    3. Einsteigerfragen
    4. Zigbee Adapter lässt sich nicht einrichten
      hausautomation.digital last edited by
      Seit Stunden lese ich hier und suche im Netz, aber ich bekomm den Adapter nicht zum laufen.
      zigbee.0
      	2022-10-11 20:12:36.643	error	Error herdsman start
      zigbee.0
      	2022-10-11 20:12:36.642	error	Failed to start Zigbee
      zigbee.0
      	2022-10-11 20:12:36.641	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      	2022-10-11 20:12:36.407	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      	2022-10-11 20:12:36.364	info	Starting Zigbee npm ...
      Was mach ich falsch? 😧
        Thomas Braun Most Active @hausautomation.digital last edited by
        @hausautomation-digital
        Zeig mal einen vollständigen Start des Adapters.
          hausautomation.digital @Thomas Braun last edited by
          zigbee.0
          	2022-10-11 20:44:08.130	error	Error herdsman start
          zigbee.0
          	2022-10-11 20:44:08.129	error	Failed to start Zigbee
          zigbee.0
          	2022-10-11 20:44:08.128	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          zigbee.0
          	2022-10-11 20:44:07.844	info	Installed Version: iobroker.zigbee@1.7.5
          zigbee.0
          	2022-10-11 20:44:07.820	info	Starting Zigbee npm ...
          zigbee.0
          	2022-10-11 20:44:07.819	info	Try to reconnect. 1 attempts left
          zigbee.0
          	2022-10-11 20:43:57.813	error	Error herdsman start
          zigbee.0
          	2022-10-11 20:43:57.812	error	Failed to start Zigbee
          zigbee.0
          	2022-10-11 20:43:57.811	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
          zigbee.0
          	2022-10-11 20:43:57.676	error	Re-commissioning your network will require re-pairing of all devices!
          zigbee.0
          	2022-10-11 20:43:57.675	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
          zigbee.0
          	2022-10-11 20:43:57.675	error	Please update configuration to prevent further issues.
          zigbee.0
          	2022-10-11 20:43:57.674	error	- Channel List: configured=26, adapter=20
          zigbee.0
          	2022-10-11 20:43:57.673	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
          zigbee.0
          	2022-10-11 20:43:57.673	error	- Extended PAN ID: configured=00124b0024c11445, adapter=00124b0024c11445
          zigbee.0
          	2022-10-11 20:43:57.671	error	- PAN ID: configured=6754, adapter=6754
          zigbee.0
          	2022-10-11 20:43:57.671	error	Configuration is not consistent with adapter state/backup!
          zigbee.0
          	2022-10-11 20:43:57.443	info	Installed Version: iobroker.zigbee@1.7.5
          zigbee.0
          	2022-10-11 20:43:56.911	info	Starting Zigbee npm ...
          zigbee.0
          	2022-10-11 20:43:56.908	info	delete old Backup files. keep only last 10
          zigbee.0
          	2022-10-11 20:43:56.804	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.17.1, js-controller: 4.0.23
          host.homebutler
          	2022-10-11 20:43:53.357	info	instance system.adapter.zigbee.0 started with pid 27988
          host.homebutler
          	2022-10-11 20:43:53.289	info	"system.adapter.zigbee.0" enabled
            Thomas Braun Most Active @hausautomation.digital last edited by Thomas Braun
            @hausautomation-digital sagte in Zigbee Adapter lässt sich nicht einrichten:
            Stell es übereinstimmend ein.
              @thomas-braun 🍻 DANKE! Hatte ich doch glatt übersehen.... Läuft!
