    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
      Thomas Braun Most Active @Andersmacher last edited by
      @andersmacher
      Ja, sieht soweit gut aus.
      iobroker repo list
      iobroker update
      sagt nun?
        Andersmacher @Thomas Braun last edited by
        pi@Pi4B-8GB:~ $ iobroker repo list
        Active repo(s): stable
        pi@Pi4B-8GB:~ $ iob stop
        pi@Pi4B-8GB:~ $ iobroker update
        Used repository: stable
        Adapter    "admin"        : 6.2.22   , installed 6.2.17 [Updatable]
        Adapter    "backitup"     : 2.4.12   , installed 2.4.10 [Updatable]
        Adapter    "cul"          : 2.0.2    , installed 2.0.2
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "fhem"         : 1.6.3    , installed 1.6.3
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
        Adapter    "history"      : 2.2.0    , installed 2.2.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
        Adapter    "landroid"     : 1.0.3    , installed 1.0.3
        Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
        Adapter    "modbus"       : 5.0.5    , installed 5.0.4  [Updatable]
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "sql"          : 2.1.8    , installed 2.1.7  [Updatable]
        Adapter    "synology"     : 2.1.9    , installed 2.1.9
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "worx"         : 1.7.0    , installed 1.7.0
        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
        pi@Pi4B-8GB:~ $
        Worx habe ich gleich ´mal auf V1.7.0 angehoben, um zu sehen, ob die Verbindung nun wieder einwandfrei klappt. Die anderen noch ausstehenden Updates sind offenbar seit dem "Verschwinden" meiner Repo-Einträge aufgelaufen. Da werde ich mich morgen drum kümmern.
        Nochmals Danke!
          Lucky_ESA Developer Most Active @KSY last edited by Lucky_ESA
          @ksy Bitte mal Node auf dem aktuellen Stand bringen. Hast du bereits auf die 2.0.1 aktualisiert?
          Sorry, bin jetzt eine Woche sehr eingeschränkt und habe keinen Zugang zu meinem Server.
          Gruß//Lucky
            Semmy @Lucky_ESA last edited by Semmy
            @lucky_esa Hallo
            Die Version 1.7.0 funktionierte noch bei mir, aber ab 2.0.0 werden keine Daten mehr aktualisiert.
            Viele Grüße
            Semmy
              Lucky_ESA Developer Most Active @Semmy last edited by
              @semmy Aktuell ist die 2.0.1
              Es wäre lieb zu schreiben welche Daten nicht aktualisiert werden. Die im Ordner mower oder rawMqtt. Gibt es Fehlermedlungen im Protokoll?
              Gruß//Lucky
                @lucky_esa Auf die Schnelle ist mir nur aufgefallen, dass der batterystate im Ordner mower auf jeden Fall nicht aktualisiert wurde.
                  Lucky_ESA Developer Most Active last edited by
                  Bedenke das ab Firmware 3.28 leider nicht mehr alle 10 Minuten Daten kommen und so kann es passieren, dass sich 8 Stunden lang die Daten nicht aktualisieren.
                  Gruß//Lucky
                    @lucky_esa Ich habe 3.28 installiert. Adapter Version 1.7.0 funktioniert tadellos, Datepunkte werden aktualisiert, jedoch nicht ab der Version 2.0.0 aufwärts.
                      Bitte die 2.0.1 verwenden. Wenn du der Meinung bist das danach die Daten nicht aktualisiert werden, dann bitte unter Instanz bei Worx debug auswählen und das Protokoll bei restart beobachten.
                        @lucky_esa Bei Version 1.7.0 ist es so, wenn ich die App auf den Smartphone aktualisiere, werden auch die Datenpunkte vom Adapter aktualisiert. Das ist bei Version 2.0.1 nicht mehr der Fall. Auch wurden heute die Zeiten nicht gesetzt mit 2.0.1. Bin jetzt wieder auf 1.7.0
                          tombox @Semmy last edited by
                          @semmy 2.0.1 aktualisiert auch den Status wenn in der app Aktualisierung angefordert wird. Kannst du sehen wenn der Adapter im log level debug läuft. Der batterystate ist unter dem Punkt p: sichtbar
                            Semmy @tombox last edited by
                            @tombox Wenn ich die App aktualisiere, wird im log mit Version 2.0.1 MQTT reconnect angezeigt, mehr nicht. debug ist aktiviert
                              @semmy sagte in Adapter: Worx Landroid v2.x.x:
                              Mit welcher Node Version bist du unterwegs? Was zeigt das Log beim start/restart der APP?
                                @lucky_esa ``` Node ist v16.17.1
                                  @semmy Ok kannst den log wieder löschen. Ist ein kress und er kann keine mqtt Verbindung aufbauen ich schau nochmal rein
                                    @semmy Kannst mal die GitHub testen ob sie mit kress und mqtt funktioniert
                                      @tombox Immer noch keine Änderung, funktioniert noch nicht.
                                        Semmy @Semmy last edited by
                                        @semmy Habe gerade noch mal die Neueste von github installiert und nun funktioniert es auch wieder. Vielen Dank.
                                          @semmy habe mal eine Frage. Hast du ein Modul installiert was du mit der APP einstellen kannst aber nicht mit iobroker?
                                            @lucky_esa Ich habe ein Marconi Modul und ein NoGo Modul eingebaut. Das Marconi kann ich weder in der App noch im Iobroker einstellen, ist auch nicht nötig.
                                            1194
                                            454961
