    4. [SourceAnalytix 0.4.8-Final] Released !
      guergen @GregorS last edited by guergen
      @gregors Wenn stable eingestellt ist, zeigt er die Beta-Adapter auch nicht mit an
      Nach welcher Anleitung hast du denn iobroker installiert?
      GregorS 1 Reply Last reply Reply Quote 0
      • GregorS
        GregorS @guergen last edited by
        @guergen
        Hier mit der Einstellung Stable + Beta
        pi@Promox-ioBroker:~$ iobroker update
        Used repositories: Stable (default), Beta (latest)
        Adapter    "admin"        : 6.2.22   , installed 6.2.22
        Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
        Adapter    "backitup"     : 2.4.14   , installed 2.4.12 [Updatable]
        Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
        Adapter    "denon"        : 1.13.4   , installed 1.13.4
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
        Adapter    "fritzdect"    : 2.2.6    , installed 2.2.3  [Updatable]
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
        Adapter    "hm-rega"      : 3.0.43   , installed 3.0.40 [Updatable]
        Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.12 [Updatable]
        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
        Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
        Adapter    "iot"          : 1.12.2   , installed 1.11.9 [Updatable]
        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
        Adapter    "jeelink"      : 1.0.3    , installed 0.1.4  [Updatable]
        Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
        Adapter    "modbus"       : 5.0.8    , installed 5.0.5  [Updatable]
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "parser"       : 1.2.1    , installed 1.1.8  [Updatable]
        Adapter    "proxmox"      : 1.3.5    , installed 1.3.4  [Updatable]
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
        Adapter    "snmp"         : 2.1.10   , installed 1.0.0  [Updatable]
        Adapter    "socketio"     : 6.1.10   , installed 4.2.0  [Updatable]
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.8  [Updatable]
        Adapter    "statistics"   : 2.2.0    , installed 2.2.0
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
        Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
        Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis"          : 1.4.15   , installed 1.2.12 [Updatable]
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
        Adapter    "web"          : 5.2.5    , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.1.5    , installed 1.3.0  [Updatable]
        pi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
        x86_64
        /usr/bin/node
        /usr/bin/npm
          @gregors Nach welcher Anleitung hast du denn iobroker installiert?
            Thomas Braun Most Active last edited by Thomas Braun
            @gregors
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            Der sourceanalytix ist bis dato nur über das Beta-Repo zu beziehen.
            • GregorS
              @guergen
              Über die Anleitung in www.iobroker.net
              • GregorS
                GregorS @Thomas Braun last edited by
                @guergen
                Habe jetzt die aktuelle Version 0.4.14
                  Thomas Braun Most Active @GregorS last edited by
                  @gregors
                  Was sagt
                  denn nun?
                  GregorS 1 Reply Last reply Reply Quote 1
                  • GregorS
                    Habe deinen Code eingegeben, und dann hatte ich u.a auch den sourceanalytix dabei und konnte ihn über die Oberfläche updaten.
                    Habe jetz noch ein anderes Problem, aber da mache ich mal ein neues Topic auf.
                      @gregors
                      Was sagt
                      denn nun?
                      • GregorS
                        @thomas-braun said in [SourceAnalytix 0.4.8-Final] Released !:
                        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                        code_tpi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        x86_64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.17.0
                        v16.17.0
                        8.15.0
                        4.0.23
                        pi
                        pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                        /home/pi
                        OK:1 http://deb.debian.org/debian bullseye InRelease
                        OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                        OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                        Paketlisten werden gelesen… Fertig
                        Abhängigkeitsbaum wird aufgebaut… Fertig
                        Statusinformationen werden eingelesen… Fertig
                        Aktualisierung für 57 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                        nodejs:
                          Installiert:           16.17.0-deb-1nodesource1
                          Installationskandidat: 16.17.1-deb-1nodesource1
                          Versionstabelle:
                             16.17.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                         *** 16.17.0-deb-1nodesource1 100
                                100 /var/lib/dpkg/status
                             12.22.12~dfsg-1~deb11u1 500
                                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                             12.22.5~dfsg-2~11u1 500
                                500 http://deb.debian.org/debian bullseye/main amd64 Packagesext
                        Adapter    "history"      : 2.2.4    , installed 2.2.4
                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                        Adapter    "parser"       : 1.2.1    , installed 1.2.1
                        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                        Adapter    "socketio"     : 6.1.10   , installed 6.1.10
                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "web"          : 5.2.5    , installed 5.2.5
                        Adapter    "ws"           : 2.1.5    , installed 2.1.5
                          @gregors sagte in [SourceAnalytix 0.4.8-Final] Released !:
                          Zieh die hoch. Und deaktivier das Beta-Repository wieder.
                          • GregorS
                            Kann ich die 57 Pakete mit iob update aktualisieren?
                              Natürlich nicht. Die kommen vom Betriebssystem...
                              Notieren und künftig regelmäßig machen:
                              iob stop
                              sudo apt update
                              sudo apt full-upgrade
                              sudo reboot
                              • GregorS
                                x86_64
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.17.1
                                v16.17.1
                                8.15.0
                                4.0.23
                                pi
                                /home/pi
                                [sudo] Passwort für pi:
                                OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                                OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                                Alle Pakete sind aktuell.
                                nodejs:
                                  Installiert:           16.17.1-deb-1nodesource1
                                  Versionstabelle:
                                 *** 16.17.1-deb-1nodesource1 500
                                Ok, sieht jetzt besser aus.
                                Lucifor1976 1 Reply Last reply Reply Quote 0
                                • Lucifor1976
                                  Lucifor1976 @GregorS last edited by
                                  Einen schönen guten Samstag.. 🙂
                                  Ich habe heute ein Problem mit Sourceanalytix
                                  Wir hatten heute Nacht einen mehrstündigen Stromausfall. Dieser war heute nacht um halb drei behoben.
                                  Heute sehe ich nun das bei den Analytix Auswertungen für Strom und Wasser falsche Daten berechnet werden.
                                  Bei Wasser zum Beispiel soll ich 507 m3 Wasser verbraucht haben und das um 11 Uhr.. 🙂 Wird heute wohl ein teuerer Tag.
                                  Bei Strom ebenfalls, witzigerweise hat er bei Strom DIe Daten von Donnerstag als Grundwert genommen und rechnet den Verbrauch von heute obendrauf...
                                  Wie bekomme ich das korrigiert?
                                  Strom:
                                  Wasser:
                                  Wasser:
                                    ManfredHi @Lucifor1976 last edited by
                                    @lucifor1976
                                    Ich hab auch gelegentlich dieses Problem.
                                    In meinem Logfile tauchen dann solche Einträge auf:
                                    Device reset detected for alias.0.Strom.Steckdosen.AVM.TV-Schlafzimmer store current cumulatedReading 301.182 as valueAtDeviceReset (previous valueAtDeviceReset : -147.477)
                                    Ich beende dann SA, wechsle in den Administrator mode und stelle den Eintrag "valueAtDeviceReset" wieder auf den vorherigen Wert, der in Klammer angeführt ist). Nach dem STart vom SA passt es dann wieder.
                                    • Lucifor1976
                                      Lucifor1976 @ManfredHi last edited by Lucifor1976
                                      @manfredh-1
                                      Ich verstehe Deinen Lösungansatz, hilft mir leider nicht da die Rohdaten nicht falsch sind:
                                      Wasser:
                                      Strom:
                                      Hier sieht man schön den Stromausfall von Freitag 22:16 bis heute Nacht 2:00 Uhr.
                                      • Lucifor1976
                                        Ich habe den Wasserzähler nun neu eingerichtet.. ist nicht schlimm der Zähler ist erst seit zwei Tagen smart.. und die Verbrauchsperiode kommt erst noch, kann ich mit leben.
                                        Bei Strom möchte ich das nun aber nicht gerne tun, sonst sind die Daten der letzen zwei Jahre weg, was ich nicht will..
                                        • JB_Sullivan
                                          JB_Sullivan last edited by
                                          @Dutchman
                                          Besteht die Möglichkeit, das man SA um die Einheit Kilometer (km) erweitert?
                                          Immer mehr Fahrzeuge sind ja via ioBroker integrierbar. D.h. man könnte mit SA und einem sich ändernden Gesamt Kilometerstand, leicht via SA, entsprechende Fahrhistorien erstellen lassen.
                                          Was hälst du von der Idee?
                                            crunchip Forum Testing Most Active @Lucifor1976 last edited by
                                            @lucifor1976 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                            und was genau ist falsch, bzw wo liegt das Problem?
                                            2302
                                            1159862
