    4. [SourceAnalytix 0.4.8-Final] Released !
      guergen @GregorS last edited by
      @gregors probiere doch mal die Version direkt auszuwählen mit:
      npm install iobroker.sourceanalytix@0.4.14
      • GregorS
        GregorS last edited by GregorS
        @guergen
        War nicht erfolgreich - habe immer noch die Version 0.4.8
        pi@Promox-ioBroker:~$ npm install iobroker.sourceanalytix@0.4.14
        added 35 packages, and audited 36 packages in 6s
        6 packages are looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        npm notice
        npm notice New minor version of npm available! 8.15.0 -> 8.19.2
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.19.2
        npm notice Run npm install -g npm@8.19.2 to update!
        npm notice
          guergen @GregorS last edited by guergen
          @gregors was ist mit
          iobroker update
          bzw mit:
          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
          GregorS 1 Reply Last reply Reply Quote 0
          • GregorS
            GregorS @guergen last edited by
            @guergen
            Da taucht der Adapter gar nicht mehr auf:
            Adapter    "admin"        : 6.2.22   , installed 6.2.22
            Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
            Adapter    "backitup"     : 2.4.12   , installed 2.4.12
            Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
            Adapter    "denon"        : 1.13.4   , installed 1.13.4
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "email"        : 1.1.3    , installed 1.1.3
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
            Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "history"      : 2.2.0    , installed 2.2.0
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "hs100"        : 2.1.2    , installed 2.1.2
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.11.9   , installed 1.11.9
            Adapter    "javascript"   : 6.0.3    , installed 6.0.3
            Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
            Adapter    "linux-control": 1.1.3    , installed 1.1.3
            Adapter    "modbus"       : 5.0.5    , installed 5.0.5
            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
            Adapter    "parser"       : 1.1.8    , installed 1.1.8
            Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
            Adapter    "radar2"       : 2.0.3    , installed 2.0.3
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
            Adapter    "snmp"         : 2.1.8    , installed 1.0.0  [Updatable]
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "statistics"   : 2.2.0    , installed 2.2.0
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.14.1   , installed 1.14.1
            Adapter    "text2command" : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
            Adapter    "vis"          : 1.4.15   , installed 1.2.12 [Updatable]
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
            pi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
            x86_64
            /usr/bin/node
            /usr/bin/npm
              @gregors Du hast kein nodejs?
              warum werden keine Versionen mit ausgegeben?
              Was hast Du denn eingestellt? Stable oder Beta?
              • GregorS
                @guergen
                Stable.
                Verstehe jetzt gar nichts mehr.
                Das System habe ich komplett neu aufgezogen - von TB auf Proxmox
                  @gregors Wenn stable eingestellt ist, zeigt er die Beta-Adapter auch nicht mit an
                  Nach welcher Anleitung hast du denn iobroker installiert?
                  • GregorS
                    @guergen
                    Hier mit der Einstellung Stable + Beta
                    pi@Promox-ioBroker:~$ iobroker update
                    Used repositories: Stable (default), Beta (latest)
                    Adapter    "backitup"     : 2.4.14   , installed 2.4.12 [Updatable]
                    Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
                    Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
                    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.3  [Updatable]
                    Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
                    Adapter    "hm-rega"      : 3.0.43   , installed 3.0.40 [Updatable]
                    Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.12 [Updatable]
                    Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
                    Adapter    "iot"          : 1.12.2   , installed 1.11.9 [Updatable]
                    Adapter    "jeelink"      : 1.0.3    , installed 0.1.4  [Updatable]
                    Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
                    Adapter    "modbus"       : 5.0.8    , installed 5.0.5  [Updatable]
                    Adapter    "parser"       : 1.2.1    , installed 1.1.8  [Updatable]
                    Adapter    "proxmox"      : 1.3.5    , installed 1.3.4  [Updatable]
                    Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
                    Adapter    "snmp"         : 2.1.10   , installed 1.0.0  [Updatable]
                    Adapter    "socketio"     : 6.1.10   , installed 4.2.0  [Updatable]
                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.8  [Updatable]
                    Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
                    Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
                    Adapter    "web"          : 5.2.5    , installed 4.3.0  [Updatable]
                    Adapter    "ws"           : 2.1.5    , installed 1.3.0  [Updatable]
                    x86_64
                    /usr/bin/node
                    /usr/bin/npm
                      @gregors Nach welcher Anleitung hast du denn iobroker installiert?
                        Thomas Braun Most Active last edited by Thomas Braun
                        @gregors
                        sudo ln -s /usr/bin/node /usr/bin/nodejs
                        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        Der sourceanalytix ist bis dato nur über das Beta-Repo zu beziehen.
                        • GregorS
                          @guergen
                          Über die Anleitung in www.iobroker.net
                          • GregorS
                            GregorS @Thomas Braun last edited by
                            @guergen
                            Habe jetzt die aktuelle Version 0.4.14
                              Thomas Braun Most Active @GregorS last edited by
                              @gregors
                              Was sagt
                              denn nun?
                              GregorS 1 Reply Last reply Reply Quote 1
                              • GregorS
                                Habe deinen Code eingegeben, und dann hatte ich u.a auch den sourceanalytix dabei und konnte ihn über die Oberfläche updaten.
                                Habe jetz noch ein anderes Problem, aber da mache ich mal ein neues Topic auf.
                                  @gregors
                                  Was sagt
                                  denn nun?
                                  • GregorS
                                    @thomas-braun said in [SourceAnalytix 0.4.8-Final] Released !:
                                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                    code_tpi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    x86_64
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.17.0
                                    v16.17.0
                                    8.15.0
                                    4.0.23
                                    pi
                                    pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                                    /home/pi
                                    OK:1 http://deb.debian.org/debian bullseye InRelease
                                    OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                                    Paketlisten werden gelesen… Fertig
                                    Abhängigkeitsbaum wird aufgebaut… Fertig
                                    Statusinformationen werden eingelesen… Fertig
                                    Aktualisierung für 57 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                    nodejs:
                                      Installiert:           16.17.0-deb-1nodesource1
                                      Installationskandidat: 16.17.1-deb-1nodesource1
                                      Versionstabelle:
                                         16.17.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                     *** 16.17.0-deb-1nodesource1 100
                                            100 /var/lib/dpkg/status
                                         12.22.12~dfsg-1~deb11u1 500
                                            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                                         12.22.5~dfsg-2~11u1 500
                                            500 http://deb.debian.org/debian bullseye/main amd64 Packagesext
                                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                    Adapter    "parser"       : 1.2.1    , installed 1.2.1
                                    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                                    Adapter    "socketio"     : 6.1.10   , installed 6.1.10
                                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                    Adapter    "web"          : 5.2.5    , installed 5.2.5
                                    Adapter    "ws"           : 2.1.5    , installed 2.1.5
                                      @gregors sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                      Zieh die hoch. Und deaktivier das Beta-Repository wieder.
                                      • GregorS
                                        Kann ich die 57 Pakete mit iob update aktualisieren?
                                          Natürlich nicht. Die kommen vom Betriebssystem...
                                          Notieren und künftig regelmäßig machen:
                                          iob stop
                                          sudo apt update
                                          sudo apt full-upgrade
                                          sudo reboot
                                          • GregorS
                                            x86_64
                                            /usr/bin/nodejs
                                            /usr/bin/node
                                            /usr/bin/npm
                                            v16.17.1
                                            v16.17.1
                                            8.15.0
                                            4.0.23
                                            pi
                                            /home/pi
                                            [sudo] Passwort für pi:
                                            OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                                            OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                                            Alle Pakete sind aktuell.
                                            nodejs:
                                              Installiert:           16.17.1-deb-1nodesource1
                                              Versionstabelle:
                                             *** 16.17.1-deb-1nodesource1 500
                                            Ok, sieht jetzt besser aus.
                                            Lucifor1976 1 Reply Last reply Reply Quote 0
                                            2302
                                            1158542
