    3. Off Topic
    4. [Gelöst] Ubuntu updaten
      Thomas Braun Most Active @Kusselin last edited by
      @kusselin
      Ja, mit
      sudo do-release-upgrade
      • Kusselin
        Kusselin @Thomas Braun last edited by
        @thomas-braun sagte in Ubuntu updaten:
        @kusselin
        Und künftig keine Zwischenversionen einsetzen sondern nur LTS-Releases.
        O.K. danke Dir ..mit dem befehl solls gehen?
          @kusselin
          Ja.
          Kusselin 1 Reply Last reply Reply Quote 0
          • Kusselin
            @thomas-braun schau...was muss ich hier denn machen??
            Checking for a new Ubuntu release
            Your Ubuntu release is not supported anymore.
            For upgrade information, please visit:
            http://www.ubuntu.com/releaseendoflife
            Please install all available updates for your release before upgrading.
              @kusselin
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              • Kusselin
                nee thomas.....das klappt so nicht...das wäre zu einfach 🙂
                 sudo apt update
                Hit:1 http://ppa.launchpad.net/ondrej/php/ubuntu impish InRelease
                Ign:2 http://archive.ubuntu.com/ubuntu impish InRelease
                Ign:3 http://archive.ubuntu.com/ubuntu impish-updates InRelease
                Ign:4 http://archive.ubuntu.com/ubuntu impish-security InRelease
                Err:5 http://archive.ubuntu.com/ubuntu impish Release
                  404  Not Found [IP: 91.189.91.39 80]
                Err:6 http://archive.ubuntu.com/ubuntu impish-updates Release
                Err:7 http://archive.ubuntu.com/ubuntu impish-security Release
                Reading package lists... Done
                E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' no longer has a Release file.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' no longer has a Release file.
                E: The repository 'http://archive.ubuntu.com/ubuntu impish-security Release' no longer has a Release file.
                root@Nextcloud-live:~# sudo apt full-upgrade
                Building dependency tree... Done
                Calculating upgrade... Done
                The following packages will be upgraded:
                  apt apt-utils isc-dhcp-client isc-dhcp-common libapt-pkg6.0 libkeyutils1
                  libnss-systemd libpam-systemd libsystemd0 libudev1 python3-distupgrade
                  systemd systemd-sysv systemd-timesyncd ubuntu-advantage-tools
                  ubuntu-release-upgrader-core udev
                17 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 10.4 MB of archives.
                After this operation, 32.8 kB of additional disk space will be used.
                Do you want to continue? [Y/n] y
                Err:1 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libnss-systemd amd64 248.3-1ubuntu8.6
                  404  Not Found [IP: 185.125.190.39 80]
                Err:2 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libsystemd0 amd64 248.3-1ubuntu8.6
                Err:3 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-timesyncd amd64 248.3-1ubuntu8.6
                Err:4 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd-sysv amd64 248.3-1ubuntu8.6
                Err:5 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libpam-systemd amd64 248.3-1ubuntu8.6
                Err:6 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 systemd amd64 248.3-1ubuntu8.6
                Err:7 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 udev amd64 248.3-1ubuntu8.6
                Err:8 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libudev1 amd64 248.3-1ubuntu8.6
                Err:9 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libapt-pkg6.0 amd64 2.3.9ubuntu0.1
                Err:10 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt amd64 2.3.9ubuntu0.1
                Err:11 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 apt-utils amd64 2.3.9ubuntu0.1
                Err:12 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 libkeyutils1 amd64 1.6.1-2ubuntu2.1
                Err:13 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-client amd64 4.4.1-2.3ubuntu1.1
                Err:14 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 isc-dhcp-common amd64 4.4.1-2.3ubuntu1.1
                Err:15 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-advantage-tools amd64 27.9~21.10.1
                Err:16 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 ubuntu-release-upgrader-core all 1:21.10.10
                Err:17 http://archive.ubuntu.com/ubuntu impish-updates/main amd64 python3-distupgrade all 1:21.10.10
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libnss-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libsystemd0_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-timesyncd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-sysv_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libpam-systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/udev_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev1_248.3-1ubuntu8.6_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/libapt-pkg6.0_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/apt/apt-utils_2.3.9ubuntu0.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/k/keyutils/libkeyutils1_1.6.1-2ubuntu2.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-client_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/i/isc-dhcp/isc-dhcp-common_4.4.1-2.3ubuntu1.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.9%7e21.10.1_amd64.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/ubuntu-release-upgrader-core_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/ubuntu-release-upgrader/python3-distupgrade_21.10.10_all.deb  404  Not Found [IP: 185.125.190.39 80]
                E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                  @kusselin
                  Installier es neu und halte da dann das EndOfLife im Auge und spring vorher auf den Nachfolger.
                    @kusselin
                    Kannst aber auch hier mal schauen:
                    https://help.ubuntu.com/community/EOLUpgrades
                    • Kusselin
                      @kusselin
                      andree Möglichkeit wie neuinstallation gibts nicht?
                      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @Kusselin last edited by Thomas Braun
                        @kusselin
                        Steht im dem Link drin:
                        Aber auch dort wird geschrieben:
                        Reinstalling is usually easier and faster, especially if you would have to upgrade through several releases.
                          crunchip Forum Testing Most Active @Kusselin last edited by
                          @kusselin hatte das kürzlich auch bei einer VM gemacht, sourceslist anpassen aufs aktuelle Ubuntu und danach das full update, geht ohne Probleme
                          Homoran Kusselin 2 Replies Last reply Reply Quote 0
                            Homoran Global Moderator Administrators @crunchip last edited by
                            @crunchip sagte in Ubuntu updaten:
                            war da das alte Repo auch nicht mehr erreichbar?
                            • Kusselin
                              Kusselin @crunchip last edited by
                              das hier:
                              ## EOL upgrade sources.list
                              # Required
                              deb http://old-releases.ubuntu.com/ubuntu/ CODENAME main restricted universe multiverse
                              deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-updates main restricted universe multiverse
                              deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-security main restricted universe multiverse
                              # Optional
                              #deb http://old-releases.ubuntu.com/ubuntu/ CODENAME-backports main restricted universe multiverse
                              muss in die source list.....
                              Bitte an euch...wo bzw. welche pfad ist das /etc/......?
                              und muss ich das alte dann komplett rausnehmen aus der source list udn das hier neu rein?
                                @kusselin
                                Das ist die /etc/apt/sources.list
                                In deinem Fall muss die so aussehen:
                                deb http://old-releases.ubuntu.com/ubuntu/ impish main restricted universe multiverse
                                deb http://old-releases.ubuntu.com/ubuntu/ impish-updates main restricted universe multiverse
                                deb http://old-releases.ubuntu.com/ubuntu/ impish-security main restricted universe multiverse
                                Weitere .list-Dateien (finden sich in /etc/apt/sources.list.d/ ) dann ggf. auch anpassen. Mindestens nach dem Upgrade auf den dann gültigen CODENAME (weiß gerade nicht bei welchem Viech die Ubuntus sind)
                                  crunchip Forum Testing Most Active @Homoran last edited by
                                  @homoran ja
                                  • Kusselin
                                    o.k.die source list habe ich gefunden während du das hier geschrieben hast..
                                    meine sieht jetzt so aus:
                                    deb http://archive.ubuntu.com/ubuntu impish main restricted universe multiverse
                                    deb http://archive.ubuntu.com/ubuntu impish-updates main restricted universe multiverse
                                    deb http://archive.ubuntu.com/ubuntu impish-security main restricted universe multiverse
                                    und die aändere ich komplett in:
                                    dann speichern und udn apt-get update udn danach apt-get upgrade....richtig?
                                    was ich jetzt aber noch nicht gerafft habe ist das mit dem Codename??
                                    Wo und wie muss ich den verwednen?
                                    Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                      @crunchip
                                      Ja, geht auch. Unter Umständen.
                                      'do-release-upgrade' macht aber u. U. noch anderes als 'nur' die Quellen umstellen. Daher würde ich immer versuchen über diesen Weg zu gehen.
                                        @kusselin sagte in Ubuntu updaten:
                                        Hast du denn in
                                        ls -lA /etc/apt/sources.list.d
                                        weitere Dateien drin? Vermultich die nodesource.list.
                                          @kusselin
                                          Wenn die sources.list geändert ist:
                                          sudo apt-get update
                                          sudo apt-get dist-upgrade
                                            Homoran Global Moderator Administrators @Kusselin last edited by Homoran
                                            richtig
                                            nicht wirklich.
                                            du sollst statt impish den aktuellen CODENAMEN eingeben.
                                            prüf mal. das könnte CANONICAL sein. ich kenne mich bei UBUNTU nicht aus
                                            4649
