ioBroker startet nicht mehr
Ergebnis von Fix:
pi@DELO0150:/opt/iobroker/iobroker-data $ iobroker fix library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:2 http://archive.raspberrypi.org/debian buster InRelease OK:3 https://deb.nodesource.com/node_16.x buster InRelease Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service. Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ==========================================================================
Ergebnis von dem zweiten Befehl:
pi@DELO0150:/opt/iobroker/iobroker-data $ getfacl /opt/iobroker/iobroker-data/objects.jsonl getfacl: Entferne führende '/' von absoluten Pfadnamen # file: opt/iobroker/iobroker-data/objects.jsonl # owner: iobroker # group: iobroker user::rw- group::r-x group:iobroker:rwx mask::rwx other::r--
@magnus-0
Hmmm. Meine Rechte sehen anders aus:echad@chet:~ $ getfacl /opt/iobroker/iobroker-data/objects.jsonl getfacl: Removing leading '/' from absolute path names # file: opt/iobroker/iobroker-data/objects.jsonl # owner: iobroker # group: iobroker user::rw- group::r-x #effective:r-- group:iobroker:rwx #effective:rw- mask::rw- other::r--
nur bei mask:: gibt es ja einen Unterschied, richtig?
Kann man evtl. ein Backup wiederherstellen?
@magnus-0 sagte in ioBroker startet nicht mehr:
Ja, meine mask nimmt den usern und den Gruppen das x-bit.
Deine mask macht gar nix... -
Hast du noch eine Idee was ich machen kann oder muss ich ein Backup versuchen einzuspielen oder neuinstallieren?
Was sagt denn jetzt
iobroker status
Und wie bist du da sonst unterwegs?
sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
Einmal folgende Ausgabe
pi@DELO0150:~ $ iobroker status Objects database error: connect ECONNREFUSED 127.0.0.1:9001 Objects database error: connect ECONNREFUSED 127.0.0.1:9001 Objects database error: connect ECONNREFUSED 127.0.0.1:9001 Objects database error: connect ECONNREFUSED 127.0.0.1:9001 Objects database error: connect ECONNREFUSED 127.0.0.1:9001 Objects database error: connect ECONNREFUSED 127.0.0.1:9001 iobroker is not running on this host. Objects type: jsonl States type: jsonl
Danach nochmal ausgeführt, dann folgende Ausgabe:
pi@DELO0150:~ $ iobroker status Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
Zweiter Befehl:
pi@DELO0150:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits pi@DELO0150:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v16.17.1 v16.17.1 8.15.0 4.0.23 pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker /home/pi OK:1 http://archive.raspberrypi.org/debian buster InRelease OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:3 https://deb.nodesource.com/node_16.x buster InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Alle Pakete sind aktuell. nodejs: Installiert: 16.17.1-deb-1nodesource1 Installationskandidat: 16.17.1-deb-1nodesource1 Versionstabelle: *** 16.17.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
Keine Idee.
@Glasfaser evtl? -
Ich habe gerade einen restore versucht, das klappt auch nicht, auch hier erscheint folgender Fehler:
pi@DELO0150:/opt/iobroker $ iobroker restore /opt/iobroker/backups/iobroker_2022_09_30-02_40_10_backupiobroker.tar.gz No connection to databases possible ...
Setze mal die Zeit auf .. Beispiel : 30000
https://forum.iobroker.net/post/716453
EDIT :
Wert auf 30000und ein
sudo reboot
