    4. iobroker kaputt nach NodeJS Update
      michaelheiml @Thomas Braun last edited by
      Hab die Command History durchgesehen.. deutet nichts in Richtung Windows iobroker Installation.
      Output Install.sh:
      pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2022-06-15
          Welcome to the ioBroker installer!
          Installer version: 2022-06-03
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://downloads.plex.tv/repo/deb public InRelease
      OK:4 https://deb.nodesource.com/node_16.x buster InRelease
      OK:5 https://linux.teamviewer.com/deb stable InRelease
      Changing npm registry to https://registry.npmjs.org
      Installed gcc-c++
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh /tmp/install-f3ce3c9e.sh
      npm ERR! node:internal/modules/cjs/loader:372
      npm ERR!       throw err;
      npm ERR!       ^
      npm ERR!
      npm ERR! Error: Cannot find module '/opt/iobroker/node_modules/jsonwebtoken/index.js'. Please verify that the package.json has a valid "main" entry
      npm ERR!     at tryPackage (node:internal/modules/cjs/loader:364:19)
      npm ERR!     at Function.Module._findPath (node:internal/modules/cjs/loader:577:18)
      npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1028:19)
      npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
      npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:10:13)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1126:14)
      npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1004:32) {
      npm ERR!   code: 'MODULE_NOT_FOUND',
      npm ERR!   path: '/opt/iobroker/node_modules/jsonwebtoken/package.json',
      npm ERR!   requestPath: 'jsonwebtoken'
      npm ERR! }
      npm ERR!     /home/pi/.npm/_logs/2022-10-10T20_14_34_985Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
      Fixing directory permissions...
          ioBroker was installed successfully
          Open http://192.168.1.254:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
        Thomas Braun Most Active @michaelheiml last edited by
        @michaelheiml
        ls -lA / | grep tmp
          @thomas-braun said in iobroker kaputt nach NodeJS Update:
          ls -lA / | grep tmp
          pi@raspberrypi:~ $ ls -lA / | grep tmp
          drwxrwxrwt  19 root root  4096 Okt 10 22:17 tmp
            @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
            ls -lA /tmp/
              pi@raspberrypi:~ $ ls -lA /tmp/
              insgesamt 72
              drwx------ 2 pi   pi   4096 Okt 10 18:21 dhcpcd-pi
              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .font-unix
              srw------- 1 pi   pi      0 Okt 10 22:03 geany_socket.c2929e62
              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .ICE-unix
              drwxr-xr-x 2 plex plex 4096 Okt 10 18:21 pms-783b7fb9-1920-49f3-b817-a0f35a1c9c16
              drwx------ 2 root root 4096 Okt 10 18:20 pulse-PKdhtXMmr18n
              drwx------ 2 pi   pi   4096 Okt 10 18:21 ssh-KmHKgJxQRO9T
              drwx------ 2 pi   pi   4096 Okt 10 18:21 ssh-q5LDIGBGNjQc
              drwx------ 3 root root 4096 Okt 10 18:20 systemd-private-d0c16273df82407fb538677a9af079b6-colord.service-GtnKyq
              drwx------ 3 root root 4096 Okt 10 18:21 systemd-private-d0c16273df82407fb538677a9af079b6-rtkit-daemon.service-5ugbb2
              drwx------ 3 root root 4096 Okt 10 18:20 systemd-private-d0c16273df82407fb538677a9af079b6-systemd-timesyncd.service-u0sQmX
              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .Test-unix
              drwx------ 3 root root 4096 Okt 10 21:17 .vnc-0
              drwx------ 3 pi   pi   4096 Okt 10 18:21 .vnc-1000
              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .vncserver-license
              drwx------ 2 root root 4096 Okt 10 18:20 .vnc-vncservice
              -r--r--r-- 1 root root   11 Okt 10 18:20 .X0-lock
              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .X11-unix
              drwxrwxrwt 2 root root 4096 Okt 10 18:20 .XIM-unix
                @michaelheiml
                Keine Ahnung. Sind mir auch zu viele Dateien mit X drin.
                  Was müsste ich denn löschen, um die aktuelle Installation los zu werden? /opt/iobroker /* ?
                  Und wenn ich iobroker_data gesichert habe und zurückspiele nach einer Neuinstallation, würde ich dann meine vorherige Konfiguration wieder haben? Oder ist das zu kurz gegriffen?
                    @michaelheiml
                    Ich würde mal
                    rm -rf /opt/iobroker/
                    versuchen.
                    Möglich. Besser ist aber ein Backup via Backitup.
                    • JLeg
                      JLeg last edited by
                      @michaelheiml
                      bevor du alles löschst, würde ich nochmal die „Rosskur“ versuchen - hat bei mir prima funktioniert:
                      cd /opt/iobroker
                      mv node_modules node_modules.old
                      mv package-lock.json package-lock.json.old
                      npm cache clean --force
                      npm install
                      npm list
                        An diesem Thread hast du mitgeschrieben:
                        https://forum.iobroker.net/topic/55683/kein-update-mehr-möglich-mit-node-js-16/303
                        Ich bin gerade per Google darauf gestoßen, weil mir
                        npm ls
                        ausspuckt:
                        ├── iobroker.backitup@ invalid: "stable" from the root project
                        Vielleicht ein Hinweis, wo es hakt?
                          Thomas Braun Most Active @michaelheiml last edited by Thomas Braun
                          @michaelheiml
                          Das bezieht sich auf die package.json
                          cat /opt/iobroker/package.json | jq
                          Da steht allerdings gemeinhin nicht stable sondern eine Versionsnummer für die Module drin.
                            "name": "iobroker.inst",
                            "version": "3.0.0",
                            "private": true,
                            "description": "Automate your Life",
                            "engines": {
                            "node": ">=10.0.0"
                            "dependencies": {
                            "iobroker.js-controller": "stable",
                            "iobroker.admin": "stable",
                            "iobroker.discovery": "stable",
                            "iobroker.backitup": "stable"
                              @michaelheiml
                              Das dürfte vom ersten setup noch drin sein. Der Installer schaut nach den als 'stable' getaggten Versionen, später wird das mit den Versionsnummern überschrieben.
                              iobroker repo list
                              sagt noch was?
                                michaelheiml @JLeg last edited by
                                @jleg
                                Fertig:
                                pi@raspberrypi:/opt/iobroker $ mv node_modules node_modules.old
                                pi@raspberrypi:/opt/iobroker $ mv package-lock.json package-lock.json.old
                                pi@raspberrypi:/opt/iobroker $ npm cache clean --force
                                npm WARN using --force Recommended protections disabled.
                                pi@raspberrypi:/opt/iobroker $ npm install
                                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                added 516 packages in 7m
                                38 packages are looking for funding
                                  run `npm fund` for details
                                pi@raspberrypi:/opt/iobroker $ npm list
                                iobroker.inst@3.0.0 /opt/iobroker
                                ├── iobroker.admin@6.2.22 invalid: "stable" from the root project
                                ├── iobroker.backitup@2.4.12 invalid: "stable" from the root project
                                ├── iobroker.discovery@3.0.3 invalid: "stable" from the root project
                                ├── iobroker.flot@1.11.0
                                └── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
                                npm ERR! code ELSPROBLEMS
                                npm ERR! invalid: iobroker.admin@6.2.22 /opt/iobroker/node_modules/iobroker.admin
                                npm ERR! invalid: iobroker.backitup@2.4.12 /opt/iobroker/node_modules/iobroker.backitup
                                npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
                                npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
                                npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_50_38_406Z-debug-0.log
                                mikeal created this issue in request/request
                                open Request’s Past, Present and Future #3142
                                  michaelheiml @Thomas Braun last edited by michaelheiml
                                  pi@raspberrypi:/opt/iobroker $ iobroker repo list
                                  Active repo(s): stable
                                  M Thomas Braun 2 Replies Last reply Reply Quote 0
                                    michaelheiml @michaelheiml last edited by
                                    @michaelheiml
                                    Hab wie im anderen Thread nach
                                    npm install
                                    noch
                                    npm prune
                                    ausgeführt, mit dem Ergebnis
                                    npm ERR! code ENOTEMPTY
                                    npm ERR! syscall rename
                                    npm ERR! path /opt/iobroker/node_modules/iobroker.admin
                                    npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_52_25_777Z-debug-0.log
                                      @michaelheiml
                                      Ergänz die Rosskur noch um die package.json
                                      cd /opt/iobroker
                                      mv package.json package.json.old
                                      npm install
                                      npm list
                                        Das BackItUp Backup sollte ich danach wieder einspielen können, wenn ich den BackItUp Adapter installiere?
                                          @michaelheiml
                                          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                            Ausgeführt, und jetzt? (Das ist der Befehl zum Löschen der versteckten Ordner, nicht?)
                                            ├── bower@1.8.14 extraneous
                                            ├── iobroker.habpanel@0.5.0 extraneous
                                            ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
                                            ├── iobroker.upnp@1.0.19
                                            └── iobroker.vis@1.4.15
                                            npm ERR! extraneous: bower@1.8.14 /opt/iobroker/node_modules/bower
                                            npm ERR! extraneous: iobroker.habpanel@0.5.0 /opt/iobroker/node_modules/iobroker.habpanel
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_57_41_547Z-debug-0.log
                                            Thomas Braun M 2 Replies Last reply Reply Quote 0
                                            3798
