    4. iobroker kaputt nach NodeJS Update
      Thomas Braun Most Active @michaelheiml last edited by
      @michaelheiml
      Ergänz die Rosskur noch um die package.json
      cd /opt/iobroker
      mv node_modules node_modules.old
      mv package.json package.json.old
      mv package-lock.json package-lock.json.old
      npm cache clean --force
      npm install
      npm list
        michaelheiml @Thomas Braun last edited by michaelheiml
        rm -rf /opt/iobroker/
        Das BackItUp Backup sollte ich danach wieder einspielen können, wenn ich den BackItUp Adapter installiere?
          Thomas Braun Most Active @michaelheiml last edited by Thomas Braun
          @michaelheiml
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
            Ausgeführt, und jetzt? (Das ist der Befehl zum Löschen der versteckten Ordner, nicht?)
            pi@raspberrypi:/opt/iobroker $ npm list
            iobroker.inst@3.0.0 /opt/iobroker
            ├── bower@1.8.14 extraneous
            ├── iobroker.admin@6.2.22 invalid: "stable" from the root project
            ├── iobroker.backitup@2.4.12 invalid: "stable" from the root project
            ├── iobroker.discovery@3.0.3 invalid: "stable" from the root project
            ├── iobroker.flot@1.11.0
            ├── iobroker.habpanel@0.5.0 extraneous
            ├── iobroker.js-controller@4.0.23 invalid: "stable" from the root project
            ├── iobroker.upnp@1.0.19
            └── iobroker.vis@1.4.15
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: bower@1.8.14 /opt/iobroker/node_modules/bower
            npm ERR! invalid: iobroker.admin@6.2.22 /opt/iobroker/node_modules/iobroker.admin
            npm ERR! invalid: iobroker.backitup@2.4.12 /opt/iobroker/node_modules/iobroker.backitup
            npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
            npm ERR! extraneous: iobroker.habpanel@0.5.0 /opt/iobroker/node_modules/iobroker.habpanel
            npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR!     /home/iobroker/.npm/_logs/2022-10-10T20_57_41_547Z-debug-0.log
            Thomas Braun M 2 Replies Last reply Reply Quote 0
              @michaelheiml
              Hast du die package.json umbenannt?
                michaelheiml @michaelheiml last edited by
                @michaelheiml
                Oh, ich komme wieder auf die Webseite. Muss ich das verstehen?
                Ja, vis, upnp, flot und habpanel hatte ich installiert (dachte gerade, wenn die jetzt gelistet sind, wird iobroker versuchen, meine Module wiederherzustellen -> daher Zugriffsversuch auf die Seite)
                  Nein. Aber es steht jetzt mehr drin.
                  Ich versteh nicht, was hier passiert gerade.
                  http://192.168.1.254:8081/#tab-adapters ist wieder erreichbar, aber es sind nur 4 meiner früheren Adapter sichtbar.
                    @michaelheiml
                    iobroker update
                      @thomas-braun said in iobroker kaputt nach NodeJS Update:
                      iobroker update
                      pi@raspberrypi:/opt/iobroker $ iobroker update
                      Used repository: stable
                      Adapter    "admin"        : 6.2.22   , installed 6.2.22
                      Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                      Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
                      Adapter    "flot"         : 1.11.0   , installed 1.11.0
                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                      Adapter    "upnp"         : 1.0.21   , installed 1.0.19 [Updatable]
                      Adapter    "vis"          : 1.4.15   , installed 1.4.15
                        @michaelheiml sagte in iobroker kaputt nach NodeJS Update:
                        Hau dein Backup rein.
                          Moment, da muss ich jetzt nur noch rausfinden, wie das geht, mach ich zum ersten Mal.
                          Ok, läuft..
                            Schlägt fehl.
                            [ERROR] [iobroker] host.raspberrypi Cannot extract from file "/opt/iobroker/backups/iobroker_2022_10_10-02_00_10_backupiobroker.tar.gz": ENOENT: Cannot cd into '/opt/iobroker/node_modules/iobroker.js-controller/tmp'
                            Außerdem versucht iobroker jetzt, alle Adapter nachzuinstallieren, aber wieder mit den Fehlermeldungen dass das nicht geht (da war ich heute auch schon mal):
                            iobroker npm-install: host.raspberrypi Cannot install iobroker.weatherunderground@3.4.2: 217
                            Fehler 217 erscheint bei jedem Modul
                            iobroker npm-install: exit 25
                            zumindest sind meine gesamten Instanzen und Objekte wieder da, trotz des Log Eintrag Fehlers von BackItUp
                              @michaelheiml
                              again...
                                Gemacht, und dann? iob stop und iob start zum Neustarten?
                                  @michaelheiml
                                  Läuft das Backup noch im Hintergrund?
                                    Wie sehe ich das? (Ob das Backup im Hintergrund noch läuft)
                                    Im Übrigen, nach iob stop hätte ich jetzt eben iob update eingegeben, mit dem Ergebnis
                                    pi@raspberrypi:/opt/iobroker $ iob stop
                                    pi@raspberrypi:/opt/iobroker $ iob update
                                    node:internal/modules/cjs/loader:959
                                      throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                        at node:internal/main/run_main_module:17:47 {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: []
                                    iob start -> startet aber iobroker wieder..
                                      Wie sehe ich das?
                                      Nach iob stop gar nicht mehr, das hast du weggeknallt, wenn es denn noch lief.
                                      Im Log File sieht man, ob da noch was läuft.
                                      iobroker logs --watch
                                      in einem zweiten Terminal mitlaufen lassen.
                                        ok.. nevermind. iob start startet den Webservice jetzt auch nicht mehr neu. Keine Ahnung was da schief läuft.
                                          pi@raspberrypi:/opt/iobroker $ iobroker logs --watch
                                            throw err;
                                            requireStack: []
                                            @michaelheiml
                                            Ich bin jetzt weg.
                                            Installier es neu, das wird vermutlich nix gescheites mehr geben.
                                            M 3 Replies Last reply Reply Quote 0
                                            3764
