    4. REDIS will be back
    REDIS will be back
      Fitti last edited by
      Nodejs 4.2.x …
        @Bluefox:
        @Fitti:
        Bei mir will iobroker mit Redis gar nicht erst starten:
        ! TypeError: 2016-09-26 18:07:30.810 error at readableAddChunk (_stream_readable.js:146:16)
        ! TypeError: 2016-09-26 18:07:30.810 error at Socket.emit (events.js:169:7)
        ! TypeError: 2016-09-26 18:07:30.810 error at emitOne (events.js:77:13)
        ! TypeError: 2016-09-26 18:07:30.810 error at Socket. (/opt/iobroker/node_modules/redis/index.js:267:27)
        ! TypeError: 2016-09-26 18:07:30.810 error at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:415:12)
        ! TypeError: 2016-09-26 18:07:30.810 error at JavascriptRedisParser.Parser.returnReply (/opt/iobroker/node_modules/redis/index.js:188:18)
        ! TypeError: 2016-09-26 18:07:30.810 error at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:816:9)
        ! TypeError: 2016-09-26 18:07:30.810 error at normal_reply (/opt/iobroker/node_modules/redis/index.js:714:21)
        ! TypeError: 2016-09-26 18:07:30.810 error at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:602:49)
        ! TypeError: 2016-09-26 18:07:30.810 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:1135:36
        ! TypeError: 2016-09-26 18:07:30.810 error that._clone is not a function
        ! uncaught 2016-09-26 18:07:30.800 error exception: that._clone is not a function
        ! host-odibroker 2016-09-26 18:07:30.739 info InRedisDB connected
        ! host-odibroker 2016-09-26 18:07:30.730 info States connected to redis 127.0.0.1:6379
        ! host-odibroker 2016-09-26 18:07:30.611 info ip addresses: 192.168.1.232 2003:c3:e3c1:1600:21e:6ff:fe33:9755 fe80::21e:6ff:fe33:9755
        ! host-odibroker 2016-09-26 18:07:30.609 info hostname: odibroker
        ! host-odibroker 2016-09-26 18:07:30.607 info Copyright © 2014-2016 bluefox, hobbyquaker
        ! host-odibroker 2016-09-26 18:07:30.590 info iobroker.js-controller version 0.12.2 js-controller starting
        ! host-odibroker 2016-09-26 18:07:24.230 info terminated
        ! host-odibroker 2016-09-26 18:07:24.225 info received SIGTERM
        ! iobroker 2016-09-26 18:07:23.906 info exit 0
        ! iobroker 2016-09-26 18:07:23.872 info Starting node restart.js
        ! host-odibroker 2016-09-26 18:07:23.411 info terminated
        ! iobroker 2016-09-26 18:07:23.377 info _restart
        Ich hatte es so in diesem thread gelesen, dass ich nicht mehr die git version von iobroker nehmen muss. Oder doch?
        Welche Module genau?
        ****Meine aktiven Module:
        Admin: 1.6.3
        Host: 0.12.2****
        Danke im voraus:
        Fitti Die Objekte gehen leider im Redis noch nicht. Du solltest für Objekte weiter hin "file" benutzen.
        Was ist mit couch? Ist das eine alternative dafür?
          apollon77 last edited by
          Also ich nehme Redis nur für States … Für Objects war mir Redis (weil ja Mem-DB und wird nur unregelmäßig persistiert) zu unsicher.
          Ich denke auch das Redis daher eher für States gedacht war und nur da getestet ist 🙂
          • Bluefox
            Bluefox last edited by
            @Fitti:
            @Bluefox:
            @Fitti:
            Admin: 1.6.3
            Host: 0.12.2****
            Danke im voraus:
            Was ist mit couch? Ist das eine alternative dafür? `
            Couch ist schon dafür, aber ich finde die Zeit nicht, um die features, die in den letzten 2 Jahre eingebaut habe, zu portieren.
              DerUwe last edited by
              Hallo
              Frage: Nutzt die mqtt implementierung auch die redis db?
              Ich habe heute die states auf redis umgestellt…
              LG
              Uwe
                Wenn DU die States auf Redis umgestellt hast werden alle state-Daten in der Redis gespeichert von allen Adaptern.
                Oder auf was gernau ziehlt Deine Frage ab?
                  Ja, das meinte ich.
                  Ich nutze zur zeit mqtt mit den ESP12 und der ESPEasy firmware.
                  In Nodered schreibe ich auch in mqtt, obwohl ich das eigentlich gar nicht muss.
                  Daher stellt sich die Frage wo die Variablen eigentlich am Besten untergebracht sind:
                  Im iobroker oder unter mqtt?
                  • Bluefox
                    @DerUwe:
                    Ja, das meinte ich.
                    Im iobroker oder unter mqtt? `
                    Im iobroker. So sind die über mqtt und iobroker erreichbar. Und so ist auch gedacht.
                      PArt last edited by
                      Auch wenn der Thread doch schon etwas älter ist muss ich auch hier einmal mein Lob lassen… Ich habe seit einigen Wochen massive Probleme mit der Performance gehabt und diese durch Redis lösen können!
                      Daumen hoch!
                      • Dutchman
                        @PArt:
                        Daumen hoch! `
                        Danke dir für den Push redis Stand auf meiner Liste Mal zu probieren aber total verschlafen jetzt habe ich wieder was zu tun am Wochenende.
                        Aus deinem post lese ich Performance boost, wienäussert sich das bei dir und wieviele states/objecten hast du?
                        Send from mobile device
                          Hallo Dutch,
                          ich hatte bei der (Wieder-) Einführung von Redis auch deutliche Performancegewinne bemerkt, finde aber meine Posts dazu nicht mehr (zumindest nicht in diesem Thread)
                          Die States werden damit in einer schnellen Datenbank abgelegt und müssen nicht aus einer (json?) Datei geparst werden.
                          Rainer
                            Naja, so schlimm ists nicht. Die JSON-Datei ist nur die Speicherform. Die Daten liegen im Speicher, aber natürlich ist eine eigene "Memory-DB" vllt nicht ganz so performant wie Redis vor allem bei Subscribes und so.
                            Ansonsten wird das JSON-File halt alle x Sekunden auf Platte gesichert was durchaus I/O kostet.
                            Aber bei Redis muss man auch aufpassen das man ADF nutzt o.ä. sonst ist im zweifel bei einem Restart alles weg
                            • Dutchman
                              hmm wird wohl an mir liegen….
                              neu installation von iobroker auf ubuntu mit nodejs 6 und redis, iobroker einmal gestartet ohne redis danach umgeschaltet (redis vorher natuerlich installiert.
                              Iobroker admin nicht erreicht, commando iobroker status sagt running....
                              log:
                              2017-07-15 23:24:39.933  - ^[[32minfo^[[39m: iobroker _restart
                              2017-07-15 23:24:39.941  - ^[[32minfo^[[39m: host.HomeMaster terminated
                              2017-07-15 23:24:40.181  - ^[[32minfo^[[39m: iobroker Starting node restart.js
                              2017-07-15 23:24:40.188  - ^[[32minfo^[[39m: iobroker exit 0
                              2017-07-15 23:24:40.333  - ^[[32minfo^[[39m: host.HomeMaster received SIGTERM
                              2017-07-15 23:24:40.334  - ^[[32minfo^[[39m: host.HomeMaster terminated
                              2017-07-15 23:24:45.707  - ^[[32minfo^[[39m: host.HomeMaster iobroker.js-controller version 1.1.2 js-controller starting
                              2017-07-15 23:24:45.711  - ^[[32minfo^[[39m: host.HomeMaster Copyright (c) 2014-2017 bluefox, hobbyquaker
                              2017-07-15 23:24:45.711  - ^[[32minfo^[[39m: host.HomeMaster hostname: HomeMaster, node: v6.11.1
                              2017-07-15 23:24:45.712  - ^[[32minfo^[[39m: host.HomeMaster ip addresses: 192.168.1.60 fe80::20c:29ff:fef3:bb55
                              2017-07-15 23:24:45.740  - ^[[32minfo^[[39m: host.HomeMaster States connected to redis: 127.0.0.1:6379
                              2017-07-15 23:24:45.741  - ^[[32minfo^[[39m: host.HomeMaster InRedisDB connected
                              2017-07-15 23:24:45.760  - ^[[31merror^[[39m: uncaught exception: Cannot read property 'views' of null
                              2017-07-15 23:24:45.762  - ^[[31merror^[[39m: TypeError: Cannot read property 'views' of null
                                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:1380:24
                                  at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:639:49)
                                  at normal_reply (/opt/iobroker/node_modules/redis/index.js:721:21)
                                  at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:819:9)
                                  at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
                                  at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
                                  at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:274:27)
                                  at emitOne (events.js:96:13)
                                  at Socket.emit (events.js:188:7)
                                  at readableAddChunk (_stream_readable.js:176:18)
                              2017-07-15 23:24:45.765  - ^[[32minfo^[[39m: iobroker _restart
                              2017-07-15 23:24:45.774  - ^[[32minfo^[[39m: host.HomeMaster terminated
                              2017-07-15 23:24:46.006  - ^[[32minfo^[[39m: iobroker Starting node restart.js
                              2017-07-15 23:24:46.012  - ^[[32minfo^[[39m: iobroker exit 0
                              2017-07-15 23:24:46.158  - ^[[32minfo^[[39m: host.HomeMaster received SIGTERM
                              2017-07-15 23:24:46.158  - ^[[32minfo^[[39m: host.HomeMaster terminated</anonymous>
                              nach umschalten auf settings ohne redis geht alles wieder
                              Edit: Dieser depp der Dutchman heist sollte mal vernuenftig lesen…. es laeuft !
                              Datei => REDIS:
                              >iobroker stop
                              >iobroker setup custom
                              ` > Type of objects DB [file, couch, redis], default [file]:
                              Host of objects DB(file), default[127.0.0.1]:
                              Port of objects DB(file), default[9001]:
                              Type of states DB [file, redis], default [file]: redis
                              Host of states DB (redis), default[127.0.0.1]:
                              Port of states DB (redis), default[6379]:
                              Data directory (file), default[../../../iobroker-data/]:
                              Host name of this machine [FastPC]:
                              creating conf/iobroker.json `
                              iobroker start
                              nur die states und nicht alles auf redis setzen !
                                hab da ein Problem mit multihost
                                redis läuft auf dem Master … kann mich auch von aussen mit verbinden
                                started
                                Sun Dec 10 2017 10:48:54 GMT+0100 (CET)Restarting iobroker...
                                Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Stopping daemon iobroker...
                                Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 631": 1
                                Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 796": 1
                                Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 1025": 1
                                Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 1018": 1
                                steht im log auf dem Master.. iobroker startet nicht…
                                multihost Umgebung
                                Master
                                Type of objects DB [file, couch, redis], default [file]: redis
                                Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
                                Port of objects DB(file), default[6379]: ENTER
                                Type of states DB [file, redis], default [file]: ENTER
                                Host of states DB (file), default[0.0.0.0]: ENTER
                                Port of states DB (file), default[6379]: ENTER
                                Host name of this machine [hostname]: ENTER
                                Slave alles gleich bis auf die IP
                                • Dutchman
                                  Hast du redis so konfiguriert dass er externe Verbindungen erlaubt ?
                                    Ich weiß nicht ob das wichtig ist, aber dein master hat angeblich keinen Namen.
                                    Zu Dutchmans hinweis
                                    http://www.iobroker.net/docu/?page_id=3 … _mit_redis
                                    Gruß Rainer
                                      @Dutchman:
                                      Send from mobile device `
                                      jo.. komme von aussen auch hin
                                      hab es an 0.0.0.0 gebunden also offen wie ein Scheunentor
                                      doch hab es nur nicht reinkopiert.
                                      hat iobroker nen debugschalter ??? vielleicht kann ich im Log was mehr sehen oder consolenausgaben ??
                                        nur die States Arthur nicht die Objekte…. ahhhhhhhhhhhhhhhhh
                                        so läuft zumindest vorerst.. hab aber in Redis keine objekte abgelegt bekommen... hmm.. die Db's sind leer
                                        UPDATE:
                                        habe redis gerade neu Installiert... jetzt werden auch die objekte in der DB angelegt..
                                          robsdobs last edited by
                                          hat jemand die objects DB auf redis laufen?
                                          Was würde das bringen?
                                          Robert
                                          • ruhr70
                                            ruhr70 last edited by
                                            @arteck:
                                            UPDATE:
                                            habe redis gerade neu Installiert... jetzt werden auch die objekte in der DB angelegt.. `
                                            womit greifst Du per GUI suf Redis zu?
                                            104
                                            22589
