    4. [Frage] Xiaomi Vacuum cleaner
    • N
      NeoGoku last edited by
      Wie ich vorgegangen bin:
      1. Skript von Mistertr bei Skripte > Common mit dem Datennamen "robby" erstellt und gestartet. Der log dazu
      ! 20:06:24.714 [info] javascript.0 Start javascript script.js.common.robby
      ! 20:06:24.716 [info] javascript.0 script.js.common.robby: registered 2 subscriptions and 0 schedules 2. Bei Instanzen > Cloud.0 > Konfiguration > Smart Geräte > die datei aus dem datenpfad javascript.0/robby_byalexa ausgewählt und dieser den namen "robby" gegeben.
      der normale log aus dem reiter
      ! cloud.0 2017-07-07 20:16:12.064 info Request devices
      ! cloud.0 2017-07-07 20:16:12.052 info Request devices
      ! mihome-vacuum.0 2017-07-07 20:16:06.169 info Connected
      ! cloud.0 2017-07-07 20:16:02.708 info Connection changed: CONNECTED4
      ! cloud.0 2017-07-07 20:16:02.456 info Connection changed: CONNECTED2
      ! cloud.0 2017-07-07 20:15:54.873 info 2017-07-07T18:15:54.873Z Connected system.user.admin
      ! mihome-vacuum.0 2017-07-07 20:15:49.040 info Disconnect
      ! cloud.0 2017-07-07 20:15:44.860 info Connection changed: DISCONNECTED1
      ! cloud.0 2017-07-07 20:15:44.858 info Connection changed: DISCONNECTED3
      ! cloud.0 2017-07-07 20:15:44.854 error Ping timeout
      ! javascript.0 2017-07-07 20:11:26.392 info script.js.common.robby: 10
      ! cloud.0 2017-07-07 20:11:23.905 info Request devices
      ! cloud.0 2017-07-07 20:11:23.873 info Request devices
      ! javascript.0 2017-07-07 20:10:06.227 info script.js.common.robby: 5
      ! javascript.0 2017-07-07 20:09:56.072 info script.js.common.robby: 10
      ! javascript.0 2017-07-07 20:09:54.899 info script.js.common.robby: 2
      ! mihome-vacuum.0 2017-07-07 20:09:26.192 info Connected
      ! mihome-vacuum.0 2017-07-07 20:09:25.913 info Expretmode disabled, states deleded
      ! mihome-vacuum.0 2017-07-07 20:09:25.859 info starting. Version 0.5.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v0.10.29
      ! host.Alexa-pi 2017-07-07 20:09:22.745 info instance system.adapter.mihome-vacuum.0 started with pid 1043
      ! host.Alexa-pi 2017-07-07 20:09:20.348 info instance system.adapter.mihome-vacuum.0 terminated with code 0 (OK)
      ! mihome-vacuum.0 2017-07-07 20:09:20.276 info terminating
      ! host.Alexa-pi 2017-07-07 20:09:20.219 info stopInstance system.adapter.mihome-vacuum.0 killing pid 1005
      ! host.Alexa-pi 2017-07-07 20:09:20.217 info stopInstance system.adapter.mihome-vacuum.0
      ! host.Alexa-pi 2017-07-07 20:09:20.211 info object change system.adapter.mihome-vacuum.0
      ! cloud.0 2017-07-07 20:09:03.088 info Request devices
      ! cloud.0 2017-07-07 20:09:03.079 info Request devices
      ! cloud.0 2017-07-07 20:08:47.481 info Request devices
      ! cloud.0 2017-07-07 20:08:37.369 info Request devices
      ! cloud.0 2017-07-07 20:08:26.008 info Request devices
      ! cloud.0 2017-07-07 20:08:25.999 info Request devices
      ! javascript.0 2017-07-07 20:06:24.699 info script.js.common.robby: registered 2 subscriptions and 0 schedules
      ! javascript.0 2017-07-07 20:06:24.554 info Start javascript script.js.common.robby ich habe alles nochmal neu aufgesetzt, jetzt sagt er mir das er robby nicht finden kann
      • Meistertr
        Schreibe mal robbie und nicht robby im cloud Adapter dann findet er den auch. Oder Staubsauger oder so. Ansonsten sieht das alles richtig aus
        Gesendet von meinem Handy
        • N
          Hab die datei in der cloud jetzt staubsauger genannt, jetzt sagt er mir "ich habe staubsauger nicht gefunden"…
          • Meistertr
            @NeoGoku:
            Hab die datei in der cloud jetzt staubsauger genannt, jetzt sagt er mir "ich habe staubsauger nicht gefunden"… `
            Hast du die Geräte in der Alexa app aktualisiert? Und werden sie dort angezeigt?
            • N
              Er wird und wurde noch nie in der Alexa App angezeigt
              ausschnitt vom log "cloud.0 2017-07-07 22:19:29.310 info Request devices" was bedeutet das
              • MathiasJ
                MathiasJ last edited by
                Nun ich suche jetzt jeden Tag eine neue Firmware für meinen Saugi.
                Die App sagt mir jedesmal, die 3.36 sei die letzte, obwohl hier von der 3.39 gesprochen wird.
                Update bei mir jedenfalls nicht möglich.
                Gruß,
                Mathias
                Gesendet von meinem SM-N915FY mit Tapatalk
                • N
                  ok, ich habe zwar keine ahnung woran es lag, aber ich habe das Problem gelöst bekommen.
                  Ich habe die cloud geupdatet, den iobroker skill in alexa nochmal neu aktiviert und das skript nochmal neu eingefügt, und jetzt gehts. und der vacuum wird auch bei alexa unter geräte angezeigt.
                  Jetzt ist meine hoffentlich letzte frage aber noch, kann ich denn vacuum auch per befehl zum dock schicken?
                  • Meistertr
                    @NeoGoku:
                    Jetzt ist meine hoffentlich letzte frage aber noch, kann ich denn vacuum auch per befehl zum dock schicken? `
                    Was meinst du mit nach hause schicken? In welchen Fall? Wenn du bei alexa sagst Sauger aus, fährt er Heim. Ansonsten musst du über Iobroker erst Pause und dann heim schicken oder den state bei js schalten dann fährt er auch heim
                    • N
                      Ich habe den Command aus nur auf Pause beschränken. Ich will mit einem separaten Command "Staubsauger dock" zB ihn zum Dock fahren lassen.
                      • Meistertr
                        Du kannst auch den Button Home in den cloud Adapter eingeben dann musst du ihn aber anders nennen zum Beispiel robbie nach Hause an
                          darkbrain85 last edited by
                          Hi!
                          Da der Hermes Kurier gestern wieder vollkommen versagt hat, ist mein Sauger wieder im Verteilzentrum. Damit ich zu mindestens meine View fertig machen kann, kann mir jemand Beispieldaten aus
                          mihome-vacuum.0.history.allTableHTML
                          und
                          mihome-vacuum.0.history.allTableJSON
                          zur verfügung stellen?
                          Danke! 😉
                          Michèl
                          • Meistertr
                            @darkbrain85:
                            Hi!
                            und
                            Danke! 😉
                            Michèl `
                            html:
                             <colgroup><col width="50"> <col width="50"> <col width="80"> <col width="100"> <col width="50"> <col width="50"></colgroup>
                              Datum |  Start |  Saugzeit |  Fläche |  ??? |  Ende |
                            | 6.7 | 15:15 | 35 min | 31.24 m² | 0 | 1 |
                            | 5.7 | 11:00 | 43 min | 29.39 m² | 0 | 1 |
                            | 4.7 | 18:33 | 32 min | 33.55 m² | 0 | 0 |
                            | 3.7 | 17:54 | 0 min | 0 m² | 0 | 0 |
                            | 3.7 | 17:43 | 1 min | 1.68 m² | 0 | 0 |
                            | 2.7 | 10:29 | 37 min | 30.95 m² | 0 | 1 |
                            | 1.7 | 20:01 | 59 min | 48.63 m² | 0 | 0 |
                            JSON:
                            [{"Datum":"6.7","Start":"15:15","Saugzeit":"35 min","Fläche":"31.24 m²","Error":0,"Ende":1},{"Datum":"5.7","Start":"11:00","Saugzeit":"43 min","Fläche":"29.39 m²","Error":0,"Ende":1},{"Datum":"4.7","Start":"18:33","Saugzeit":"32 min","Fläche":"33.55 m²","Error":0,"Ende":0},{"Datum":"3.7","Start":"17:54","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":0},{"Datum":"3.7","Start":"17:43","Saugzeit":"1 min","Fläche":"1.68 m²","Error":0,"Ende":0},{"Datum":"2.7","Start":"10:29","Saugzeit":"37 min","Fläche":"30.95 m²","Error":0,"Ende":1},{"Datum":"1.7","Start":"20:01","Saugzeit":"59 min","Fläche":"48.63 m²","Error":0,"Ende":0}]
                              Super! Danke!
                              • Chris_71
                                Chris_71 last edited by
                                Hi looxer01,
                                vielen Dank für deinen View - endlich einen Timer, ohne Handy, der funktioniert…
                                Allerdings sind die Buttons PAUSE, START und HOME sowie die 4 Reset-Buttons für die Bürsten etc. bei mir nicht sichtbar, die Widgets sind aber vorhanden. Beim View von MeisterTR fehlen die Buttons bei mir auch. Eine Idee woran es liegen kann ?
                                VG
                                Chris
                                  looxer01 last edited by
                                  Hi Chris
                                  @Chris_71:
                                  Allerdings sind die Buttons PAUSE, START und HOME sowie die 4 Reset-Buttons für die Bürsten etc. bei mir nicht sichtbar, `
                                  zwei Dinge. Die pics müssen vorhanden sein. Siehe dazu den Post des Views von MeisterTR.
                                  Dann muessen die pics einmal genutzt worden sein. Damit sie richtig oder ueberhaupt erscheinen.
                                  Das Problem hatte ich nämlich auch und es dann so geloest.
                                  Um das zu tun würde ich zunächst den Adapter deaktivieren (bei den Instanzen auf Pause drücken)
                                  sonst setzt du noch deine Verbrauchsdaten zurück.
                                  Dann alle Knöpfe drücken. Anschließend wieder aktivieren.
                                  vG Looxer
                                    Hi!
                                    Mein kleiner ist heute angekommen. Dank der hervorragenden Hilfe hier war meine View auch schon fertig. Funktionierte auf anhieb. Vielen Dank an alle Beteiligten!
                                    Allerdings werden bei mir die beiden History Datenpunkte nicht gefüllt. HTML und auch JSON bleiben einfach leer. Woran kann das liegen? Oder werden die Daten hier erst nach einer gewissen Zeit eingetragen?
                                    Edit:
                                    Mir ist gerade noch aufgefallen, dass beim Datenpunkt "mihome-vacuum.0.info.cleanedtime" eine Differenz zwischen App und Adapter besteht. Aktuell zeigt die App bei mir 4 Minuten, während iobroker 5 Minuten anzeigt. Rundungsproblem bei Xiaomi oder im Adapter?
                                    • Meistertr
                                      @darkbrain85:
                                      Hi!
                                      Edit:
                                      Mir ist gerade noch aufgefallen, dass beim Datenpunkt "mihome-vacuum.0.info.cleanedtime" eine Differenz zwischen App und Adapter besteht. Aktuell zeigt die App bei mir 4 Minuten, während iobroker 5 Minuten anzeigt. Rundungsproblem bei Xiaomi oder im Adapter? `
                                      Hi. Es sind ja historische Daten. Da du ihn heute erst bekommen hast gibt es noch keine historie [emoji1] die Daten werden von dem Roboter in Tage einsortiert. Um den trafic zu minimieren orientiert sich der Adapter an den Tagen, wenn es dort Änderungen gibt holt er die Daten. Würde sonst unnötig das Netzwerk belasten. Also wenn du morgen saugst wird alles befüllt.
                                      Es ist kein rundungsfehler, sondern einfach aufgerundet, da kommt es nicht auf eine Minute an, meiner ist jetzt bei über 7000 und da passt es dann.
                                        Ach ja guck… mittlerweile habe ich auch eine Historie. Wurde auf einmal aktualisiert. Ich dachte man könnte dort schön sehen ob der Roboter auch unterwegs war wenn man nicht da war. So viel Traffic erzeugt das doch nicht im Netzwerk. Also meins könnte das verkraften. Gerade so....
                                        Mit dem Aufrunden kann ich wohl leben denke ich;-)
                                        Edit:
                                        Nach Neustart des Adapters wird die Historie ja direkt aktualisiert. Ich würde es bevorzugen wenn dies auch nach dem Saugvorgang passieren würde. Meinetwegen auch nur alle 10 Minuten oder so wenn es sein muss. Wenn ich nach Hause komme, will ich auf dem Tablet sofort sehen ob der Sauger unterwegs war und was er gemacht hat.
                                        Ist das machbar? Das würde meine Dankbarkeit quasi ins unermessliche steigern. 😉
                                        Gesendet von iPad mit Tapatalk
                                        • Chris_71
                                          @looxer01:
                                          Dann alle Knöpfe drücken. Anschließend wieder aktivieren. `
                                          Hi looxer01,
                                          Im View hab ich noch nicht einmal "Platzhalter" für die Buttons da kann ich nichts anklicken.
                                          VG,
                                          Chris
                                            Edit:
                                            Hat sich erledigt! 😉
                                            2196
                                            968499
