      Elluminatus @Armilar last edited by Elluminatus
      @armilar Ich bekomme einen Fehler. Den Pfad squeezeboxrpc.0.Players.piCoreKUE gibt es aber, habe gerade nachgeschaut, hmm
      00:10:22.196	info	javascript.0 (10558) Start javascript script.js.common.NSPanel.LMS
      00:10:22.207	warn	javascript.0 (10558) script.js.common.NSPanel.LMS: Object "squeezeboxrpc.0.Players.piCoreKUE" does not exist
      00:10:22.208	info	javascript.0 (10558) script.js.common.NSPanel.LMS: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      00:10:22.210	error	javascript.0 (10558) script.js.common.NSPanel.LMS: TypeError: Cannot read properties of null (reading 'common')
      00:10:22.210	error	javascript.0 (10558) at createAlias (script.js.common.NSPanel.LMS:15:35)
      00:10:22.210	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:39:1
      00:10:22.211	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:51:3
      Der Haken bei SetObject ist bereits gesetzt
      • Armilar
        Armilar Most Active Forum Testing @Elluminatus last edited by
        @elluminatus sagte in SONOFF NSPanel mit Lovelace UI:
        Kopier es nochmal. Habe noch Änderungen in den Rollen gemacht. Kann es ja leider nicht selbst testen
          @armilar Hab es nochmal kopiert, leider derselbe Fehler:
          00:27:57.980	info	javascript.0 (10558) Start javascript script.js.common.NSPanel.LMS
          00:27:57.991	warn	javascript.0 (10558) script.js.common.NSPanel.LMS: Object "squeezeboxrpc.0.Players.piCoreKUE" does not exist
          00:27:57.992	info	javascript.0 (10558) script.js.common.NSPanel.LMS: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          00:27:57.994	error	javascript.0 (10558) script.js.common.NSPanel.LMS: TypeError: Cannot read properties of null (reading 'common')
          00:27:57.995	error	javascript.0 (10558) at createAlias (script.js.common.NSPanel.LMS:15:35)
          00:27:57.995	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:39:1
          00:27:57.995	error	javascript.0 (10558) at script.js.common.NSPanel.LMS:51:3
          Hier nochmal zur Kontrolle was ich eingefügt habe:
          const aliasPath = 'alias.0.Media.WT_KE_HWR';  // ggfs. Anpassen
          const aliasDevice = 'SqueezeBoxRPC';       // ggfs. Anpassen
          //Ergibt alias.0.NSPanel_1.Media.SqueezeBoxRPC
          const squeezeBoxInstanz = 'squeezeboxrpc.0.Players.'; // Anpasssen, wenn nicht Instanz 0
          const squeezeBoxDevice = 'piCoreKUE'; // Anpassen an dein eigenes Device
          var typeAlias, read, write, nameAlias, role, desc, min, max, unit, states, custom;
          function createAlias(idDst, idName,idSrc, idRd, idType, idRole, idAliasType) {
            if(existsState(idDst)) log(idDst + ' schon vorhanden !', 'warn');
            else {
               var obj = {};
               obj.type = idType;
               obj.common = getObject(idSrc).common;
               obj.common.alias = {};
               if(idRd) {
                   obj.common.alias.id = {};
                   obj.common.alias.id.read = idRd;
                   obj.common.alias.id.write = idSrc;
                   obj.common.read = true;
               } else obj.common.alias.id = idSrc;
               obj.common.type = idAliasType;
               if(obj.common.read !== false && read) obj.common.alias.read = read;
               if(obj.common.write !== false && write) obj.common.alias.write = write;
               obj.common.name = idName;
               obj.common.role = idRole;
               obj.common.desc = idDst;
               if(min !== undefined) obj.common.min = min;
               if(max !== undefined) obj.common.max = max;
               if(unit) obj.common.unit = unit;
               obj.common.states = states;
               if(custom && obj.common.custom) obj.common.custom = custom;
               obj.native = {};
               setObject(idDst, obj);
          createAlias(aliasPath + '.' + aliasDevice, '', squeezeBoxInstanz + squeezeBoxDevice, '', 'channel', 'media', 'string');
          createAlias(aliasPath + '.' + aliasDevice + '.ALBUM', 'ALBUM',  squeezeBoxInstanz + squeezeBoxDevice + '.Album', '', 'state', 'media.album', 'string');
          createAlias(aliasPath + '.' + aliasDevice + '.ARTIST', 'ARTIST', squeezeBoxInstanz + squeezeBoxDevice + '.Artist', '', 'state', 'media.artist', 'string');
          createAlias(aliasPath + '.' + aliasDevice + '.TITLE', 'TITLE', squeezeBoxInstanz + squeezeBoxDevice + '.Title', '', 'state', 'media.title', 'string');
          createAlias(aliasPath + '.' + aliasDevice + '.NEXT', 'NEXT', squeezeBoxInstanz + squeezeBoxDevice + '.btnForward', '', 'state', 'button.forward', 'boolean');
          createAlias(aliasPath + '.' + aliasDevice + '.PREV', 'PREV', squeezeBoxInstanz + squeezeBoxDevice + '.btnRewind', '', 'state', 'button.reverse', 'boolean');
          createAlias(aliasPath + '.' + aliasDevice + '.PLAY', 'PLAY', squeezeBoxInstanz + squeezeBoxDevice + '.state', '', 'state', 'media.state', 'boolean');
          createAlias(aliasPath + '.' + aliasDevice + '.PAUSE', 'PAUSE', squeezeBoxInstanz + squeezeBoxDevice + '.state', '', 'state', 'media.state', 'boolean');
          createAlias(aliasPath + '.' + aliasDevice + '.STOP', 'STOP', squeezeBoxInstanz + squeezeBoxDevice + '.state', '', 'state', 'media.state', 'boolean');
          createAlias(aliasPath + '.' + aliasDevice + '.STATE', 'STATE', squeezeBoxInstanz + squeezeBoxDevice + '.Power', '', 'state', 'switch', 'boolean');
          createAlias(aliasPath + '.' + aliasDevice + '.VOLUME', 'VOLUME', squeezeBoxInstanz + squeezeBoxDevice + '.Volume', '', 'state', 'level.volume', 'number');
          createAlias(aliasPath + '.' + aliasDevice + '.VOLUME_ACTUAL', 'VOLUME_ACTUAL', squeezeBoxInstanz + squeezeBoxDevice + '.Volume', '', 'state', 'value.volume', 'number');
          • Armilar
            Armilar Most Active Forum Testing @Elluminatus last edited by Armilar
              else {
                 var obj = {};
                 obj.type = idType;
                 if(idRd) {
                 obj.native = {};
            kommentiere das erste createAlias´mal aus (Zeile 39)
            //createAlias(aliasPath + '.' + aliasDevice, '', squeezeBoxInstanz + squeezeBoxDevice, '', 'channel', 'media', 'string');
              @armilar Das ist jetzt ohne Fehler durchgelaufen. Kannst Du mir kurz helfen, was als nächstes gemacht werden muss? Muss ich jetzt einenAlias mit Media anlegen oder im Vorfeld den Erfolg nochmal überprüfen? Danke für Deinen Einsatz.
              • Armilar
                Unter Objekte Alias findest du deinen neuen Media-Alias (der im Moment aber keiner ist)
                Gehe mal in den Ordner (hier im Bild blau) und klicke auf den Stift am Ende. Im ersten Tab sollte "media" unter Rolle eingetragen werden
                Jetzt ist es ein Media-Alias
                Im Anschluss folgst du der Beschreibung von gestern:
                https://forum.iobroker.net/post/867924
                Das hatten wir aber auch schon einfacher 😉
                  @armilar Jetzt muss ich doch nochmal nachfragen, also ich habe da in den Alias jetzt die ganzen Einträge wie bspw. Album etc.
                  Aber ich sehe den von Dir benannten Stift nicht am Ende?
                  • Armilar
                    Schalte mal in den Expertenmodus...
                    Kannst du wahrscheinlich dann auch schon mit klick auf den Bereich erledigen
                    oder unter Objektdaten wäre es dann in etwa so:
                      "type": "channel",
                      "common": {
                        "name": "",
                        "alias": {
                          "id": "squeezeboxrpc.0.Players.piCoreKUE"
                        "type": "string",
                        "role": "media",
                        "desc": "alias.0.NSPanel_1.Media.SqueezeBoxRPC"
                      "native": {},
                      "user": "system.user.admin",
                      "ts": 1664852646982,
                      "_id": "alias.0.NSPanel_1.Media.SqueezeBoxRPC",
                      "acl": {
                        "object": 1636,
                        "owner": "system.user.admin",
                    Dann kannst du auch gleich als type "channel" mitgeben.
                      @armilar
                      Ich kann leider nichts davon machen, ich habe kein Zahnrad, keinen Stift und kann nicht auf die Objektdaten zugreifen und auch nicht direkt auf den State. Bei den anderen geht es...?
                      • Armilar
                        @armilar
                        64ae6eaa-f86a-4847-ab96-67026caa706f-image.png Der ist an?
                          @armilar ja ist er
                          Armilar 2 Replies Last reply Reply Quote 0
                          • Armilar
                            @armilar ja ist er
                            Bist du von den Berechtigungen limitiert?
                            • Armilar
                              @armilar ja ist er
                              Könntest du mal versuchen den Alias mit dem Alias-Manager zu öffnen?
                              Da dürfte es auch gehen
                                @armilar Wie kann ich dies erkennen, bzw. wo kann ich dies überprüfen?
                                  Elluminatus @Elluminatus last edited by Elluminatus
                                  @elluminatus Dort ist er nicht angelegt
                                  Das Bild ist dort auch zuende.
                                  Hab jetzt nochmal eine neue Struktur angelegt
                                  Kann aber trotzdem nicht mehr sehen oder machen
                                  • Armilar
                                    Da bist du richtig. Jetzt nach Aktionen wie in meinem Bild oben "Gewählter Alias". Unter common.role media wählen und dann speichern
                                    E 2 Replies Last reply Reply Quote 0
                                      @armilar So das hat jetzt geklappt wenn ich das richtig sehe:
                                      • I
                                        icemanmw @Armilar last edited by
                                        @armilar
                                        vielen Dank. Das probiere ich gleich aus.
                                        Super erklärt und verständlich
                                        Ich melde mich wenn es alles klappt.
                                          @armilar So es ist fast geschafft! Anzeige läuft:
                                          Jetzt ist lediglich noch die letzte Einstellung:
                                          "items": [<PageItem>{
                                                          adapterPlayerInstance: "squeezeboxrpc.0.Players.piCoreKUE.",
                                                          speakerList: ['LENOVO-W11-X','Terrasse','Überall','Gartenhaus','Esszimmer','Heimkino','Echo Dot Küche','Echo Spot Buero']
                                          Was muss ich unten in der Speaker List eintragen? Den Playernamen? piCoreKUE bspw?
                                          Und was hat im Display das Icon mit den drei Strichen und der Note normalerweise für eine Funktion?
                                          • Armilar
                                            Das sieht doch schon ganz ordentlich aus...
                                            Unter Speaker würde ich mal nachsehen, wenn etwas abspielt, welcher Datenpunkt mit sinnvollen Geräten gefüllt ist. Das könntest du dann ebenfalls mal posten. Ebenfalls würde mich interessieren, wie der Wechsel von einem Raum zum anderen funktioniert. Dann könnte der Fall squeezeboxrpc das später korrekt verarbeiten. Aktuell gibt es ja keine Umschaltlogik für squeezebox im TS-Script. Aber ich denke fürs erste könnte da piCoreKUE drinstehen. Falls du so eine Umschaltlogik z.B. in Blockly hast, dann einfach hier posten. Falls du weißt welcher Datenpunkt mit welchem Inhalt gefüllt werden muss, könnte ich dir dabei ebenfalls helfen.
                                            Ja die Note mit einer Liste ist eine Note mit einer Liste. Einfach nur ein Icon ohne Funktion. Bei Spotitfy ist es das SpotifyLogo, bei Alexa gab es auch mal ein icon, heute nicht mehr und das Sonos Logo gibt es auch nicht. Wenn du ein passendes Logo in den 6500 icons findest, könnte ich das reinsetzen.
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6620496
