    3. Off Topic
    4. [Gelöst] Ubuntu updaten
    • Kusselin
      Kusselin @Jan1 last edited by
      @jan1 ja genau...das sehe ich ja auch...das es alt ist....
      und da muss es doch eine möglichkeit über console geben ubzugraden auf die nächst höhere version
        Thomas Braun Most Active @Kusselin last edited by
        @kusselin
        Ja, mit
        sudo do-release-upgrade
        • Kusselin
          Kusselin @Thomas Braun last edited by
          @thomas-braun sagte in Ubuntu updaten:
          @kusselin
          Und künftig keine Zwischenversionen einsetzen sondern nur LTS-Releases.
          O.K. danke Dir ..mit dem befehl solls gehen?
            @kusselin
            Ja.
            Kusselin 1 Reply Last reply Reply Quote 0
            • Kusselin
              @thomas-braun schau...was muss ich hier denn machen??
              Checking for a new Ubuntu release
              Your Ubuntu release is not supported anymore.
              For upgrade information, please visit:
              http://www.ubuntu.com/releaseendoflife
              Please install all available updates for your release before upgrading.
                @kusselin
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                • Kusselin
                  nee thomas.....das klappt so nicht...das wäre zu einfach 🙂
                   sudo apt update
                  Hit:1 http://ppa.launchpad.net/ondrej/php/ubuntu impish InRelease
                  Ign:2 http://archive.ubuntu.com/ubuntu impish InRelease
                  Ign:3 http://archive.ubuntu.com/ubuntu impish-updates InRelease
                  Ign:4 http://archive.ubuntu.com/ubuntu impish-security InRelease
                  Err:5 http://archive.ubuntu.com/ubuntu impish Release
                    404  Not Found [IP: 91.189.91.39 80]
                  Err:6 http://archive.ubuntu.com/ubuntu impish-updates Release
                  Err:7 http://archive.ubuntu.com/ubuntu impish-security Release
                  Reading package lists... Done
                  E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' no longer has a Release file.
                  N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                  N: See apt-secure(8) manpage for repository creation and user configuration details.
                  E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' no longer has a Release file.
                  E: The repository 'http://archive.ubuntu.com/ubuntu impish-security Release' no longer has a Release file.
                  root@Nextcloud-live:~# sudo apt full-upgrade
                  Building dependency tree... Done
                  Calculating upgrade... Done
                  The following packages will be upgraded:
                    apt apt-utils isc-dhcp-client isc-dhcp-common libapt-pkg6.0 libkeyutils1
                    libnss-systemd libpam-systemd libsystemd0 libudev1 python3-distupgrade
                    systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools
                    ubuntu-release-upgrader-core udev
                  17 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 10.4 MB of archives.
                  After this operation, 32.8 kB of additional disk space will be used.
                  Do you want to continue? [Y/n] y
                  Err:1 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libnss-systemd amd64 248.3-1ubuntu8.6
                    404  Not Found [IP: 185.125.190.39 80]
                  Err:2 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libsystemd0 amd64 248.3-1ubuntu8.6
                  Err:3 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-timesyncd amd64 248.3-1ubuntu8.6
                  Err:4 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-sysv amd64 248.3-1ubuntu8.6
                  Err:5 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libpam-systemd amd64 248.3-1ubuntu8.6
                  Err:6 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd amd64 248.3-1ubuntu8.6
                  Err:7 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 udev amd64 248.3-1ubuntu8.6
                  Err:8 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libudev1 amd64 248.3-1ubuntu8.6
                  Err:9 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libapt-pkg6.0 amd64 2.3.9ubuntu0.1
                  Err:10 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt amd64 2.3.9ubuntu0.1
                  Err:11 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt-utils amd64 2.3.9ubuntu0.1
                  Err:12 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libkeyutils1 amd64 1.6.1-2ubuntu2.1
                  Err:13 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.3ubuntu1.1
                  Err:14 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.3ubuntu1.1
                  Err:15 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-advantage-tools amd64 27.9~21.10.1
                  Err:16 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-release-upgrader-core all 1:21.10.10
                  Err:17 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 python3-distupgrade all 1:21.10.10
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libnss-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libsystemd0_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-timesyncd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-sysv_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libpam-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/udev_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev1_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/k/keyutils/libkeyutils1_1.6.1-2ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.9%7e21.10.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
                  E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                    @kusselin
                    Installier es neu und halte da dann das EndOfLife im Auge und spring vorher auf den Nachfolger.
                      @kusselin
                      Kannst aber auch hier mal schauen:
                      https://help.ubuntu.com/community/EOLUpgrades
                      • Kusselin
                        @kusselin
                        andree Möglichkeit wie neuinstallation gibts nicht?
                        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Kusselin last edited by Thomas Braun
                          @kusselin
                          Steht im dem Link drin:
                          Aber auch dort wird geschrieben:
                          Reinstalling is usually easier and faster, especially if you would have to upgrade through several releases.
                            crunchip Forum Testing Most Active @Kusselin last edited by
                            @kusselin hatte das kürzlich auch bei einer VM gemacht, sourceslist anpassen aufs aktuelle Ubuntu und danach das full update, geht ohne Probleme
                            Homoran Kusselin 2 Replies Last reply Reply Quote 0
                              Homoran Global Moderator Administrators @crunchip last edited by
                              @crunchip sagte in Ubuntu updaten:
                              war da das alte Repo auch nicht mehr erreichbar?
                              • Kusselin
                                Kusselin @crunchip last edited by
                                das hier:
                                ## EOL upgrade sources.list
                                # Required
                                deb http://old-releases.ubuntu.com/ubuntu/ CODENAME main restricted universe multiverse
                                deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-updates main restricted universe multiverse
                                deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-security main restricted universe multiverse
                                # Optional
                                #deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-backports main restricted universe multiverse
                                muss in die source list.....
                                Bitte an euch...wo bzw. welche pfad ist das /etc/......?
                                und muss ich das alte dann komplett rausnehmen aus der source list udn das hier neu rein?
                                  @kusselin
                                  Das ist die /etc/apt/sources.list
                                  In deinem Fall muss die so aussehen:
                                  deb http://old-releases.ubuntu.com/ubuntu/ impish main restricted universe multiverse
                                  deb http://old-releases.ubuntu.com/ubuntu/ impish-updates main restricted universe multiverse
                                  deb http://old-releases.ubuntu.com/ubuntu/ impish-security main restricted universe multiverse
                                  Weitere .list-Dateien (finden sich in /etc/apt/sources.list.d/ ) dann ggf. auch anpassen. Mindestens nach dem Upgrade auf den dann gültigen CODENAME (weiß gerade nicht bei welchem Viech die Ubuntus sind)
                                    crunchip Forum Testing Most Active @Homoran last edited by
                                    @homoran ja
                                    • Kusselin
                                      o.k.die source list habe ich gefunden während du das hier geschrieben hast..
                                      meine sieht jetzt so aus:
                                      deb http://archive.ubuntu.com/ubuntu impish main restricted universe multiverse
                                      deb http://archive.ubuntu.com/ubuntu impish-updates main restricted universe multiverse
                                      deb http://archive.ubuntu.com/ubuntu impish-security main restricted universe multiverse
                                      und die aändere ich komplett in:
                                      dann speichern und udn apt-get update udn danach apt-get upgrade....richtig?
                                      was ich jetzt aber noch nicht gerafft habe ist das mit dem Codename??
                                      Wo und wie muss ich den verwednen?
                                      Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                        @crunchip
                                        Ja, geht auch. Unter Umständen.
                                        'do-release-upgrade' macht aber u. U. noch anderes als 'nur' die Quellen umstellen. Daher würde ich immer versuchen über diesen Weg zu gehen.
                                          @kusselin sagte in Ubuntu updaten:
                                          Hast du denn in
                                          ls -lA /etc/apt/sources.list.d
                                          weitere Dateien drin? Vermultich die nodesource.list.
                                            @kusselin
                                            Wenn die sources.list geändert ist:
                                            sudo apt-get update
                                            sudo apt-get dist-upgrade
                                            4649
