    4. Node-Red
    5. Mit Node-Red Openweathermap mit Standorten mit Owentracks.
    • N
      NetFritz last edited by Homoran
      Hallo
      Ich möchte in einen Mobilen System (Wohnmobil) die Wetterdaten von Openweathermap abfragen.
      Owentracks liefert die Standortdaten über MQTT.
      Die Wetterdaten werden über Openweathermap API abgefragt.
      in der Simulation wo ich die GPS Daten lat un lon vorgebe läuft das schon.
      Blos bekomme ich es nicht hin die GPS Daten von Owentracks mit Openweathermap zu verbinden.
              "id": "9159ccfcf71468ba",
              "type": "tab",
              "label": "Flow 2",
              "disabled": false,
              "info": "",
              "env": []
              "id": "68ff18aa1b5e338e",
              "type": "function",
              "z": "9159ccfcf71468ba",
              "name": "lat",
              "func": "var latiude = { payload: msg.payload.lat };\nvar unix = latiude;\nvar str = \"lat:\";\nmsg.payload = unix;\nreturn msg.payload;\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 290,
              "y": 120,
              "wires": [
                      "9e2cbcddc4ed8922"
              "id": "504c52975b40417a",
              "type": "function",
              "name": "lon",
              "func": "var longitude = { payload: msg.payload.lon };\nmsg.payload = longitude;\nreturn msg.payload;\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 290,
              "y": 180,
              "wires": [
                      "4a5a62e0cbd3dceb"
              "id": "dd24d2477409f1e8",
              "type": "mqtt in",
              "name": "",
              "topic": "#",
              "qos": "2",
              "datatype": "auto-detect",
              "broker": "e72556340bb92c91",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 130,
              "y": 140,
              "wires": [
                      "504c52975b40417a",
                      "68ff18aa1b5e338e"
              "id": "9e2cbcddc4ed8922",
              "type": "debug",
              "name": "lat",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 510,
              "y": 120,
              "wires": []
              "id": "4a5a62e0cbd3dceb",
              "type": "debug",
              "name": "lon",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 510,
              "y": 180,
              "wires": []
              "id": "021a98c9b6d3c1cb",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "lat",
              "payload": "52.345",
              "payloadType": "num",
              "x": 160,
              "y": 340,
              "wires": [
                      "7fd7848685667f31"
              "id": "7fd7848685667f31",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "property": "payload",
              "propertyType": "msg",
              "key": "topic",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": true,
              "timeout": "",
              "count": "2",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 320,
              "y": 380,
              "wires": [
                      "5181d7da0422a756",
                      "a18da81bd8de15a8"
              "id": "c1237e7f1cad8040",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "lon",
              "payload": "9.1272736",
              "x": 170,
              "y": 420,
              "wires": [
                      "7fd7848685667f31"
              "id": "5181d7da0422a756",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload.appid",
                      "pt": "msg",
                      "to": "xxxxxxxxxxxxxxxxxxxxxxxxxx",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 540,
              "y": 400,
              "wires": [
                      "79f896ab2598bab8",
                      "01cce51743f36f9e"
              "id": "79f896ab2598bab8",
              "type": "debug",
              "name": "debug lat u. lon u key",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 900,
              "y": 320,
              "wires": []
              "id": "01cce51743f36f9e",
              "type": "http request",
              "name": "",
              "method": "GET",
              "ret": "txt",
              "paytoqs": "query",
              "url": "http://api.openweathermap.org/data/2.5/weather",
              "tls": "",
              "persist": false,
              "proxy": "",
              "insecureHTTPParser": false,
              "authType": "",
              "senderr": false,
              "headers": [],
              "x": 870,
              "y": 400,
              "wires": [
                      "95db18fe3639c97c"
              "id": "95db18fe3639c97c",
              "type": "debug",
              "name": "debug wetter",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1090,
              "y": 400,
              "wires": []
              "id": "a18da81bd8de15a8",
              "type": "debug",
              "name": "debug lat u. lon",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 540,
              "y": 340,
              "wires": []
              "id": "e72556340bb92c91",
              "type": "mqtt-broker",
              "name": "Mosquitto",
              "broker": "127.0.0.1",
              "port": "1883",
              "clientid": "",
              "autoConnect": true,
              "usetls": false,
              "protocolVersion": "3",
              "keepalive": "60",
              "cleansession": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      MOD-EDIT: Code in code-tags und Spoiler gesetzt!
      Was kann ich machen das die GPS Daten von Owentracks mit der Openweathermap API verbunden werden?
      Gruß NetFritz
      • mickym
        mickym Most Active @NetFritz last edited by mickym
        @netfritz Wenn Du den Flow nicht in CodeTags packst - dann brauchst Du den nicht hier posten, weil der nicht importierbar ist.
        Aber unabhängig davon - ich nutze auch die OPenweathermap API und ich vestehe das Problem nicht. Du musst doch nur die längen und Breitengrade von in die URL beim API Aufruf einbauen.
        Meine URL wird dann mit allen benötigten Daten zusammengebaut:
        • N
          @mickym
          Hallo habe es mal mitb einem node template versucht.
          Es leuft einfach nicht richtig.
          Es wir mir in der Debug entweder nur die Daten von Owentracks angezeigt oder es kommen nan einen deploy die Wetterdaten Stücken weise an.
          Ich hoffe Du kannst mir weiterhelfen.
          Vielen Dank
          Der Flow kommt noch das Forum schreibt immer nur Fehler
          Gruß NetFritz
          N mickym 2 Replies Last reply Reply Quote 0
          • N
            NetFritz @NetFritz last edited by NetFritz
            code_text
                    "type": "tab",
                    "label": "Flow 2",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "type": "function",
                    "name": "lat",
                    "func": "var latiude = { payload: msg.payload.lat };\nmsg.payload = latiude;\nreturn msg.payload;\n",
                    "outputs": 1,
                    "noerr": 0,
                    "initialize": "",
                    "finalize": "",
                    "libs": [],
                    "x": 950,
                    "y": 140,
                    "wires": [
                            "9e2cbcddc4ed8922"
                    "type": "function",
                    "name": "lon",
                    "outputs": 1,
                    "noerr": 0,
                    "initialize": "",
                    "finalize": "",
                    "libs": [],
                    "x": 950,
                    "y": 220,
                    "wires": [
                            "4a5a62e0cbd3dceb"
                    "type": "mqtt in",
                    "name": "von Owentracks",
                    "topic": "#",
                    "qos": "2",
                    "nl": false,
                    "rap": true,
                    "rh": 0,
                    "inputs": 0,
                    "x": 740,
                    "y": 300,
                    "wires": [
                            "504c52975b40417a",
                            "68ff18aa1b5e338e",
                            "340e4f32fdfeb328"
                    "type": "debug",
                    "name": "lat",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1270,
                    "y": 140,
                    "wires": []
                    "type": "debug",
                    "name": "lon",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1270,
                    "y": 220,
                    "wires": []
                    "id": "340e4f32fdfeb328",
                    "type": "template",
                    "name": "current with lat,lon",
                    "field": "url",
                    "fieldType": "msg",
                    "format": "handlebars",
                    "syntax": "mustache",
                    "template": "https://api.openweathermap.org/data/2.5/weather?lat={{lat}}&lon={{lon}}&lang=de&appid=f9cc084b8fe86a8c1d01f5xxxxxxxx",
                    "output": "str",
                    "x": 990,
                    "y": 300,
                    "wires": [
                            "b7474f232f101d7a"
                    "id": "b7474f232f101d7a",
                    "type": "debug",
                    "name": "Request",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1280,
                    "y": 300,
                    "wires": []
                    "port": "1883",
                    "clientid": "",
                    "usetls": false,
                    "keepalive": "60",
                    "birthTopic": "",
                    "birthQos": "0",
                    "birthPayload": "",
                    "birthMsg": {},
                    "closeTopic": "",
                    "closeQos": "0",
                    "closePayload": "",
                    "closeMsg": {},
                    "willTopic": "",
                    "willQos": "0",
                    "willPayload": "",
                    "willMsg": {},
                    "userProps": "",
                    "sessionExpiry": ""
            • mickym
              @netfritz Längen und Breitengrad sind doch schon in einem Objekt enthalten. Das Schlechteste was man tun kann ist, das wieder auseinanderzureißen
              Normalerweise ist doch so ein waypoint etwas, wo beides schon enthalten ist - bei mir sieht das so aus:
                "_type": "waypoint",
                "desc": "Test",
                "lat": 52.054783,
                "lon": 9.621828,
                "rad": 100,
                "rid": "3ff5fd",
                "tst": 1651687577
              oder so ähnlich - da ist doch dann alles schon drin.
              Die msg.url dann halt in die http-request Node.
                     "type": "template",
                     "field": "url",
                     "fieldType": "msg",
                     "template": "https://api.openweathermap.org/data/2.5/weather?lat={{payload.lat}}&lon={{payload.lon}}&lang=de&appid=xxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                     "output": "str",
                     "x": 810,
                     "y": 320,
                     "wires": [
                             "b7474f232f101d7a"
                     "type": "debug",
                     "name": "Request",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "url",
                     "statusVal": "",
                     "x": 1020,
                     "y": 320,
                     "wires": []
                     "id": "408321c5104ff51e",
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "{\"_type\":\"waypoint\",\"desc\":\"Test\",\"lat\":52.054783,\"lon\":9.621828,\"rad\":100,\"rid\":\"3ff5fd\",\"tst\":1651687577}",
                     "payloadType": "json",
                     "x": 570,
                     "y": 320,
                     "wires": [
                             "340e4f32fdfeb328",
                             "b3ce2f9474d3a32a"
                     "id": "b3ce2f9474d3a32a",
                     "type": "debug",
                     "name": "Input",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 770,
                     "y": 260,
                     "wires": []
              • N
                NetFritz @mickym last edited by
                @mickym
                Hallo Danke.
                Habe deinen Flow bei mir reinkopiert.
                Habe jetzt in der Debug Ausgabe die URL von der Wetter Seite drin.
                Brauche ich jetzt noch ein HTTp-Request Baustein.
                Habe mal einen hinter dem Template Baustein eingefügt und die URL freigelassen.
                Geht so aber nicht.
                Muß da was eingestellt werden oder ein anderen Baustein?
                Gruß NetFritz
                • mickym
                  @netfritz
                  Geht aber so nicht.
                  Ist halt nicht besonders hilfreich. 😞
                  Was sagt den die HTTP Request Node - halt überall eine Debug Node dran machen und Screenshot von den aufgeklappten Ausgaben wenigstens posten. Oder hier in CodeTags - Du kannst doch überprüfen, ob dir URL die aus der Template Node rauskommt - auch im Browser was tut. Ausserdem weiß ich ja nicht, ob mein Input richtig war. Das eine ist der Flow - aber wichtig sind auch die richtigen Daten, damit man das ggf. nachvollziehen kann.
                  • N
                    @mickym
                    Die URL die im Debug erscheint habe ich im Broser eingegeben und die Ausgabe liefert die Wetterdaten.
                    Hier die Locations Daten von Owentracks:
                    Gruß NetFritz
                    code_
                    text
                    object
                    _type: "location"
                    BSSID: "44:4e:6d:22:57:c1"
                    SSID: "FRITZ22"
                    acc: 13
                    alt: 77
                    batt: 42
                    bs: 2
                    conn: "w"
                    created_at: 1665255249
                    lat: 52.5556384
                    lon: 9.1231715
                    m: 1
                    t: "u"
                    tid: "fl"
                    tst: 1665240465
                    vac: 1
                    vel: 0
                    ```Die geteste URL
                    "https://api.openweathermap.org/data/2.5/weather?lat=52.5556384&lon=9.1231715&lang=de&appid=f9cc084b8fe86a8c1d01f57b608xxxx"
                    code_text```
                    code_text
                    Der Flow
                            "id": "d001ab7a313af255",
                            "type": "tab",
                            "label": "Flow 5",
                            "disabled": false,
                            "info": "",
                            "env": []
                            "id": "82522982ba5818e6",
                            "type": "template",
                            "z": "d001ab7a313af255",
                            "field": "url",
                            "fieldType": "msg",
                            "template": "https://api.openweathermap.org/data/2.5/weather?lat={{payload.lat}}&lon={{payload.lon}}&lang=de&appid=f9cc084b8fe86a8c1d01f57b608xxxxxx",
                            "output": "str",
                            "x": 630,
                            "y": 240,
                            "wires": [
                                    "1637264f0faf5bff"
                            "id": "1ab5aafd2ecc2f34",
                            "type": "debug",
                            "name": "Request",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "url",
                            "statusVal": "",
                            "x": 1140,
                            "y": 240,
                            "wires": []
                            "id": "08d56aa9b9b8c5c9",
                            "type": "debug",
                            "name": "Input",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 590,
                            "y": 200,
                            "wires": []
                            "id": "4f5db8ab7298dbb4",
                            "type": "mqtt in",
                            "name": "",
                            "topic": "#",
                            "qos": "2",
                            "nl": false,
                            "rap": true,
                            "rh": 0,
                            "inputs": 0,
                            "x": 290,
                            "y": 240,
                            "wires": [
                                    "82522982ba5818e6",
                                    "08d56aa9b9b8c5c9"
                            "id": "1637264f0faf5bff",
                            "name": "",
                            "method": "GET",
                            "ret": "txt",
                            "paytoqs": "query",
                            "url": "",
                            "tls": "",
                            "persist": false,
                            "proxy": "",
                            "authType": "",
                            "senderr": false,
                            "headers": [],
                            "x": 930,
                            "y": 240,
                            "wires": [
                                    "1ab5aafd2ecc2f34"
                            "port": "1883",
                            "clientid": "",
                            "usetls": false,
                            "keepalive": "60",
                            "birthTopic": "",
                            "birthQos": "0",
                            "birthPayload": "",
                            "birthMsg": {},
                            "closeTopic": "",
                            "closeQos": "0",
                            "closePayload": "",
                            "closeMsg": {},
                            "willTopic": "",
                            "willQos": "0",
                            "willPayload": "",
                            "willMsg": {},
                            "userProps": "",
                            "sessionExpiry": ""
                    • mickym
                      @netfritz sagte in Mit Node-Red Openweathermap mit Standorten mit Owentracks.:
                      Schau Dir mal deine Debug Node hinter der http-request Node an. Du analysierst die msg.url und nicht die msg.payload. Außerdem solltest Du Dir ein analysiertes JSON Objekt ausgeben lassen. Ich hab die Debug Node - als msg.url genommen, da das die Eingabe für die HTTP-Request Node ist - die Ausgabe kommt aber in der payload.
                      • N
                        @mickym
                        Hallo
                        Fehler gefunden hatte im Debug Node msg.url stehen.
                        Umgeändert aus msg.playload schon zeigt er die Wetterdaten an.
                        Vielen Dank
                        1.0k
                        401
