    3. Einsteigerfragen
    4. Absturzursache Raspi und iO Broker finden
      Lucky_ESA Developer Most Active last edited by
      Ein Log 1 Stunde vor auftreten des Problems kann vielleicht helfen. Versuchen solltest du das um vielleicht deinen Fehler zu finden.
      Gruß//Lucky
        Laser @Lucky_ESA last edited by Laser
        @lucky_esa
        Muß diese ständige "Time Synchronistation" sein?
        Oct 12 10:29:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:29:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:29:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:29:58 raspberrypi systemd-timesyncd[1224156]: Timed out waiting for reply from 116.203.151.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:29:58 raspberrypi systemd-timesyncd[1224156]: Initial synchronization to time server 167.86.115.96:123 (0.debian.pool.ntp.org).
        Oct 12 10:30:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:30:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:30:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:30:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:30:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:30:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:30:33 raspberrypi systemd-timesyncd[1224327]: Timed out waiting for reply from 116.203.151.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:30:33 raspberrypi systemd-timesyncd[1224327]: Initial synchronization to time server 167.86.115.96:123 (0.debian.pool.ntp.org).
        Oct 12 10:30:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:30:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:30:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:30:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:30:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:30:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:30:58 raspberrypi systemd-timesyncd[1224431]: Timed out waiting for reply from 116.203.151.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:30:58 raspberrypi systemd-timesyncd[1224431]: Initial synchronization to time server 167.86.115.96:123 (0.debian.pool.ntp.org).
        Oct 12 10:31:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:31:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:31:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:31:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:31:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:31:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:31:22 raspberrypi systemd-timesyncd[1224606]: Initial synchronization to time server 90.187.148.77:123 (0.debian.pool.ntp.org).
        Oct 12 10:31:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:31:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:31:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:31:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:31:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:31:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:31:48 raspberrypi systemd-timesyncd[1224709]: Initial synchronization to time server 90.187.148.77:123 (0.debian.pool.ntp.org).
        Oct 12 10:32:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:32:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:32:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:32:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:32:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:32:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:32:22 raspberrypi systemd-timesyncd[1224887]: Initial synchronization to time server 90.187.148.77:123 (0.debian.pool.ntp.org).
        Oct 12 10:32:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:32:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:32:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:32:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:32:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:32:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:32:48 raspberrypi systemd-timesyncd[1224987]: Initial synchronization to time server 90.187.148.77:123 (0.debian.pool.ntp.org).
        Oct 12 10:33:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:33:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:33:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:33:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:33:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:33:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:33:23 raspberrypi systemd-timesyncd[1225157]: Initial synchronization to time server 90.187.148.77:123 (0.debian.pool.ntp.org).
        Oct 12 10:33:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:33:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:33:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:33:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:33:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:33:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:33:48 raspberrypi systemd-timesyncd[1225266]: Initial synchronization to time server 162.159.200.123:123 (0.debian.pool.ntp.org).
        Oct 12 10:34:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:34:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:34:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:34:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:34:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:34:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:34:22 raspberrypi systemd-timesyncd[1225431]: Initial synchronization to time server 162.159.200.123:123 (0.debian.pool.ntp.org).
        Oct 12 10:34:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:34:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:34:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:34:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:34:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:34:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:34:47 raspberrypi systemd-timesyncd[1225539]: Initial synchronization to time server 162.159.200.123:123 (0.debian.pool.ntp.org).
        Oct 12 10:35:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:35:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:35:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:35:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:35:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:35:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:35:23 raspberrypi systemd-timesyncd[1225711]: Initial synchronization to time server 162.159.200.123:123 (0.debian.pool.ntp.org).
        Oct 12 10:35:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:35:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:35:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:35:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:35:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:35:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:35:48 raspberrypi systemd-timesyncd[1225817]: Initial synchronization to time server 162.159.200.123:123 (0.debian.pool.ntp.org).
        Oct 12 10:36:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:36:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:36:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:36:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:36:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:36:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:36:23 raspberrypi systemd-timesyncd[1225987]: Initial synchronization to time server 80.86.85.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:36:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:36:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:36:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:36:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:36:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:36:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:36:48 raspberrypi systemd-timesyncd[1226095]: Initial synchronization to time server 80.86.85.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:37:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:37:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:37:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:37:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:37:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:37:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:37:23 raspberrypi systemd-timesyncd[1226274]: Initial synchronization to time server 80.86.85.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:37:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:37:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:37:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:37:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:37:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:37:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:37:47 raspberrypi systemd-timesyncd[1226380]: Initial synchronization to time server 80.86.85.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:37:53 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:37:54 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:37:54 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:37:54 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:37:54 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:37:54 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:37:54 raspberrypi systemd-timesyncd[1226428]: Initial synchronization to time server 80.86.85.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:38:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:38:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:38:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:38:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:38:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:38:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:38:23 raspberrypi systemd-timesyncd[1226584]: Initial synchronization to time server 80.86.85.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:38:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:38:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:38:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:38:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:38:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:38:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:38:48 raspberrypi systemd-timesyncd[1226690]: Initial synchronization to time server 178.215.228.24:123 (0.debian.pool.ntp.org).
        Oct 12 10:39:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:39:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:39:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:39:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:39:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:39:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:39:23 raspberrypi systemd-timesyncd[1226856]: Initial synchronization to time server 178.215.228.24:123 (0.debian.pool.ntp.org).
        Oct 12 10:39:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:39:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:39:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:39:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:39:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:39:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:39:47 raspberrypi systemd-timesyncd[1226970]: Initial synchronization to time server 178.215.228.24:123 (0.debian.pool.ntp.org).
        Oct 12 10:40:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:40:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:40:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:40:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:40:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:40:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:40:23 raspberrypi systemd-timesyncd[1227140]: Initial synchronization to time server 178.215.228.24:123 (0.debian.pool.ntp.org).
        Oct 12 10:40:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:40:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:40:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:40:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:40:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:40:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:40:48 raspberrypi systemd-timesyncd[1227250]: Initial synchronization to time server 178.215.228.24:123 (0.debian.pool.ntp.org).
        Oct 12 10:41:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:41:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:41:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:41:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:41:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:41:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:41:23 raspberrypi systemd-timesyncd[1227419]: Initial synchronization to time server 164.68.124.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:41:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:41:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:41:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:41:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:41:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:41:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:41:48 raspberrypi systemd-timesyncd[1227524]: Initial synchronization to time server 164.68.124.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:42:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:42:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:42:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:42:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:42:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:42:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:42:23 raspberrypi systemd-timesyncd[1227695]: Initial synchronization to time server 164.68.124.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:42:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:42:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:42:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:42:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:42:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:42:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:42:48 raspberrypi systemd-timesyncd[1227796]: Initial synchronization to time server 164.68.124.74:123 (0.debian.pool.ntp.org).
        Oct 12 10:43:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:43:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:43:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:43:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:43:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:43:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:43:23 raspberrypi systemd-timesyncd[1227965]: Initial synchronization to time server 213.172.105.106:123 (0.debian.pool.ntp.org).
        Oct 12 10:43:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:43:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:43:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:43:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:43:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:43:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:43:48 raspberrypi systemd-timesyncd[1228075]: Initial synchronization to time server 213.172.105.106:123 (0.debian.pool.ntp.org).
        Oct 12 10:44:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:44:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:44:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:44:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:44:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:44:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:44:22 raspberrypi systemd-timesyncd[1228251]: Initial synchronization to time server 213.172.105.106:123 (0.debian.pool.ntp.org).
        Oct 12 10:44:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:44:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:44:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:44:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:44:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:44:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:44:48 raspberrypi systemd-timesyncd[1228361]: Initial synchronization to time server 213.172.105.106:123 (0.debian.pool.ntp.org).
        Oct 12 10:45:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:45:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:45:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:45:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:45:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:45:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:45:22 raspberrypi systemd-timesyncd[1228528]: Initial synchronization to time server 213.172.105.106:123 (0.debian.pool.ntp.org).
        Oct 12 10:45:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:45:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:45:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:45:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:45:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:45:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:45:48 raspberrypi systemd-timesyncd[1228637]: Initial synchronization to time server 185.197.135.21:123 (0.debian.pool.ntp.org).
        Oct 12 10:46:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:46:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:46:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:46:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:46:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:46:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:46:22 raspberrypi systemd-timesyncd[1228807]: Initial synchronization to time server 185.197.135.21:123 (0.debian.pool.ntp.org).
        Oct 12 10:46:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:46:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:46:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:46:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:46:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:46:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:46:48 raspberrypi systemd-timesyncd[1228916]: Initial synchronization to time server 185.197.135.21:123 (0.debian.pool.ntp.org).
        Oct 12 10:47:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:47:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:47:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:47:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:47:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:47:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:47:23 raspberrypi systemd-timesyncd[1229083]: Initial synchronization to time server 185.120.22.14:123 (0.debian.pool.ntp.org).
        Oct 12 10:47:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:47:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:47:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:47:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:47:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:47:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:47:47 raspberrypi systemd-timesyncd[1229193]: Initial synchronization to time server 185.197.135.21:123 (0.debian.pool.ntp.org).
        Oct 12 10:48:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:48:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:48:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:48:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:48:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:48:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:48:23 raspberrypi systemd-timesyncd[1229372]: Initial synchronization to time server 5.161.44.72:123 (0.debian.pool.ntp.org).
        Oct 12 10:48:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:48:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:48:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:48:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:48:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:48:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:48:48 raspberrypi systemd-timesyncd[1229481]: Initial synchronization to time server 5.161.44.72:123 (0.debian.pool.ntp.org).
        Oct 12 10:49:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:49:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:49:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:49:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:49:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:49:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:49:23 raspberrypi systemd-timesyncd[1229654]: Initial synchronization to time server 5.161.44.72:123 (0.debian.pool.ntp.org).
        Oct 12 10:49:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:49:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:49:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:49:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:49:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:49:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:49:48 raspberrypi systemd-timesyncd[1229764]: Initial synchronization to time server 5.161.44.72:123 (0.debian.pool.ntp.org).
        Oct 12 10:50:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:50:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:50:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:50:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:50:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:50:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:50:23 raspberrypi systemd-timesyncd[1229934]: Initial synchronization to time server 162.159.200.1:123 (0.debian.pool.ntp.org).
        Oct 12 10:50:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:50:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:50:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:50:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:50:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:50:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:50:48 raspberrypi systemd-timesyncd[1230041]: Initial synchronization to time server 162.159.200.1:123 (0.debian.pool.ntp.org).
        Oct 12 10:51:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:51:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:51:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:51:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:51:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:51:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:51:23 raspberrypi systemd-timesyncd[1230210]: Initial synchronization to time server 162.159.200.1:123 (0.debian.pool.ntp.org).
        Oct 12 10:51:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:51:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:51:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:51:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:51:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:51:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:51:48 raspberrypi systemd-timesyncd[1230320]: Initial synchronization to time server 162.159.200.1:123 (0.debian.pool.ntp.org).
        Oct 12 10:52:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:52:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:52:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:52:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:52:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:52:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:52:22 raspberrypi systemd-timesyncd[1230489]: Initial synchronization to time server 162.159.200.1:123 (0.debian.pool.ntp.org).
        Oct 12 10:52:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:52:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:52:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:52:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:52:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:52:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:52:47 raspberrypi systemd-timesyncd[1230590]: Initial synchronization to time server 162.159.200.1:123 (0.debian.pool.ntp.org).
        Oct 12 10:52:53 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:52:53 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:52:53 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:52:53 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:52:53 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:52:54 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:52:54 raspberrypi systemd-timesyncd[1230638]: Initial synchronization to time server 188.40.142.18:123 (0.debian.pool.ntp.org).
        Oct 12 10:53:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:53:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:53:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:53:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:53:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:53:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:53:23 raspberrypi systemd-timesyncd[1230791]: Initial synchronization to time server 188.40.142.18:123 (0.debian.pool.ntp.org).
        Oct 12 10:53:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:53:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:53:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:53:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:53:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:53:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:53:48 raspberrypi systemd-timesyncd[1230896]: Initial synchronization to time server 188.40.142.18:123 (0.debian.pool.ntp.org).
        Oct 12 10:54:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:54:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:54:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:54:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:54:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:54:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:54:23 raspberrypi systemd-timesyncd[1231071]: Initial synchronization to time server 188.40.142.18:123 (0.debian.pool.ntp.org).
        Oct 12 10:54:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:54:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:54:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:54:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:54:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:54:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:54:48 raspberrypi systemd-timesyncd[1231173]: Initial synchronization to time server 188.40.142.18:123 (0.debian.pool.ntp.org).
        Oct 12 10:55:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:55:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:55:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:55:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:55:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:55:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:55:23 raspberrypi systemd-timesyncd[1231341]: Initial synchronization to time server 129.250.35.250:123 (0.debian.pool.ntp.org).
        Oct 12 10:55:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:55:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:55:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:55:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:55:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:55:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:55:47 raspberrypi systemd-timesyncd[1231448]: Initial synchronization to time server 129.250.35.250:123 (0.debian.pool.ntp.org).
        Oct 12 10:56:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:56:22 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:56:22 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:56:22 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:56:22 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:56:22 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:56:22 raspberrypi systemd-timesyncd[1231621]: Initial synchronization to time server 129.250.35.250:123 (0.debian.pool.ntp.org).
        Oct 12 10:56:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:56:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:56:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:56:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:56:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:56:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:56:48 raspberrypi systemd-timesyncd[1231730]: Initial synchronization to time server 129.250.35.250:123 (0.debian.pool.ntp.org).
        Oct 12 10:57:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:57:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:57:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:57:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:57:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:57:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:57:23 raspberrypi systemd-timesyncd[1231898]: Initial synchronization to time server 129.250.35.250:123 (0.debian.pool.ntp.org).
        Oct 12 10:57:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:57:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:57:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:57:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:57:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:57:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:57:48 raspberrypi systemd-timesyncd[1232003]: Initial synchronization to time server 185.242.112.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:58:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:58:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:58:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:58:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:58:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:58:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:58:23 raspberrypi systemd-timesyncd[1232174]: Initial synchronization to time server 185.242.112.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:58:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:58:47 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:58:47 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:58:47 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:58:47 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:58:47 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:58:47 raspberrypi systemd-timesyncd[1232280]: Initial synchronization to time server 185.242.112.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:59:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:59:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:59:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:59:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:59:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:59:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:59:23 raspberrypi systemd-timesyncd[1232453]: Initial synchronization to time server 185.242.112.53:123 (0.debian.pool.ntp.org).
        Oct 12 10:59:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 10:59:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 10:59:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 10:59:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 10:59:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 10:59:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 10:59:48 raspberrypi systemd-timesyncd[1232558]: Initial synchronization to time server 185.242.112.53:123 (0.debian.pool.ntp.org).
        Oct 12 11:00:22 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 11:00:23 raspberrypi systemd[1]: Starting debmatic set interface clock...
        Oct 12 11:00:23 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 11:00:23 raspberrypi systemd[1]: debmatic-setinterfaceclock.service: Succeeded.
        Oct 12 11:00:23 raspberrypi systemd[1]: Finished debmatic set interface clock.
        Oct 12 11:00:23 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 11:00:23 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 11:00:23 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 11:00:23 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 11:00:23 raspberrypi systemd-timesyncd[1232729]: Initial synchronization to time server 130.255.77.87:123 (0.debian.pool.ntp.org).
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: bits received from HRNG source: 2200064
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: bits sent to kernel pool: 2158944
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: entropy added to kernel pool: 2158944
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2 successes: 110
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2 failures: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2(2001-10-10) Monobit: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2(2001-10-10) Poker: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2(2001-10-10) Runs: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2(2001-10-10) Long run: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: HRNG source speed: (min=180.888; avg=581.010; max=658.927)Kibits/s
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: FIPS tests speed: (min=24.485; avg=43.559; max=78.170)Mibits/s
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: Lowest ready-buffers level: 2
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: Entropy starvations: 0
        Oct 12 11:00:37 raspberrypi rngd[543]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
        Oct 12 11:00:47 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 11:00:48 raspberrypi systemd[1]: Stopping Network Time Synchronization...
        Oct 12 11:00:48 raspberrypi systemd[1]: systemd-timesyncd.service: Succeeded.
        Oct 12 11:00:48 raspberrypi systemd[1]: Stopped Network Time Synchronization.
        Oct 12 11:00:48 raspberrypi systemd[1]: Starting Network Time Synchronization...
        Oct 12 11:00:48 raspberrypi systemd[1]: Started Network Time Synchronization.
        Oct 12 11:00:48 raspberrypi systemd-timesyncd[1232837]: Initial synchronization to time server 130.255.77.87:123 (0.debian.pool.ntp.org).
        Oct 12 11:01:04 raspberrypi bash[534]: Send diag info: {"uuid":"92cc5b8d-2c54-82ea-f8cd-e45e3c652986","language":"de","country":"Germany","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.17.0","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.2.22","platform":"Javascript/Node.js"},"backitup":{"version":"2.4.12","platform":"Javascript/Node.js"},"cul":{"version":"1.3.5","platform":"javascript/Node.js"},"discovery":{"version":"3.0.5","platform":"Javascript/Node.js"},"echarts":{"version":"1.0.12","platform":"Javascript/Node.js"},"flot":{"version":"1.11.0","platform":"Javascript/Node.js"},"habpanel":{"version":"0.4.3","platform":"javascript/Node.js"},"history":{"version":"2.2.0","platform":"Javascript/Node.js"},"hm-rega":{"version":"3.0.40","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.12","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"jarvis":{"version":"2.2.1","platform":"Javascript/Node.js"},"javascript":{"version":"6.0.3","platform":"Javascript/Node.js"},"mqtt":{"version":"4.0.7","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Node.js"},"onvif":{"version":"0.4.4","platform":"Javascript/Node.js"},"owfs":{"version":"0.7.0","platform":"Javascript/Node.js"},"ping":{"version":"1.5.0","platform":"Javascript/Node.js"},"rflink":{"version":"2.1.6","platform":"Javascript/Node.js"},"rpi2":{"version":"1.3.2","platform":"Javascript/Node.js"},"shelly":{"version":"6.0.0","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.4","platform":"Javascript/Node.js"},"socketio":{"version":"4.2.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.7.5","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":21,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":1938026496,"ostype":"Linux","city":"Naumburg (Saale)","vis":80}
        Oct 12 11:13:52 raspberrypi dhcpcd[809]: eth0: Router Advertisement from fe80::e228:6dff:fe35:ee21
        Oct 12 12:07:58 raspberrypi kernel: [263234.188075] raw-uart raw-uart: generic_raw_uart_handle_rx_char(): rx fifo full.
        Oct 12 12:09:04 raspberrypi kernel: [263236.735882] raw-uart raw-uart: generic_raw_uart_handle_rx_char(): rx fifo full.
          Thomas Braun Most Active @Laser last edited by
          @laser
          Welches Log ist das?
            Laser @Thomas Braun last edited by
            cat syslog | grep 'Oct 12'
              @laser
              Mein Raspberry zeigt da nicht so regelmäßig Einträge zur Zeitsynchronisation.
              Läuft das sowas wie piHole oder ähnliches im Netzwerk?
                Habe auch nicht jede Minuten eine time sync. Ein Log 1 Stunde vor dem Error wäre gut, in den o. g. Log finde ich den Error nicht. Hast du 2GB RAM? Das ist zu knapp...
                Poste mal den gesamten Tag lösche aber bitte die Zeilen mit Send diag info. Auch die aus den o.g. Log.
                Gruß//Lucky
                  2GB RAM hat der Pi. Mit "top" wird 6,5 ... 12% RAM Auslastung angezeigt. Swapfile auf 500MB vergrößert.
                  pi@raspberrypi:~ $ free -h
                  Mem:           1.8Gi       1.1Gi       142Mi       0.0Ki       580Mi       658Mi
                  Swap:          511Mi          0B       511Mi
                  Wenn ich das Log gleich nach "error" durchsuche, wie bisher schon getan, müßte das doch die "error's " anzeigen?
                  -> kein Pihole o.ä.
                    Homoran Global Moderator Administrators @Laser last edited by
                    @laser sagte in Absturzursache Raspi und iO Broker finden:
                    aber der kommt wohl nicht an den ntp server
                      Swapfile
                      Jetzt hast du irgendwie zwei. Macht keinen Sinn.
                        Laser @Thomas Braun last edited by Laser
                        Das macht wirklich keinen Sinn -2x swapfile. Habe nach Neustart den Post editiert und eine Zeile nicht gelöscht.
                          Laser @Laser last edited by Laser
                          @laser
                          Heute wieder keine Verbindung über SSH. Dieses Mal allerdings wurde die Verbindung durch Abziehen und Anstecken des LAN- Kabels wieder hergestellt.
                          Im Pi ist eine feste IP-Adresse eingestellt. Keine Fehlermelung im Error- Log.
                          Die Verbindung war ab 8:30 Uhr weg. 8:00 wurde über backitup noch ein Backup gemacht.
                          GLH 510 1 Reply Last reply Reply Quote 0
                          • GLH 510
                            GLH 510 @Laser last edited by
                            @laser Ist das Problem jetzt weg oder gab es noch eine andere Lösung?
                              Laser @GLH 510 last edited by Laser
                              @glh-510
                              Es ist seltener geworden. Aber in der vorigen Woche war die Einheit wieder einmal nicht erreichbar. Nur 5V-Kabel ab und dran hat geholfen.
                                @laser
                                Schau mal per
                                iob diag
                                rein.
                                  Copy text starting here:
                                                       v.2023-01-02
                                  Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                                  Installation:           Native
                                  Timezone:               Europe/Berlin
                                  User-ID:                1000
                                  X-Server:               false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     4
                                  Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                          /usr/bin/node           v16.19.1
                                                          /usr/bin/npm            8.19.3
                                                          /usr/bin/npx            8.19.3
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.3.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Status admin:
                                  + system.adapter.admin.1                  : admin                 : Heizung                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  Pending iob updates:    0
                                  Active repo(s): stable
                                  Objects:                3207
                                  States:                 2406
                                  Size of iob-Database:
                                  8.4M    /opt/iobroker/iobroker-data/objects.jsonl
                                  7.5M    /opt/iobroker/iobroker-data/states.jsonl
                                  Der lange Rest der Diagnose ist verschwunden...
                                    @laser
                                    Die Langfassung aus dem Mittelteil sagt mehr. Und bitte die CodeTags sauber verwenden, damit man das besser lesen kann.
                                      Habe das noch mal durchlaufen lassen. Das gleiche Ergebnis. Die endlose Passage fehlt wieder.
                                        @laser
                                        Kopier es halt, bevor du per Tastendruck auf die Zusammenfassung gehst.
                                        Alternativ liegt aber auch ein log in /home/iobroker herum.
                                          Ein Versuch:
                                          Skript v.2023-01-02
                                          *** BASE SYSTEM ***
                                          Model           : Raspberry Pi 4 Model B Rev 1.4
                                          Architecture:   armv7l
                                          Docker:         false
                                          Virtualization: none
                                          Distributor ID: Raspbian
                                          Description:    Raspbian GNU/Linux 11 (bullseye)
                                          Release:        11
                                          Codename:       bullseye
                                          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                          NAME="Raspbian GNU/Linux"
                                          VERSION_ID="11"
                                          VERSION="11 (bullseye)"
                                          VERSION_CODENAME=bullseye
                                          ID=raspbian
                                          ID_LIKE=debian
                                          HOME_URL="http://www.raspbian.org/"
                                          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                          Systemuptime and Load:
                                           10:06:57 up 1 day,  1:32,  1 user,  load average: 0.41, 0.57, 0.50
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                          Wed Mar  1 09:06:57 UTC 2023
                                          Wed Mar  1 10:06:57 CET 2023
                                          CET +0100
                                          Europe/Berlin
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            1.9G        1.1G        192M        1.0M        596M        861M
                                          Swap:            99M        1.0M         98M
                                          Total:          2.0G        1.1G        291M
                                                   1871 M total memory
                                                   1082 M used memory
                                                    278 M active memory
                                                   1280 M inactive memory
                                                    192 M free memory
                                                     59 M buffer memory
                                                    536 M swap cache
                                                     99 M total swap
                                                      1 M used swap
                                                     98 M free swap
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      110G  3.5G  102G   4% /
                                          devtmpfs       devtmpfs  775M     0  775M   0% /dev
                                          tmpfs          tmpfs     936M     0  936M   0% /dev/shm
                                          tmpfs          tmpfs     375M  1.1M  374M   1% /run
                                          /dev/sda1      vfat      255M   50M  206M  20% /boot
                                          tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
                                          Messages in dmesg:
                                          [Tue Feb 28 08:34:47 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1E:BF:CD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a8b32cdb-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Tue Feb 28 08:34:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                          [Tue Feb 28 08:34:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Tue Feb 28 08:34:52 2023] EXT4-fs (sda2): re-mounted. Opts: commit=600. Quota mode: none.
                                          [Tue Feb 28 08:34:56 2023] systemd[1]: Started Periodic ext4 Online Metadata Check for All Filesystems.
                                          [Tue Feb 28 08:34:56 2023] systemd[1]: Starting Remove Stale Online ext4 Metadata Check Snapshots...
                                          [Tue Feb 28 08:34:56 2023] systemd[1]: Finished Remove Stale Online ext4 Metadata Check Snapshots.
                                          Show mounted filesystems (real ones only):
                                          TARGET      SOURCE    FSTYPE  OPTIONS
                                          /           /dev/sda2 ext4    rw,noatime,commit=600
                                          |-/run/owfs OWFS      fuse.OW rw,nosuid,nodev,relatime,user_id=0,group_id=0,allo
                                          `-/boot     /dev/sda1 vfat    rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
                                          /var:
                                          498M    /var/
                                          279M    /var/cache
                                          274M    /var/cache/apt
                                          210M    /var/cache/apt/archives
                                          94M     /var/lib
                                          /opt/iobroker/backups:
                                          4.0K    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          530M    /opt/iobroker/iobroker-data/
                                          343M    /opt/iobroker/iobroker-data/history
                                          137M    /opt/iobroker/iobroker-data/files
                                          51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                          34M     /opt/iobroker/iobroker-data/backup-objects
                                          9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
                                          8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
                                          8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
                                          8.3M    /opt/iobroker/iobroker-data/states.jsonl
                                          *** NodeJS-Installation ***
                                          /usr/bin/npm            8.19.3
                                          /usr/bin/npx            8.19.3
                                          nodejs:
                                            Installed: 16.19.1-deb-1nodesource1
                                            Candidate: 16.19.1-deb-1nodesource1
                                            Version table:
                                           *** 16.19.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               12.22.12~dfsg-1~deb11u3 500
                                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  4.0.24
                                          admin:          6.3.5
                                          javascript:     6.1.4
                                          Adapters from github:   0
                                          Adapter State
                                          + system.adapter.backitup.0               : backitup              : Heizung                                  -  enabled
                                          + system.adapter.discovery.0              : discovery             : Heizung                                  -  enabled
                                          + system.adapter.echarts.0                : echarts               : Heizung                                  -  enabled
                                            system.adapter.flot.0                   : flot                  : Heizung                                  - disabled
                                          + system.adapter.history.0                : history               : Heizung                                  -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : Heizung                                  -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : Heizung                                  -  enabled, port: 0
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : Heizung                                  -  enabled, port: 0
                                          + system.adapter.info.0                   : info                  : Heizung                                  -  enabled
                                          + system.adapter.javascript.0             : javascript            : Heizung                                  -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : Heizung                                  -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.net-tools.0              : net-tools             : Heizung                                  -  enabled
                                          + system.adapter.opendtu.0                : opendtu               : Heizung                                  -  enabled
                                          + system.adapter.owfs.0                   : owfs                  : Heizung                                  -  enabled, port: 4304
                                          + system.adapter.rpi2.0                   : rpi2                  : Heizung                                  -  enabled
                                          + system.adapter.shelly.1                 : shelly                : Heizung                                  -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : Heizung                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.vis-bars.0               : vis-bars              : Heizung                                  - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Heizung                                  - disabled
                                            system.adapter.vis.0                    : vis                   : Heizung                                  -  enabled
                                          + system.adapter.web.0                    : web                   : Heizung                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.zigbee.0                 : zigbee                : Heizung                                  -  enabled, port: /dev/ttyACM0
                                          + instance is alive
                                          ioBroker-Repositories
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 6.3.5    , installed 6.3.5
                                          Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                          Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
                                          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                                          Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                                          Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
                                          Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                                          Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                                          Adapter    "info"         : 1.9.19   , installed 1.9.19
                                          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                          Controller "js-controller": 4.0.24   , installed 4.0.24
                                          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                          Adapter    "owfs"         : 0.7.0    , installed 0.7.0
                                          Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                                          Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                          Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                                          Objects and States
                                          Objects:        3207
                                          States:         2406
                                          ^C
                                            Thomas Braun Most Active @Laser last edited by Thomas Braun
                                            @laser
                                            Das ist ja nur ein Bruchteil. Scroll an den Anfang...
                                            Oder hol das log aus /home/iobroker/iob_diag.log ab.
                                            148
                                            9284
