    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      Thomas Braun Most Active @david83 last edited by Thomas Braun
      @david83
      Unscharf ausgedrückt von mir. Ich hatte im Log nur seit heute morgen den alexa2 drin stehen. Ob die Echos offline sind weiß ich gar nicht.
      echad@chet:~ $ iobroker logs --watch | uniq
      2022-10-06 00:00:38.060  - info: followthesun.0 (61057) Cronjob 'Sun parameter calculation' starts
      2022-10-06 02:33:02.962  - info: history.0 (60755) Delete old history "/opt/iobroker/iobroker-data/history/20220929/history.javascript.0.Speedtest.Ergebnisse.Download_MBit.json"
      2022-10-06 02:52:53.413  - info: host.chet Delete log file iobroker.2022-09-28.log.gz
      2022-10-06 03:33:02.968  - info: history.0 (60755) Delete old history "/opt/iobroker/iobroker-data/history/20220929/history.javascript.0.Speedtest.Ergebnisse.Upload_MBit.json"
      2022-10-06 03:33:02.970  - info: history.0 (60755) Delete old history dir "/opt/iobroker/iobroker-data/history/20220929"
      2022-10-06 07:26:52.609  - info: host.chet Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-10-06 07:54:25.101  - info: info.0 (61087) Reading/updating systemdata.
      2022-10-06 07:54:25.784  - info: info.0 (61087) cpu Temp res = {"main":47.712,"cores":[],"max":47.712,"socket":[],"chipset":null}
      2022-10-06 08:01:24.981  - info: host.chet "system.adapter.parcel.0" enabled
      2022-10-06 08:01:25.345  - info: host.chet instance system.adapter.parcel.0 started with pid 222179
      2022-10-06 08:01:28.713  - info: parcel.0 (222179) starting. Version 0.0.21 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.10.0, js-controller: 4.0.23
      2022-10-06 08:01:28.789  - info: parcel.0 (222179) Login to DHL
      2022-10-06 08:01:29.462  - info: parcel.0 (222179) Login to DHL successful
      2022-10-06 08:01:29.484  - info: parcel.0 (222179) Login to DPD
      2022-10-06 08:01:32.509  - info: parcel.0 (222179) Login to DPD successful
      2022-10-06 08:01:33.352  - info: parcel.0 (222179) Login to T17 User
      2022-10-06 08:01:33.964  - info: parcel.0 (222179) Login to T17 User successful
      2022-10-06 08:01:33.981  - info: parcel.0 (222179) Login to Amazon
      2022-10-06 08:01:37.052  - info: parcel.0 (222179) Login to Amazon successful
      2022-10-06 08:01:37.065  - info: parcel.0 (222179) Login to GLS
      2022-10-06 08:01:37.747  - info: parcel.0 (222179) Login to GLS successful
      2022-10-06 08:01:37.754  - info: parcel.0 (222179) Login to UPS
      2022-10-06 08:01:38.253  - info: parcel.0 (222179) Login to UPS successful
      2022-10-06 08:01:38.555  - info: parcel.0 (222179) Login to Hermes
      2022-10-06 08:01:39.103  - info: parcel.0 (222179) Login to Hermes successful
      2022-10-06 10:49:51.040  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 10s
      2022-10-06 10:50:02.170  - info: alexa2.0 (60838) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-10-06 13:32:32.208  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 15s
      2022-10-06 13:32:48.405  - info: alexa2.0 (60838) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-10-06 13:48:18.412  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 20s
      2022-10-06 13:49:08.448  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 25s
      2022-10-06 13:49:08.449  - info: alexa2.0 (60838) Alexa-Push-Connection Error: WebSocket was closed before the connection was established
      2022-10-06 13:49:08.449  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 30s
      2022-10-06 13:50:08.478  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 35s
      2022-10-06 13:50:08.579  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 40s
      2022-10-06 13:50:49.348  - info: alexa2.0 (60838) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-10-06 14:27:49.050  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 45s
      2022-10-06 14:28:34.769  - info: alexa2.0 (60838) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-10-06 15:05:04.783  - info: alexa2.0 (60838) Alexa-Push-Connection disconnected - retry: Retry Connection in 50s
      2022-10-06 15:05:30.154  - info: host.chet stopInstance system.adapter.alexa2.0 (force=false, process=true)
      2022-10-06 15:05:30.189  - info: alexa2.0 (60838) Got terminate signal TERMINATE_YOURSELF
      2022-10-06 15:05:30.192  - info: alexa2.0 (60838) terminating
      2022-10-06 15:05:30.193  - info: alexa2.0 (60838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-06 15:05:30.242  - info: host.chet stopInstance system.adapter.alexa2.0 send kill signal
      2022-10-06 15:05:30.797  - info: host.chet instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-06 15:05:33.341  - info: host.chet instance system.adapter.alexa2.0 started with pid 244227
      2022-10-06 15:05:35.578  - info: alexa2.0 (244227) starting. Version 3.19.9 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.10.0, js-controller: 4.0.23
      2022-10-06 15:05:39.726  - info: alexa2.0 (244227) Update cookie in adapter configuration ... restarting ...
      2022-10-06 15:05:39.814  - info: host.chet stopInstance system.adapter.alexa2.0 (force=false, process=true)
      2022-10-06 15:05:39.822  - info: alexa2.0 (244227) Got terminate signal TERMINATE_YOURSELF
      2022-10-06 15:05:39.825  - info: alexa2.0 (244227) terminating
      2022-10-06 15:05:39.828  - info: alexa2.0 (244227) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-06 15:05:39.863  - info: host.chet stopInstance system.adapter.alexa2.0 send kill signal
      2022-10-06 15:05:40.471  - info: host.chet instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-06 15:05:42.961  - info: host.chet instance system.adapter.alexa2.0 started with pid 244283
      2022-10-06 15:05:45.106  - info: alexa2.0 (244283) starting. Version 3.19.9 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.10.0, js-controller: 4.0.23
      2022-10-06 15:05:51.667  - info: alexa2.0 (244283) Initialize all Device states ...
      2022-10-06 15:07:14.867  - info: alexa2.0 (244283) Subscribing to states...
      2022-10-06 15:07:18.614  - info: alexa2.0 (244283) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-10-06 15:07:40.966  - info: alexa2.0 (244283) Initialization Done ...
      2022-10-06 15:25:48.630  - info: alexa2.0 (244283) Alexa-Push-Connection disconnected - retry: Retry Connection in 10s
      2022-10-06 15:25:59.382  - info: alexa2.0 (244283) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2022-10-06 15:56:29.394  - info: alexa2.0 (244283) Alexa-Push-Connection disconnected - retry: Retry Connection in 15s
      2022-10-06 15:56:45.174  - info: alexa2.0 (244283) Alexa-Push-Connection (macDms = true) established. Disable Polling
      Jedenfalls scheint da gerade herumgewerkelt zu werden.
      • DJMarc75
        DJMarc75 @Thomas Braun last edited by
        Dito - seit heute Morgen un/regelmäßig selbiges im LOG
          A Former User @david83 last edited by
          @david83 hmm das ist aber komisch weil ich die Sonoff Geräte schon lange nicht mehr angerührt habe. Evtl müssen wir hier, wie bei Shelly, den selector optimieren. Hattest du die denn immer auf 15 min stehen? Welche Datenpunkte aktualisieren sich häufig? Habe den auf den Datenpunkt alive stehen. Wenn der sich in den 15 min nicht aktualisiert ist klar das er dann offline meldet. Evtl ist es nicht die beste Wahl und wir müssen hier auf einen anderen Punkt gucken? Ansonsten hast du zwei Möglichkeiten entweder die Zeit erhöhen oder auf -1 gehen dann meldet er nur offline wenn der Datenpunkt Alive auch false zeigt.
          david83 1 Reply Last reply Reply Quote 0
          • david83
            david83 @Guest last edited by
            @ciddi89 sagte:
            Ja
            Habe ich noch nicht nachgeschaut.
            Ok vielleicht liegt hier schon mein Problem, ich bin davon ausgegangen das der Adapter nur Geräte meldet wo der Datenpunkte.alive auf false steht. Die Entwicklung ist wohl an mir vorbei gegangen....
            Werde diese Lösung probieren und schauen welcher Datenpunkt sich noch eignen könnte
            • david83
              david83 @david83 last edited by
              @ciddi89
              Ok habe die Sonoff und Alexa Geräte auf -1 gestellt. Scheint so zu funktionieren.
              Zu den Datenpunkten:
              Beim Sonoff Adapter wird der Datenpunkt Uptime alle 10 sec. aktualisiert (laut Zeitstempel) vielleicht wäre das eine Option?
              Bei den Alexa Geräten stehen fast alle Datenpunkte seit fast 3 Stunden ohne Aktualisierung unverändert an. (laut Zeitstempel) nur der Datenpunkt alexa2.0.Echo-Devices.xxxxxxxxxxxxx.Preferences.ringNotificationsEnabled aktualisiert sich bei mir alle 5 min. Vielleicht wäre dieser Datenpunkt eine Option. Allerdings gibt es diesen Datenpunkz nur bei den Echos...
              Mfg David
                @david83 ja cool danke für deine Infos. Ich schaue mal, weil wir schon mal den selektor für Sonoff geändert haben. Weil nicht alle Geräte alle Datenpunkte haben. Wenn es nicht uptime war werde ich es wie bei Shelly auch auf uptime Umstellen. Das Sind auf jeden Fall die, die sich auch aktualisieren.
                Und ja mit Alexa, da sind wir dran, aber das wird wohl ein Fall für sich sein. Ich weiß nicht ob @DJMarc75 schon was in Erfahrung gebracht hat wegen den Datenpunkt online. Anscheinend werden die Datenpunkte nur bei den Echos ordentlich aktualisiert. Bei meinem firetv leider nicht. Vielleicht wird der Adapter daher dann auch nur noch Echos unterstützen können. Mal sehen…
                • DJMarc75
                  DJMarc75 @Guest last edited by
                  @ciddi89 sagte in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
                  Leider nein aber Amazon furwerkt seit Tagen immer an anderen Sachen rum - fällt schwer da darauf zu reagieren. Daher ist Geduld gefragt und ein Hoffen auf positive News seitens Amazon (Hoffnung stirbt ja zuletzt) 😀
                    A Former User @DJMarc75 last edited by
                    @djmarc75 ja hab’s schon mit bekommen 😬😬
                    Thomas Braun da_Woody 2 Replies Last reply Reply Quote 1
                      @ciddi89
                      Zum Unterschied zwischen Echos und anderen Geräten :
                      https://www.smarthomeassistent.de/amazon-alexa-warum-kann-man-ziggy-nicht-auf-einem-fire-tv-cube-aktivieren/
                        A Former User @Thomas Braun last edited by
                        @thomas-braun da geht es ja nur um das Aktivierungswort. Aber zeigt halt auch das zwischen den Geräten noch mehr Unterschiede gibt.
                          @ciddi89
                          Das die Geräte unterschiedlich gehandhabt werden wollte ich damit zeigen.
                            Malz1902 last edited by
                            Ich bekam meine tägliche Auflistung welche Geräter Offline sind, momentan sind es 13 Sonoff Steckdosen aber in der Auflistung standen nur noch 2 drin, gestern standen noch alle 13 drin, sehr komisch
                            Hatte gestern Nachmittag nur einmal über Github aktualisiert
                            • da_Woody
                              da_Woody @Guest last edited by
                              @ciddi89 schon ne zeit beobachtet bei den shelly. wenn rssi stabil ist, dann kommt in der offline liste:
                              die dinger funktionieren aber wenn sich rssi manchmal anscheinend ändert.
                              abgesehn davon, wie schon beschrieben, mag ich die in der blacklist eintragen, aber doch in der offlinelist sehen. ich weis, es nervt... 😉
                                A Former User @da_Woody last edited by
                                @da_woody ja ich habe bei shelly nun den uptime state gewählt. Der sollte eigentlich sehr genau sein. Und ja ich weiss, ich habe es auch nicht vergessen also noch ein bisschen Geduld. 😉
                                @Malz1902 hmm okay ist merkwürdig, da ich bezüglich Sonoff Geräte wirklich nichts gemacht habe. Hast du im Experten Modus auf -1 gestellt oder gehst du auf Zeit bei Sonoff Geräten? Hast du evtl. ioBroker neugestartet? Dann ändern sich die Timestamps und das dauert dann wieder die Zeit bis sie diese in der liste wieder auftauche.
                                • Negalein
                                  Negalein Global Moderator @Guest last edited by
                                  Derzeit unterstützte Adapter/Geräte sind:
                                  könntest du noch die TP-Link HS100/HS110 Stecker integrieren?
                                    "type": "state",
                                    "common": {
                                      "name": "Serverschrank",
                                      "def": true,
                                      "type": "boolean",
                                      "read": true,
                                      "write": true,
                                      "role": "switch",
                                      "desc": "Switch on/off",
                                      "custom": {
                                        "eventlist.0": {
                                          "enabled": true,
                                          "event": "%n",
                                          "trueText": "eingeschaltet",
                                          "falseText": "ausgeschaltet",
                                          "trueColor": "green",
                                          "falseColor": "red",
                                          "changesOnly": true
                                        "iot.1": {
                                          "smartName": {
                                            "smartType": "SMARTPLUG"
                                    "native": {
                                      "ip": "10.0.1.80"
                                    "_id": "hs100.0.10_0_1_80.state",
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                      "owner": "system.user.admin",
                                    "from": "system.adapter.hs100.0",
                                    "user": "system.user.admin",
                                    "ts": 1664965383320
                                    A Former User @Negalein last edited by
                                    @negalein hmm das ist ja nur ein State Datenpunkt. Was soll da groß überwacht werden?
                                    • Negalein
                                      Ahhh, hab den falschen erwischt
                                        "type": "state",
                                        "common": {
                                          "def": "-1",
                                          "type": "string",
                                          "read": true,
                                          "write": false,
                                          "role": "value",
                                          "desc": "last update"
                                        "native": {
                                          "ip": "10.0.1.80"
                                        "ts": 1664965383320,
                                        "_id": "hs100.0.10_0_1_80.last_update",
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636,
                                        @negalein erledigt 👨‍🏭
                                          Malz1902 @Guest last edited by
                                          @ciddi89 steht auf -1 und Neustart gab es auch keinen. Heeute in der Übersicht stand nur ein Zigbee Gerät drin was offline ist, alle andere tauchen in der Liste gar nicht auf obwohl offline
                                          • D3ltoroxp
                                            D3ltoroxp last edited by D3ltoroxp
                                            Thema Sonoff, die Dose ist eingesteckt wird auch als alive angezeigt, aber das ist vom 1.10. Uptime z.b. 15:42 von heute. Daher werden die mir wohl auch alle offline angezeigt.
                                            Hmip ist erst später dazu gekommen ? Ich habe momentan Homematic, hab da aber gar keine Geräte mehr. Hab gesehen das jetzt HmIP vorhanden ist, also wird hier auch ganz klar unterschieden ? Dann müsste ich jetzt für meine IP Geräte eben HmIP aktivieren ?
                                            1462
                                            499571
