    4. iobroker kaputt nach NodeJS Update
      Thomas Braun Most Active @michaelheiml last edited by Thomas Braun
      @michaelheiml
      Das bezieht sich auf die package.json
      cat /opt/iobroker/package.json | jq
      Da steht allerdings gemeinhin nicht stable sondern eine Versionsnummer für die Module drin.
        michaelheiml @Thomas Braun last edited by
        "name": "iobroker.inst",
        "version": "3.0.0",
        "private": true,
        "description": "Automate your Life",
        "engines": {
        "node": ">=10.0.0"
        "dependencies": {
        "iobroker.js-controller": "stable",
        "iobroker.admin": "stable",
        "iobroker.discovery": "stable",
        "iobroker.backitup": "stable"
          @michaelheiml
          Das dürfte vom ersten setup noch drin sein. Der Installer schaut nach den als 'stable' getaggten Versionen, später wird das mit den Versionsnummern überschrieben.
          iobroker repo list
          sagt noch was?
            michaelheiml @JLeg last edited by
            @jleg
            Fertig:
            pi@raspberrypi:/opt/iobroker $ mv node_modules node_modules.old
            pi@raspberrypi:/opt/iobroker $ mv package-lock.json package-lock.json.old
            pi@raspberrypi:/opt/iobroker $ npm cache clean --force
            npm WARN using --force Recommended protections disabled.
            pi@raspberrypi:/opt/iobroker $ npm install
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            added 516 packages in 7m
            38 packages are looking for funding
              run `npm fund` for details
            pi@raspberrypi:/opt/iobroker $ npm list
            iobroker.inst@3.0.0 /opt/iobroker
            ├── iobroker.admin@6.2.22 invalid: "stable" from the root project
            ├── iobroker.backitup@2.4.12 invalid: "stable" from the root project
            ├── iobroker.discovery@3.0.3 invalid: "stable" from the root project
            ├── iobroker.flot@1.11.0
            └── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
            npm ERR! code ELSPROBLEMS
            npm ERR! invalid: iobroker.admin@6.2.22 /opt/iobroker/node_modules/iobroker.admin
            npm ERR! invalid: iobroker.backitup@2.4.12 /opt/iobroker/node_modules/iobroker.backitup
            npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
            npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_50_38_406Z-debug-0.log
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
              michaelheiml @Thomas Braun last edited by michaelheiml
              pi@raspberrypi:/opt/iobroker $ iobroker repo list
              Active repo(s): stable
              M Thomas Braun 2 Replies Last reply Reply Quote 0
                michaelheiml @michaelheiml last edited by
                @michaelheiml
                Hab wie im anderen Thread nach
                npm install
                noch
                npm prune
                ausgeführt, mit dem Ergebnis
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/iobroker.admin
                npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_52_25_777Z-debug-0.log
                  @michaelheiml
                  Ergänz die Rosskur noch um die package.json
                  cd /opt/iobroker
                  mv package.json package.json.old
                  npm install
                  npm list
                    rm -rf /opt/iobroker/
                    Das BackItUp Backup sollte ich danach wieder einspielen können, wenn ich den BackItUp Adapter installiere?
                      @michaelheiml
                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                        Ausgeführt, und jetzt? (Das ist der Befehl zum Löschen der versteckten Ordner, nicht?)
                        ├── bower@1.8.14 extraneous
                        ├── iobroker.habpanel@0.5.0 extraneous
                        ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
                        ├── iobroker.upnp@1.0.19
                        └── iobroker.vis@1.4.15
                        npm ERR! extraneous: bower@1.8.14 /opt/iobroker/node_modules/bower
                        npm ERR! extraneous: iobroker.habpanel@0.5.0 /opt/iobroker/node_modules/iobroker.habpanel
                        npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_57_41_547Z-debug-0.log
                        Thomas Braun M 2 Replies Last reply Reply Quote 0
                          @michaelheiml
                          Hast du die package.json umbenannt?
                            @michaelheiml
                            Oh, ich komme wieder auf die Webseite. Muss ich das verstehen?
                            Ja, vis, upnp, flot und habpanel hatte ich installiert (dachte gerade, wenn die jetzt gelistet sind, wird iobroker versuchen, meine Module wiederherzustellen -> daher Zugriffsversuch auf die Seite)
                              Nein. Aber es steht jetzt mehr drin.
                              Ich versteh nicht, was hier passiert gerade.
                              http://192.168.1.254:8081/#tab-adapters ist wieder erreichbar, aber es sind nur 4 meiner früheren Adapter sichtbar.
                                @michaelheiml
                                iobroker update
                                  @thomas-braun said in iobroker kaputt nach NodeJS Update:
                                  iobroker update
                                  pi@raspberrypi:/opt/iobroker $ iobroker update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                  Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
                                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                  Adapter    "upnp"         : 1.0.21   , installed 1.0.19 [Updatable]
                                  Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                    @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
                                    Hau dein Backup rein.
                                      Moment, da muss ich jetzt nur noch rausfinden, wie das geht, mach ich zum ersten Mal.
                                      Ok, läuft..
                                        Schlägt fehl.
                                        [ERROR] [iobroker] host.raspberrypi Cannot extract from file "/opt/iobroker/backups/iobroker_2022_10_10-02_00_10_backupiobroker.tar.gz": ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.js-controller/tmp'
                                        Außerdem versucht iobroker jetzt, alle Adapter nachzuinstallieren, aber wieder mit den Fehlermeldungen dass das nicht geht (da war ich heute auch schon mal):
                                        iobroker npm-install: host.raspberrypi Cannot install iobroker.weatherunderground@3.4.2: 217
                                        Fehler 217 erscheint bei jedem Modul
                                        iobroker npm-install: exit 25
                                        zumindest sind meine gesamten Instanzen und Objekte wieder da, trotz des Log Eintrag Fehlers von BackItUp
                                          @michaelheiml
                                          again...
                                            Gemacht, und dann? iob stop und iob start zum Neustarten?
                                            3765
