    4. Fehler mit hm.rpc
    Fehler mit hm.rpc
      emil70 @Jan201 last edited by emil70
      @jan201
      Wie hast du die Instanz eingestellt ? Hast in Homematic und Firewall etwas eingestellt?
      Wegen CodeTags siehe das Bild
        Jan201 @emil70 last edited by
        @emil70 said in Fehler mit hm.rpc:
        @jan201
        Moin, ja genau wie in den Bildern habe ich es auch stehen. Habe Node jetzt auf 14.20.1 geupdatet.
          Thomas Braun Most Active @Jan201 last edited by
          @jan201 sagte in Fehler mit hm.rpc:
          Bring es auf 16.
            Jan201 @Thomas Braun last edited by
            @thomas-braun said in Fehler mit hm.rpc:
            Bring es auf 16.
            was mache ich hierbei?
            root@iobroker:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
            sudo apt install nodejs
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            ## Installing the NodeSource Node.js 16.x repo...
            ## Populating apt-get cache...
            + apt-get update
            Ign:1 http://archive.ubuntu.com/ubuntu impish InRelease
            Ign:2 http://archive.ubuntu.com/ubuntu impish-updates InRelease
            Ign:3 http://archive.ubuntu.com/ubuntu impish-security InRelease
            Err:4 http://archive.ubuntu.com/ubuntu impish Release
              404  Not Found [IP: 185.125.190.39 80]
            Hit:5 https://deb.nodesource.com/node_14.x impish InRelease
            Err:6 http://archive.ubuntu.com/ubuntu impish-updates Release
            Err:7 http://archive.ubuntu.com/ubuntu impish-security Release
            Reading package lists... Done
            E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' no longer has a Release file.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' no longer has a Release file.
            E: The repository 'http://archive.ubuntu.com/ubuntu impish-security Release' no longer has a Release file.
            Error executing command, exiting
            Building dependency tree... Done
            nodejs is already the newest version (14.20.1-deb-1nodesource1).
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            ln: failed to create symbolic link '/usr/bin/nodejs': File exists
              Thomas Braun Most Active @Jan201 last edited by Thomas Braun
              @jan201
              impish ist abgekündigt. Den Fall hatten wir gerade gestern. Such mal danach.
              Da muss man die Quellen anpassen.
              Edit:
              https://forum.iobroker.net/topic/58944/gelöst-ubuntu-updaten
                @jan201
                Edit:
                Okay, kann alles geschlossen werden. Jetzt geht der Container garnicht mehr.
                Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                  @jan201
                  Was haste denn jetzt gemacht?
                  Und Container sind doch so leicht zu handhaben, wird mir immer erzählt
                  • Glasfaser
                    Glasfaser @Jan201 last edited by
                    Diese INFO sollte ganz nach oben in deiner Thread Eröffnung .
                    Deshalb steht auch im angegeben Thread den Ich dir oben genannt habe alles drin .,,
                    So ist das nur ein Frage ---- Antwort Spiel !!
                      @jan201
                      nach der anleitung geupdatet. Habe es aber dank Snapshot wieder zurück bekommen. und versuche es nocheinmal.
                      auch hier kommt dann:
                      lxc-console: 200: tools/lxc_console.c: main: 129 200 is not running
                      [EOF - dtach terminating]
                      • Glasfaser
                        @jan201
                        Dein Thread Titel lautet : Fehler mit hm.rpc
                        der Fehler im Log hat nichts mit NodeJS zu tun.
                        Und ohne weiter Info´s kann man hier nicht helfen !
                        deshalb :
                        @glasfaser sagte in Fehler mit hm.rpc:
                          Jan201 @Glasfaser last edited by
                          @glasfaser said in Fehler mit hm.rpc:
                          @jan201
                          deshalb :
                          Das ist richtig. Aber das ist ja nun ein Folgeproblem.
                          Ich sollte Node auf 16 udgraden, das geht aber nicht weil mein Ubuntu zu alt ist. also das erstmal Upgraden. Das funktioniert also nicht. Wo soll ich nun anfangen? für jedes einzelne einen Thead eröffnen?
                          Was für Info´s möchtest du denn haben?
                          • Glasfaser
                            Glasfaser @Jan201 last edited by Glasfaser
                            Empfehlung ...
                            also schleppst du immer Fehler mit
                            Dann setze es neu auf ... dann ein Backup rein .
                            und lass die Finger von root ,melde dich als User an !
                              Empfehlung ...
                              Das sind doch mal vernünftige Aussagen. Ich würde mich gerne über User einloggen, jedoch weiß ich den Anmeldenamen und Passwort nicht mehr.
                              Das kommt nach dem update raus:
                              reparing to unpack .../012-libisc-export1105_1%3a9.11.19+dfsg-2.1ubuntu3_amd64.deb ...
                              Unpacking libisc-export1105:amd64 (1:9.11.19+dfsg-2.1ubuntu3) over (1:9.11.19+dfsg-2.1ubuntu1) ...
                              Preparing to unpack .../013-libdns-export1110_1%3a9.11.19+dfsg-2.1ubuntu3_amd64.deb ...
                              Unpacking libdns-export1110 (1:9.11.19+dfsg-2.1ubuntu3) over (1:9.11.19+dfsg-2.1ubuntu1) ...
                              Preparing to unpack .../014-isc-dhcp-client_4.4.1-2.3ubuntu2.3_amd64.deb ...
                              Unpacking isc-dhcp-client (4.4.1-2.3ubuntu2.3) over (4.4.1-2.3ubuntu1) ...
                              Preparing to unpack .../015-isc-dhcp-common_4.4.1-2.3ubuntu2.3_amd64.deb ...
                              Unpacking isc-dhcp-common (4.4.1-2.3ubuntu2.3) over (4.4.1-2.3ubuntu1) ...
                              Preparing to unpack .../016-iso-codes_4.9.0-1_all.deb ...
                              Unpacking iso-codes (4.9.0-1) over (4.6.0-1) ...
                              Preparing to unpack .../017-less_590-1build1_amd64.deb ...
                              Unpacking less (590-1build1) over (551-2) ...
                              Preparing to unpack .../018-libatm1_1%3a2.5.1-4build2_amd64.deb ...
                              Unpacking libatm1:amd64 (1:2.5.1-4build2) over (1:2.5.1-4build1) ...
                              Preparing to unpack .../019-libestr0_0.1.10-2.1build3_amd64.deb ...
                              Unpacking libestr0:amd64 (0.1.10-2.1build3) over (0.1.10-2.1build2) ...
                              Preparing to unpack .../020-libfastjson4_0.99.9-1build2_amd64.deb ...
                              Unpacking libfastjson4:amd64 (0.99.9-1build2) over (0.99.9-1build1) ...
                              Preparing to unpack .../021-libfribidi-dev_1.0.8-2ubuntu3.1_amd64.deb ...
                              Unpacking libfribidi-dev:amd64 (1.0.8-2ubuntu3.1) over (1.0.8-2ubuntu2) ...
                              Preparing to unpack .../022-libfribidi0_1.0.8-2ubuntu3.1_amd64.deb ...
                              Unpacking libfribidi0:amd64 (1.0.8-2ubuntu3.1) over (1.0.8-2ubuntu2) ...
                              Preparing to unpack .../023-libnetplan0_0.104-0ubuntu2.1_amd64.deb ...
                              Unpacking libnetplan0:amd64 (0.104-0ubuntu2.1) over (0.103-0ubuntu7.2) ...
                              Preparing to unpack .../024-libslang2_2.3.2-5build4_amd64.deb ...
                              Unpacking libslang2:amd64 (2.3.2-5build4) over (2.3.2-5build2) ...
                              Preparing to unpack .../025-libnewt0.52_0.52.21-5ubuntu2_amd64.deb ...
                              Unpacking libnewt0.52:amd64 (0.52.21-5ubuntu2) over (0.52.21-4ubuntu7) ...
                              Preparing to unpack .../026-libxml2_2.9.13+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libxml2:amd64 (2.9.13+dfsg-1ubuntu0.1) over (2.9.12+dfsg-4) ...
                              Preparing to unpack .../027-logrotate_3.19.0-1ubuntu1.1_amd64.deb ...
                              Unpacking logrotate (3.19.0-1ubuntu1.1) over (3.18.0-2ubuntu1) ...
                              Preparing to unpack .../028-lsb-release_11.1.0ubuntu4_all.deb ...
                              Unpacking lsb-release (11.1.0ubuntu4) over (11.1.0ubuntu3) ...
                              Preparing to unpack .../029-netcat-openbsd_1.218-4ubuntu1_amd64.deb ...
                              Unpacking netcat-openbsd (1.218-4ubuntu1) over (1.217-3ubuntu1) ...
                              Preparing to unpack .../030-netplan.io_0.104-0ubuntu2.1_amd64.deb ...
                              Unpacking netplan.io (0.104-0ubuntu2.1) over (0.103-0ubuntu7.2) ...
                              Preparing to unpack .../031-networkd-dispatcher_2.1-2ubuntu0.22.04.2_all.deb ...
                              Unpacking networkd-dispatcher (2.1-2ubuntu0.22.04.2) over (2.1-2) ...
                              Preparing to unpack .../032-python3-pkg-resources_59.6.0-1.2_all.deb ...
                              Unpacking python3-pkg-resources (59.6.0-1.2) over (52.0.0-4) ...
                              Preparing to unpack .../033-rsyslog_8.2112.0-2ubuntu2.2_amd64.deb ...
                              Unpacking rsyslog (8.2112.0-2ubuntu2.2) over (8.2102.0-2ubuntu2) ...
                              Preparing to unpack .../034-shared-mime-info_2.1-2_amd64.deb ...
                              Unpacking shared-mime-info (2.1-2) over (2.1-1) ...
                              Preparing to unpack .../035-sudo_1.9.9-1ubuntu2_amd64.deb ...
                              Unpacking sudo (1.9.9-1ubuntu2) over (1.9.5p2-3ubuntu2) ...
                              Preparing to unpack .../036-tzdata_2022c-0ubuntu0.22.04.0_all.deb ...
                              Unpacking tzdata (2022c-0ubuntu0.22.04.0) over (2021e-0ubuntu0.21.10) ...
                              Preparing to unpack .../037-ubuntu-advantage-tools_27.11.2~22.04.1_amd64.deb ...
                              Unpacking ubuntu-advantage-tools (27.11.2~22.04.1) over (27.4.2~21.10.1) ...
                              Preparing to unpack .../038-xxd_2%3a8.2.3995-1ubuntu2.1_amd64.deb ...
                              Unpacking xxd (2:8.2.3995-1ubuntu2.1) over (2:8.2.2434-3ubuntu3.1) ...
                              Preparing to unpack .../039-vim-tiny_2%3a8.2.3995-1ubuntu2.1_amd64.deb ...
                              Unpacking vim-tiny (2:8.2.3995-1ubuntu2.1) over (2:8.2.2434-3ubuntu3.1) ...
                              Preparing to unpack .../040-vim-common_2%3a8.2.3995-1ubuntu2.1_all.deb ...
                              Unpacking vim-common (2:8.2.3995-1ubuntu2.1) over (2:8.2.2434-3ubuntu3.1) ...
                              Preparing to unpack .../041-whiptail_0.52.21-5ubuntu2_amd64.deb ...
                              Unpacking whiptail (0.52.21-5ubuntu2) over (0.52.21-4ubuntu7) ...
                              Preparing to unpack .../042-ubuntu-minimal_1.481_amd64.deb ...
                              Unpacking ubuntu-minimal (1.481) over (1.472) ...
                              Preparing to unpack .../043-xdg-user-dirs_0.17-2ubuntu4_amd64.deb ...
                              Unpacking xdg-user-dirs (0.17-2ubuntu4) over (0.17-2ubuntu3) ...
                              Preparing to unpack .../044-apparmor_3.0.4-2ubuntu2.1_amd64.deb ...
                              Unpacking apparmor (3.0.4-2ubuntu2.1) over (3.0.3-0ubuntu1) ...
                              Preparing to unpack .../045-bash-completion_1%3a2.11-5ubuntu1_all.deb ...
                              Unpacking bash-completion (1:2.11-5ubuntu1) over (1:2.11-2ubuntu1) ...
                              Preparing to unpack .../046-liblmdb0_0.9.24-1build2_amd64.deb ...
                              Unpacking liblmdb0:amd64 (0.9.24-1build2) over (0.9.24-1) ...
                              Preparing to unpack .../047-libmaxminddb0_1.5.2-1build2_amd64.deb ...
                              Unpacking libmaxminddb0:amd64 (1.5.2-1build2) over (1.5.2-1) ...
                              Preparing to unpack .../048-libuv1_1.43.0-1_amd64.deb ...
                              Unpacking libuv1:amd64 (1.43.0-1) over (1.40.0-2ubuntu1) ...
                              Preparing to unpack .../049-bind9-dnsutils_1%3a9.18.1-1ubuntu1.2_amd64.deb ...
                              Unpacking bind9-dnsutils (1:9.18.1-1ubuntu1.2) over (1:9.16.15-1ubuntu1.1) ...
                              Preparing to unpack .../050-bind9-libs_1%3a9.18.1-1ubuntu1.2_amd64.deb ...
                              Unpacking bind9-libs:amd64 (1:9.18.1-1ubuntu1.2) over (1:9.16.15-1ubuntu1.1) ...
                              Preparing to unpack .../051-bind9-host_1%3a9.18.1-1ubuntu1.2_amd64.deb ...
                              Unpacking bind9-host (1:9.18.1-1ubuntu1.2) over (1:9.16.15-1ubuntu1.1) ...
                              Preparing to unpack .../052-bsdextrautils_2.37.2-4ubuntu3_amd64.deb ...
                              Unpacking bsdextrautils (2.37.2-4ubuntu3) over (2.36.1-8ubuntu2) ...
                              Preparing to unpack .../053-busybox-static_1%3a1.30.1-7ubuntu3_amd64.deb ...
                              Unpacking busybox-static (1:1.30.1-7ubuntu3) over (1:1.30.1-6ubuntu3.1) ...
                              Preparing to unpack .../054-command-not-found_22.04.0_all.deb ...
                              Unpacking command-not-found (22.04.0) over (21.10.0) ...
                              Preparing to unpack .../055-python3-commandnotfound_22.04.0_all.deb ...
                              Unpacking python3-commandnotfound (22.04.0) over (21.10.0) ...
                              Preparing to unpack .../056-dmidecode_3.3-3ubuntu0.1_amd64.deb ...
                              Unpacking dmidecode (3.3-3ubuntu0.1) over (3.3-3) ...
                              Preparing to unpack .../057-dosfstools_4.2-1build3_amd64.deb ...
                              Unpacking dosfstools (4.2-1build3) over (4.2-1build2) ...
                              Preparing to unpack .../058-ed_1.18-1_amd64.deb ...
                              Unpacking ed (1.18-1) over (1.17-1) ...
                              Preparing to unpack .../059-file_1%3a5.41-3_amd64.deb ...
                              Unpacking file (1:5.41-3) over (1:5.39-3) ...
                              Preparing to unpack .../060-libmagic1_1%3a5.41-3_amd64.deb ...
                              Unpacking libmagic1:amd64 (1:5.41-3) over (1:5.39-3) ...
                              Preparing to unpack .../061-libmagic-mgc_1%3a5.41-3_amd64.deb ...
                              Unpacking libmagic-mgc (1:5.41-3) over (1:5.39-3) ...
                              Selecting previously unselected package tnftp.
                              Preparing to unpack .../062-tnftp_20210827-4build1_amd64.deb ...
                              Unpacking tnftp (20210827-4build1) ...
                              Preparing to unpack .../063-ftp_20210827-4build1_all.deb ...
                              Unpacking ftp (20210827-4build1) over (0.17-34.1.1) ...
                              Preparing to unpack .../064-gettext-base_0.21-4ubuntu4_amd64.deb ...
                              Unpacking gettext-base (0.21-4ubuntu4) over (0.21-4ubuntu3) ...
                              Preparing to unpack .../065-libuchardet0_0.0.7-1build2_amd64.deb ...
                              Unpacking libuchardet0:amd64 (0.0.7-1build2) over (0.0.7-1build1) ...
                              Preparing to unpack .../066-groff-base_1.22.4-8build1_amd64.deb ...
                              Unpacking groff-base (1.22.4-8build1) over (1.22.4-7) ...
                              Preparing to unpack .../067-hdparm_9.60+ds-1build3_amd64.deb ...
                              Unpacking hdparm (9.60+ds-1build3) over (9.60+ds-1build2) ...
                              Preparing to unpack .../068-info_6.8-4build1_amd64.deb ...
                              Unpacking info (6.8-4build1) over (6.7.0.dfsg.2-6) ...
                              Preparing to unpack .../069-iputils-tracepath_3%3a20211215-1_amd64.deb ...
                              Unpacking iputils-tracepath (3:20211215-1) over (3:20210202-1) ...
                              Preparing to unpack .../070-libdrm-common_2.4.110-1ubuntu1_all.deb ...
                              Unpacking libdrm-common (2.4.110-1ubuntu1) over (2.4.107-8ubuntu1) ...
                              Preparing to unpack .../071-libdrm2_2.4.110-1ubuntu1_amd64.deb ...
                              Unpacking libdrm2:amd64 (2.4.110-1ubuntu1) over (2.4.107-8ubuntu1) ...
                              Selecting previously unselected package libjansson4:amd64.
                              Preparing to unpack .../072-libjansson4_2.13.1-1.1build3_amd64.deb ...
                              Unpacking libjansson4:amd64 (2.13.1-1.1build3) ...
                              Selecting previously unselected package libnftables1:amd64.
                              Preparing to unpack .../073-libnftables1_1.0.2-1ubuntu3_amd64.deb ...
                              Unpacking libnftables1:amd64 (1.0.2-1ubuntu3) ...
                              Preparing to unpack .../074-parted_3.4-2build1_amd64.deb ...
                              Unpacking parted (3.4-2build1) over (3.4-1) ...
                              Preparing to unpack .../075-libparted2_3.4-2build1_amd64.deb ...
                              Unpacking libparted2:amd64 (3.4-2build1) over (3.4-1) ...
                              Preparing to unpack .../076-libpcap0.8_1.10.1-4build1_amd64.deb ...
                              Unpacking libpcap0.8:amd64 (1.10.1-4build1) over (1.10.0-2build1) ...
                              Preparing to unpack .../077-pci.ids_0.0~2022.01.22-1_all.deb ...
                              Unpacking pci.ids (0.0~2022.01.22-1) over (0.0~2021.08.22-1) ...
                              Preparing to unpack .../078-pciutils_1%3a3.7.0-6_amd64.deb ...
                              Unpacking pciutils (1:3.7.0-6) over (1:3.7.0-5ubuntu2) ...
                              Preparing to unpack .../079-libpci3_1%3a3.7.0-6_amd64.deb ...
                              Unpacking libpci3:amd64 (1:3.7.0-6) over (1:3.7.0-5ubuntu2) ...
                              Preparing to unpack .../080-libpipeline1_1.5.5-1_amd64.deb ...
                              Unpacking libpipeline1:amd64 (1.5.5-1) over (1.5.3-1build1) ...
                              Preparing to unpack .../081-libpng-dev_1.6.37-3build5_amd64.deb ...
                              Unpacking libpng-dev:amd64 (1.6.37-3build5) over (1.6.37-3build4) ...
                              Preparing to unpack .../082-libpng16-16_1.6.37-3build5_amd64.deb ...
                              Unpacking libpng16-16:amd64 (1.6.37-3build5) over (1.6.37-3build4) ...
                              Preparing to unpack .../083-libplymouth5_0.9.5+git20211018-1ubuntu3_amd64.deb ...
                              Unpacking libplymouth5:amd64 (0.9.5+git20211018-1ubuntu3) over (0.9.5git20210406-0ubuntu2) ...
                              Preparing to unpack .../084-libusb-1.0-0_2%3a1.0.25-1ubuntu2_amd64.deb ...
                              Unpacking libusb-1.0-0:amd64 (2:1.0.25-1ubuntu2) over (2:1.0.24-3) ...
                              Preparing to unpack .../085-libx11-data_2%3a1.7.5-1_all.deb ...
                              Unpacking libx11-data (2:1.7.5-1) over (2:1.7.2-1) ...
                              Preparing to unpack .../086-libxau-dev_1%3a1.0.9-1build5_amd64.deb ...
                              Unpacking libxau-dev:amd64 (1:1.0.9-1build5) over (1:1.0.9-1build3) ...
                              Preparing to unpack .../087-libxau6_1%3a1.0.9-1build5_amd64.deb ...
                              Unpacking libxau6:amd64 (1:1.0.9-1build5) over (1:1.0.9-1build3) ...
                              Preparing to unpack .../088-x11proto-dev_2021.5-1_all.deb ...
                              Unpacking x11proto-dev (2021.5-1) over (2020.1-1) ...
                              Preparing to unpack .../089-libxdmcp-dev_1%3a1.1.3-0ubuntu5_amd64.deb ...
                              Unpacking libxdmcp-dev:amd64 (1:1.1.3-0ubuntu5) over (1:1.1.3-0ubuntu4) ...
                              Preparing to unpack .../090-libxdmcp6_1%3a1.1.3-0ubuntu5_amd64.deb ...
                              Unpacking libxdmcp6:amd64 (1:1.1.3-0ubuntu5) over (1:1.1.3-0ubuntu4) ...
                              Preparing to unpack .../091-libxcb1-dev_1.14-3ubuntu3_amd64.deb ...
                              Unpacking libxcb1-dev:amd64 (1.14-3ubuntu3) over (1.14-3ubuntu1) ...
                              Preparing to unpack .../092-libxcb1_1.14-3ubuntu3_amd64.deb ...
                              Unpacking libxcb1:amd64 (1.14-3ubuntu3) over (1.14-3ubuntu1) ...
                              Preparing to unpack .../093-libpthread-stubs0-dev_0.4-1build2_amd64.deb ...
                              Unpacking libpthread-stubs0-dev:amd64 (0.4-1build2) over (0.4-1build1) ...
                              Preparing to unpack .../094-libx11-dev_2%3a1.7.5-1_amd64.deb ...
                              Unpacking libx11-dev:amd64 (2:1.7.5-1) over (2:1.7.2-1) ...
                              Preparing to unpack .../095-libx11-6_2%3a1.7.5-1_amd64.deb ...
                              Unpacking libx11-6:amd64 (2:1.7.5-1) over (2:1.7.2-1) ...
                              Preparing to unpack .../096-libxext-dev_2%3a1.3.4-1build1_amd64.deb ...
                              Unpacking libxext-dev:amd64 (2:1.3.4-1build1) over (2:1.3.4-0ubuntu3) ...
                              Preparing to unpack .../097-libxext6_2%3a1.3.4-1build1_amd64.deb ...
                              Unpacking libxext6:amd64 (2:1.3.4-1build1) over (2:1.3.4-0ubuntu3) ...
                              Preparing to unpack .../098-libxmuu1_2%3a1.1.3-3_amd64.deb ...
                              Unpacking libxmuu1:amd64 (2:1.1.3-3) over (2:1.1.3-0ubuntu1) ...
                              Preparing to unpack .../099-lshw_02.19.git.2021.06.19.996aaad9c7-2build1_amd64.deb ...
                              Unpacking lshw (02.19.git.2021.06.19.996aaad9c7-2build1) over (02.18.85-0.7ubuntu1) ...
                              Preparing to unpack .../100-lsof_4.93.2+dfsg-1.1build2_amd64.deb ...
                              Unpacking lsof (4.93.2+dfsg-1.1build2) over (4.93.2+dfsg-1.1) ...
                              Preparing to unpack .../101-man-db_2.10.2-1_amd64.deb ...
                              Unpacking man-db (2.10.2-1) over (2.9.4-2) ...
                              Preparing to unpack .../102-mtr-tiny_0.95-1_amd64.deb ...
                              Unpacking mtr-tiny (0.95-1) over (0.94-1build1) ...
                              Preparing to unpack .../103-nano_6.2-1_amd64.deb ...
                              Unpacking nano (6.2-1) over (5.6.1-1build1) ...
                              Selecting previously unselected package nftables.
                              Preparing to unpack .../104-nftables_1.0.2-1ubuntu3_amd64.deb ...
                              Unpacking nftables (1.0.2-1ubuntu3) ...
                              Preparing to unpack .../105-plymouth-theme-ubuntu-text_0.9.5+git20211018-1ubuntu3_amd64.deb ...
                              Unpacking plymouth-theme-ubuntu-text (0.9.5+git20211018-1ubuntu3) over (0.9.5git20210406-0ubuntu2) ...
                              Preparing to unpack .../106-plymouth_0.9.5+git20211018-1ubuntu3_amd64.deb ...
                              Unpacking plymouth (0.9.5+git20211018-1ubuntu3) over (0.9.5git20210406-0ubuntu2) ...
                              Preparing to unpack .../107-psmisc_23.4-2build3_amd64.deb ...
                              Unpacking psmisc (23.4-2build3) over (23.4-2build1) ...
                              Preparing to unpack .../108-publicsuffix_20211207.1025-1_all.deb ...
                              Unpacking publicsuffix (20211207.1025-1) over (20210108.1309-1) ...
                              Preparing to unpack .../109-python3-distro-info_1.1build1_all.deb ...
                              Unpacking python3-distro-info (1.1build1) over (1.0) ...
                              Preparing to unpack .../110-ubuntu-release-upgrader-core_1%3a22.04.14_all.deb ...
                              Unpacking ubuntu-release-upgrader-core (1:22.04.14) over (1:21.10.8) ...
                              Preparing to unpack .../111-python3-distupgrade_1%3a22.04.14_all.deb ...
                              Unpacking python3-distupgrade (1:22.04.14) over (1:21.10.8) ...
                              Preparing to unpack .../112-python3-update-manager_1%3a22.04.9_all.deb ...
                              Unpacking python3-update-manager (1:22.04.9) over (1:21.10.5) ...
                              Preparing to unpack .../113-update-manager-core_1%3a22.04.9_all.deb ...
                              Unpacking update-manager-core (1:22.04.9) over (1:21.10.5) ...
                              Preparing to unpack .../114-libunwind8_1.3.2-2build2_amd64.deb ...
                              Unpacking libunwind8:amd64 (1.3.2-2build2) over (1.3.2-2) ...
                              Preparing to unpack .../115-strace_5.16-0ubuntu3_amd64.deb ...
                              Unpacking strace (5.16-0ubuntu3) over (5.13-0ubuntu1) ...
                              Preparing to unpack .../116-tcpdump_4.99.1-3build2_amd64.deb ...
                              Unpacking tcpdump (4.99.1-3build2) over (4.99.0-2) ...
                              Preparing to unpack .../117-telnet_0.17-44build1_amd64.deb ...
                              Unpacking telnet (0.17-44build1) over (0.17-42) ...
                              Preparing to unpack .../118-time_1.9-0.1build2_amd64.deb ...
                              Unpacking time (1.9-0.1build2) over (1.9-0.1) ...
                              Preparing to unpack .../119-usb.ids_2022.04.02-1_all.deb ...
                              Unpacking usb.ids (2022.04.02-1) over (2021.07.19-1) ...
                              Preparing to unpack .../120-usbutils_1%3a014-1build1_amd64.deb ...
                              Unpacking usbutils (1:014-1build1) over (1:013-3build1) ...
                              Preparing to unpack .../121-wget_1.21.2-2ubuntu1_amd64.deb ...
                              Unpacking wget (1.21.2-2ubuntu1) over (1.21-1ubuntu3) ...
                              Preparing to unpack .../122-ubuntu-standard_1.481_amd64.deb ...
                              Unpacking ubuntu-standard (1.481) over (1.472) ...
                              Preparing to unpack .../123-ufw_0.36.1-4build1_all.deb ...
                              Unpacking ufw (0.36.1-4build1) over (0.36.1-1ubuntu1) ...
                              Preparing to unpack .../124-xauth_1%3a1.1-1build2_amd64.deb ...
                              Unpacking xauth (1:1.1-1build2) over (1:1.1-1) ...
                              Preparing to unpack .../125-build-essential_12.9ubuntu3_amd64.deb ...
                              Unpacking build-essential (12.9ubuntu3) over (12.9ubuntu2) ...
                              Preparing to unpack .../126-cifs-utils_2%3a6.14-1ubuntu0.1_amd64.deb ...
                              Unpacking cifs-utils (2:6.14-1ubuntu0.1) over (2:6.11-3.1) ...
                              Preparing to unpack .../127-libubsan1_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking libubsan1:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../128-libtsan0_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking libtsan0:amd64 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../129-libgomp1_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking libgomp1:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../130-libitm1_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking libitm1:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../131-libatomic1_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking libatomic1:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../132-libasan6_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking libasan6:amd64 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../133-liblsan0_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking liblsan0:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../134-libquadmath0_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking libquadmath0:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../135-g++-11_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking g++-11 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../136-gcc-11_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking gcc-11 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../137-libstdc++-11-dev_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking libstdc++-11-dev:amd64 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../138-libgcc-11-dev_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking libgcc-11-dev:amd64 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../139-libcc1-0_12.1.0-2ubuntu1~22.04_amd64.deb ...
                              Unpacking libcc1-0:amd64 (12.1.0-2ubuntu1~22.04) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../140-cpp-11_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking cpp-11 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../141-gcc-11-base_11.2.0-19ubuntu1_amd64.deb ...
                              Unpacking gcc-11-base:amd64 (11.2.0-19ubuntu1) over (11.2.0-7ubuntu2) ...
                              Preparing to unpack .../142-libisl23_0.24-2build1_amd64.deb ...
                              Unpacking libisl23:amd64 (0.24-2build1) over (0.24-1) ...
                              Preparing to unpack .../143-libmpfr6_4.1.0-3build3_amd64.deb ...
                              Unpacking libmpfr6:amd64 (4.1.0-3build3) over (4.1.0-3build1) ...
                              Preparing to unpack .../144-libmpc3_1.2.1-2build1_amd64.deb ...
                              Unpacking libmpc3:amd64 (1.2.1-2build1) over (1.2.0-1build1) ...
                              Preparing to unpack .../145-curl_7.81.0-1ubuntu1.4_amd64.deb ...
                              Unpacking curl (7.81.0-1ubuntu1.4) over (7.74.0-1.3ubuntu2) ...
                              Preparing to unpack .../146-libcurl4_7.81.0-1ubuntu1.4_amd64.deb ...
                              Unpacking libcurl4:amd64 (7.81.0-1ubuntu1.4) over (7.74.0-1.3ubuntu2) ...
                              Preparing to unpack .../147-libfakeroot_1.28-1ubuntu1_amd64.deb ...
                              Unpacking libfakeroot:amd64 (1.28-1ubuntu1) over (1.25.3-1.1ubuntu2) ...
                              Preparing to unpack .../148-fakeroot_1.28-1ubuntu1_amd64.deb ...
                              Unpacking fakeroot (1.28-1ubuntu1) over (1.25.3-1.1ubuntu2) ...
                              Preparing to unpack .../149-libfontconfig1-dev_2.13.1-4.2ubuntu5_amd64.deb ...
                              Unpacking libfontconfig1-dev:amd64 (2.13.1-4.2ubuntu5) over (2.13.1-4.2ubuntu3) ...
                              Preparing to unpack .../150-libfreetype6-dev_2.11.1+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libfreetype6-dev:amd64 (2.11.1+dfsg-1ubuntu0.1) over (2.10.4+dfsg-1build1) ...
                              Preparing to unpack .../151-libfreetype-dev_2.11.1+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libfreetype-dev:amd64 (2.11.1+dfsg-1ubuntu0.1) over (2.10.4+dfsg-1build1) ...
                              Preparing to unpack .../152-libfreetype6_2.11.1+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libfreetype6:amd64 (2.11.1+dfsg-1ubuntu0.1) over (2.10.4+dfsg-1build1) ...
                              Preparing to unpack .../153-libfontconfig-dev_2.13.1-4.2ubuntu5_amd64.deb ...
                              Unpacking libfontconfig-dev:amd64 (2.13.1-4.2ubuntu5) over (2.13.1-4.2ubuntu3) ...
                              Preparing to unpack .../154-fontconfig-config_2.13.1-4.2ubuntu5_all.deb ...
                              Unpacking fontconfig-config (2.13.1-4.2ubuntu5) over (2.13.1-4.2ubuntu3) ...
                              Preparing to unpack .../155-libfontconfig1_2.13.1-4.2ubuntu5_amd64.deb ...
                              Unpacking libfontconfig1:amd64 (2.13.1-4.2ubuntu5) over (2.13.1-4.2ubuntu3) ...
                              Preparing to unpack .../156-fontconfig_2.13.1-4.2ubuntu5_amd64.deb ...
                              Unpacking fontconfig (2.13.1-4.2ubuntu5) over (2.13.1-4.2ubuntu3) ...
                              Preparing to unpack .../157-libgdk-pixbuf-2.0-dev_2.42.8+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libgdk-pixbuf-2.0-dev:amd64 (2.42.8+dfsg-1ubuntu0.1) over (2.42.6+dfsg-1build2) ...
                              Preparing to unpack .../158-libgdk-pixbuf-2.0-0_2.42.8+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libgdk-pixbuf-2.0-0:amd64 (2.42.8+dfsg-1ubuntu0.1) over (2.42.6+dfsg-1build2) ...
                              Preparing to unpack .../159-libgdk-pixbuf2.0-common_2.42.8+dfsg-1ubuntu0.1_all.deb ...
                              Unpacking libgdk-pixbuf2.0-common (2.42.8+dfsg-1ubuntu0.1) over (2.42.6+dfsg-1build2) ...
                              Preparing to unpack .../160-libjpeg-turbo8-dev_2.1.2-0ubuntu1_amd64.deb ...
                              Unpacking libjpeg-turbo8-dev:amd64 (2.1.2-0ubuntu1) over (2.0.6-0ubuntu2) ...
                              Preparing to unpack .../161-libjpeg-turbo8_2.1.2-0ubuntu1_amd64.deb ...
                              Unpacking libjpeg-turbo8:amd64 (2.1.2-0ubuntu1) over (2.0.6-0ubuntu2) ...
                              Preparing to unpack .../162-libjpeg8-dev_8c-2ubuntu10_amd64.deb ...
                              Unpacking libjpeg8-dev:amd64 (8c-2ubuntu10) over (8c-2ubuntu8) ...
                              Preparing to unpack .../163-libjpeg8_8c-2ubuntu10_amd64.deb ...
                              Unpacking libjpeg8:amd64 (8c-2ubuntu10) over (8c-2ubuntu8) ...
                              Preparing to unpack .../164-libjbig-dev_2.1-3.1build3_amd64.deb ...
                              Unpacking libjbig-dev:amd64 (2.1-3.1build3) over (2.1-3.1build1) ...
                              Preparing to unpack .../165-libjbig0_2.1-3.1build3_amd64.deb ...
                              Unpacking libjbig0:amd64 (2.1-3.1build3) over (2.1-3.1build1) ...
                              Preparing to unpack .../166-libjpeg-dev_8c-2ubuntu10_amd64.deb ...
                              Unpacking libjpeg-dev:amd64 (8c-2ubuntu10) over (8c-2ubuntu8) ...
                              Preparing to unpack .../167-libtiff-dev_4.3.0-6ubuntu0.1_amd64.deb ...
                              Unpacking libtiff-dev:amd64 (4.3.0-6ubuntu0.1) over (4.3.0-1) ...
                              Preparing to unpack .../168-libtiffxx5_4.3.0-6ubuntu0.1_amd64.deb ...
                              Unpacking libtiffxx5:amd64 (4.3.0-6ubuntu0.1) over (4.3.0-1) ...
                              Preparing to unpack .../169-libdeflate-dev_1.10-2_amd64.deb ...
                              Unpacking libdeflate-dev:amd64 (1.10-2) over (1.7-2ubuntu2) ...
                              Preparing to unpack .../170-libdeflate0_1.10-2_amd64.deb ...
                              Unpacking libdeflate0:amd64 (1.10-2) over (1.7-2ubuntu2) ...
                              Selecting previously unselected package libwebp7:amd64.
                              Preparing to unpack .../171-libwebp7_1.2.2-2_amd64.deb ...
                              Unpacking libwebp7:amd64 (1.2.2-2) ...
                              Preparing to unpack .../172-libtiff5_4.3.0-6ubuntu0.1_amd64.deb ...
                              Unpacking libtiff5:amd64 (4.3.0-6ubuntu0.1) over (4.3.0-1) ...
                              Preparing to unpack .../173-libgdk-pixbuf2.0-bin_2.42.8+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking libgdk-pixbuf2.0-bin (2.42.8+dfsg-1ubuntu0.1) over (2.42.6+dfsg-1build2) ...
                              Preparing to unpack .../174-gir1.2-gdkpixbuf-2.0_2.42.8+dfsg-1ubuntu0.1_amd64.deb ...
                              Unpacking gir1.2-gdkpixbuf-2.0:amd64 (2.42.8+dfsg-1ubuntu0.1) over (2.42.6+dfsg-1build2) ...
                              Preparing to unpack .../175-libgraphite2-dev_1.3.14-1build2_amd64.deb ...
                              Unpacking libgraphite2-dev:amd64 (1.3.14-1build2) over (1.3.14-1) ...
                              Preparing to unpack .../176-libgraphite2-3_1.3.14-1build2_amd64.deb ...
                              Unpacking libgraphite2-3:amd64 (1.3.14-1build2) over (1.3.14-1) ...
                              Preparing to unpack .../177-libharfbuzz-dev_2.7.4-1ubuntu3.1_amd64.deb ...
                              Unpacking libharfbuzz-dev:amd64 (2.7.4-1ubuntu3.1) over (2.7.4-1ubuntu1) ...
                              Preparing to unpack .../178-libharfbuzz0b_2.7.4-1ubuntu3.1_amd64.deb ...
                              Unpacking libharfbuzz0b:amd64 (2.7.4-1ubuntu3.1) over (2.7.4-1ubuntu1) ...
                              Preparing to unpack .../179-libharfbuzz-icu0_2.7.4-1ubuntu3.1_amd64.deb ...
                              Unpacking libharfbuzz-icu0:amd64 (2.7.4-1ubuntu3.1) over (2.7.4-1ubuntu1) ...
                              Preparing to unpack .../180-libharfbuzz-gobject0_2.7.4-1ubuntu3.1_amd64.deb ...
                              Unpacking libharfbuzz-gobject0:amd64 (2.7.4-1ubuntu3.1) over (2.7.4-1ubuntu1) ...
                              dpkg: considering deconfiguration of icu-devtools, which would be broken by installation of libicu-dev:amd64 ...
                              dpkg: yes, will deconfigure icu-devtools (broken by libicu-dev:amd64)
                              Preparing to unpack .../181-libicu-dev_70.1-2_amd64.deb ...
                              De-configuring icu-devtools (67.1-7ubuntu1), to allow installation of libicu-dev:amd64 (70.1-2) ...
                              Unpacking libicu-dev:amd64 (70.1-2) over (67.1-7ubuntu1) ...
                              Preparing to unpack .../182-icu-devtools_70.1-2_amd64.deb ...
                              Unpacking icu-devtools (70.1-2) over (67.1-7ubuntu1) ...
                              Preparing to unpack .../183-gir1.2-harfbuzz-0.0_2.7.4-1ubuntu3.1_amd64.deb ...
                              Unpacking gir1.2-harfbuzz-0.0:amd64 (2.7.4-1ubuntu3.1) over (2.7.4-1ubuntu1) ...
                              Preparing to unpack .../184-liblzo2-2_2.10-2build3_amd64.deb ...
                              Unpacking liblzo2-2:amd64 (2.10-2build3) over (2.10-2build1) ...
                              Preparing to unpack .../185-libcairo2-dev_1.16.0-5ubuntu2_amd64.deb ...
                              Unpacking libcairo2-dev:amd64 (1.16.0-5ubuntu2) over (1.16.0-5ubuntu1) ...
                              Preparing to unpack .../186-libcairo-script-interpreter2_1.16.0-5ubuntu2_amd64.deb ...
                              Unpacking libcairo-script-interpreter2:amd64 (1.16.0-5ubuntu2) over (1.16.0-5ubuntu1) ...
                              Preparing to unpack .../187-libxrender-dev_1%3a0.9.10-1build4_amd64.deb ...
                              Unpacking libxrender-dev:amd64 (1:0.9.10-1build4) over (1:0.9.10-1build2) ...
                              Preparing to unpack .../188-libxrender1_1%3a0.9.10-1build4_amd64.deb ...
                              Unpacking libxrender1:amd64 (1:0.9.10-1build4) over (1:0.9.10-1build2) ...
                              Preparing to unpack .../189-libice-dev_2%3a1.0.10-1build2_amd64.deb ...
                              Unpacking libice-dev:amd64 (2:1.0.10-1build2) over (2:1.0.10-1build1) ...
                              Preparing to unpack .../190-libice6_2%3a1.0.10-1build2_amd64.deb ...
                              Unpacking libice6:amd64 (2:1.0.10-1build2) over (2:1.0.10-1build1) ...
                              Preparing to unpack .../191-libsm-dev_2%3a1.2.3-1build2_amd64.deb ...
                              Unpacking libsm-dev:amd64 (2:1.2.3-1build2) over (2:1.2.3-1build1) ...
                              Preparing to unpack .../192-libsm6_2%3a1.2.3-1build2_amd64.deb ...
                              Unpacking libsm6:amd64 (2:1.2.3-1build2) over (2:1.2.3-1build1) ...
                              Preparing to unpack .../193-libpixman-1-dev_0.40.0-1build4_amd64.deb ...
                              Unpacking libpixman-1-dev:amd64 (0.40.0-1build4) over (0.40.0-1build2) ...
                              Preparing to unpack .../194-libpixman-1-0_0.40.0-1build4_amd64.deb ...
                              Unpacking libpixman-1-0:amd64 (0.40.0-1build4) over (0.40.0-1build2) ...
                              Preparing to unpack .../195-libxcb-render0-dev_1.14-3ubuntu3_amd64.deb ...
                              Unpacking libxcb-render0-dev:amd64 (1.14-3ubuntu3) over (1.14-3ubuntu1) ...
                              Preparing to unpack .../196-libxcb-render0_1.14-3ubuntu3_amd64.deb ...
                              Unpacking libxcb-render0:amd64 (1.14-3ubuntu3) over (1.14-3ubuntu1) ...
                              Preparing to unpack .../197-libxcb-shm0-dev_1.14-3ubuntu3_amd64.deb ...
                              Unpacking libxcb-shm0-dev:amd64 (1.14-3ubuntu3) over (1.14-3ubuntu1) ...
                              Preparing to unpack .../198-libxcb-shm0_1.14-3ubuntu3_amd64.deb ...
                              Unpacking libxcb-shm0:amd64 (1.14-3ubuntu3) over (1.14-3ubuntu1) ...
                              Preparing to unpack .../199-libcairo-gobject2_1.16.0-5ubuntu2_amd64.deb ...
                              Unpacking libcairo-gobject2:amd64 (1.16.0-5ubuntu2) over (1.16.0-5ubuntu1) ...
                              Preparing to unpack .../200-libcairo2_1.16.0-5ubuntu2_amd64.deb ...
                              Unpacking libcairo2:amd64 (1.16.0-5ubuntu2) over (1.16.0-5ubuntu1) ...
                              Preparing to unpack .../201-libpango1.0-dev_1.50.6+ds-2_amd64.deb ...
                              Unpacking libpango1.0-dev:amd64 (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../202-pango1.0-tools_1.50.6+ds-2_amd64.deb ...
                              Unpacking pango1.0-tools (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../203-gir1.2-pango-1.0_1.50.6+ds-2_amd64.deb ...
                              Unpacking gir1.2-pango-1.0:amd64 (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../204-libpangoxft-1.0-0_1.50.6+ds-2_amd64.deb ...
                              Unpacking libpangoxft-1.0-0:amd64 (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../205-libpangoft2-1.0-0_1.50.6+ds-2_amd64.deb ...
                              Unpacking libpangoft2-1.0-0:amd64 (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../206-libpango-1.0-0_1.50.6+ds-2_amd64.deb ...
                              Unpacking libpango-1.0-0:amd64 (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../207-libpangocairo-1.0-0_1.50.6+ds-2_amd64.deb ...
                              Unpacking libpangocairo-1.0-0:amd64 (1.50.6+ds-2) over (1.48.10+ds1-1) ...
                              Preparing to unpack .../208-libxft-dev_2.3.4-1_amd64.deb ...
                              Unpacking libxft-dev:amd64 (2.3.4-1) over (2.3.3-0ubuntu4) ...
                              Preparing to unpack .../209-libxft2_2.3.4-1_amd64.deb ...
                              Unpacking libxft2:amd64 (2.3.4-1) over (2.3.3-0ubuntu4) ...
                              Preparing to unpack .../210-libthai-data_0.1.29-1build1_all.deb ...
                              Unpacking libthai-data (0.1.29-1build1) over (0.1.28-4.1) ...
                              Preparing to unpack .../211-libdatrie-dev_0.2.13-2_amd64.deb ...
                              Unpacking libdatrie-dev:amd64 (0.2.13-2) over (0.2.13-1ubuntu2) ...
                              Preparing to unpack .../212-libdatrie1_0.2.13-2_amd64.deb ...
                              Unpacking libdatrie1:amd64 (0.2.13-2) over (0.2.13-1ubuntu2) ...
                              Preparing to unpack .../213-libthai-dev_0.1.29-1build1_amd64.deb ...
                              Unpacking libthai-dev:amd64 (0.1.29-1build1) over (0.1.28-4.1) ...
                              Preparing to unpack .../214-libthai0_0.1.29-1build1_amd64.deb ...
                              Unpacking libthai0:amd64 (0.1.29-1build1) over (0.1.28-4.1) ...
                              Preparing to unpack .../215-librsvg2-dev_2.52.5+dfsg-3_amd64.deb ...
                              Unpacking librsvg2-dev:amd64 (2.52.5+dfsg-3) over (2.50.7+dfsg-1) ...
                              Preparing to unpack .../216-librsvg2-common_2.52.5+dfsg-3_amd64.deb ...
                              Unpacking librsvg2-common:amd64 (2.52.5+dfsg-3) over (2.50.7+dfsg-1) ...
                              Preparing to unpack .../217-librsvg2-2_2.52.5+dfsg-3_amd64.deb ...
                              Unpacking librsvg2-2:amd64 (2.52.5+dfsg-3) over (2.50.7+dfsg-1) ...
                              Preparing to unpack .../218-gir1.2-rsvg-2.0_2.52.5+dfsg-3_amd64.deb ...
                              Unpacking gir1.2-rsvg-2.0:amd64 (2.52.5+dfsg-3) over (2.50.7+dfsg-1) ...
                              Preparing to unpack .../219-libavahi-compat-libdnssd-dev_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-compat-libdnssd-dev:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../220-libavahi-client-dev_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-client-dev:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../221-libavahi-common-dev_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-common-dev:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../222-libavahi-compat-libdnssd1_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-compat-libdnssd1:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../223-libavahi-client3_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-client3:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../224-libavahi-common3_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-common3:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../225-libavahi-common-data_0.8-5ubuntu5_amd64.deb ...
                              Unpacking libavahi-common-data:amd64 (0.8-5ubuntu5) over (0.8-5ubuntu4) ...
                              Preparing to unpack .../226-libxpm4_1%3a3.5.12-1build2_amd64.deb ...
                              Unpacking libxpm4:amd64 (1:3.5.12-1build2) over (1:3.5.12-1) ...
                              Preparing to unpack .../227-libgd3_2.3.0-2ubuntu2_amd64.deb ...
                              Unpacking libgd3:amd64 (2.3.0-2ubuntu2) over (2.3.0-2ubuntu1) ...
                              Preparing to unpack .../228-libc-devtools_2.35-0ubuntu3.1_amd64.deb ...
                              Unpacking libc-devtools (2.35-0ubuntu3.1) over (2.34-0ubuntu3) ...
                              Preparing to unpack .../229-libevent-2.1-7_2.1.12-stable-1build3_amd64.deb ...
                              Unpacking libevent-2.1-7:amd64 (2.1.12-stable-1build3) over (2.1.12-stable-1) ...
                              Preparing to unpack .../230-libfuse2_2.9.9-5ubuntu3_amd64.deb ...
                              Unpacking libfuse2:amd64 (2.9.9-5ubuntu3) over (2.9.9-5ubuntu2) ...
                              Preparing to unpack .../231-libgif-dev_5.1.9-2build2_amd64.deb ...
                              Unpacking libgif-dev (5.1.9-2build2) over (5.1.9-2build1) ...
                              Preparing to unpack .../232-libgif7_5.1.9-2build2_amd64.deb ...
                              Unpacking libgif7:amd64 (5.1.9-2build2) over (5.1.9-2build1) ...
                              Preparing to unpack .../233-libldap-common_2.5.13+dfsg-0ubuntu0.22.04.1_all.deb ...
                              Unpacking libldap-common (2.5.13+dfsg-0ubuntu0.22.04.1) over (2.5.6+dfsg-1~exp1ubuntu1) ...
                              Preparing to unpack .../234-linux-libc-dev_5.15.0-50.56_amd64.deb ...
                              Unpacking linux-libc-dev:amd64 (5.15.0-50.56) over (5.13.0-22.22) ...
                              Preparing to unpack .../235-ltrace_0.7.3-6.1ubuntu6_amd64.deb ...
                              Unpacking ltrace (0.7.3-6.1ubuntu6) over (0.7.3-6.1ubuntu3) ...
                              Preparing to unpack .../236-mailcap_3.70+nmu1ubuntu1_all.deb ...
                              Unpacking mailcap (3.70+nmu1ubuntu1) over (3.69ubuntu1) ...
                              Preparing to unpack .../237-net-tools_1.60+git20181103.0eebece-1ubuntu5_amd64.deb ...
                              Unpacking net-tools (1.60+git20181103.0eebece-1ubuntu5) over (1.60+git20181103.0eebece-1ubuntu2) ...
                              Preparing to unpack .../238-nodejs_14.20.1-deb-1nodesource1_amd64.deb ...
                              Unpacking nodejs (14.20.1-deb-1nodesource1) over (14.18.2-deb-1nodesource1) ...
                              Preparing to unpack .../239-rpcsvc-proto_1.4.2-0ubuntu6_amd64.deb ...
                              Unpacking rpcsvc-proto (1.4.2-0ubuntu6) over (1.4.2-0ubuntu5) ...
                              Selecting previously unselected package systemd-hwe-hwdb.
                              Preparing to unpack .../240-systemd-hwe-hwdb_249.11.1_all.deb ...
                              Unpacking systemd-hwe-hwdb (249.11.1) ...
                              Preparing to unpack .../241-unzip_6.0-26ubuntu3.1_amd64.deb ...
                              Unpacking unzip (6.0-26ubuntu3.1) over (6.0-26ubuntu1) ...
                              Preparing to unpack .../242-x11proto-xext-dev_2021.5-1_all.deb ...
                              Unpacking x11proto-xext-dev (2021.5-1) over (2020.1-1) ...
                              Setting up libksba8:amd64 (1.6.0-2build1) ...
                              Setting up media-types (7.0.0) ...
                              Installing new version of config file /etc/mime.types ...
                              Setting up cpio (2.13+dfsg-7) ...
                              Setting up x11proto-dev (2021.5-1) ...
                              Setting up libpcrecpp0v5:amd64 (2:8.39-13ubuntu0.22.04.1) ...
                              Setting up libpipeline1:amd64 (1.5.5-1) ...
                              Setting up liblmdb0:amd64 (0.9.24-1build2) ...
                              Setting up libtext-iconv-perl (1.7-7build3) ...
                              Setting up libgraphite2-3:amd64 (1.3.14-1build2) ...
                              Setting up libpixman-1-0:amd64 (0.40.0-1build4) ...
                              Setting up libtext-charwidth-perl (0.04-10build3) ...
                              Setting up gcc-11-base:amd64 (11.2.0-19ubuntu1) ...
                              Setting up libxau6:amd64 (1:1.0.9-1build5) ...
                              Setting up net-tools (1.60+git20181103.0eebece-1ubuntu5) ...
                              Setting up time (1.9-0.1build2) ...
                              Setting up lto-disabled-list (24) ...
                              Setting up pci.ids (0.0~2022.01.22-1) ...
                              Setting up libpsl5:amd64 (0.21.0-1.2build2) ...
                              Setting up libpixman-1-dev:amd64 (0.40.0-1build4) ...
                              Setting up apt-utils (2.4.8) ...
                              Setting up telnet (0.17-44build1) ...
                              Setting up libxau-dev:amd64 (1:1.0.9-1build5) ...
                              Setting up bsdextrautils (2.37.2-4ubuntu3) ...
                              Setting up wget (1.21.2-2ubuntu1) ...
                              Setting up libpcre16-3:amd64 (2:8.39-13ubuntu0.22.04.1) ...
                              Setting up init (1.62) ...
                              Setting up libdatrie1:amd64 (0.2.13-2) ...
                              Setting up xdg-user-dirs (0.17-2ubuntu4) ...
                              Setting up libpam0g-dev:amd64 (1.4.0-11ubuntu2) ...
                              Setting up libmagic-mgc (1:5.41-3) ...
                              Setting up psmisc (23.4-2build3) ...
                              Setting up libyaml-0-2:amd64 (0.2.2-1build2) ...
                              Setting up libip6tc2:amd64 (1.8.7-1ubuntu5) ...
                              Setting up libglib2.0-0:amd64 (2.72.1-1) ...
                              No schema files found: doing nothing.
                              Setting up distro-info-data (0.52ubuntu0.1) ...
                              Setting up fontconfig-config (2.13.1-4.2ubuntu5) ...
                              Setting up libestr0:amd64 (0.1.10-2.1build3) ...
                              Setting up libfastjson4:amd64 (0.99.9-1build2) ...
                              Setting up libmaxminddb0:amd64 (1.5.2-1build2) ...
                              Setting up unzip (6.0-26ubuntu3.1) ...
                              Setting up libcbor0.8:amd64 (0.8.0-2ubuntu1) ...
                              Setting up libbrotli1:amd64 (1.0.9-2build6) ...
                              Setting up libsqlite3-0:amd64 (3.37.2-2) ...
                              Setting up libgdk-pixbuf2.0-common (2.42.8+dfsg-1ubuntu0.1) ...
                              Setting up dosfstools (4.2-1build3) ...
                              Setting up rsyslog (8.2112.0-2ubuntu2.2) ...
                              The user `syslog' is already a member of `adm'.
                              Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogd
                              Removing obsolete conffile /etc/init.d/rsyslog ...
                              Setting up binutils-common:amd64 (2.38-3ubuntu1) ...
                              Setting up x11-common (1:7.7+23ubuntu2) ...
                              Installing new version of config file /etc/X11/Xsession ...
                              Installing new version of config file /etc/X11/Xsession.d/20x11-common_process-args ...
                              Installing new version of config file /etc/X11/Xsession.d/90x11-common_ssh-agent ...
                              Installing new version of config file /etc/init.d/x11-common ...
                              Setting up libnghttp2-14:amd64 (1.43.0-1build3) ...
                              Setting up libmagic1:amd64 (1:5.41-3) ...
                              Setting up libdeflate0:amd64 (1.10-2) ...
                              Setting up less (590-1build1) ...
                              Setting up linux-libc-dev:amd64 (5.15.0-50.56) ...
                              Setting up libctf-nobfd0:amd64 (2.38-3ubuntu1) ...
                              Setting up libnetplan0:amd64 (0.104-0ubuntu2.1) ...
                              Setting up gettext-base (0.21-4ubuntu4) ...
                              Setting up libnss-systemd:amd64 (249.11-0ubuntu3.6) ...
                              Setting up xkb-data (2.33-1) ...
                              Setting up liblzo2-2:amd64 (2.10-2build3) ...
                              Setting up libnpth0:amd64 (1.6-3build2) ...
                              Setting up hdparm (9.60+ds-1build3) ...
                              Setting up libntfs-3g89 (1:2021.8.22-3ubuntu1.1) ...
                              Setting up file (1:5.41-3) ...
                              Setting up kmod (29-1ubuntu1) ...
                              Setting up libassuan0:amd64 (2.5.5-1build1) ...
                              Setting up libgomp1:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up libfuse2:amd64 (2.9.9-5ubuntu3) ...
                              Setting up libatm1:amd64 (1:2.5.1-4build2) ...
                              Setting up perl-modules-5.34 (5.34.0-3ubuntu1) ...
                              Setting up lshw (02.19.git.2021.06.19.996aaad9c7-2build1) ...
                              Setting up bzip2 (1.0.8-5build1) ...
                              Setting up libffi-dev:amd64 (3.4.2-4) ...
                              Setting up libldap-common (2.5.13+dfsg-0ubuntu0.22.04.1) ...
                              Setting up libunwind8:amd64 (1.3.2-2build2) ...
                              Setting up libpthread-stubs0-dev:amd64 (0.4-1build2) ...
                              Setting up libjbig0:amd64 (2.1-3.1build3) ...
                              Setting up libpcre2-16-0:amd64 (10.39-3ubuntu0.1) ...
                              Setting up xxd (2:8.2.3995-1ubuntu2.1) ...
                              Setting up ntfs-3g (1:2021.8.22-3ubuntu1.1) ...
                              Setting up libfakeroot:amd64 (1.28-1ubuntu1) ...
                              Setting up libasan6:amd64 (11.2.0-19ubuntu1) ...
                              Setting up libjansson4:amd64 (2.13.1-1.1build3) ...
                              Setting up acl (2.3.1-1) ...
                              Setting up libsasl2-modules-db:amd64 (2.1.27+dfsg2-3ubuntu1) ...
                              Setting up tzdata (2022c-0ubuntu0.22.04.0) ...
                              Current default time zone: 'Etc/UTC'
                              Local time is now:      Sat Oct 15 09:43:47 UTC 2022.
                              Universal Time is now:  Sat Oct 15 09:43:47 UTC 2022.
                              Run 'dpkg-reconfigure tzdata' if you wish to change it.
                              Setting up libcap2-bin (1:2.44-1build3) ...
                              Setting up fakeroot (1.28-1ubuntu1) ...
                              Setting up libtalloc2:amd64 (2.3.3-2build1) ...
                              Setting up eject (2.37.2-4ubuntu3) ...
                              Setting up apparmor (3.0.4-2ubuntu2.1) ...
                              Installing new version of config file /etc/apparmor.d/abstractions/exo-open ...
                              Installing new version of config file /etc/apparmor.d/abstractions/ibus ...
                              Installing new version of config file /etc/apparmor.d/abstractions/nameservice ...
                              Installing new version of config file /etc/apparmor.d/abstractions/nss-systemd ...
                              Installing new version of config file /etc/apparmor.d/abstractions/openssl ...
                              Installing new version of config file /etc/apparmor.d/abstractions/python ...
                              Installing new version of config file /etc/apparmor.d/abstractions/samba ...
                              Installing new version of config file /etc/apparmor.d/abstractions/ubuntu-helpers ...
                              Installing new version of config file /etc/apparmor.d/abstractions/video ...
                              Installing new version of config file /etc/apparmor.d/lsb_release ...
                              Reloading AppArmor profiles
                              Setting up libgraphite2-dev:amd64 (1.3.14-1build2) ...
                              Setting up libpcre2-32-0:amd64 (10.39-3ubuntu0.1) ...
                              Setting up libisc-export1105:amd64 (1:9.11.19+dfsg-2.1ubuntu3) ...
                              Setting up libglib2.0-data (2.72.1-1) ...
                              Setting up libtirpc-dev:amd64 (1.3.2-2ubuntu0.1) ...
                              Setting up libuv1:amd64 (1.43.0-1) ...
                              Setting up rpcsvc-proto (1.4.2-0ubuntu6) ...
                              Setting up libpython2.7-minimal:amd64 (2.7.18-13ubuntu1.1) ...
                              Setting up vim-common (2:8.2.3995-1ubuntu2.1) ...
                              Setting up libexpat1-dev:amd64 (2.4.7-1) ...
                              Setting up libslang2:amd64 (2.3.2-5build4) ...
                              Setting up libtevent0:amd64 (0.11.0-1build1) ...
                              Setting up busybox-static (1:1.30.1-7ubuntu3) ...
                              Setting up libwrap0:amd64 (7.6.q-31build2) ...
                              Setting up libx11-data (2:1.7.5-1) ...
                              Setting up make (4.3-4.1build1) ...
                              Setting up libmpfr6:amd64 (4.1.0-3build3) ...
                              Setting up gnupg-l10n (2.2.27-3ubuntu2.1) ...
                              Setting up ed (1.18-1) ...
                              Setting up librtmp1:amd64 (2.4+20151223.gitfa8646d.1-2build4) ...
                              Setting up python2.7-minimal (2.7.18-13ubuntu1.1) ...
                              Setting up bash-completion (1:2.11-5ubuntu1) ...
                              Setting up uuid-dev:amd64 (2.37.2-4ubuntu3) ...
                              Setting up libavahi-common-data:amd64 (0.8-5ubuntu5) ...
                              Setting up libncurses6:amd64 (6.3-2) ...
                              Setting up strace (5.16-0ubuntu3) ...
                              Setting up libdbus-1-3:amd64 (1.12.20-2ubuntu4) ...
                              Setting up dbus (1.12.20-2ubuntu4) ...
                              A reboot is required to replace the running dbus-daemon.
                              Please reboot the system when convenient.
                              Setting up xz-utils (5.2.5-2ubuntu1) ...
                              Setting up libfribidi0:amd64 (1.0.8-2ubuntu3.1) ...
                              Setting up libquadmath0:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up libpng16-16:amd64 (1.6.37-3build5) ...
                              Setting up libpcre32-3:amd64 (2:8.39-13ubuntu0.22.04.1) ...
                              Setting up libmpc3:amd64 (1.2.1-2build1) ...
                              Setting up libmnl0:amd64 (1.0.4-3build2) ...
                              Setting up systemd-timesyncd (249.11-0ubuntu3.6) ...
                              Setting up libevent-core-2.1-7:amd64 (2.1.12-stable-1build3) ...
                              Setting up libatomic1:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up udev (249.11-0ubuntu3.6) ...
                              Setting up libevent-2.1-7:amd64 (2.1.12-stable-1build3) ...
                              Setting up usrmerge (25ubuntu2) ...
                              Setting up patch (2.7.6-7build2) ...
                              Setting up libss2:amd64 (1.46.5-2ubuntu1.1) ...
                              Setting up usb.ids (2022.04.02-1) ...
                              Setting up sudo (1.9.9-1ubuntu2) ...
                              Installing new version of config file /etc/pam.d/sudo ...
                              Installing new version of config file /etc/sudo.conf ...
                              Installing new version of config file /etc/sudo_logsrvd.conf ...
                              Installing new version of config file /etc/sudoers ...
                              Installing new version of config file /etc/sudoers.d/README ...
                              Setting up libudev-dev:amd64 (249.11-0ubuntu3.6) ...
                              Setting up libsepol-dev:amd64 (3.3-1build1) ...
                              Setting up libncursesw6:amd64 (6.3-2) ...
                              Setting up libjpeg-turbo8:amd64 (2.1.2-0ubuntu1) ...
                              Setting up libxtables12:amd64 (1.8.7-1ubuntu5) ...
                              Setting up logsave (1.46.5-2ubuntu1.1) ...
                              Setting up libsasl2-2:amd64 (2.1.27+dfsg2-3ubuntu1) ...
                              Setting up libssh-4:amd64 (0.9.6-2build1) ...
                              Setting up lsof (4.93.2+dfsg-1.1build2) ...
                              Setting up libwebp7:amd64 (1.2.2-2) ...
                              Setting up systemd-hwe-hwdb (249.11.1) ...
                              Setting up liblzma-dev:amd64 (5.2.5-2ubuntu1) ...
                              Setting up libubsan1:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up libgif7:amd64 (5.1.9-2build2) ...
                              Setting up zlib1g-dev:amd64 (1:1.2.11.dfsg-2ubuntu9.1) ...
                              Setting up nano (6.2-1) ...
                              Installing new version of config file /etc/nanorc ...
                              Setting up libpci3:amd64 (1:3.7.0-6) ...
                              Setting up libnuma1:amd64 (2.0.14-3ubuntu2) ...
                              Setting up libpcre2-posix3:amd64 (10.39-3ubuntu0.1) ...
                              Setting up x11proto-xext-dev (2021.5-1) ...
                              Setting up libmd0:amd64 (1.0.4-1build1) ...
                              Setting up keyutils (1.6.1-2ubuntu3) ...
                              Setting up python-apt-common (2.3.0ubuntu2.1) ...
                              Setting up dmsetup (2:1.02.175-2.1ubuntu4) ...
                              Setting up libnsl-dev:amd64 (1.3.0-2build2) ...
                              Setting up sensible-utils (0.0.17) ...
                              Setting up libgif-dev (5.1.9-2build2) ...
                              Setting up uuid-runtime (2.37.2-4ubuntu3) ...
                              uuidd.service is a disabled or a static unit not running, not starting it.
                              Setting up libcrypt-dev:amd64 (1:4.4.27-1) ...
                              Setting up libnfnetlink0:amd64 (1.0.1-3build3) ...
                              Setting up libplymouth5:amd64 (0.9.5+git20211018-1ubuntu3) ...
                              Setting up libuchardet0:amd64 (0.0.7-1build2) ...
                              Setting up libmpdec3:amd64 (2.5.1-2build2) ...
                              Setting up libpam-systemd:amd64 (249.11-0ubuntu3.6) ...
                              Setting up git-man (1:2.34.1-1ubuntu1.4) ...
                              Setting up libthai-data (0.1.29-1build1) ...
                              Setting up libgirepository-1.0-1:amd64 (1.72.0-1) ...
                              Setting up isc-dhcp-common (4.4.1-2.3ubuntu2.3) ...
                              Setting up mawk (1.3.4.20200120-3) ...
                              Setting up libusb-1.0-0:amd64 (2:1.0.25-1ubuntu2) ...
                              Setting up dmidecode (3.3-3ubuntu0.1) ...
                              Setting up libbinutils:amd64 (2.38-3ubuntu1) ...
                              Setting up libfido2-1:amd64 (1.10.0-1) ...
                              Setting up libisl23:amd64 (0.24-2build1) ...
                              Setting up openssl (3.0.2-0ubuntu1.6) ...
                              Installing new version of config file /etc/ssl/openssl.cnf ...
                              Setting up libbsd0:amd64 (0.11.5-1) ...
                              Setting up libdeflate-dev:amd64 (1.10-2) ...
                              Setting up libdrm-common (2.4.110-1ubuntu1) ...
                              Setting up libelf1:amd64 (0.186-1build1) ...
                              Setting up libpam-cap:amd64 (1:2.44-1build3) ...
                              Setting up iputils-ping (3:20211215-1) ...
                              Setting up readline-common (8.1.2-1) ...
                              Setting up publicsuffix (20211207.1025-1) ...
                              Setting up libcc1-0:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up iso-codes (4.9.0-1) ...
                              Setting up info (6.8-4build1) ...
                              Setting up liblocale-gettext-perl (1.07-4build3) ...
                              Setting up libbrotli-dev:amd64 (1.0.9-2build6) ...
                              Setting up liblsan0:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up libprocps8:amd64 (2:3.3.17-6ubuntu2) ...
                              Setting up iputils-tracepath (3:20211215-1) ...
                              Setting up libitm1:amd64 (12.1.0-2ubuntu1~22.04) ...
                              Setting up libgdbm6:amd64 (1.23-1) ...
                              Setting up libpopt0:amd64 (1.18-3build1) ...
                              Setting up libicu70:amd64 (70.1-2) ...
                              Setting up libtsan0:amd64 (11.2.0-19ubuntu1) ...
                              Setting up libctf0:amd64 (2.38-3ubuntu1) ...
                              Setting up libjpeg8:amd64 (8c-2ubuntu10) ...
                              Setting up pinentry-curses (1.1.1-1build2) ...
                              Setting up logrotate (3.19.0-1ubuntu1.1) ...
                              logrotate.service is a disabled or a static unit not running, not starting it.
                              Setting up cpp-11 (11.2.0-19ubuntu1) ...
                              Setting up distro-info (1.1build1) ...
                              Setting up libblkid-dev:amd64 (2.37.2-4ubuntu3) ...
                              Setting up libice6:amd64 (2:1.0.10-1build2) ...
                              Setting up libjpeg-turbo8-dev:amd64 (2.1.2-0ubuntu1) ...
                              Setting up libxdmcp6:amd64 (1:1.1.3-0ubuntu5) ...
                              Setting up libxcb1:amd64 (1.14-3ubuntu3) ...
                              Setting up libnewt0.52:amd64 (0.52.21-5ubuntu2) ...
                              Setting up irqbalance (1.8.0-1build1) ...
                              Installing new version of config file /etc/default/irqbalance ...
                              Setting up libpcre2-dev:amd64 (10.39-3ubuntu0.1) ...
                              Setting up libice-dev:amd64 (2:1.0.10-1build2) ...
                              Setting up libxcb-render0:amd64 (1.14-3ubuntu3) ...
                              Setting up libselinux1-dev:amd64 (3.3-1build2) ...
                              Setting up libpcre3-dev:amd64 (2:8.39-13ubuntu0.22.04.1) ...
                              Setting up libfribidi-dev:amd64 (1.0.8-2ubuntu3.1) ...
                              Setting up libedit2:amd64 (3.1-20210910-1build1) ...
                              Setting up libreadline8:amd64 (8.1.2-1) ...
                              Setting up cron (3.0pl1-137ubuntu3) ...
                              Setting up ltrace (0.7.3-6.1ubuntu6) ...
                              Setting up libpng-dev:amd64 (1.6.37-3build5) ...
                              Setting up netcat-openbsd (1.218-4ubuntu1) ...
                              Setting up libavahi-common3:amd64 (0.8-5ubuntu5) ...
                              Setting up libjbig-dev:amd64 (2.1-3.1build3) ...
                              Setting up libdns-export1110 (1:9.11.19+dfsg-2.1ubuntu3) ...
                              Setting up libglib2.0-bin (2.72.1-1) ...
                              Setting up debconf-i18n (1.5.79ubuntu1) ...
                              Setting up libnftnl11:amd64 (1.2.1-1build1) ...
                              Setting up e2fsprogs (1.46.5-2ubuntu1.1) ...
                              Installing new version of config file /etc/mke2fs.conf ...
                              e2scrub_all.service is a disabled or a static unit not running, not starting it.
                              Setting up rpcbind (1.2.6-2build1) ...
                              Setting up libxcb-shm0:amd64 (1.14-3ubuntu3) ...
                              Setting up vim-tiny (2:8.2.3995-1ubuntu2.1) ...
                              Setting up usbutils (1:014-1build1) ...
                              Setting up libwbclient0:amd64 (2:4.15.9+dfsg-0ubuntu0.2) ...
                              Setting up libldap-2.5-0:amd64 (2.5.13+dfsg-0ubuntu0.22.04.1) ...
                              Setting up libpython2.7-stdlib:amd64 (2.7.18-13ubuntu1.1) ...
                              Setting up libpython3.10-stdlib:amd64 (3.10.6-1~22.04) ...
                              Setting up libthai0:amd64 (0.1.29-1build1) ...
                              Setting up ca-certificates (20211016) ...
                              Updating certificates in /etc/ssl/certs...
                              rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
                              7 added, 8 removed; done.
                              Setting up libxdmcp-dev:amd64 (1:1.1.3-0ubuntu5) ...
                              Setting up libfreetype6:amd64 (2.11.1+dfsg-1ubuntu0.1) ...
                              Setting up libpcap0.8:amd64 (1.10.1-4build1) ...
                              Setting up mtr-tiny (0.95-1) ...
                              Setting up ssl-cert (1.1.2) ...
                              Setting up icu-devtools (70.1-2) ...
                              Setting up libgdbm-compat4:amd64 (1.23-1) ...
                              Setting up gir1.2-glib-2.0:amd64 (1.72.0-1) ...
                              Setting up pciutils (1:3.7.0-6) ...
                              Setting up postfix (3.6.4-1ubuntu1) ...
                              Installing new version of config file /etc/init.d/postfix ...
                              Installing new version of config file /etc/network/if-up.d/postfix ...
                              Installing new version of config file /etc/postfix/postfix-script ...
                              Installing new version of config file /etc/ppp/ip-up.d/postfix ...
                              Installing new version of config file /etc/resolvconf/update-libc.d/postfix ...
                              Postfix (main.cf) configuration was untouched.  If you need to make changes,
                              edit /etc/postfix/main.cf (and others) as needed.  To view Postfix
                              configuration values, see postconf(1).
                              After modifying main.cf, be sure to run 'systemctl reload postfix'.
                              Setting up libparted2:amd64 (3.4-2build1) ...
                              Setting up libgcc-11-dev:amd64 (11.2.0-19ubuntu1) ...
                              Setting up libdrm2:amd64 (2.4.110-1ubuntu1) ...
                              Setting up whiptail (0.52.21-5ubuntu2) ...
                              Setting up libnetfilter-conntrack3:amd64 (1.0.9-1) ...
                              Setting up groff-base (1.22.4-8build1) ...
                              Setting up libavahi-common-dev:amd64 (0.8-5ubuntu5) ...
                              Setting up procps (2:3.3.17-6ubuntu2) ...
                              Installing new version of config file /etc/init.d/procps ...
                              Installing new version of config file /etc/sysctl.d/README.sysctl ...
                              Setting up gpgconf (2.2.27-3ubuntu2.1) ...
                              Setting up libcurl4:amd64 (7.81.0-1ubuntu1.4) ...
                              Setting up libx11-6:amd64 (2:1.7.5-1) ...
                              Setting up libharfbuzz0b:amd64 (2.7.4-1ubuntu3.1) ...
                              Setting up libtiff5:amd64 (4.3.0-6ubuntu0.1) ...
                              Setting up curl (7.81.0-1ubuntu1.4) ...
                              Setting up libfontconfig1:amd64 (2.13.1-4.2ubuntu5) ...
                              Setting up tnftp (20210827-4build1) ...
                              update-alternatives: using /usr/bin/tnftp to provide /usr/bin/ftp (ftp) in auto mode
                              Setting up keyboard-configuration (1.205ubuntu3) ...
                              Your console font configuration will be updated the next time your system
                              boots. If you want to update it now, run 'setupcon' from a virtual console.
                              Setting up libjpeg8-dev:amd64 (8c-2ubuntu10) ...
                              Setting up libbpf0:amd64 (1:0.5.0-1) ...
                              Setting up libsm6:amd64 (2:1.2.3-1build2) ...
                              Setting up libicu-dev:amd64 (70.1-2) ...
                              Setting up libxml2:amd64 (2.9.13+dfsg-1ubuntu0.1) ...
                              Setting up libavahi-client3:amd64 (0.8-5ubuntu5) ...
                              Setting up libmount-dev:amd64 (2.37.2-4ubuntu3) ...
                              Setting up libxmuu1:amd64 (2:1.1.3-3) ...
                              Setting up gpg (2.2.27-3ubuntu2.1) ...
                              Setting up rsync (3.2.3-8ubuntu3) ...
                              Setting up libpython3-stdlib:amd64 (3.10.6-1~22.04) ...
                              Setting up libtiffxx5:amd64 (4.3.0-6ubuntu0.1) ...
                              Setting up gnupg-utils (2.2.27-3ubuntu2.1) ...
                              Setting up binutils-x86-64-linux-gnu (2.38-3ubuntu1) ...
                              Setting up tcpdump (4.99.1-3build2) ...
                              Installing new version of config file /etc/apparmor.d/usr.bin.tcpdump ...
                              Setting up fontconfig (2.13.1-4.2ubuntu5) ...
                              Regenerating fonts cache... done.
                              Setting up libperl5.34:amd64 (5.34.0-3ubuntu1) ...
                              Setting up libpython2.7:amd64 (2.7.18-13ubuntu1.1) ...
                              Setting up libnfsidmap1:amd64 (1:2.6.1-1ubuntu1.1) ...
                              Setting up libpython2.7-dev:amd64 (2.7.18-13ubuntu1.1) ...
                              Setting up gir1.2-freedesktop:amd64 (1.72.0-1) ...
                              Setting up libharfbuzz-icu0:amd64 (2.7.4-1ubuntu3.1) ...
                              Setting up libnftables1:amd64 (1.0.2-1ubuntu3) ...
                              Setting up gpg-agent (2.2.27-3ubuntu2.1) ...
                              Setting up libxcb1-dev:amd64 (1.14-3ubuntu3) ...
                              Setting up nftables (1.0.2-1ubuntu3) ...
                              Setting up python3.10 (3.10.6-1~22.04) ...
                              Setting up libxpm4:amd64 (1:3.5.12-1build2) ...
                              Setting up python2.7 (2.7.18-13ubuntu1.1) ...
                              Setting up libxrender1:amd64 (1:0.9.10-1build4) ...
                              Setting up bind9-libs:amd64 (1:9.18.1-1ubuntu1.2) ...
                              Setting up plymouth (0.9.5+git20211018-1ubuntu3) ...
                              Installing new version of config file /etc/init.d/plymouth ...
                              Installing new version of config file /etc/init.d/plymouth-log ...
                              update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
                              Setting up libsm-dev:amd64 (2:1.2.3-1build2) ...
                              Setting up iptables (1.8.7-1ubuntu5) ...
                              Setting up iproute2 (5.15.0-1ubuntu2) ...
                              Installing new version of config file /etc/iproute2/rt_protos ...
                              Setting up openssh-client (1:8.9p1-3) ...
                              Setting up gpgsm (2.2.27-3ubuntu2.1) ...
                              Setting up libpango-1.0-0:amd64 (1.50.6+ds-2) ...
                              Setting up libjpeg-dev:amd64 (8c-2ubuntu10) ...
                              Setting up libx11-dev:amd64 (2:1.7.5-1) ...
                              Setting up libxext6:amd64 (2:1.3.4-1build1) ...
                              Setting up isc-dhcp-client (4.4.1-2.3ubuntu2.3) ...
                              Installing new version of config file /etc/apparmor.d/sbin.dhclient ...
                              Setting up parted (3.4-2build1) ...
                              Setting up libcurl3-gnutls:amd64 (7.81.0-1ubuntu1.4) ...
                              Setting up python3 (3.10.6-1~22.04) ...
                              running python rtupdate hooks for python3.10...
                              running python post-rtupdate hooks for python3.10...
                              Setting up libharfbuzz-gobject0:amd64 (2.7.4-1ubuntu3.1) ...
                              Setting up binutils (2.38-3ubuntu1) ...
                              Setting up libavahi-compat-libdnssd1:amd64 (0.8-5ubuntu5) ...
                              Setting up nodejs (14.20.1-deb-1nodesource1) ...
                              Setting up man-db (2.10.2-1) ...
                              Installing new version of config file /etc/cron.daily/man-db ...
                              Installing new version of config file /etc/cron.weekly/man-db ...
                              Installing new version of config file /etc/manpath.config ...
                              Updating database of manual pages ...
                              man-db.service is a disabled or a static unit not running, not starting it.
                              Setting up gir1.2-harfbuzz-0.0:amd64 (2.7.4-1ubuntu3.1) ...
                              Setting up libcairo2:amd64 (1.16.0-5ubuntu2) ...
                              Setting up libfreetype-dev:amd64 (2.11.1+dfsg-1ubuntu0.1) ...
                              Setting up nfs-common (1:2.6.1-1ubuntu1.1) ...
                              Installing new version of config file /etc/default/nfs-common ...
                              Replacing config file /etc/idmapd.conf with new version
                              Creating config file /etc/nfs.conf with new version
                              auth-rpcgss-module.service is a disabled or a static unit not running, not starting it.
                              nfs-idmapd.service is a disabled or a static unit not running, not starting it.
                              nfs-utils.service is a disabled or a static unit not running, not starting it.
                              proc-fs-nfsd.mount is a disabled or a static unit not running, not starting it.
                              rpc-gssd.service is a disabled or a static unit not running, not starting it.
                              rpc-statd-notify.service is a disabled or a static unit not running, not starting it.
                              rpc-statd.service is a disabled or a static unit not running, not starting it.
                              rpc-svcgssd.service is a disabled or a static unit not running, not starting it.
                              rpc_pipefs.target is a disabled or a static unit not running, not starting it.
                              var-lib-nfs-rpc_pipefs.mount is a disabled or a static unit not running, not starting it.
                              Setting up dirmngr (2.2.27-3ubuntu2.1) ...
                              Setting up libxcb-shm0-dev:amd64 (1.14-3ubuntu3) ...
                              Setting up perl (5.34.0-3ubuntu1) ...
                              Setting up libtiff-dev:amd64 (4.3.0-6ubuntu0.1) ...
                              Setting up python3-gi (3.42.1-0ubuntu1) ...
                              Setting up shared-mime-info (2.1-2) ...
                              Setting up libgd3:amd64 (2.3.0-2ubuntu2) ...
                              Setting up ftp (20210827-4build1) ...
                              Setting up libxcb-render0-dev:amd64 (1.14-3ubuntu3) ...
                              Setting up git (1:2.34.1-1ubuntu1.4) ...
                              Setting up libdpkg-perl (1.21.1ubuntu2.1) ...
                              Setting up libxext-dev:amd64 (2:1.3.4-1build1) ...
                              Setting up libstdc++-11-dev:amd64 (11.2.0-19ubuntu1) ...
                              Setting up gpg-wks-server (2.2.27-3ubuntu2.1) ...
                              Setting up python3-netifaces:amd64 (0.11.0-1build2) ...
                              Setting up gcc-11 (11.2.0-19ubuntu1) ...
                              Setting up xauth (1:1.1-1build2) ...
                              Setting up libgdk-pixbuf-2.0-0:amd64 (2.42.8+dfsg-1ubuntu0.1) ...
                              Setting up libcairo-gobject2:amd64 (1.16.0-5ubuntu2) ...
                              Setting up libpangoft2-1.0-0:amd64 (1.50.6+ds-2) ...
                              Setting up lsb-release (11.1.0ubuntu4) ...
                              Setting up bind9-host (1:9.18.1-1ubuntu1.2) ...
                              Setting up python3-lib2to3 (3.10.6-1~22.04) ...
                              Setting up mailcap (3.70+nmu1ubuntu1) ...
                              Setting up python3-distro-info (1.1build1) ...
                              Setting up libxrender-dev:amd64 (1:0.9.10-1build4) ...
                              Setting up libalgorithm-diff-xs-perl (0.04-6build3) ...
                              Setting up libpangocairo-1.0-0:amd64 (1.50.6+ds-2) ...
                              Setting up libc-devtools (2.35-0ubuntu3.1) ...
                              Setting up python2.7-dev (2.7.18-13ubuntu1.1) ...
                              Setting up python3-pkg-resources (59.6.0-1.2) ...
                              Setting up python3-distutils (3.10.6-1~22.04) ...
                              Setting up libcairo-script-interpreter2:amd64 (1.16.0-5ubuntu2) ...
                              Setting up libglib2.0-dev-bin (2.72.1-1) ...
                              Setting up openssh-sftp-server (1:8.9p1-3) ...
                              Setting up python3-dbus (1.2.18-3build1) ...
                              Setting up libxft2:amd64 (2.3.4-1) ...
                              Setting up libpangoxft-1.0-0:amd64 (1.50.6+ds-2) ...
                              Setting up gpg-wks-client (2.2.27-3ubuntu2.1) ...
                              Setting up openssh-server (1:8.9p1-3) ...
                              Installing new version of config file /etc/init.d/ssh ...
                              Installing new version of config file /etc/ssh/moduli ...
                              Replacing config file /etc/ssh/sshd_config with new version
                              rescue-ssh.target is a disabled or a static unit not running, not starting it.
                              Setting up gir1.2-gdkpixbuf-2.0:amd64 (2.42.8+dfsg-1ubuntu0.1) ...
                              Setting up g++-11 (11.2.0-19ubuntu1) ...
                              Setting up libfile-fcntllock-perl (0.22-3build7) ...
                              Setting up python3-gdbm:amd64 (3.10.6-1~22.04) ...
                              Setting up python3-apt (2.3.0ubuntu2.1) ...
                              Setting up pango1.0-tools (1.50.6+ds-2) ...
                              Setting up cifs-utils (2:6.14-1ubuntu0.1) ...
                              Setting up python3-yaml (5.4.1-1ubuntu1) ...
                              Setting up ufw (0.36.1-4build1) ...
                              Setting up dpkg-dev (1.21.1ubuntu2.1) ...
                              Setting up libfreetype6-dev:amd64 (2.11.1+dfsg-1ubuntu0.1) ...
                              Setting up netplan.io (0.104-0ubuntu2.1) ...
                              Setting up librsvg2-2:amd64 (2.52.5+dfsg-3) ...
                              Setting up gir1.2-pango-1.0:amd64 (1.50.6+ds-2) ...
                              Setting up plymouth-theme-ubuntu-text (0.9.5+git20211018-1ubuntu3) ...
                              Setting up python3-commandnotfound (22.04.0) ...
                              Setting up pkg-config (0.29.2-1ubuntu3) ...
                              Setting up librsvg2-common:amd64 (2.52.5+dfsg-3) ...
                              Setting up libdatrie-dev:amd64 (0.2.13-2) ...
                              Setting up libgdk-pixbuf2.0-bin (2.42.8+dfsg-1ubuntu0.1) ...
                              Setting up gnupg (2.2.27-3ubuntu2.1) ...
                              Setting up build-essential (12.9ubuntu3) ...
                              Setting up ubuntu-advantage-tools (27.11.2~22.04.1) ...
                              Installing new version of config file /etc/logrotate.d/ubuntu-advantage-tools ...
                              Installing new version of config file /etc/ubuntu-advantage/help_data.yaml ...
                              Installing new version of config file /etc/ubuntu-advantage/uaclient.conf ...
                              Created symlink /etc/systemd/system/multi-user.target.wants/ubuntu-advantage.service → /lib/systemd/system/ubuntu-advantage.service.
                              Setting up bind9-dnsutils (1:9.18.1-1ubuntu1.2) ...
                              Setting up gir1.2-rsvg-2.0:amd64 (2.52.5+dfsg-3) ...
                              Setting up networkd-dispatcher (2.1-2ubuntu0.22.04.2) ...
                              Setting up ssh (1:8.9p1-3) ...
                              Setting up libfontconfig-dev:amd64 (2.13.1-4.2ubuntu5) ...
                              Setting up ubuntu-standard (1.481) ...
                              Setting up libglib2.0-dev:amd64 (2.72.1-1) ...
                              Setting up libdbus-1-dev:amd64 (1.12.20-2ubuntu4) ...
                              Setting up command-not-found (22.04.0) ...
                              Setting up libthai-dev:amd64 (0.1.29-1build1) ...
                              Setting up libcairo2-dev:amd64 (1.16.0-5ubuntu2) ...
                              Setting up libxft-dev:amd64 (2.3.4-1) ...
                              Setting up libgdk-pixbuf-2.0-dev:amd64 (2.42.8+dfsg-1ubuntu0.1) ...
                              Setting up libharfbuzz-dev:amd64 (2.7.4-1ubuntu3.1) ...
                              Setting up libfontconfig1-dev:amd64 (2.13.1-4.2ubuntu5) ...
                              Setting up libavahi-client-dev:amd64 (0.8-5ubuntu5) ...
                              Setting up libpango1.0-dev:amd64 (1.50.6+ds-2) ...
                              Setting up librsvg2-dev:amd64 (2.52.5+dfsg-3) ...
                              Setting up libavahi-compat-libdnssd-dev:amd64 (0.8-5ubuntu5) ...
                              Setting up python3-update-manager (1:22.04.9) ...
                              Setting up kbd (2.3.0-3ubuntu4) ...
                              Setting up console-setup-linux (1.205ubuntu3) ...
                              Setting up console-setup (1.205ubuntu3) ...
                              Setting up ubuntu-minimal (1.481) ...
                              Setting up python3-distupgrade (1:22.04.14) ...
                              Setting up ubuntu-release-upgrader-core (1:22.04.14) ...
                              Installing new version of config file /etc/update-manager/release-upgrades ...
                              Installing new version of config file /etc/update-motd.d/91-release-upgrade ...
                              Setting up update-manager-core (1:22.04.9) ...
                              Processing triggers for install-info (6.8-4build1) ...
                              Processing triggers for libc-bin (2.35-0ubuntu3.1) ...
                              Processing triggers for ca-certificates (20211016) ...
                              0 added, 0 removed; done.
                              Running hooks in /etc/ca-certificates/update.d...
                              done.
                              Processing triggers for libgdk-pixbuf-2.0-0:amd64 (2.42.8+dfsg-1ubuntu0.1) ...
                              Reading package lists... Done
                              Building dependency tree... Done
                              Searching for obsolete software
                              Remove obsolete packages?
                              70 packages are going to be removed.
                               Continue [yN]  Details [d]
                              Danach startet es nicht mehr.
                              • Glasfaser
                                @jan201 sagte in Fehler mit hm.rpc:
                                Was für ein Update ...
                                setze in neu auf ... Backup rein .. fertig .
                                Thomas Braun J 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @Glasfaser last edited by
                                  @glasfaser sagte in Fehler mit hm.rpc:
                                  setze in neu auf
                                  Und dann diesmal mit der richtigen Zeitzone, mit einem Standarduser und künftig regelmäßigen Updates. Dann wird ein Schuh draus.
                                    Jan201 @Glasfaser last edited by
                                    @glasfaser said in Fehler mit hm.rpc:
                                    Okay, die nächste frage: proxmomx sagt:
                                    WARNING: You have not turned on protection against thin pools running out of space.
                                      WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
                                      Logical volume "vm-300-disk-0" created.
                                      WARNING: Sum of all thin volume sizes (168.00 GiB) exceeds the size of thin pool pve/data and the amount of free space in volume group (<16.00 GiB).
                                    Creating filesystem with 2097152 4k blocks and 524288 inodes
                                    Filesystem UUID: 12919e46-8fa3-42d5-b95e-8323ae1a5b76
                                    Superblock backups stored on blocks:
                                    	32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
                                    extracting archive '/var/lib/vz/template/cache/ubuntu-22.04-standard_22.04-1_amd64.tar.zst'
                                    Total bytes read: 508579840 (486MiB, 99MiB/s)
                                    Detected container architecture: amd64
                                      Logical volume "vm-300-disk-0" successfully removed
                                    TASK ERROR: unable to create CT 300 - unsupported Ubuntu version '22.04'
                                    das ist die runtergeladene version die ich unter "local(pve) > Templates" runtergeladen bekomme
                                      Homoran Global Moderator Administrators @Jan201 last edited by
                                      Vielleicht wäre es hilfreich, mir zu sagen wie ich das in "CodeTags" mache
                                      Ich würde mich gerne über User einloggen, jedoch weiß ich den Anmeldenamen und Passwort nicht mehr.
                                      dann leg doch einen neuen an.
                                      und was ist hiermit?
                                      Dein Thread Titel lautet : Fehler mit hm.rpc
                                      Inzwischen sind wir meilenweit offtopic.
                                      Worum geht es dir?
                                        Jan201 @Homoran last edited by
                                        @homoran said in Fehler mit hm.rpc:
                                        Worum geht es dir?
                                        Genau, wir sind meilenweit entfert. Meine Probleme sind nun noch größer als vorher, da ich auch mit filezilla nicht mein iobroker backup runtergeladen bekomme. das ist mir nun egal.
                                        Mein nächstes Problem ist gerade, das ich Ubuntu 22.04 nicht installiert bekomme, sie meinen letzten Post.
                                          Thomas Braun Most Active @Jan201 last edited by Thomas Braun
                                          @jan201
                                          Die Installation unter Proxmox ist in der Doku zum ioBroker zu finden.
                                          Die Empfehlung geht auch soweit ich weiß eher zu Debian, nicht unbedingt Ubuntu.
                                            hilft dir im Moment nicht, aber anscheinend waren da nicht unbedeutende Fehler in deiner Installation. Darüberhinaus war diese noch an mehreren Stellen veraltet.
                                            Bevor wir jetzt versuchen dieses mit fraglichem Ausgang wiederherzustellen, eine ernst gemeinte Frage:
                                            Wieso arbeitest du mit Containern, wenn du dich damit nicht auskennst. Eine VM wäre wie ein PC zu handeln.
                                            und aus dem selben Grund: warum Proxmox und nicht nativ auf dem (welchen) Rechner?
                                            Nach der Beantwortung machen wir dann weiter warum du
                                            4659
