    4. Test Adapter Midea Dimstal Klimaanlagen v0.0.x
      Picard @tombox last edited by
      @tombox Ist in der 0.1.0 auch die Unterstützung für den Luftentfeuchter DF-20DEN7-WF mit drin?
      Wann wird denn der Adapter offiziell aktualisiert? Ich muss gestehen ich installiere beim iobroker ungern etwas über git.
        tombox @gosund last edited by
        @gosund ihr könnt mal die GitHub version probieren und berichten wie die funktioniert
          gosund @tombox last edited by gosund
          @tombox
          Leider funktioniert die 0.1.0 nicht bei mir:
          midea.0
          	2022-09-11 14:38:09.030	error	*** PY *** Python Error Call to 'appliance_state' failed: > appliance_state = await this.midea_beautiful.appliance_state$({ at async Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:156:29) at async Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:80:5) ... across the bridge ... > six.raise_from(e, None) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:445) at raise_from (<string>:3) > httplib_response = conn.getresponse() at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:440) > response.begin() at getresponse (/usr/lib/python3.9/http/client.py:1347) > version, status, reason = self._read_status() at begin (/usr/lib/python3.9/http/client.py:307) > line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") at _read_status (/usr/lib/python3.9/http/client.py:268) > return self._sock.recv_into(b) at readinto (/usr/lib/python3.9/socket.py:704) > return self.read(nbytes, buffer) at recv_into (/usr/lib/python3.9/ssl.py:1241) > return self._sslobj.read(len, buffer) at read (/usr/lib/python3.9/ssl.py:1099) > resp = conn.urlopen( at send (/usr/lib/python3/dist-packages/requests/adapters.py:439) > retries = retries.increment( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:755) > raise six.reraise(type(error), error, _stacktrace) at increment (/usr/lib/python3/dist-packages/urllib3/util/retry.py:532) > raise value at reraise (/usr/lib/python3/dist-packages/six.py:719) > httplib_response = self._make_request( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:699) > self._raise_timeout(err=e, url=url, timeout_value=read_timeout) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:447) > raise ReadTimeoutError( at _raise_timeout (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:336) > response = requests.post( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:273) > return request('post', url, data=data, json=json, **kwargs) at post (/usr/lib/python3/dist-packages/requests/api.py:119) > return session.request(method=method, url=url, **kwargs) at request (/usr/lib/python3/dist-packages/requests/api.py:61) > resp = self.send(prep, **send_kwargs) at request (/usr/lib/python3/dist-packages/requests/sessions.py:542) > r = adapter.send(request, **kwargs) at send (/usr/lib/python3/dist-packages/requests/sessions.py:655) > raise ReadTimeout(e, request=request) at send (/usr/lib/python3/dist-packages/requests/adapters.py:529) > appliance.identify(cloud, use_cloud) at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1046) > self.refresh(cloud if use_cloud else None) at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:831) > responses = self._status(cmd, cloud) at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381) > responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538) > response = self.api_request( at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > self._retry_check(endpoint, cause) at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:335) > raise CloudRequestError( at _retry_check (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:350) *** JS *** midea_beautiful.exceptions.CloudRequestError: Too many retries while calling /v1/appliance/transparent/send, last error HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=2)
          midea.0
          	2022-09-11 14:38:09.029	error	Error
          midea.0
          	2022-09-11 14:37:50.251	info	function () { [native code] }
          midea.0
          	2022-09-11 14:37:50.249	info	[{id=145135534918692, address=xx.xx.xx.xx, port=6444, version=3, name=KLIMAANLAGE_XXXX, online=True, type=0xac, subtype=0, flags=0, extra=1, reserved=0, mac=30b23748e50f, ssid=net_ac_E50F, udp_version=4000000, protocol=069fcd, version=3.0.8, sn=000000P0000000Q130B2XXXXXXXX0000, state=[Air conditioner]{id=14500000000****, type=0xac mode=4, running=False, turbo=False, fan_speed=102, turbo_fan=False, purifier=False, dryer=False, target_temperature=28.0, indoor_temperature=24.4, outdoor_temperature=2.2250738585072014e-308, vertical_swing=False horizontal_swing=False comfort_sleep=False, error_code=0, prompt=False, supports={'eco': 1, 'mode': 1, 'fan_swing': 1, 'electricity': 0, 'strong_fan': 1, 'fan_speed': 1, 'temperature0': 32, 'temperature1': 60, 'temperature2': 32, 'temperature3': 60, 'temperature4': 32, 'temperature5': 60, 'temperature6': 0}}}]
          midea.0
          	2022-09-11 14:37:50.246	info	Found 1 devices
            @gosund Das sieht aber nicht so schlecht aus. Ein Objekt müsste eigentlich geschrieben haben. Kommt der Fehler bei jedem Update oder unregelmäßig.
              @tombox
              Ist gerade etwas schwierig, da ich wieder auf meine alte Installation umgeschaltet habe. Soweit ich das sehe, kommt der Fehler, wenn ich versuche die Anlage über das Objekt einzuschalten.
              Welche App soll ich in den Einstellungen wählen?
              Kommuniziert Dein Adapter eigentlich über die Cloud oder direkt mit der Anlage im LAN?
                @gosund Über die cloud. App muss man wählen bei der man registriert bzw austesten
                reindeer-web S 2 Replies Last reply Reply Quote 0
                • reindeer-web
                  reindeer-web @tombox last edited by
                  @tombox
                  Ich nutze den Entfeuchter Midea MDDF-20DEN7-WF.
                  Mit der Version 0.1.0 ist es mir jetzt endlich gelungen, Datenpunkte zu erhalten, die ich in meiner Visualisierung anzeigen lassen kann.
                  Leider kommen immer wieder (alle paar Stunden) diese beiden identischen Fehlermeldungen:
                  SyntaxError: Unexpected token b in JSON at position 84 at JSON.parse (<anonymous>) at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:166:32) at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
                    stefan-ohg @tombox last edited by stefan-ohg
                    Post bitte ignorieren, habe meinen Fehler gefunden, kann den Post aber nicht löschen.
                    Gruß Stefan
                      Marc9025 last edited by
                      @tombox
                      Erstmal vielen dank für deine Mühe.
                      Ich habe 2 Fragen 😉
                      Leider bekomme ich den Adapter bei mir nicht installiert das steht im log :
                      host.raspberrypi
                      2022-10-06 10:03:41.408 info iobroker exit 0
                      host.raspberrypi
                      2022-10-06 10:03:40.307 info iobroker upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png
                      host.raspberrypi
                      2022-10-06 10:03:40.295 info iobroker upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/jsonConfig.json jsonConfig.json application/json
                      host.raspberrypi
                      2022-10-06 10:03:40.193 info iobroker upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html
                      host.raspberrypi
                      2022-10-06 10:03:40.074 info iobroker 143 packages are looking for funding run npm fund for details
                      host.raspberrypi
                      2022-10-06 10:03:37.088 info iobroker + iobroker.midea@0.1.0updated 1 package in 301.601s
                      host.raspberrypi
                      2022-10-06 10:03:37.086 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                      host.raspberrypi
                      2022-10-06 10:03:37.052 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                      host.raspberrypi
                      2022-10-06 10:03:37.011 info iobroker npm WARN pythonia@1.0.0 requires a peer of ws@^7.5.1 but none is installed. You must install peer dependencies yourself.
                      host.raspberrypi
                      2022-10-06 10:03:36.979 info iobroker npm WARN http-cookie-agent@4.0.1 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                      host.raspberrypi
                      2022-10-06 10:03:36.949 info iobroker npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
                      host.raspberrypi
                      2022-10-06 10:03:30.908 info iobroker Installing midea-beautiful-air
                      host.raspberrypi
                      2022-10-06 10:03:30.907 info iobroker pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)
                      host.raspberrypi
                      2022-10-06 10:03:24.788 info iobroker Python 3 found
                      host.raspberrypi
                      2022-10-06 10:03:24.787 info iobroker Python 3.9.2
                      host.raspberrypi
                      2022-10-06 10:03:24.763 info iobroker Start Python package installation
                      host.raspberrypi
                      2022-10-06 10:03:24.761 info iobroker
                      host.raspberrypi
                      2022-10-06 10:03:24.617 info iobroker > iobroker.midea@0.1.0 postinstall /opt/iobroker/node_modules/iobroker.midea> node ./pythonPackages.js
                      host.raspberrypi
                      2022-10-06 10:03:24.616 info iobroker
                      ist es vielleicht weil ich eine 64 Bit Version habe?
                      Ich habe eine Quick Connet Klimaanlage von Dimstal. Leider benutz diese eine andere app.
                      https://play.google.com/store/apps/details?id=com.broadlink.acfreedom&hl=de&gl=US
                      ist da die Einbindung auch möglich?
                      Thomas Braun T 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @Marc9025 last edited by
                        @marc9025 sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                        Nein, bei mir läuft der Adapter auch auf einem 64bit RaspberryOS.
                        Dein Log ist auch nicht vollständig. Der Anfang und das Ende fehlt vermutlich.
                          tombox @Marc9025 last edited by
                          @marc9025 Installation sieht gut aus. Hast du manuell eine Instanz erstellt?
                            Marc9025 @tombox last edited by
                            @tombox
                            ich habe jetzt noch mal installiert und das zeigt er mir an.
                            Unter Instanzen wird der Adapter mir nicht angezeigt aber unter Objekten gibt es einen Ordner midea. Da gibt es aber nur den Ordner admin
                            $ iobroker url https://github.com/TA2k/ioBroker.midea --host raspberrypi --debug
                            install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96
                            NPM version: 6.14.17
                            Installing TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96... (System call)
                            Python 3.9.2Python 3 found
                            pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)Installing midea-beautiful-air
                            WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/
                            • iobroker.midea@0.1.0updated 1 package in 356.909s
                            Process exited with code 0
                              @marc9025 Python packages ist zur zeit sehr langsam probier in ein paar stunden nochmal
                                @tombox
                                jetzt hat es funktioniert.
                                Jetzt aber zu meiner 2 Frage 🙂
                                ich habe ja nicht die midea app sondern die AC Freedom. Damit wird es nicht gehen oder ?
                                  @marc9025 https://github.com/TA2k/ioBroker.midea/issues/154
                                  DraycD created this issue in TA2k/ioBroker.midea
                                  open New Dimstal AC not compatible? #154
                                    @tombox
                                    aber ich gerade gesehen.
                                    Braust du noch Zugansdaten zum testen ?
                                      @marc9025 Nein die Geräte können nicht in den adapter integriert werden
                                        @tombox
                                        okay das ist schade, dann habe ich wohl Pech gehabt.
                                          @tombox
                                          hallo noch mal,
                                          ich habe versucht die Klimaanlage von einem Kollegen hinzuzufügen (nethome app).
                                          Der Login hat geklappt und er übergibt auch den String mit den daten(im log)
                                          Aber er erstellt keine Datenpunkte und er gibt die Beiden Fehler aus:
                                          midea.0
                                          2022-10-06 15:27:32.344 error TypeError: objectString.replaceAll is not a function at Midea.pythonToJson (/opt/iobroker/node_modules/iobroker.midea/main.js:177:8) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:115:36) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:79:5)
                                          midea.0
                                          2022-10-06 15:27:32.338 error TypeError: objectString.replaceAll is not a function
                                            @marc9025 Sicher eine node 14 installation. Bitte nochmal installieren dann sollte es auch damit gehen
                                            dimstal midea nethome nethome plus
                                            65
                                            368
                                            82927
