Test Adapter Energiefluss v3.6.x GitHub/Latest
Entschuldige die späte Rückmeldung!
Die datenpunkte selbst verwende ich aktuell schon in meiner Vis, sind also gefüllt.
Bin mir nicht ganz sicher was du mit "Code" meinst, hier mal die Onjektdaten der Datenpunkte
@xreactz Das sind Datenpunkte die Du schon hast und wahrscheinlich angegeben hast.
Ich fragte nach den Datenpunkten, die der Energiefluss-Adapter erstellt.Unter -> energiefluss.<InstanzNummer>.*
Diese Werte stellt man in sogenannte Code-Tags, damit man sie besser lesen kann. Ist das 5. Zeichen von links ( </> ), wenn Du einen Beitrag verfasst.
@skb
Danke für die Erlätuerung!
Hoffe es passt so:
Config:{"lines":{"lines":{"solar_to_house":false,"grid_to_house":false,"solar_to_grid":false,"house_to_car":false,"grid_to_battery":false,"solar_to_battery":false,"battery_to_house":false,"house_to_custom0":false,"house_to_custom1":false,"house_to_custom2":false,"house_to_custom3":false},"style":{"line_size":4,"animation_width":8,"animation":"4 12 4 12 4 100","animation_duration":2000,"animation_linecap":"round"},"color":{"solar_to_battery":"","solar_to_grid":"","solar_to_house":"","house_to_car":"","grid_to_house":"","grid_to_battery":"","battery_to_house":"","default":"#000000","house_to_custom0":"","house_to_custom1":"","house_to_custom2":"","house_to_custom3":""},"animation_colors":{"solar_to_battery":"","solar_to_grid":"","solar_to_house":"","house_to_car":"","grid_to_house":"","grid_to_battery":"","battery_to_house":"","default":"#ffce4a","house_to_custom0":"","house_to_custom1":"","house_to_custom2":"","house_to_custom3":""}},"elements":{"elements":{"house":false,"production":false,"grid":false,"car":false,"battery":false,"custom0":false,"custom1":false,"custom2":false,"custom3":false},"style":{"size":2,"circle_radius":50,"shadow":true,"shadow_color":"rgba(0, 0, 0, 0.7)","rect_height":100,"rect_width":100,"rect_corner":15},"fill":{"house":"","grid":"","production":"","battery":"","car":"","custom0":"","custom1":"","custom2":"","custom3":""},"color":{"house":"#00b5dd","grid":"#61687a","production":"#ffce4a","battery":"#a1d343","car":"#c5902e","custom0":"#f20e40","custom1":"#f20e40","custom2":"#f20e40","custom3":"#f20e40"}},"fonts":{"font_src":"","font":"sans-serif","font_size_label":"12","font_size_value":"14","font_size_percent":"14","font_size_unit":"14","font_size_unit_percent":"14","font_size_remaining":"14"},"general":{"no_battery":true,"unit":"kW","battery_animation":true,"type":"circle","custom_type":"consumer"},"icons":{"icons":{"house":false,"production":false,"grid":false,"car":false,"battery":false,"custom0":false,"custom1":false,"custom2":false,"custom3":false},"color":{"default":"#000000"}},"texts":{"texts":{"consumption_text":false,"production_text":false,"grid_text":false,"battery_text":false,"battery_remaining_text":false,"car_text":false,"custom0_text":false,"custom1_text":false,"custom2_text":false,"custom3_text":false},"labels":{"consumption":"Verbrauch","production":"Erzeugung","grid":"Netz","battery":"Batterie","battery_remaining":"Restzeit","car":"Auto","custom0":"","custom1":"","custom2":"","custom3":""},"color":{"default":"#000000","battery_remaining":"#000000"}},"values":{"values":{"consumption_value":false,"production_value":false,"grid_value":false,"car_value":false,"car_percent":false,"car_custom_percent":false,"battery_value":false,"battery_percent":false,"custom0_value":false,"custom1_value":false,"custom2_value":false,"custom3_value":false}},"custom_symbol":{"icon_custom0":"","icon_custom1":"","icon_custom2":"","icon_custom3":""}}Und Data:
{"values":{"car_plugged":false,"car_custom_plugged":false,"consumption_value":"1781.43","production_value":"5110.43","grid_value":"3329.00"},"animations":{"solar_to_house":true,"grid_to_house":false,"solar_to_grid":true,"house_to_car":false,"grid_to_battery":false,"solar_to_battery":false,"battery_to_house":false,"house_to_custom0":false,"house_to_custom1":false,"house_to_custom2":false,"house_to_custom3":false},"battery_animation":{"direction":"none"},"color":{"consumption_value":"#00b5dd","grid_value":"#61687a","production_value":"#ffce4a","car_value":"#c5902e","car_plugged":"#a1d343","car_percent":"#c5902e","battery_value":"#a1d343","battery_remaining":"#a1d343","battery_percent":"#a1d343","custom0_value":"#f20e40","custom1_value":"#f20e40","custom2_value":"#f20e40","custom3_value":"#f20e40","car_custom_percent":"#f20e40","car_custom_plugged":"#a1d343"}} -
@xreactz Danke. Werde ich mit meinem Testsystem einmal nachstellen.
@xreactz Weisst Du, wie oft sich deine Werte ändern?
Kann es vielleicht sein, das Du mehr statische Werte verwendest? Deine angegebenen Datenpunkte müssen sich ändern, damit der Adapter logischerweise den Energiefluss darstellen und ggf. auch wechseln kann.
Abfrage meines Wechselrichters erfolgt alle 60 sec, bin aber gerade dabei die Datenabfrage per Modbus zu realisieren, dann geht es flotter.
@xreactz Dann müsstest Du eigentlich nach 60 Sekunden eine Anzeige bekommen.
Wie gesagt, kommt leider nur kurz "Loading Config" oder so ähnlich, danach White Screen. Egal welcher Browser.
Funktioniert der Configauszug in deinem Testsystem ?
@xreactz Genau und danach sollte dann beim nächsten Ändern der Werte eigentlich eine Anzeige kommen. Da sich bei mir die Werte alle 10 Sekunden ändern, ist die Anzeige auch schneller da.
Deine Daten schaue ich mir Morgen früh an - aktuell im Office unterwegs
Hab gerade die Abfrage per Hand durchgeführt und die Energiefluss Site offen gelassen, keine Änderung bleibt leider beim White Screen. Egal wie schnell ich die Daten aus dem Wechselrichter ziehe oder per die Daten per Hand ändere.
@xreactz Das ist etwas komisch - könntest Du den Adapter einmal auf Debug stellen und dann im Log schauen, ob eine Reaktion auf die Änderung eines Wertes kommt?
Danke!
@skb
Die Warn Meldungen bitte nicht beachten, die Werte verwende ich noch nicht somit kann das PY Skript noch nichts abfragen. Ist aber für deinen Adapter irrelevant da diese Datenpunkte nicht verwendet werden.
@xreactz Initial States sind irgendwie leer. Und die Elements to be displayed stehen alle auf false.
Ok, habe die Elements to Display welche von mir benötigt werden mal manuell auf true gesetzt, dann hab ich endlich einen Ansicht !
Bei einem Instanzneustart ist jedoch wieder alles auf false.... Durch welchen Datenpunkt bzw. wie kann ich das beeinflussen bzw. das Problem lösen ?
{ "lines": { "lines": { "solar_to_house": true, "grid_to_house": true, "solar_to_grid": true, "house_to_car": false, "grid_to_battery": false, "solar_to_battery": false, "battery_to_house": false, "house_to_custom0": false, "house_to_custom1": false, "house_to_custom2": false, "house_to_custom3": false }, "style": { "line_size": 4, "animation_width": 8, "animation": "4 12 4 12 4 100", "animation_duration": 2000, "animation_linecap": "round" }, "color": { "solar_to_battery": "", "solar_to_grid": "", "solar_to_house": "", "house_to_car": "", "grid_to_house": "", "grid_to_battery": "", "battery_to_house": "", "default": "#000000", "house_to_custom0": "", "house_to_custom1": "", "house_to_custom2": "", "house_to_custom3": "" }, "animation_colors": { "solar_to_battery": "", "solar_to_grid": "", "solar_to_house": "", "house_to_car": "", "grid_to_house": "", "grid_to_battery": "", "battery_to_house": "", "default": "#ffce4a", "house_to_custom0": "", "house_to_custom1": "", "house_to_custom2": "", "house_to_custom3": "" } }, "elements": { "elements": { "house": true, "production": true, "grid": true, "car": false, "battery": false, "custom0": false, "custom1": false, "custom2": false, "custom3": false }, "style": { "size": 2, "circle_radius": 50, "shadow": true, "shadow_color": "rgba(0, 0, 0, 0.7)", "rect_height": 100, "rect_width": 100, "rect_corner": 15 }, "fill": { "house": "", "grid": "", "production": "", "battery": "", "car": "", "custom0": "", "custom1": "", "custom2": "", "custom3": "" }, "color": { "house": "#00b5dd", "grid": "#61687a", "production": "#ffce4a", "battery": "#a1d343", "car": "#c5902e", "custom0": "#f20e40", "custom1": "#f20e40", "custom2": "#f20e40", "custom3": "#f20e40" } }, "fonts": { "font_src": "", "font": "sans-serif", "font_size_label": "12", "font_size_value": "14", "font_size_percent": "14", "font_size_unit": "14", "font_size_unit_percent": "14", "font_size_remaining": "14" }, "general": { "no_battery": true, "unit": "kW", "battery_animation": true, "type": "circle", "custom_type": "consumer" }, "icons": { "icons": { "house": true, "production": true, "grid": true, "car": false, "battery": false, "custom0": false, "custom1": false, "custom2": false, "custom3": false }, "color": { "default": "#000000" } }, "texts": { "texts": { "consumption_text": true, "production_text": true, "grid_text": true, "battery_text": false, "battery_remaining_text": false, "car_text": false, "custom0_text": false, "custom1_text": false, "custom2_text": false, "custom3_text": false }, "labels": { "consumption": "Verbrauch", "production": "Erzeugung", "grid": "Netz", "battery": "Batterie", "battery_remaining": "Restzeit", "car": "Auto", "custom0": "", "custom1": "", "custom2": "", "custom3": "" }, "color": { "default": "#000000", "battery_remaining": "#000000" } }, "values": { "values": { "consumption_value": true, "production_value": true, "grid_value": true, "car_value": false, "car_percent": false, "car_custom_percent": false, "battery_value": false, "battery_percent": false, "custom0_value": false, "custom1_value": false, "custom2_value": false, "custom3_value": false } }, "custom_symbol": { "icon_custom0": "", "icon_custom1": "", "icon_custom2": "", "icon_custom3": "" } } -
@xreactz Ich denke, Du müsstest einmal die Datenpunkte, die von Dir verwendet werden, auf den Typ "number" ändern - zum Test vielleicht. Da wir ja hier mit nummerischen Werten arbeiten, wäre es hier von Vorteil, zu sehen, ob es am Datentyp liegt, wie @Latzi schon sagte (hatte ich vorher überlesen).
Danke!
Hatte ich schon getestet, ändert leider nichts.
Habe es jetzt nochmal probiert und alle Werte auf Datenformat "number" geändert und vorher die notwendigen Parameter auf true gesetzt und dann die Instanz neu gestartet. Leider dann auch wieder White Screen. Erst wenn ich wieder alles auf true setzte funkt. wieder alles.
@xreactz Kommt denn im Log der Eintrag "Initial Values" mit Werten? Wenn nein, stimmt mit den Werten noch etwas nicht. Sollten die InitialWerte nicht gelesen werden können, liest der Adapter auch keine anderen Daten.
"Initial Values" kommt nur, wenn der Adapter im Debug läuft - als Hinweis.
Ok --> Initial Values bleibt leer...
Welcher Datentyp soll verwendet werden bzw. wie sieht das bei euch/dir aus ?
Bei mir sind nun alle Datenpunkte welche verwendet werden so:
{ "common": { "name": "PV-Anlage.PV-Power", "role": "value", "type": "number" }, "native": {}, "type": "state", "_id": "javascript.0.PV-Anlage.PV-Power", "from": "system.adapter.admin.0", "user": "system.user.admin", "ts": 1666100495293 }Gruß
