    3. Entwicklung
    4. Adapter: jeelink
    Adapter: jeelink
      foxthefox Developer last edited by
      Wechsel mal noch in das Verzeichnis /opt/iobroker und setz den Befehl nochmal ab.
        ebu last edited by
        Hallo, ok der Adapter läuft danke. Aber wie kriege ich jetzt meine TX29IT in den Adapter?
        Ich habe den jeelink v3c mit Standard-Firmware.
        Muss ich die ID manuell einpflegen? Wo finde ich die?
        jeelink.0	2017-06-26 22:07:07.520	info	data received: A i1 g210 @ 868 MHz q1
        jeelink.0	2017-06-26 22:07:07.515	info	data received: Current configuration:
        jeelink.0	2017-06-26 22:07:07.511	info	data received: 123z - total power down, needs a reset to start up again
        jeelink.0	2017-06-26 22:07:07.500	info	data received: v - return firmware version and current settings
        jeelink.0	2017-06-26 22:07:07.491	info	data received: - 1: hex, 3: hex+ascii)
        jeelink.0	2017-06-26 22:07:07.483	info	data received: x - set reporting format (0: decimal, 2: decimal+ascii
        jeelink.0	2017-06-26 22:07:07.471	info	data received: q - set quiet mode (1 = don't report bad packets)
        jeelink.0	2017-06-26 22:07:07.461	info	data received: sent with its next ack. Group number becomes sticky
        jeelink.0	2017-06-26 22:07:07.450	info	data received: ,,p post semaphore for group node , to be
        jeelink.0	2017-06-26 22:07:07.439	info	data received: ...,m - add message string to ram, see p command
        jeelink.0	2017-06-26 22:07:07.430	info	data received: l - turn activity LED on PB1 on or off
        jeelink.0	2017-06-26 22:07:07.422	info	data received: n - set group as sticky. Group 0 only, see p command
        jeelink.0	2017-06-26 22:07:07.409	info	data received: 128,,n - release group/node index number entry in eeprom
        jeelink.0	2017-06-26 22:07:07.398	info	data received: ... - space character is a valid delimiter
        jeelink.0	2017-06-26 22:07:07.390	info	data received: ...,s - send data packet to node , no ack
        jeelink.0	2017-06-26 22:07:07.381	info	data received: if using group 0 then sticky group number is used
        jeelink.0	2017-06-26 22:07:07.373	info	data received: ...,a - send data packet to node , request ack
        jeelink.0	2017-06-26 22:07:07.366	info	data received: t - broadcast max-size test packet, request ack
        jeelink.0	2017-06-26 22:07:07.350	info	data received: c - set collect mode (advanced, normally 0)
        jeelink.0	2017-06-26 22:07:07.343	info	data received: g - set network group (RFM12 only allows 212, 0 = any)
        jeelink.0	2017-06-26 22:07:07.337	info	data received: 96..3903 is the range supported by the RFM12B
        jeelink.0	2017-06-26 22:07:07.329	info	data received: o - change frequency offset within the band (default 1600)
        jeelink.0	2017-06-26 22:07:07.307	info	data received: b - set MHz band (4 = 433, 8 = 868, 9 = 915)
        jeelink.0	2017-06-26 22:07:07.306	info	data received: i - set node ID (standard node ids are 1..30)
        jeelink.0	2017-06-26 22:07:07.305	info	data received: Available commands:
        jeelink.0	2017-06-26 22:07:07.284	info	data received:
        jeelink.0	2017-06-26 22:07:07.265	info	data received: 81D2010840060000000000000000EC84 GOOD CRC 0
        jeelink.0	2017-06-26 22:07:07.256	info	Config eeProm:
        jeelink.0	2017-06-26 22:07:07.256	info	data received: [RF12demo.13]FF
        jeelink.0	2017-06-26 22:07:07.247	info	data received:
        jeelink.0	2017-06-26 22:07:05.755	info	open
        jeelink.0	2017-06-26 22:07:05.701	info	RFM12B setting up object = LaCrosse 3
        jeelink.0	2017-06-26 22:07:05.698	info	RFM12B setting up object = LaCrosse 2
        jeelink.0	2017-06-26 22:07:05.694	info	RFM12B setting up object = emonTH1
        jeelink.0	2017-06-26 22:07:05.687	info	entered ready
        jeelink.0	2017-06-26 22:07:05.681	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.jeelink, node: v8.0.0
        jeelink.0	2017-06-26 22:07:05.656	debug	statesDB connected
        jeelink.0	2017-06-26 22:07:05.577	debug	objectDB connected
          Ich war zwar mal der Meinung, dass es mit der richtigen Übertragungsrate auch mit der Standardfirmware funktioniert. Aber das ist wohl nicht so.
          Schau mal zum Flashen in den post #37 und folgende.
            ebu last edited by
            funktioniert. Man muss die Firmware draufspielen.
            Danke Dir 😄
              ebu last edited by
              sorry ich schon wieder. Jetzt lief der Adapter mal einen Tag, seit Tagen krieg ich ihn jetzt nicht mehr zum Laufen. Ich habe den Adapter auch schon mehrfach gelöscht und wieder reinstallt. Jemand eine Idee für mich?
                Diagnose ist nicht so einfach. Im log ist als unterstes noch eine Objekt Änderung enthalten. Stürzt der Adapter nach empfangenen werten ab? Gibt es das zyklische Neustarten auch bei einer leeren Konfiguration? Hast du keine eindeutigen IDs vergeben? Wenn der Adapter einen Tag lang läuft sollte er danach auch laufen.[emoji848]
                  ebu last edited by
                  sorry ich will ja nicht nerven, aber ich krieg ich es nicht mehr hin. Jetzt habe ich sowiel geändert und gelöscht, jetzt kriege ich meinen jeelink nicht mehr geflashed. Habe die neuste Arduino drauf. Jemand nen Tipp?
                  ! Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
                  ! C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Admin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Admin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Admin\Desktop\LaCrosseITPlusReader10.1q_HMS_mod4\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\Admin\AppData\Local\Temp\arduino_build_89714 -warnings=none -build-cache C:\Users\Admin\AppData\Local\Temp\arduino_cache_533919 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Users\Admin\AppData\Local\Temp\untitled1115861587.tmp\sketch_jul05a\sketch_jul05a.ino
                  ! C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Admin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Admin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Admin\Desktop\LaCrosseITPlusReader10.1q_HMS_mod4\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\Admin\AppData\Local\Temp\arduino_build_89714 -warnings=none -build-cache C:\Users\Admin\AppData\Local\Temp\arduino_cache_533919 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -verbose C:\Users\Admin\AppData\Local\Temp\untitled1115861587.tmp\sketch_jul05a\sketch_jul05a.ino
                  ! Using board 'uno' from platform in folder: C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18
                  ! Using core 'arduino' from platform in folder: C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18
                  ! Detecting libraries used…
                  ! "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "C:\Users\Admin\AppData\Local\Temp\arduino_build_89714\sketch\sketch_jul05a.ino.cpp" -o "nul"
                  ! "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "C:\Users\Admin\AppData\Local\Temp\arduino_build_89714\sketch\sketch_jul05a.ino.cpp" -o "nul"
                  ! "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\cores\arduino" "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\variants\standard" "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI\src" "C:\Users\Admin\AppData\Local\Temp\arduino_build_89714\sketch\sketch_jul05a.ino.cpp" -o "C:\Users\Admin\AppData\Local\Temp\arduino_build_89714\preproc\ctags_target_for_gcc_minus_e.cpp"
                  ! C:\Users\Admin\AppData\Local\Temp\untitled1115861587.tmp\sketch_jul05a\LaCrosseITPlusReader10.ino:16:17: fatal error: RFM.h: No such file or directory
                  ! #include "RFM.h"
                  ! compilation terminated.
                  ! Bibliothek SPI in Version 1.0 im Ordner: C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.18\libraries\SPI wird verwendet
                  ! exit status 1
                  ! Fehler beim Kompilieren für das Board Arduino/Genuino Uno.
                  Die Bibliothek SPI wird verwendet?
                    Habe leider keine Erfahrung was man da machen kann. Ich benutze den jeelink mit der orignal Firmware und Sensoren von openenergy/emonTH.
                    • dabbeljuh
                      dabbeljuh last edited by
                      N'Abend zusammen,
                      kann mir jemand verraten, was ich verkehrt mache, dass ich zwar im Log die Einträge meiner TX29 DTH erhalte, aber in der Instanz / den Objekten von Jeelink.0 die Geräte nicht auftauchen?
                      Im Log steht z.B. das hier:
                      received ID :44 is not defined in the adapter or not unique received address
                      jeelink.0	2017-07-10 23:09:25.493	debug	splice : 44,1,4,229,63
                      jeelink.0	2017-07-10 23:09:25.493	info	data received: OK 9 44 1 4 229 63
                      jeelink.0	2017-07-10 23:09:21.827	debug	received ID :4 is not defined in the adapter or not unique received address
                      jeelink.0	2017-07-10 23:09:21.826	debug	splice : 4,1,4,231,63
                      jeelink.0	2017-07-10 23:09:21.826	info	data received: OK 9 4 1 4 231 63
                      jeelink.0	2017-07-10 23:09:21.562	debug	redis publish io.system.adapter.jeelink.0.outputCount {"val":8,"ack":true,"ts":1499720961556,"q":0,"from":"system.adapter.jeelink.0","lc":1499710016995}
                      jeelink.0	2017-07-10 23:09:21.562	debug	redis publish io.system.adapter.jeelink.0.inputCount {"val":0,"ack":true,"ts":1499720961554,"q":0,"from":"system.adapter.jeelink.0","lc":1499710016994}
                      jeelink.0	2017-07-10 23:09:21.561	debug	redis publish io.system.adapter.jeelink.0.uptime {"val":10385,"ack":true,"ts":1499720961552,"q":0,"from":"system.adapter.jeelink.0","lc":1499720961552}
                      jeelink.0	2017-07-10 23:09:21.561	debug	redis publish io.system.adapter.jeelink.0.memHeapUsed {"val":8.31,"ack":true,"ts":1499720961550,"q":0,"from":"system.adapter.jeelink.0","lc":1499720961550}
                      jeelink.0	2017-07-10 23:09:21.561	debug	redis publish io.system.adapter.jeelink.0.memHeapTotal {"val":11.99,"ack":true,"ts":1499720961548,"q":0,"from":"system.adapter.jeelink.0","lc":1499710924062}
                      jeelink.0	2017-07-10 23:09:21.560	debug	redis publish io.system.adapter.jeelink.0.memRss {"val":30.88,"ack":true,"ts":1499720961547,"q":0,"from":"system.adapter.jeelink.0","lc":1499720961547}
                      jeelink.0	2017-07-10 23:09:21.560	debug	redis publish io.system.adapter.jeelink.0.connected {"val":true,"ack":true,"ts":1499720961545,"q":0,"from":"system.adapter.jeelink.0","lc":1499710578976}
                      jeelink.0	2017-07-10 23:09:21.559	debug	redis publish io.system.adapter.jeelink.0.alive {"val":true,"ack":true,"ts":1499720961544,"q":0,"from":"system.adapter.jeelink.0","lc":1499710578974}
                      jeelink.0	2017-07-10 23:09:21.149	debug	received ID :44 is not defined in the adapter or not unique received address
                      jeelink.0	2017-07-10 23:09:21.149	debug	splice : 44,1,4,229,63
                      jeelink.0	2017-07-10 23:09:21.148	info	data received: OK 9 44 1 4 229 63
                      Danke und Gruß
                        Wie sieht denn deine Konfiguration aus. Mach mal nen Screenshot.
                        • dabbeljuh
                          die Konfig sieht derzeit so aus:
                          Ist die Version 0.0.4 des Adapters
                          VG
                            @dabbeljuh:
                            filename="instanz_jeelink.JPG" index="0">~~
                            VG `
                            Da sind noch die beispieldaten drin. Also erste Zeile kannst du die Adresse von 18 auf 4 stellen und dann noch anstatt emonth lacrosse rein. Bei der 2ten Zeile nur die 55 gegen 44 tauschen. Wenn noch mehr Sensoren, dann weitere Zeilen eröffnen und die Adressen entsprechend dem log eintragen.
                            • dabbeljuh
                              Autsch, auf die Idee hätte ich natürlich auch selbst kommen können. Vielen Dank für die Hilfe und natürlich den Adapter als solches! 🙂
                                ebu last edited by
                                mein Problem bleibt leider: Auch nach 100fachen deinstallieren und installieren startet der Adapter nicht mehr. Auch bei einer leeren Konfiguration stürzt er alle paar Sekunden ab. Die Sensoren kann ich nicht definieren, weil ich ja die IDs nicht kenne. Die habe ich letztes mal mit laufendem Adapter in der Log erhalten.
                                Die Firmware auf dem jeelink habe ich wieder zum Laufen bekommen.
                                  @ebu:
                                  Die Firmware auf dem jeelink habe ich wieder zum Laufen bekommen. `
                                  Ich hab keine Ahnung was das sein könnte, zumal es schon lief.
                                  Ist die USB-Schnittstelle richtig definiert (ist es das richtige device)?
                                  Du könntest mal die Version von npm installieren (0.0.3) die ist fast identisch (Taupunkt und abs Luftfeuchte ist da schon drin, bis auf ein paar Änderungen wegen der Autokonfiguration).
                                  Diese Version könnte stabiler sein.
                                  sudo npm install iobroker.jeelink –unsafe-perm
                                  Ist der Adapter im debug Modus und sieht das log noch genauso wie in deinem vorigen post aus?
                                  Diese Fehlermeldungen "terminated with Code..." sind leider nicht grad aussagekräftig.
                                  • dabbeljuh
                                    Hast du denn den Adapter mal über die Konsole komplett deinstalliert und neu eingespielt? Bei mir gab es ähnliche Probleme mit dem ZWave-Adapter. Hab ihn deinstalliert, dann
                                    sudo apt-get install libudev-dev, sudo ldconfig und sudo ldconfig /usr/local/lib64
                                    ausgeführt und schließlich den Adapter wieder installiert.
                                    VG
                                      ebu last edited by
                                      komplett deinstalliert und auch die 3 Befehle versucht - keine Verbesserung. Ja, er zeigt sonst nichts an im debug Modus. Immer nur das Gleiche:
                                      __host.raspberrypi 2017-07-11 17:42:35.208 error instance system.adapter.jeelink.0 terminated with code 1 ()
                                      host.raspberrypi 2017-07-11 17:42:34.513 info instance system.adapter.jeelink.0 started with pid 1663
                                      host.raspberrypi 2017-07-11 17:42:04.490 info Restart adapter system.adapter.jeelink.0 because enabled__
                                      Wie kriege ich genau die 0.0.3 installiert? Bei mir hat er mit deinem Befehl wieder die .4 draufgespielt..
                                        Also auf npm liegt nur 0.0.3. das verstehe ich nicht, wie dann wieder 0.0.4 zustande kommt. Evtl. Ist es nicht ganz gelöscht. Da hilft iobroker update jeelink
                                        Interessant wäre das log gleich nach dem Start des Adapters, also nach stop/Start unter Instanzen.
                                          ebu last edited by
                                          __host.raspberrypi 2017-07-11 21:34:45.184 info Restart adapter system.adapter.jeelink.0 because enabled
                                          host.raspberrypi 2017-07-11 21:34:45.183 error instance system.adapter.jeelink.0 terminated with code 1 ()
                                          host.raspberrypi 2017-07-11 21:34:44.764 info instance system.adapter.jeelink.0 started with pid 3984
                                          host.raspberrypi 2017-07-11 21:34:14.739 info Restart adapter system.adapter.jeelink.0 because enabled
                                          host.raspberrypi 2017-07-11 21:34:14.738 error instance system.adapter.jeelink.0 terminated with code 1 ()
                                          host.raspberrypi 2017-07-11 21:34:14.244 info instance system.adapter.jeelink.0 started with pid 3978
                                          host.raspberrypi 2017-07-11 21:34:14.221 info object change system.adapter.jeelink.0__
                                          davor ist nichts. Er beginnt mit object change..
                                            @ebu:
                                            davor ist nichts. Er beginnt mit object change.. `
                                            das ist alles sehr komisch.
                                            Entweder müsste es "failed to open :" oder "open" für den Verbindungsaufbau mit dem Stick geben.
                                            Und davor gibt es nur das Anlegen der Objekte.
                                            Kannst du irgendwelche Objekte konfigurieren bzw. die Beispieldinge mal drin lassen. Werden dann diese auch angelegt?
                                            Habe in github 3 debug Meldungen ergänzt. Versuch mal diese neue Version zu installieren und im debug Modus den Anfang anschauen bzw. posten.
                                            jeelink
                                            28
                                            185
                                            45382
