    4. [SourceAnalytix 0.4.8-Final] Released !
    • GregorS
      GregorS @guergen last edited by
      @guergen
      Sorry.
      v 16.17.0
        guergen @GregorS last edited by
        @gregors probiere doch mal die Version direkt auszuwählen mit:
        npm install iobroker.sourceanalytix@0.4.14
        • GregorS
          GregorS last edited by GregorS
          @guergen
          War nicht erfolgreich - habe immer noch die Version 0.4.8
          pi@Promox-ioBroker:~$ npm install iobroker.sourceanalytix@0.4.14
          added 35 packages, and audited 36 packages in 6s
          6 packages are looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          npm notice
          npm notice New minor version of npm available! 8.15.0 -> 8.19.2
          npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.19.2
          npm notice Run npm install -g npm@8.19.2 to update!
          npm notice
            guergen @GregorS last edited by guergen
            @gregors was ist mit
            iobroker update
            bzw mit:
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
            GregorS 1 Reply Last reply Reply Quote 0
            • GregorS
              @guergen
              Da taucht der Adapter gar nicht mehr auf:
              Adapter    "admin"        : 6.2.22   , installed 6.2.22
              Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
              Adapter    "backitup"     : 2.4.12   , installed 2.4.12
              Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
              Adapter    "denon"        : 1.13.4   , installed 1.13.4
              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
              Adapter    "email"        : 1.1.3    , installed 1.1.3
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "flot"         : 1.11.0   , installed 1.11.0
              Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
              Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
              Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
              Adapter    "history"      : 2.2.0    , installed 2.2.0
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
              Adapter    "hs100"        : 2.1.2    , installed 2.1.2
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "iot"          : 1.11.9   , installed 1.11.9
              Adapter    "javascript"   : 6.0.3    , installed 6.0.3
              Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
              Adapter    "linux-control": 1.1.3    , installed 1.1.3
              Adapter    "modbus"       : 5.0.5    , installed 5.0.5
              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
              Adapter    "parser"       : 1.1.8    , installed 1.1.8
              Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
              Adapter    "radar2"       : 2.0.3    , installed 2.0.3
              Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
              Adapter    "snmp"         : 2.1.8    , installed 1.0.0  [Updatable]
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "statistics"   : 2.2.0    , installed 2.2.0
              Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
              Adapter    "telegram"     : 1.14.1   , installed 1.14.1
              Adapter    "text2command" : 2.2.2    , installed 2.2.2
              Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
              Adapter    "vis"          : 1.4.15   , installed 1.2.12 [Updatable]
              Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
              pi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
              x86_64
              /usr/bin/node
              /usr/bin/npm
                @gregors Du hast kein nodejs?
                warum werden keine Versionen mit ausgegeben?
                Was hast Du denn eingestellt? Stable oder Beta?
                • GregorS
                  @guergen
                  Stable.
                  Verstehe jetzt gar nichts mehr.
                  Das System habe ich komplett neu aufgezogen - von TB auf Proxmox
                    @gregors Wenn stable eingestellt ist, zeigt er die Beta-Adapter auch nicht mit an
                    Nach welcher Anleitung hast du denn iobroker installiert?
                    • GregorS
                      @guergen
                      Hier mit der Einstellung Stable + Beta
                      pi@Promox-ioBroker:~$ iobroker update
                      Used repositories: Stable (default), Beta (latest)
                      Adapter    "backitup"     : 2.4.14   , installed 2.4.12 [Updatable]
                      Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
                      Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
                      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.3  [Updatable]
                      Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
                      Adapter    "hm-rega"      : 3.0.43   , installed 3.0.40 [Updatable]
                      Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.12 [Updatable]
                      Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
                      Adapter    "iot"          : 1.12.2   , installed 1.11.9 [Updatable]
                      Adapter    "jeelink"      : 1.0.3    , installed 0.1.4  [Updatable]
                      Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
                      Adapter    "modbus"       : 5.0.8    , installed 5.0.5  [Updatable]
                      Adapter    "parser"       : 1.2.1    , installed 1.1.8  [Updatable]
                      Adapter    "proxmox"      : 1.3.5    , installed 1.3.4  [Updatable]
                      Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
                      Adapter    "snmp"         : 2.1.10   , installed 1.0.0  [Updatable]
                      Adapter    "socketio"     : 6.1.10   , installed 4.2.0  [Updatable]
                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.8  [Updatable]
                      Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
                      Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
                      Adapter    "web"          : 5.2.5    , installed 4.3.0  [Updatable]
                      Adapter    "ws"           : 2.1.5    , installed 1.3.0  [Updatable]
                      x86_64
                      /usr/bin/node
                      /usr/bin/npm
                        @gregors Nach welcher Anleitung hast du denn iobroker installiert?
                          Thomas Braun Most Active last edited by Thomas Braun
                          @gregors
                          sudo ln -s /usr/bin/node /usr/bin/nodejs
                          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          Der sourceanalytix ist bis dato nur über das Beta-Repo zu beziehen.
                          • GregorS
                            @guergen
                            Über die Anleitung in www.iobroker.net
                            • GregorS
                              GregorS @Thomas Braun last edited by
                              @guergen
                              Habe jetzt die aktuelle Version 0.4.14
                                Thomas Braun Most Active @GregorS last edited by
                                @gregors
                                Was sagt
                                denn nun?
                                GregorS 1 Reply Last reply Reply Quote 1
                                • GregorS
                                  Habe deinen Code eingegeben, und dann hatte ich u.a auch den sourceanalytix dabei und konnte ihn über die Oberfläche updaten.
                                  Habe jetz noch ein anderes Problem, aber da mache ich mal ein neues Topic auf.
                                    @gregors
                                    Was sagt
                                    denn nun?
                                    • GregorS
                                      @thomas-braun said in [SourceAnalytix 0.4.8-Final] Released !:
                                      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                      code_tpi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      x86_64
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.17.0
                                      v16.17.0
                                      8.15.0
                                      4.0.23
                                      pi
                                      pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                                      /home/pi
                                      OK:1 http://deb.debian.org/debian bullseye InRelease
                                      OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                                      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                                      Paketlisten werden gelesen… Fertig
                                      Abhängigkeitsbaum wird aufgebaut… Fertig
                                      Statusinformationen werden eingelesen… Fertig
                                      Aktualisierung für 57 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                      nodejs:
                                        Installiert:           16.17.0-deb-1nodesource1
                                        Installationskandidat: 16.17.1-deb-1nodesource1
                                        Versionstabelle:
                                           16.17.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                       *** 16.17.0-deb-1nodesource1 100
                                              100 /var/lib/dpkg/status
                                           12.22.12~dfsg-1~deb11u1 500
                                              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                                           12.22.5~dfsg-2~11u1 500
                                              500 http://deb.debian.org/debian bullseye/main amd64 Packagesext
                                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                      Adapter    "parser"       : 1.2.1    , installed 1.2.1
                                      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                                      Adapter    "socketio"     : 6.1.10   , installed 6.1.10
                                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                      Adapter    "web"          : 5.2.5    , installed 5.2.5
                                      Adapter    "ws"           : 2.1.5    , installed 2.1.5
                                        @gregors sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                        Zieh die hoch. Und deaktivier das Beta-Repository wieder.
                                        • GregorS
                                          Kann ich die 57 Pakete mit iob update aktualisieren?
                                            Natürlich nicht. Die kommen vom Betriebssystem...
                                            Notieren und künftig regelmäßig machen:
                                            iob stop
                                            sudo apt update
                                            sudo apt full-upgrade
                                            sudo reboot
                                            2302
                                            1158455
