    4. [Problem]Fehler nach Update. Nichts geht mehr
      Thomas Braun Most Active @nevs84 last edited by
      @nevs84
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      • N
        nevs84 @Thomas Braun last edited by
        @thomas-braun said in [Problem]Fehler nach Update. Nichts geht mehr:
        pi@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm ERR! code 24
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh /tmp/install-51355609.sh
        npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        npm ERR!     /home/iobroker/.npm/_logs/2022-10-04T13_00_00_679Z-debug-0.log
          @nevs84
          Zumindest die npm-Meldungen sind weg...
          sudo install lsof
          lsof /opt/iobroker/iobroker-data/objects.jsonl
          N Thomas Braun 2 Replies Last reply Reply Quote 0
          • N
            sudo install lsof
            pi@iobroker:/opt/iobroker $ sudo install lsof
            install: Fehlender Zieldatei‐Operand hinter 'lsof'
            „install --help“ liefert weitere Informationen.
              Thomas Braun Most Active @Thomas Braun last edited by
              sudo apt install lsof
              sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                @nevs84
                Übrigens ist hier erklärt, warum es zur ursprünglichen Meldung kommt:
                https://help.heroku.com/ZV7S7D6T/why-is-my-node-build-is-suddenly-displaying-npm-err-cb-apply-is-not-a-function
                Und genau aus diesem Grund raten wir immer davon ab npm separat in die Hand zu nehmen.
                • N
                  pi@iobroker:/opt/iobroker $ sudo apt install lsof
                  Die folgenden NEUEN Pakete werden installiert:
                    lsof
                  0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  Es müssen 307 kB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 447 kB Plattenplatz zusätzlich benutzt.
                  Holen:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf lsof armhf 4.91+dfsg-1 [307 kB]
                  Es wurden 307 kB in 1 s geholt (455 kB/s).
                  Vormals nicht ausgewähltes Paket lsof wird gewählt.
                  (Lese Datenbank ... 127192 Dateien und Verzeichnisse sind derzeit installiert.)
                  Vorbereitung zum Entpacken von .../lsof_4.91+dfsg-1_armhf.deb ...
                  Entpacken von lsof (4.91+dfsg-1) ...
                  lsof (4.91+dfsg-1) wird eingerichtet ...
                  Trigger für man-db (2.8.5-2) werden verarbeitet ...
                  pi@iobroker:/opt/iobroker $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                    @nevs84 sagte in [Problem]Fehler nach Update. Nichts geht mehr:
                    ls -l /opt/iobroker/iobroker-data/objects.jsonl
                    • N
                      @thomas-braun Danke! This is a conflict between npm <= 5 and newer versions of Node 12 and 14. The solution is to upgrade npm to >= 6, which is installed with Node 12 and Node 14 by default.! Verstanden
                      • N
                        pi@iobroker:/opt/iobroker $ ls -l /opt/iobroker/iobroker-data/objects.jsonl
                        -rwxrwxrwx+ 1 iobroker iobroker 583059237 Okt  4 06:59 /opt/iobroker/iobroker-data/objects.jsonl
                          Thomas Braun Most Active @nevs84 last edited by Thomas Braun
                          @nevs84
                          Irgendwo muss man das timeout hochsetzen.
                          Ich weiß gerade aber nicht wo.
                          Das sind ja 583MByte da bei dir...
                          Das ist natürlich für einen RPi3 mit seinen 1GB Ram nicht zu schlucken.
                          • N
                            @thomas-braun Ich suche und lese gerade...werde aber gerade noch nicht so richtig schlau draus!
                            • N
                              free -m -t
                              Mem:            923         128         510          16         284         727
                              Swap:            99          52          47
                              Total:         1023         180         558
                                @nevs84
                                Ja. Und? 583MByte sind trotzdem ein zu großer Happen. Das bekommt der kleine PI nicht schnell genug verputzt.
                                • N
                                  @thomas-braun Vielen Dank für deine Mühen und deine Zeit bis hierhin. Ich habe jetzt gerade noch eine Stunde bzgl. des TimeOuts gelesen aber komme hier an diesem Punkt nicht weiter. Ich habe versucht den ioBroker (wie oben auch schon von @Homoran erwähnt) neu zu installieren, was ebenfalls fehl schlägt. Hat jemand noch eine Idee bzgl. des Timeouts? Oder eine anderen schlauen Tipp bzgl. der Neuinstallation? Möchte gerne das Formatieren vermeiden! Grüße
                                      Installing ioBroker (3/4)
                                  npm ERR! code 24
                                  npm ERR! command sh /tmp/install-8412f0be.sh
                                  npm ERR!     /home/pi/.npm/_logs/2022-10-05T19_24_32_093Z-debug-0.log
                                    Thomas Braun Most Active last edited by
                                    @nevs84
                                    Frag mal @Glasfaser , der hat den Befehl glaube ich parat.
                                      https://forum.iobroker.net/topic/53378/server-cannot-start-inmem-objects-on-port-9001/173
                                      • N
                                        nevs84 @Thomas Braun last edited by nevs84
                                        @thomas-braun Hab den Thread durchgelesen und den Timeout wie beschrieben hochgesetzt...keine Änderung. Der Fehler bleibt leider immer derselbe....wie kann ich nun am besten mein Backup einspielen (Was ja aktuell auch nicht geht aufgrund des nicht laufenden IOBrokers)? Bin dankbar für jeden Input.
                                          @nevs84
                                          Ich würde es von Null auf neuinstallieren.
                                          • N
                                            @thomas-braun Das heisst formatieren und neu imagen? Oder gibt es da noch andere Möglichkeiten?
                                            cb.apply is not a function
                                            3342
