    4. iobroker kaputt nach NodeJS Update
      michaelheiml @Thomas Braun last edited by
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh /tmp/install-d8eb892e.sh
      npm ERR! node:internal/modules/cjs/loader:372
      npm ERR!       throw err;
      npm ERR!       ^
      npm ERR!
      npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/jsonwebtoken/index.js'. Please verify that the package.json has a valid "main" entry
      npm ERR!     at tryPackage (node:internal/modules/cjs/loader:364:19)
      npm ERR!     at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
      npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
      npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:10:13)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
      npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32) {
      npm ERR!   code: 'MODULE_NOT_FOUND',
      npm ERR!   path: '/opt/iobroker/node_modules/jsonwebtoken/package.json',
      npm ERR!   requestPath: 'jsonwebtoken'
      npm ERR! }
      npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T19_34_15_220Z-debug-0.log
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Thomas Braun Most Active @michaelheiml last edited by
        @michaelheiml
        cat /opt/iobroker/node_modules/jsonwebtoken/index.js
          cat: /opt/iobroker/node_modules/jsonwebtoken/index.js: Datei oder Verzeichnis nicht gefunden
            @michaelheiml
            iob fix
            sagt?
                  Installing prerequisites (1/3)
              OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              OK:2 https://downloads.plex.tv/repo/deb public InRelease
              OK:3 https://linux.teamviewer.com/deb stable InRelease
              OK:4 http://archive.raspberrypi.org/debian buster InRelease
              OK:5 https://deb.nodesource.com/node_16.x buster InRelease
              Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/3)
              Created /etc/sudoers.d/iobroker
              Fixing directory permissions...
                  Checking autostart (3/3)
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
                @michaelheiml
                iob status
                iob setup first
                  node:internal/modules/cjs/loader:959
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      at node:internal/main/run_main_module:17:47 {
                    requireStack: []
                  M Thomas Braun 2 Replies Last reply Reply Quote 0
                    michaelheiml @michaelheiml last edited by
                    @michaelheiml
                    Im Ordner /opt/iobroker/node_modules/iobroker.js-controller/ gibt es auch keine iobroker.js
                    Diese Dateien schon:
                    iob.bat
                    iobroker.bat
                    LICENSE
                    _service_iobroker.bat
                    -> .bat? Windows? Ist es normal, dass es diese Dateien unter raspbian auch gibt?
                      @michaelheiml
                      Bitte vollständige Eingabezeile mitposten. Ich weiß jetzt nicht auf welches Kommando das die Ausgabe ist.
                        michaelheiml @Thomas Braun last edited by michaelheiml
                        Auf beide dieselbe Ausgabe:
                        iob status
                        iob setup first
                          throw err;
                          requireStack: []
                          @michaelheiml
                          Unabhängig voneinander eingeben, nicht in einem Rutsch...
                          Btw:
                          echad@chet:/opt/iobroker $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/
                          total 392
                          drwxrwxr-x+   7 iobroker iobroker   4096 Oct  9 11:54 .
                          drwxrwxr-x+ 704 iobroker iobroker  36864 Oct 10 17:13 ..
                          drwxrwxr-x+   2 iobroker iobroker   4096 Jul 30 03:42 backups
                          -rw-rwxr--+   1 iobroker iobroker    420 Jul 29 20:20 compactgroupController.js
                          drwxrwxr-x+   2 iobroker iobroker   4096 Jul 29 20:20 conf
                          -rw-rwxr--+   1 iobroker iobroker    158 Jul 29 20:20 controller.js
                          -rwxrwxr-x+   1 iobroker iobroker     34 Jul 29 20:20 iobroker.js
                          -rw-rwxr--+   1 iobroker iobroker  54395 Jul 29 20:20 io-package.json
                          drwxrwxr-x+   9 iobroker iobroker   4096 Jul 29 20:20 lib
                          -rw-rwxr--+   1 iobroker iobroker   1135 Jul 29 20:20 LICENSE
                          -rw-rwxr--+   1 iobroker iobroker 249293 Jul 29 20:20 main.js
                          drwxrwxr-x+   5 iobroker iobroker   4096 Jul 29 20:20 node_modules
                          -rw-rwxr--+   1 iobroker iobroker   3277 Jul 29 20:20 package.json
                          -rw-rw-r--+   1 iobroker iobroker    177 Oct 10 17:14 pids.txt
                          -rw-rwxr--+   1 iobroker iobroker    193 Jul 29 20:20 README.md
                          drwxrwxr-x+   2 iobroker iobroker   4096 Oct 10 03:42 tmp
                            pi@raspberrypi:/opt/iobroker $ iob status
                              throw err;
                              requireStack: []
                            pi@raspberrypi:/opt/iobroker $ iob setup first
                              throw err;
                              requireStack: []
                              Der Ordner sieht bei mir gänzlich anders aus. Keine .js Dateien. Kann es sein, dass durch irgendeinen Fehler von mir ich die Windows Version von iobroker installiert habe?
                                @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
                                Kann ich dir nicht sagen. Ich weiß ja nicht was du da veranstaltet hast.
                                  Wie sieht der denn aus?
                                    Offenbar einen Quark 😉
                                    Na jedenfalls.. das ist mein Ordner Inhalt:
                                    iob.bat
                                    iobroker.bat
                                    lib
                                    LICENSE
                                    node_modules
                                    Mehr nicht.
                                    Thomas Braun M 2 Replies Last reply Reply Quote 0
                                      @michaelheiml
                                      Kopier dir doch den Befehl den ich auch verwendet habe. Dann reden wir über das gleiche.
                                        @michaelheiml
                                        Zum Installieren habe ich jedenfalls den Befehl aus der Anleitung verwendet.
                                        curl -sLf https://iobroker.net/install.sh | bash -
                                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.js-controller $ ls -la /opt/iobroker/node_modules/iobroker.js-controller/
                                        insgesamt 96
                                        drwxrwxrwx+   4 iobroker iobroker  4096 Okt 10 18:14 .
                                        drwxrwxrwx+ 394 iobroker iobroker 69632 Okt 10 21:37 ..
                                        -rw-rwxrw-+   1 iobroker iobroker    41 Okt 10 18:14 iob.bat
                                        -rw-rwxrw-+   1 iobroker iobroker     0 Okt 10 18:14 iobroker.bat
                                        drwxrwxrwx+   2 iobroker iobroker  4096 Okt 10 18:14 lib
                                        -rw-rwxrw-+   1 iobroker iobroker  1135 Okt 10 18:14 LICENSE
                                        drwxrwxrwx+   5 iobroker iobroker  4096 Okt 10 18:14 node_modules
                                        -rw-rwxrw-+   1 iobroker iobroker   144 Okt 10 18:14 _service_iobroker.bat
                                          Und wie läuft der Installer?
                                            Hab die Command History durchgesehen.. deutet nichts in Richtung Windows iobroker Installation.
                                            Output Install.sh:
                                            pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                                            library: loaded
                                            Library version=2022-06-15
                                                Welcome to the ioBroker installer!
                                                Installer version: 2022-06-03
                                                You might need to enter your password a couple of times.
                                                Installing prerequisites (1/4)
                                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                            OK:3 https://downloads.plex.tv/repo/deb public InRelease
                                            OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                                            OK:5 https://linux.teamviewer.com/deb stable InRelease
                                            Changing npm registry to https://registry.npmjs.org
                                            Installed gcc-c++
                                                Creating ioBroker user and directory (2/4)
                                            Directory /opt/iobroker created
                                                Installing ioBroker (3/4)
                                            npm ERR! code 1
                                            npm ERR! command sh /tmp/install-f3ce3c9e.sh
                                            npm ERR!       throw err;
                                            npm ERR!       ^
                                            npm ERR!
                                            npm ERR! }
                                            npm ERR!     /home/pi/.npm/_logs/2022-10-10T20_14_34_985Z-debug-0.log
                                                Finalizing installation (4/4)
                                            Autostart enabled!
                                                ioBroker was installed successfully
                                                Open http://192.168.1.254:8081 in a browser and start configuring!
                                            You need to re-login before doing anything else on the console!
                                            3764
