussehen
                                    ich poste das script morgen
                                    das balken widget gibt es auch dazu - material design widgets muss dafür installiert sein
                                    • Dr.Pie
                                      @liv-in-sky ok...
                                        liv-in-sky last edited by liv-in-sky
                                        habe neue version des scriptes:
                                        • es gibt insgesamt 5 datenpunkte, die von euch angelegt werden müssen - die JSON datenpunkte müssen vom Typ string sein, die anderen vom type number
                                        • die dp-id's müssen dann ins script eingetragen werden !! (roter pfeil) - das hilft etwas, wenn man mehrere scripte am laufen hat (strom, gas,..)
                                        • ebenso der ausgangspunkt (blauer pfeil)- da wir die differenz anzeigen, muss der erste wert eine richtige referenz bekommen.
                                        • auch der preis pro einheit (orange)
                                        • und die anzahl der zu sehenden balken im diagramm(schwarzer pfeil)
                                        • der wert, der im input widget eingegeben wird, muss immer größer sein, als der vorherige !
                                        • zusätzlich zu dem balkendiagramm, sollte man das ganze noch in der history loggen - zur sicherheit der daten - besonders den dp mit der json tabelle
                                        • bei einer fehleingabe: es kann das json für die tabelle direkt im datenpunkt geändert werden
                                        das script resetten:
                                        setzt man den wert im folgenden bilds auf true und speichert das script und setzt ihn anschliessend wieder auf false und speichert wieder , sind alle daten gelöscht !!!! und man beginnt von vorne mit der eingabe - die tabelle mit all den daten ist dann WEG - daher immer über die history (influx,sql) sichern - oder vorher den wert des datenpunktes koperen und irgendwo speichern
                                        hier nun das blockly script:
                                         <variables>
                                           <variable id="7U~MWL[kr+7LviVI)1{w">preisMyEinheit</variable>
                                           <variable id="~$fPv%Kyw)rO::w-m?E$">howMuchEntries</variable>
                                           <variable id="QA8t!{GsE8j]Pvl#UHSM">anzahlMyBalken</variable>
                                           <variable id="^!A6]jY#f3XzB0]GQ~wv">differenz-DP</variable>
                                           <variable id="7w@gB$l[Mlki0afmB2+M">AusgangsWert-DP</variable>
                                           <variable id="=66FKd/y?5PF~?B@N:sP">jsonGraph-DP</variable>
                                           <variable id="H~#)ub)2_REHmR+9ncx)">jsonTabelle-DP</variable>
                                           <variable id=",%k:F-/2F#$2@[S,BdfF">anzahlBalken</variable>
                                           <variable id="N,ovEQDxsG~o=7a~[]FI">preisProEinheit</variable>
                                           <variable id="U`P$=S|1L/AFeLiCdNoQ">entriesTable</variable>
                                           <variable id="-o}80PkV@Uu+dTj8JK}0">inputWert-DP</variable>
                                         </variables>
                                         <block type="comment" id="IBBK#/gbAVL^jJsrHB*k" x="12" y="-313">
                                           <field name="COMMENT">diese datenpunkte anlegen !!!!!!</field>
                                             <block type="variables_set" id="B/@z{z1}j8-8J[g)9,F5">
                                               <field name="VAR" id="^!A6]jY#f3XzB0]GQ~wv">differenz-DP</field>
                                                 <block type="text" id="K]yM7r|%^_u#4wWb`3Yh">
                                                   <field name="TEXT">0_userdata.0.CONTROL-OWN.STROMZÄHLER.MONATDIFFERENZStromDaten</field>
                                                 <block type="variables_set" id="){p(FBl[TCquy#%|GeOR">
                                                   <field name="VAR" id="7w@gB$l[Mlki0afmB2+M">AusgangsWert-DP</field>
                                                     <block type="text" id="?GdJU3=;)gjJ=MP^Lc[D">
                                                       <field name="TEXT">0_userdata.0.CONTROL-OWN.STROMZÄHLER.AusgangsWert</field>
                                                     <block type="variables_set" id="U_@cvjQ:(;J9iKy`cs/5">
                                                       <field name="VAR" id="=66FKd/y?5PF~?B@N:sP">jsonGraph-DP</field>
                                                         <block type="text" id="zo9^*phNCg}]x!;WUOL0">
                                                           <field name="TEXT">0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONFuerGraph</field>
                                                         <block type="variables_set" id="9afZDk.1RSkGAPfc2P_!">
                                                           <field name="VAR" id="H~#)ub)2_REHmR+9ncx)">jsonTabelle-DP</field>
                                                             <block type="text" id="N^!JYHJ,N,;I*{m8^u@z">
                                                               <field name="TEXT">0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONStromDaten</field>
                                                             <block type="variables_set" id="i548*aorb)p8VkX/St^?">
                                                               <field name="VAR" id="-o}80PkV@Uu+dTj8JK}0">inputWert-DP</field>
        <block type="text" id="~mk{}BafnK!ZevzfZ36i">
        <field name="TEXT">0_userdata.0.CONTROL-OWN.STROMZÄHLER.INPUTStromDaten</field>
        <block type="comment" id="v6dN%tOrFaxbbvM3P#R@">
        <field name="COMMENT">diese datenpunkte wert definieren !!!!!</field>
        <block type="control_ex" id="2Co(O+V9Vq!tzXFX):[L">
        <value name="OID">
        <shadow type="field_oid">
        <field name="oid">Object ID</field>
        <block type="variables_get" id="|%=BNFq=bW_/@%NKcoYJ">
        <shadow type="logic_boolean">
        <block type="math_number" id="{QN;!Qdiyeo-d)lWebGk">
        <field name="NUM">28134.6</field>
        <value name="DELAY_MS">
        <block type="math_number" id="/0z[]$^A3gImfghTAe}7">
        <block type="comment" id="GXb[J4PTQq+Rq=GYCTDo">
        <field name="COMMENT">preisProEinheitSetzen</field>
        <block type="variables_set" id="3;1V8XG,[OiQ~ya}Ksck">
        <field name="VAR" id="N,ovEQDxsG~o=7a~[]FI">preisProEinheit</field>
        <block type="math_number" id="e%SmBuiz;;dST1d`Q,gW">
        <field name="NUM">0.39</field>
        <block type="comment" id="jl@P7y@Z?Awlg/`3(I:m">
        <field name="COMMENT">anzahl der balken im balkendiagramm</field>
        <block type="variables_set" id="97/Y1}t!]-+Q:1Ywm_1W">
        <field name="VAR" id=",%k:F-/2F#$2@[S,BdfF">anzahlBalken</field>
        <block type="math_number" id="vx5DuZq6hyIkd,N/^:r-">
        <field name="NUM">5</field>
        <block type="comment" id="p:~a+!eN$I~C=F-oQ^`6">
        <field name="COMMENT">bei 999999 kein limit</field>
        <block type="variables_set" id="#acd(L~dK@/*EFyZ9J07">
        <field name="VAR" id="U`P$=S|1L/AFeLiCdNoQ">entriesTable</field>
        <block type="math_number" id=".vE9.WZ090uO4,HlUDr5">
        <field name="NUM">999999</field>
        <block type="comment" id="BHGLyc[^,cU^jJ~p{[kM">
        <field name="COMMENT">bei "wahr" werden daten zurückgesetzt</field>
        <block type="comment" id="Q;UTLyy2d6mE6#qM*q0J">
        <field name="COMMENT">außer "AusgangsWert"</field>
        <block type="comment" id="Wb3+9gM=IEvI4%`q~kT!">
        <field name="COMMENT">auf wahr setzen - script speichern</field>
        <block type="comment" id="JT9[wzQ(,L1{raU/dCNF">
        <field name="COMMENT">dann wieder auf "false" setzen</field>
        <block type="comment" id="n$G?`bPG1{T6.U`Vu/*f">
        <field name="COMMENT">dann wieder speichern</field>
        <block type="controls_if" id="`joUQLFhXVIk@f@OOdhb">
        <block type="logic_boolean" id="Cl98utk_3$7+_x|bF40e">
        <block type="control_ex" id="@0^.?OD1OKEMax76r/XO">
        <value name="OID">
        <block type="variables_get" id="m.*[c)W^VxTefM$[_aGv">
        <block type="math_number" id="~$WcCIiDMjNA3rvn-H5@">
        <shadow type="math_number" id="gXEb$QPue7JGCZ~wR(E/">
        <block type="math_number" id="xM^0#.D`SvfC[1$W0y3s">
        <block type="control_ex" id="s!u}1WgLe!iZV?S[BS.F">
        <value name="OID">
        <block type="variables_get" id="I[Z6Lg5+L[|z:z?Qmt!.">
        <block type="text" id="cK=@%$vy2!p/WTPeDiD?">
        <field name="TEXT">{}</field>
        <block type="math_number" id="]?rwTGNy8MJ)Y8]{1s!j">
        <block type="control_ex" id="+w$JaHl6:B#W7EVgbMx.">
        <value name="OID">
        <block type="variables_get" id="9DaT4|.#Kp(Ij=DT4T|4">
        <shadow type="logic_boolean" id="~f86`f0G_s%8(4Kl)xIF">
        <block type="text" id="3R#N$Oe@OFGhl(WluF*j">
        <shadow type="math_number" id="_Aq~4Y+S,d}tAzvv.MUS">
        <block type="math_number" id="B]Vb[HOn5;`##@P6gfmq">
        <block type="control_ex" id="9_/Pnq/NFY)@N,VP,.SR">
        <value name="OID">
        <shadow type="field_oid" id="M#xP@4$OZRXvbal0HSCn">
        <block type="variables_get" id="tv-)D_/?L^yT,Oz2vVlM">
        <shadow type="logic_boolean" id="05QwkSlg*9vXbg5Zh/1:">
        <block type="math_number" id="CIAjTQq$6RT6:D:#i9J-">
        <shadow type="math_number" id="{B:Joj8xSESj|=jvXOAS">
        <block type="math_number" id="Z+tF)6N[LYLMR6Xg8$yr">
        <block type="on_ext" id="PDmK@1JoBw#1^VyNI$YM">
        <value name="OID0">
        <shadow type="field_oid" id="B[_i##}%Tqcm!*Ps{3G#">
        <block type="variables_get" id="g?.j)zcLVo0~box?-a-`">
        <block type="timeouts_settimeout" id="n1%@TqD7D)$uC,oaMfSj">
        <field name="DELAY">3</field>
        <block type="get_value_var" id="?c;rhJu{bc=oUKEZpjbk">
        <value name="OID">
        <shadow type="text">
        <block type="variables_get" id="+}ea1q6U_g^=2D2:wEbL">
        <block type="variables_set" id="YPD9ey#Kic}HdrXOz(kI">
        <block type="math_arithmetic" id="*xKw:UU^H7kGO34Os+]Y">
        <block type="on_source" id="}=^vH@]*i:GC-TvAS1Tw">
        <shadow type="math_number" id="x!D2]LUBf4w.)IC*d]CU">
        <block type="get_value_var" id="Us#XusmVp@xfIt-R*gM7">
        <value name="OID">
        <shadow type="text" id="k@hy$RX.d83:M]{%]EDW">
        <block type="variables_get" id="o=7tucO3L)c-_5DIl]hd">
        <block type="control_ex" id="JUo`[3o$x[+piO8`zo]A">
        <value name="OID">
        <block type="variables_get" id="8g{gAGWRwO~qxVqS}J)y">
        <block type="variables_get" id="{Q1(^j=EhXkU3Lw7otg:">
        <shadow type="math_number" id="14eNmBGr.C#aE}kg_ija">
        <block type="procedures_callnoreturn" id="fHaB@#mq%*i%]=cI=`Gc">
        <mutation name="objectFunc"></mutation>
        <value name="IF1">
        <block type="get_value_var" id="Z4YXFUC`aBQI%d3;4PIv">
        <value name="OID">
        <block type="variables_get" id="-;}?5zw1FAC?5H=!lP`M">
        <block type="variables_set" id="s7`fX10zMp_9|-jCy*$#">
        <block type="math_arithmetic" id="ggOLCnrrxc9qXbUHMU,x">
        <block type="on_source" id="j(Jep6+EXxJDSVoz`U_-">
        <block type="on_source" id="S=0:|QYL-$Aj3|m8|E}j">
        <block type="get_value_var" id="+:3os^?!Znc3Ta%L11JR">
        <value name="OID">
        <block type="variables_get" id="k+w8XJkDjENcfh5M4YcZ">
        <block type="control_ex" id="+hVcJl6]m#H$3t?y@A*q">
        <value name="OID">
        <block type="variables_get" id="1D{$2U?;_H]=r+P(O$Rs">
        <block type="variables_get" id="0*-cc:aPJh:hJa7=C$vo">
        <shadow type="math_number" id="OnS?DYzC(_`]qrC6mGyU">
        <block type="procedures_callnoreturn" id="@5z,g~O-:+wz0Z-2pDj1">
        <value name="TEXT">
                                         <block type="procedures_defcustomreturn" id="-dj~-jKd1)aXigrUB7Nn" x="587" y="138">
                                             <arg name="preisMyEinheit" varid="7U~MWL[kr+7LviVI)1{w"></arg>
                                             <arg name="howMuchEntries" varid="~$fPv%Kyw)rO::w-m?E$"></arg>
                                           </mutation>
                                           <field name="NAME">makeJSONTable</field>
                                           <field name="SCRIPT">DQoNCkpzb25EYXRhLnB1c2goew0KICAgICJEYXR1bSI6bXlEYXRlLA0KICAgICJWZXJicmF1Y2hNb25hdCI6TWF0aC5yb3VuZChteURpZmZlcmVueioxMCkvMTAsDQogICAgIkFiZ2VsZXNlbmVyV2VydCI6bXlWYWx1ZSwNCiAgICAiVGltZXN0YW1wIjogRGF0ZS5ub3coKSwNCiAgICAiUHJlaXMiOiAgTWF0aC5yb3VuZChwcmVpc015RWluaGVpdCpteURpZmZlcmVueioxMDApLzEwMA0KfSkNCg0KaWYgKGhvd011Y2hFbnRyaWVzPDk5OTk5OSkgew0KICAgaWYoSnNvbkRhdGEubGVuZ3RoID4gaG93TXVjaEVudHJpZXMpIEpzb25EYXRhLnNoaWZ0KCk7IH0vLyBtYXguIHggWmVpbGVuIA0KcmV0dXJuIEpzb25EYXRhOw==</field>
                                         <block type="procedures_defcustomreturn" id="|~(06FvVEu(8KG323^j}" x="588" y="162">
                                             <arg name="myStromJSON" varid="PrPY;|4]dTeDTohPAkR{"></arg>
                                             <arg name="anzahlMyBalken" varid="QA8t!{GsE8j]Pvl#UHSM"></arg>
                                           </mutation>
                                           <field name="NAME">makeObjectGraph</field>
                                           <field name="SCRIPT">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</field>
                                         <block type="procedures_defnoreturn" id="Q8h+XqHkQktzY8CbVJM;" x="587" y="262">
                                           <field name="NAME">objectFunc</field>
                                             <block type="control_ex" id="4S_0l*~Rx3jx?Ib5mqDS">
                                               <value name="OID">
                                                 <shadow type="field_oid" id="K.+1=3!+R,7UlM`44K9h">
                                                 <block type="variables_get" id="Wd]6dZ!TLToAKEf/fSIX">
                                                 <shadow type="logic_boolean" id="}Nd-q{q:pNjw!r7qI_3j">
                                                 <block type="procedures_callcustomreturn" id="j70*|D!s`UXSV9jH4}i[">
                                                   <mutation name="makeObjectGraph">
                                                     <arg name="myStromJSON"></arg>
                                                     <arg name="anzahlMyBalken"></arg>
                                                   </mutation>
                                                   <value name="ARG0">
                                                     <block type="variables_get" id="fk:*7igTe]Mdjem+BIEr">
                                                   <value name="ARG1">
                                                     <block type="variables_get" id="s%tS^MgcQVFBU!1c{lBo">
                                                 <shadow type="math_number" id="..X(tI*-_0y?y,Lp?#Kv">
                                         <block type="procedures_defnoreturn" id="4!+9YQ-Yv-QN$!yE=,7A" x="887" y="513">
                                             <block type="control_ex" id="#.sw^L.mHuLdGSS2ho[)">
                                               <value name="OID">
                                                 <block type="variables_get" id="5EfE/TZ)^W*t-])vtrD/">
                                                 <shadow type="logic_boolean" id="Po}z|LLOLd}T8R[s/mwS">
                                                       <mutation name="makeJSONTable">
                                                         <arg name="preisMyEinheit"></arg>
                                                         <arg name="howMuchEntries"></arg>
                                                       </mutation>
                                                       <value name="ARG0">
                                                       <value name="ARG1">
                                                         <block type="get_value_var" id=".3RBv9[5`52219f:P`0R">
                                                           <value name="OID">
                                                             <block type="variables_get" id="rmx~WoeiD/O8z(zWC.,@">
                                                       <value name="ARG2">
                                                       <value name="ARG3">
                                                         <block type="text_join" id="|_F|)mGy4:_d+1JjwC6;">
                                                           <value name="ADD0">
                                                             <block type="convert_from_date" id="Xr@5!]qVPVI2C1Wyz$Hj">
                                                               <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="true"></mutation>
                                                               <field name="OPTION">Mt</field>
                                                               <field name="LANGUAGE">de</field>
        <block type="math_arithmetic" id="ai|N[X`%/z:E;e%_^#Qj">
        <shadow type="math_number" id="Svc?@4`|qppHj!d49iN7">
        <block type="time_get" id="nTqy,B@z`A/TS.F2a,!Y">
        <shadow type="math_number" id="|rHf?/g645HM6XF|@Wg5">
        <block type="math_number" id="puM+08Z|hpF3gBt#psby">
        <field name="NUM">2332800000</field>
                                                           <value name="ADD1">
                                                             <block type="text" id="MAxUZID+8tI_ux~{S3!x">
                                                               <field name="TEXT"> </field>
                                                           <value name="ADD2">
                                                             <block type="convert_from_date" id="EmF)4I#@vM6l^1l{I#Hq">
                                                               <field name="OPTION">fy</field>
        <block type="math_arithmetic" id="X))0JisbKS?y(#f2[Sk%">
        <block type="time_get" id="-}`7d66RkCFZ=Wh}}NO+">
        <block type="math_number" id="NgNSjFZ{^)PbKHYCXcnS">
                                                       <value name="ARG4">
                                                         <block type="variables_get" id="PENRnb~7uia5WCi]q+4_">
                                                       <value name="ARG5">
                                                         <block type="variables_get" id="Ayg6JeXjBdY6.5%(u6mS">
                                                 <shadow type="math_number" id="8^[.xS;#2,Qb%?N_H_l7">
                                         <block type="convert_from_date" id="aT54!grlK95Q3-xCm@Dh" disabled="true" x="1287" y="937">
                                        das widget mit der tabelle (inventwo json widget muss installiert sein)
                                        [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"10","iTableRefreshRate":"0","iTblSortOrder":"desc","iColCount":"5","iColShow1":"true","iTblHeadTextAlign1":"center","iTblTextAlign1":"center","iTblCellFormat1":"normal","iTblCellImageSize1":"200","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellThresholdsDp1":"","iTblCellThresholdsText1":"","iOpacityAll":"1","iTblRowEvenColor":"#333333","iTblRowUnevenColor":"#343829","iTblHeaderColor":"#333333","iRowSpacing":"10","iTblRowEvenTextColor":"#ffffff","iTblRowUnevenTextColor":"#ffffff","iTblHeaderTextColor":"#ffffff","iBorderSize":"0","iBorderStyleLeft":"none","iBorderStyleRight":"none","iBorderStyleUp":"none","iBorderStyleDown":"none","iBorderColor":"#ffffff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONStromDaten","iTblShowHead":true,"iColShow2":"true","iTblHeadTextAlign2":"center","iTblTextAlign2":"center","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellThresholdsDp2":"","iTblCellThresholdsText2":"","iColShow3":true,"iTblHeadTextAlign3":"center","iTblTextAlign3":"center","iTblCellFormat3":"normal","iTblCellImageSize3":"200","iTblCellBooleanCheckbox3":"false","iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellThresholdsDp3":"","iTblCellThresholdsText3":"","iTblSortAttr":"Timestamp","iHorScroll":false,"iVertScroll":true,"iColShow4":false,"iTblHeadTextAlign4":"center","iTblTextAlign4":"left","iTblCellFormat4":"normal","iTblCellImageSize4":"200","iTblCellBooleanCheckbox4":"false","iTblCellBooleanColorFalse4":"#ff0000","iTblCellBooleanColorTrue4":"#00ff00","iTblCellNumberDecimals4":"2","iTblCellNumberDecimalSeperator4":".","iTblCellNumberThousandSeperator4":",","iTblCellThresholdsDp4":"","iTblCellThresholdsText4":"","iColShow5":"true","iTblHeadTextAlign5":"center","iTblTextAlign5":"center","iTblCellFormat5":"normal","iTblCellImageSize5":"200","iTblCellBooleanCheckbox5":"false","iTblCellBooleanColorFalse5":"#ff0000","iTblCellBooleanColorTrue5":"#00ff00","iTblCellNumberDecimals5":"2","iTblCellNumberDecimalSeperator5":".","iTblCellNumberThousandSeperator5":",","iTblCellThresholdsDp5":"","iTblCellThresholdsText5":""},"style":{"left":"853px","top":"635px","width":"687px","height":"219px","border-width":"1px","border-style":"solid","border-color":"#20f824","border-radius":"15px"},"widgetSet":"vis-inventwo"}]
                                          das widget mit dem balkendiagramm (material design widget muss installiert sein)
                                          [{"tpl":"tplVis-materialdesign-Chart-JSON","data":{"oid":"0_userdata.0.CONTROL-OWN.STROMZÄHLER.JSONFuerGraph","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","chartType":"bar","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background","chartAreaBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.background_chart","globalColor":"#mdwTheme:vis-materialdesign.0.colors.charts.global","titleLayout":"#mdwTheme:vis-materialdesign.0.fontSizes.card.title","titleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.card.title","colorBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background","colorTitleSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_title","colorTextSectionBackground":"#mdwTheme:vis-materialdesign.0.colors.card.background_body","colorTitle":"#mdwTheme:vis-materialdesign.0.colors.card.title","showLegend":"true","legendPosition":"right","legendFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.legend","legendFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.legend","legendFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.legend","legendPointStyle":"true","showTooltip":"true","tooltipMode":"nearest","tooltipPosition":"nearest","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_background","tooltipShowColorBox":true,"tooltipTitleFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_title","tooltipTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_title","tooltipTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_title","tooltipBodyFontColor":"#mdwTheme:vis-materialdesign.0.colors.charts.tooltip_text","tooltipBodyFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.tooltip_text","tooltipBodyFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.tooltip_text","tooltipBodyAlignment":"left","xAxisPosition":"bottom","xAxisTicksSource":"auto","xAxisTitleColor":"#mdwTheme:vis-materialdesign.0.colors.charts.x_axis_title","xAxisTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.x_axis_title","xAxisTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.x_axis_title","xAxisValueLabelColor":"white","xAxisValueFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.x_axis_values","xAxisValueFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.x_axis_values","xAxisDistanceBetweenTicks":"0","xAxisValueDistanceToAxis":"11","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":false,"xAxisGridLinesColor":"#mdwTheme:vis-materialdesign.0.colors.charts.x_axis_gridlines","xAxisShowTicks":true,"xAxisZeroLineColor":"#mdwTheme:vis-materialdesign.0.colors.charts.x_axis_zeroline","xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisTitleColor":"#mdwTheme:vis-materialdesign.0.colors.charts.y_axis_values","yAxisTitleFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.y_axis_title","yAxisTitleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.y_axis_title","yAxisValueLabelColor":"#mdwTheme:vis-materialdesign.0.colors.charts.y_axis_values","yAxisValueFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.charts.y_axis_values","yAxisValueFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.charts.y_axis_values","yAxisValueDistanceToAxis":"16","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"debug":false,"xAxisOffset":false,"barWidth":"44","axisLabelAutoSkip":false,"xAxisTickLength":"0","tooltipXpadding":"","tooltipTitleMarginBottom":"","tooltipYpadding":"","cardUse":false,"chartPaddingTop":"40"},"style":{"left":"562px","top":"332px","width":"332px","height":"148px"},"widgetSet":"materialdesign"}]
                                            noch was zum anfangswert - ich habe einen zählerstand vom februar gefunden - habe den vom zählerstand vom heutigen abgezogen und durch die vergangenen monate geteilt. dann habe ich das ergebnis (Quotient) vom heutigen zählerstand abgezogen und als anfangswert gesetzt. anschliessend habe ich den heutigen wert in das imputfeld eingegeben um einen ungefähren anfangszustand zu haben
                                            sieht dann so aus:
                                            der nächste wert kommt dann am 1.11.2022. (im neuen monat)
                                            noch nebenbei - man könnte das auch autom mit einem script machen - z.b. die sonoff kwh jeden ersten im monat in den dp schreiben anstatt im inputfeld eingeben - so kann ich z.b. beobachten, was meine schreibtisch ecke bzw büro monatlich verschlingt - alles am schreibtisch ist an einem sonoff pow angeschlossen.
                                            dazu das script und widgets kopieren, neue dp anlegen - variablen im script neu definieren - dieses beispiel funktioniert sicher auch nur mit histor y(influxdb) und grafana (nutze ich nicht und flot ist zu häßlich 🙂 ).
                                            das script täglich auszuführen oder gar mehrmals täglich würde ich nicht empfehlen, da der json-wert (tabelle) sehr groß werden würde - man müßte dann eine filo-json bauen, damit das json limitiert bleibt - im jahr 12 werte ist jedoch kein problem
                                            datenpunkt grafana influx tabelle vis zählerstände
                                            4372
