    4. Test Tesla-Motors v1.0.0
      exmerci last edited by
      System ist auf dem neuesten Stand. Danke vielmals.
      Tesla Adapter habe ich mit deinem Befehl über die Konsole installiert. Hat geklappt, musste allerdings gleich upgedatet werden.
      Jetzt gucke ich mal, ob ich weiterkomme.
      Habe wieder viel gelernt.
        Thomas Braun Most Active @exmerci last edited by
        @exmerci
        iobroker update
        sagt nun?
          exmerci @Thomas Braun last edited by
          Adapter    "admin"        : 6.2.22   , installed 6.2.22
          Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
          Adapter    "backitup"     : 2.4.12   , installed 2.4.12
          Adapter    "cloud"        : 4.2.2    , installed 4.2.2
          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "email"        : 1.1.3    , installed 1.1.3
          Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
          Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
          Adapter    "ham"          : 5.3.0    , installed 5.3.0
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "history"      : 2.2.0    , installed 2.2.0
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "hs100"        : 2.1.2    , installed 2.1.2
          Adapter    "ical"         : 1.13.1   , installed 1.13.1
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
          Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
          Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
          Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
          Adapter    "meross"       : 1.14.0   , installed 1.14.0
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
          Adapter    "onvif"        : 0.4.4    , installed 0.4.4
          Adapter    "parcel"       : 0.0.20   , installed 0.0.20
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "shelly"       : 6.0.0    , installed 6.0.0
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
          Adapter    "tesla-motors" : 1.3.0    , installed 1.3.0
          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
          Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
          Ich dachte ich könnte jetzt weitermachen, aber ich habe keine Tesla Instanz
            @exmerci sagte in Test Tesla-Motors v1.0.0:
            Weil bei Installationen aus dem GitHub eine Instanz manuell hinzugefügt werden muss.
            Wäre bei ordentlicher Installation aus den Repos nicht erforderlich.
              Und wie geht das?
              Oder kann ich das jetzt wieder deinstallieren (wie ohne Instanz) und normal wieder installieren?
                @exmerci
                iobroker upgrade tesla-motors@1.3.0
                  @thomas-braun sagte in Test Tesla-Motors v1.0.0:
                  Irgendwie tut sich da nichts. Der Adapter ist weiterhin installiert, aber keine Instanz.
                    @exmerci
                    Dann klick auf das +-Zeichen.
                    Oder
                    iobroker add tesla-motors.0
                      exmerci @Thomas Braun last edited by exmerci
                      Soweit so gut. Leider klappt der Login nicht. Mal suchen, ob in dem Thread schon etwas darüber steht.
                      PS. Jetzt geht es. Ich musste einen Teil aus der Browserzeile entfernen. Hatte ich übersehen.
                        exmerci @lobomau last edited by
                        @lobomau sagte in Test Tesla-Motors v1.0.0:
                        @danielos vampire drain war zuletzt kein Problem mit dem Adapter. Bist du aktuell? Bei mir läuft 1.3.0.
                        Aktualisiert bei mir alle 15s.
                        ich bin noch neu was Tesla und diesen Thread betrifft.
                        Was heisst "vampire drain war zuletzt kein Problem"?
                        Wenn ich das richtig verstanden habe, ist es so, wenn ich alle 60 Sekunden aktualisiere, schläft das Auto nie ein, oder?
                        Das heisst doch aber auch, das immer ordentlich Akku verbraucht wird, oder? Macht das Sinn? Angenommen das Auto steht mal eine Woche ohne Ladekabel, dann könnte es sein, das es dann leer ist, richtig?
                        lobomau 1 Reply Last reply Reply Quote 0
                        • lobomau
                          lobomau @exmerci last edited by lobomau
                          @exmerci genau... meiner schläft nach 10min ein, wenn ich ihn in Ruhe lasse. Und das mache ich auch. Ist also meistens am Schlafen, wenn nicht gerade geladen oder gefahren wird. Nicht schlafen lassen kostet bestimmt 2-3% Tag. Sonst bist du unter 1%.
                          Mit meinen Einstellungen habe ich kein Problem. Wenn er trotzdem nicht schläft, kann es an einem Script liegen, dass andauernd Daten abruft. Der Adapter alleine macht kein Problem.
                            exmerci @lobomau last edited by exmerci
                            @lobomau
                            Wenn er nicht geladen wird. Ok. Und wie machst du das? Weckst du ihn alle 10 Minuten auf, solange das Kabel dran hängt?
                            Und wie merkt der Adapter, das dass Kabel angeschlossen wurde?
                            • lobomau
                              @exmerci nein, auch mit Kabel dran schläft er ein, wenn nicht gerade geladen wird.
                              Der Adapter ist so gemacht, dass er nur Daten regelmäßig abruft, wenn der Tesla nicht schläft.
                              Stelle alle SCripte mal auf aus und nimm meine Einstellungen. Dann sollte er nach 10 min einschlafen. Oder du hast noch Drittsoftware-Geschichten am Laufen undabhängig von ioBroker.
                              Edit: wenn das Kabel angeschlossen wird, ist/wird der Tesla natürlich erstmal wach und schläft nach 10min wieder ein, wenn nicht geladen wird.
                                @lobomau
                                Ich habe noch gar nichts am Laufen, sondern wollte erst anfangen. Aber gleich richtig 🙂
                                Also wenn du nach Haus kommst, und das Kabel anschliesst oder aber schon zu Hause bist und das Kabel anschliesst, merkt das Script das?
                                Und das Script merkt auch von selbst, wenn der Wagen nicht geladen wird, oder wie hältst du ihn für die Zeit wach?
                                • lobomau
                                  Richtig.
                                  wenn nicht geladen und sonst nichts mit dem Auto gemacht wird, also auch nicht Handyapp benutzt wird, schläft der Tesla dann nach 10min ein und dann gibts auch keine Daten mehr zum Adapter. Also als permanten Außenlufttemperatur Sensor ist der Tesla nur bedingt geeignet 😉
                                  Aber da ich kein Programmierer bin, kann ich jetzt auch nicht sagen wie es exakt funktioniert.
                                    Dafür habe ich auch Thermometer, die keine 60K € kosten. 🙂
                                    Danke für die Erklärungen. Dann werde ich mir mal was zusammenbasteln.
                                      Vielleicht bin ich wieder blind, aber gibt es einen Datenpunkt, in dem man sehen kann, wann die Daten das letzte mal aktualisiert wurden?
                                      JLeg 1 Reply Last reply Reply Quote 0
                                      • JLeg
                                        JLeg @exmerci last edited by
                                        …jeder Datenpunkt hat (mehrere) Zeitstempel - z.B. bei Blockly mal die Auswahl beim „Objekt“ (Trigger) ausklappen…
                                          dpcFan @danielos last edited by
                                          @danielos Hallo! Mein UseCase ist gleich und es stoppt derzeit noch am Adapter, der baut keine Connection auf... "Invalid codeURL please visit instance settings and copy url after login" obwohl ich nun alles gemacht habe, was in der Doku steht! Wenn ich aber das PRoblem gelöst habe, kommt es zum "Nachbauen", worin hast Du die Logik umgesetzt? JavaScript? Kannst Du mir das Script zur Verfügung stellen (ich bin nicht faul, habe das Auto grade ne Woche und will nicht Nächte verbringen, es in meine Haustechnik zu integrieren....).
                                          T E 2 Replies Last reply Reply Quote 0
                                            tombox @dpcFan last edited by
                                            @dpcfan hast du 1.3.1 installiert?
                                            930
                                            244160
