    4. [SourceAnalytix 0.4.8-Final] Released !
      guergen @GregorS last edited by
      @gregors Node so richtig?
      GregorS 1 Reply Last reply Reply Quote 0
      • GregorS
        GregorS @guergen last edited by
        @guergen
        Sorry.
        v 16.17.0
          @gregors probiere doch mal die Version direkt auszuwählen mit:
          npm install iobroker.sourceanalytix@0.4.14
          • GregorS
            GregorS last edited by GregorS
            @guergen
            War nicht erfolgreich - habe immer noch die Version 0.4.8
            pi@Promox-ioBroker:~$ npm install iobroker.sourceanalytix@0.4.14
            added 35 packages, and audited 36 packages in 6s
            6 packages are looking for funding
              run `npm fund` for details
            found 0 vulnerabilities
            npm notice
            npm notice New minor version of npm available! 8.15.0 -> 8.19.2
            npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.19.2
            npm notice Run npm install -g npm@8.19.2 to update!
            npm notice
              guergen @GregorS last edited by guergen
              @gregors was ist mit
              iobroker update
              bzw mit:
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
              • GregorS
                @guergen
                Da taucht der Adapter gar nicht mehr auf:
                Adapter    "admin"        : 6.2.22   , installed 6.2.22
                Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                Adapter    "denon"        : 1.13.4   , installed 1.13.4
                Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                Adapter    "email"        : 1.1.3    , installed 1.1.3
                Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                Adapter    "flot"         : 1.11.0   , installed 1.11.0
                Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                Adapter    "history"      : 2.2.0    , installed 2.2.0
                Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "iot"          : 1.11.9   , installed 1.11.9
                Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
                Adapter    "linux-control": 1.1.3    , installed 1.1.3
                Adapter    "modbus"       : 5.0.5    , installed 5.0.5
                Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                Adapter    "parser"       : 1.1.8    , installed 1.1.8
                Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
                Adapter    "snmp"         : 2.1.8    , installed 1.0.0  [Updatable]
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "statistics"   : 2.2.0    , installed 2.2.0
                Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                Adapter    "text2command" : 2.2.2    , installed 2.2.2
                Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                Adapter    "vis"          : 1.4.15   , installed 1.2.12 [Updatable]
                Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                pi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
                x86_64
                /usr/bin/node
                /usr/bin/npm
                  @gregors Du hast kein nodejs?
                  warum werden keine Versionen mit ausgegeben?
                  Was hast Du denn eingestellt? Stable oder Beta?
                  • GregorS
                    @guergen
                    Stable.
                    Verstehe jetzt gar nichts mehr.
                    Das System habe ich komplett neu aufgezogen - von TB auf Proxmox
                      @gregors Wenn stable eingestellt ist, zeigt er die Beta-Adapter auch nicht mit an
                      Nach welcher Anleitung hast du denn iobroker installiert?
                      • GregorS
                        @guergen
                        Hier mit der Einstellung Stable + Beta
                        pi@Promox-ioBroker:~$ iobroker update
                        Used repositories: Stable (default), Beta (latest)
                        Adapter    "backitup"     : 2.4.14   , installed 2.4.12 [Updatable]
                        Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
                        Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
                        Adapter    "fritzdect"    : 2.2.6    , installed 2.2.3  [Updatable]
                        Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
                        Adapter    "hm-rega"      : 3.0.43   , installed 3.0.40 [Updatable]
                        Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.12 [Updatable]
                        Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
                        Adapter    "iot"          : 1.12.2   , installed 1.11.9 [Updatable]
                        Adapter    "jeelink"      : 1.0.3    , installed 0.1.4  [Updatable]
                        Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
                        Adapter    "modbus"       : 5.0.8    , installed 5.0.5  [Updatable]
                        Adapter    "parser"       : 1.2.1    , installed 1.1.8  [Updatable]
                        Adapter    "proxmox"      : 1.3.5    , installed 1.3.4  [Updatable]
                        Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
                        Adapter    "snmp"         : 2.1.10   , installed 1.0.0  [Updatable]
                        Adapter    "socketio"     : 6.1.10   , installed 4.2.0  [Updatable]
                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.8  [Updatable]
                        Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
                        Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
                        Adapter    "web"          : 5.2.5    , installed 4.3.0  [Updatable]
                        Adapter    "ws"           : 2.1.5    , installed 1.3.0  [Updatable]
                        x86_64
                        /usr/bin/node
                        /usr/bin/npm
                          @gregors Nach welcher Anleitung hast du denn iobroker installiert?
                            Thomas Braun Most Active last edited by Thomas Braun
                            @gregors
                            sudo ln -s /usr/bin/node /usr/bin/nodejs
                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            Der sourceanalytix ist bis dato nur über das Beta-Repo zu beziehen.
                            • GregorS
                              @guergen
                              Über die Anleitung in www.iobroker.net
                              • GregorS
                                GregorS @Thomas Braun last edited by
                                @guergen
                                Habe jetzt die aktuelle Version 0.4.14
                                  Thomas Braun Most Active @GregorS last edited by
                                  @gregors
                                  Was sagt
                                  denn nun?
                                  GregorS 1 Reply Last reply Reply Quote 1
                                  • GregorS
                                    Habe deinen Code eingegeben, und dann hatte ich u.a auch den sourceanalytix dabei und konnte ihn über die Oberfläche updaten.
                                    Habe jetz noch ein anderes Problem, aber da mache ich mal ein neues Topic auf.
                                      @gregors
                                      Was sagt
                                      denn nun?
                                      • GregorS
                                        @thomas-braun said in [SourceAnalytix 0.4.8-Final] Released !:
                                        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                        code_tpi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        x86_64
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.17.0
                                        v16.17.0
                                        8.15.0
                                        4.0.23
                                        pi
                                        pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                                        /home/pi
                                        OK:1 http://deb.debian.org/debian bullseye InRelease
                                        OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                                        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                                        Paketlisten werden gelesen… Fertig
                                        Abhängigkeitsbaum wird aufgebaut… Fertig
                                        Statusinformationen werden eingelesen… Fertig
                                        Aktualisierung für 57 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                        nodejs:
                                          Installiert:           16.17.0-deb-1nodesource1
                                          Installationskandidat: 16.17.1-deb-1nodesource1
                                          Versionstabelle:
                                             16.17.1-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                         *** 16.17.0-deb-1nodesource1 100
                                                100 /var/lib/dpkg/status
                                             12.22.12~dfsg-1~deb11u1 500
                                                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                                             12.22.5~dfsg-2~11u1 500
                                                500 http://deb.debian.org/debian bullseye/main amd64 Packagesext
                                        Adapter    "history"      : 2.2.4    , installed 2.2.4
                                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                        Adapter    "parser"       : 1.2.1    , installed 1.2.1
                                        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                                        Adapter    "socketio"     : 6.1.10   , installed 6.1.10
                                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                        Adapter    "web"          : 5.2.5    , installed 5.2.5
                                        Adapter    "ws"           : 2.1.5    , installed 2.1.5
                                          @gregors sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                          Zieh die hoch. Und deaktivier das Beta-Repository wieder.
                                          • GregorS
                                            Kann ich die 57 Pakete mit iob update aktualisieren?
                                            2302
                                            1158164
