    4. JavaScript
    5. Benötige Programmierhilfe Javascript
    • OliverIO
      OliverIO @Rushmed last edited by
      @rushmed
      ne erst mal nicht, ausser es passiert etwas besonderes.
      bitte mal auch skript mehrmals starten und stoppen und dann schauen wieviele gleiche nachrichten kommen.
        Rushmed Most Active @OliverIO last edited by Rushmed
        @oliverio Das läuft soweit klasse, supervielen Dank!
        Nach Script Neustart, aus und an Schalten kann ich doppelte aber bisher auch nur doppelte Rückmeldungen provozieren.
        1.9.2022, 20:09:07.380	[info ]: javascript.0 (1961154) Stop script script.js.Garage
        1.9.2022, 20:09:07.382	[info ]: javascript.0 (1961154) script.js.Garage: client ended
        1.9.2022, 20:09:08.366	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
        1.9.2022, 20:09:08.404	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
        1.9.2022, 20:09:08.407	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
        1.9.2022, 20:09:08.408	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        1.9.2022, 20:09:08.424	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
        1.9.2022, 20:09:22.539	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
        1.9.2022, 20:09:22.540	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055762540,"q":0,"from":"system.adapter.javascript.0","lc":1662055762540,"c":"script.js.Garage"})
        1.9.2022, 20:09:22.586	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        for device: Garagentor
        1.9.2022, 20:09:22.872	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:09:22.873	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055762873,"q":0,"from":"system.adapter.javascript.0","lc":1662055762873,"c":"script.js.Garage"})
        1.9.2022, 20:09:39.711	[info ]: javascript.0 (1961154) Stop script script.js.Garage
        1.9.2022, 20:09:39.777	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
        1.9.2022, 20:09:39.826	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
        1.9.2022, 20:09:39.828	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
        1.9.2022, 20:09:39.828	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        1.9.2022, 20:09:39.841	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
        1.9.2022, 20:10:14.468	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
        1.9.2022, 20:10:14.469	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055814469,"q":0,"from":"system.adapter.javascript.0","lc":1662055814469,"c":"script.js.Garage"})
        1.9.2022, 20:10:14.470	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
        1.9.2022, 20:10:14.472	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055814471,"q":0,"from":"system.adapter.javascript.0","lc":1662055814469,"c":"script.js.Garage"})
        1.9.2022, 20:10:14.525	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:10:14.552	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:10:15.732	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:10:15.733	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055815733,"q":0,"from":"system.adapter.javascript.0","lc":1662055815733,"c":"script.js.Garage"})
        1.9.2022, 20:10:15.734	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:10:15.737	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055815737,"q":0,"from":"system.adapter.javascript.0","lc":1662055815733,"c":"script.js.Garage"})
        1.9.2022, 20:10:26.293	[info ]: javascript.0 (1961154) Stop script script.js.Garage
        1.9.2022, 20:10:26.295	[info ]: javascript.0 (1961154) script.js.Garage: client ended
        1.9.2022, 20:10:27.303	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
        1.9.2022, 20:10:27.308	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
        1.9.2022, 20:10:27.309	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
        1.9.2022, 20:10:27.309	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        1.9.2022, 20:10:27.319	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
        1.9.2022, 20:10:35.826	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
        1.9.2022, 20:10:35.828	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055835828,"q":0,"from":"system.adapter.javascript.0","lc":1662055835828,"c":"script.js.Garage"})
        1.9.2022, 20:10:36.069	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:10:36.286	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:10:36.287	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055836287,"q":0,"from":"system.adapter.javascript.0","lc":1662055836287,"c":"script.js.Garage"})
        1.9.2022, 20:10:36.287	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:10:36.288	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055836288,"q":0,"from":"system.adapter.javascript.0","lc":1662055836287,"c":"script.js.Garage"})
        1.9.2022, 20:10:55.516	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
        1.9.2022, 20:10:55.516	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055855516,"q":0,"from":"system.adapter.javascript.0","lc":1662055855516,"c":"script.js.Garage"})
        1.9.2022, 20:10:55.558	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:10:56.676	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:10:56.677	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055856677,"q":0,"from":"system.adapter.javascript.0","lc":1662055856677,"c":"script.js.Garage"})
        1.9.2022, 20:10:56.678	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:10:56.678	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055856678,"q":0,"from":"system.adapter.javascript.0","lc":1662055856677,"c":"script.js.Garage"})
        1.9.2022, 20:11:17.185	[info ]: javascript.0 (1961154) Stop script script.js.Garage
        1.9.2022, 20:11:17.187	[info ]: javascript.0 (1961154) script.js.Garage: client ended
        1.9.2022, 20:11:21.690	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
        1.9.2022, 20:11:21.695	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
        1.9.2022, 20:11:21.696	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
        1.9.2022, 20:11:21.696	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        1.9.2022, 20:11:21.705	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
        1.9.2022, 20:11:30.967	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
        1.9.2022, 20:11:30.968	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055890968,"q":0,"from":"system.adapter.javascript.0","lc":1662055890968,"c":"script.js.Garage"})
        1.9.2022, 20:11:31.081	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:11:46.199	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
        1.9.2022, 20:11:46.200	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055906200,"q":0,"from":"system.adapter.javascript.0","lc":1662055906200,"c":"script.js.Garage"})
        1.9.2022, 20:11:46.244	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:11:46.486	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:11:46.487	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055906487,"q":0,"from":"system.adapter.javascript.0","lc":1662055906487,"c":"script.js.Garage"})
        1.9.2022, 20:11:46.487	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:11:46.488	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055906488,"q":0,"from":"system.adapter.javascript.0","lc":1662055906487,"c":"script.js.Garage"})
        1.9.2022, 20:12:16.341	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
        1.9.2022, 20:12:16.342	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055936342,"q":0,"from":"system.adapter.javascript.0","lc":1662055936342,"c":"script.js.Garage"})
        1.9.2022, 20:12:16.401	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
        1.9.2022, 20:12:38.113	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:12:38.114	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055958114,"q":0,"from":"system.adapter.javascript.0","lc":1662055958114,"c":"script.js.Garage"})
        1.9.2022, 20:12:38.114	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:12:38.115	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055958115,"q":0,"from":"system.adapter.javascript.0","lc":1662055958114,"c":"script.js.Garage"})
        1.9.2022, 20:12:44.504	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:12:44.505	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055964505,"q":0,"from":"system.adapter.javascript.0","lc":1662055964505,"c":"script.js.Garage"})
        1.9.2022, 20:12:44.505	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:12:44.506	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055964506,"q":0,"from":"system.adapter.javascript.0","lc":1662055964505,"c":"script.js.Garage"})
        1.9.2022, 20:12:46.161	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:12:46.162	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055966162,"q":0,"from":"system.adapter.javascript.0","lc":1662055966162,"c":"script.js.Garage"})
        1.9.2022, 20:12:46.163	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:12:46.164	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055966163,"q":0,"from":"system.adapter.javascript.0","lc":1662055966162,"c":"script.js.Garage"})
        1.9.2022, 20:12:56.426	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;opening
        1.9.2022, 20:12:56.426	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"opening","ack":false,"ts":1662055976426,"q":0,"from":"system.adapter.javascript.0","lc":1662055976426,"c":"script.js.Garage"})
        1.9.2022, 20:12:56.427	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;opening
        1.9.2022, 20:12:56.427	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"opening","ack":false,"ts":1662055976427,"q":0,"from":"system.adapter.javascript.0","lc":1662055976426,"c":"script.js.Garage"})
        1.9.2022, 20:12:56.502	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:12:56.502	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055976502,"q":0,"from":"system.adapter.javascript.0","lc":1662055976502,"c":"script.js.Garage"})
        1.9.2022, 20:12:56.507	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
        1.9.2022, 20:12:56.508	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055976508,"q":0,"from":"system.adapter.javascript.0","lc":1662055976502,"c":"script.js.Garage"})
        1.9.2022, 20:13:12.637	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closing
        1.9.2022, 20:13:12.638	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closing","ack":false,"ts":1662055992638,"q":0,"from":"system.adapter.javascript.0","lc":1662055992638,"c":"script.js.Garage"})
        1.9.2022, 20:13:12.639	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closing
        1.9.2022, 20:13:12.640	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closing","ack":false,"ts":1662055992639,"q":0,"from":"system.adapter.javascript.0","lc":1662055992638,"c":"script.js.Garage"})
        1.9.2022, 20:13:13.538	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closed
        1.9.2022, 20:13:13.538	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closed","ack":false,"ts":1662055993538,"q":0,"from":"system.adapter.javascript.0","lc":1662055993538,"c":"script.js.Garage"})
        1.9.2022, 20:13:13.539	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closed
        1.9.2022, 20:13:13.539	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closed","ack":false,"ts":1662055993539,"q":0,"from":"system.adapter.javascript.0","lc":1662055993538,"c":"script.js.Garage"})
        1.9.2022, 20:16:12.242	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:16:12.242	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662056172242,"q":0,"from":"system.adapter.javascript.0","lc":1662056172242,"c":"script.js.Garage"})
        1.9.2022, 20:16:12.243	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
        1.9.2022, 20:16:12.243	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662056172243,"q":0,"from":"system.adapter.javascript.0","lc":1662056172242,"c":"script.js.Garage"})
        Kannst du bitte noch diese Meldungen noch aus dem Log entfernen:
        • OliverIO
          @rushmed
          das ist die verbose Einstellung, oben rechts im skript
          wenn du die ausmachst, dann kommt die nicht mehr
            Rushmed Most Active last edited by
            @oliverio Ok, probiere ich aus.
            Könnte man Licht auch als einen boolschen Datenpunkt anlegen über den sowohl manuell gesteuert als auch die Status der Lampe zurück gegeben werden?
            Die Ausgabe von R; im LOG ist denke ich sinnvoll. Vor allem falls bei der ersten Einrichtung etwas schiefgeht. Vll. muss auch nicht R;OK in den LOG sondern nur die möglichen Fehler.
            Anwort Bedeutung
            Error: Invalid command Ungültiger Befehl
            Error: Not enough parameters
            Error: Unknown garage Garage ist nicht bekannt. Kontrollieren Sie den Namen der Garage in ihrer Smart Home Anwendung oder in der maveo app.
            Ich kann den Command DP nicht mit InfluxDB loggen, die Datenreihe bleibt leer. Wir der Wert so schnell zurück gesetzt dass Influx das nicht mitbekommt?
            • OliverIO
              @rushmed said in Benötige Programmierhilfe Javascript:
              Theoretisch schon, aber du ja jetzt einen lesbaren Status
              und ein Vergleich auf == "LightOn" oder auf == true
              kommt auf das selbe heraus
              Da muss ich mal schauen. eigentlich wollte ich ja console.debug machen, aber das hat zu einem Fehler geführt. Gedacht war, das nicht zu viel im log erscheint, sondern nur wenn man das will.
              wenn du einzelne Nachrichten ausschalten willst, dann kannst du vor dem Befehle console.log
              das Kommentarzeichen // schreiben. Dann werden die Anweisungen nicht mehr ausgeführt
              Anwort Bedeutung
              Nein, InfluxDB wird nur bestätigte Nachrichten aufzeichnen.
              Du schreibst den Befehl auch als unbestätigt rein. Musst du aber auch, der Trigger hört aktuell nur auf unbestätigte Nachrichten
                @oliverio OK danke, verbose deaktiviert, funktioniert.
                @oliverio sagte in Benötige Programmierhilfe Javascript:
                Ich brauche das für meine Alexas als ein Gerät (DP) der sowohl zum Steuern da ist als auch immer den aktuellen Status beinhaltet. Habe einen DP Lampe Garagentor angelgt den ich an und aus schalten kann. Den hab ich dann als Write für einen Alias Garagentorbeleuchtung eingetragen und Status Garagentorbeleuchtung als Read. Vom Status habe ich vorher die Ausgabe im Script auf true/false geändert. Das funktioniert nicht, vermutlich weil DP 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht als Typ Sting und nicht Boolean kommt. 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht als boolean festzulegen geht auch nicht, dan meckert das Script.
                Sorry, Fehlalarm. Die Fehler erscheinen wir gewünscht im Log.
                Hab das Resultat unserer Arbeit hier zusammengefasst.
                • Gerudom 0
                  Gerudom 0 last edited by
                  Hallo, wie verhält es sich denn wenn das Garagentor auf Status "Intermediate" steht. Also gekippt ist ?
                  Im Status steht hier nur "Opening" was falsch ist. Hat da jemand eine Idee ? Ich finde es nirgends in den Beschreibungen
                  • OliverIO
                    OliverIO @Gerudom 0 last edited by
                    @gerudom-0
                    und wo kommt der neue Status her?
                    Der ist nirgends beschrieben oder erwähnt hier.
                    Die Doku vom Hersteller ist auch sehr dürftig.
                    Was sollte den deiner Meinung nach passieren?
                    • Gerudom 0
                      @oliverio naja also mein Garagentor kann kippen. In der App wäre es der Button in der Mitte Lüften. Warum der Status nicht beschrieben ist kann ich nicht sagen. Das es ihn aber gibt ist Fakt. Auf diesem Status zählt der dann nämlich die Zeit nach dem drücken. Warum relevant? Ich hab ne Lichtsteuerung die das Tor beleuchtet. Licht geh an wenn Status opening und bei Open mach dies und das. Gleiches Spiel bei Close. Der Status intermediate wird warum auch immer in der API mit dem Dauerstatus Opening quittiert. In meiner Lichtsteuerung also Dauerlicht... Kann das nicht abfangen. Ein logisches und mit negierter Open Abfrage funktioniert leider auch nur bedingt. Es ist schon echt komisch was die Marantec Firma da seit Jahren produziert.
                      OliverIO R 2 Replies Last reply Reply Quote 0
                      • OliverIO
                        OliverIO @Gerudom 0 last edited by OliverIO
                        Ok, wir versuchen es mal langsam
                        @gerudom-0 sagte in Benötige Programmierhilfe Javascript:
                        Ja das ist klar, das du es siehst. Problem ist, das wir nur die ankommenden Daten interpretieren können ohne das wir das sehen.
                        Lüften? Ich habe den Garagentoröffner nicht. Ich habe nicht mal eine Garage. Von daher weiß ich nichts von einer Fernbedienung oder wie sie aussieht.
                        Nochmal die Frage, hast du den auf der Schnittstelle gesehen? Sendet das Garagentor diese Daten? oder ist es nur das was du siehst: Tor ist gestoppt?
                        Welche Zeit? Wo sieht man das das der zählt? Aus den bisherigen Berichten kommen keine Einzeldaten zur Zeit. ggfs. wird der Status Opening mehrmals wiederholt. Allerdings konnte ich da noch keine Regel ableiten, auf Basis der man was interpretieren kann.
                        Weil ich genau den Status (also das Skript), den die Steuerung übermittelt, übersetze und dann direkt in einen Datenpunkt schreibe.
                        Frag doch mal beim Support an, wie du das auf der Schnittstelle erkennen kannst? Leider ist die Dokumentation etwas älter und mittlerweile sendet die Steuerung auch leicht abgewandelte Daten. Ein aktuelles offizielles Dokument das zum aktuellen Status passt habe ich nicht gesehen.
                          Rushmed Most Active @Gerudom 0 last edited by
                          @gerudom-0 Vll. erstmal ein paar Eckdaten. Um welchen Torantrieb geht es bei dir? Hersteller, Bezeichnung? Welche App?
                          Gerudom 0 1 Reply Last reply Reply Quote 0
                          • Gerudom 0
                            Gerudom 0 @Rushmed last edited by
                            @rushmed Marantec comfort 370 heißt der Antrieb und von Maveo gibt's die Smarte Lösung dazu samt ios App. https://apps.apple.com/de/app/maveo-app/id1552198418
                            Ich hab Mal beim Support gefragt was die dazu sagen.
                            • OliverIO
                              @gerudom-0
                              und in dieser app sieht man dieses intermediate?
                              bzw. was sagt die app, wenn das tor mitten drin stoppt?
                              Nachtrag:
                              Ich habe mir mal die App angeschaut.
                              Allerdings die android App, weil man bei den apple-apps nicht "reinschauen" kann.
                              https://play.google.com/store/apps/details?id=com.marantec.maveoprogta&hl=de&gl=US
                              Diese App funktioniert über eine andere Schnittstelle, wie der Code oben.
                              Die App nimmt per Bluetooth kontakt auf und wertet dann diese Daten, welche aber komplett anders aufgebaut sind, aus.
                              In dieser App sehe ich die folgenden States:
                              • GATE_POSITION_IN_BETWEEN
                              • GATE_POSITION_OPEN
                              • GATE_POSITION_OPENING
                              • GATE_POSITION_CLOSING
                              • GATE_POSITION_CLOSED
                              und siehe da, es gibt einen weiteren Status, den die tcp schnittstelle nicht liefert.
                              Ich interpretiere GATE_POSITION_IN_BETWEEN als mittendrin gestoppt, da opening und closing = mitten drin aber in Bewegung bedeutet.
                              In die App reinschauen ist allerdings kein dankbarer job, da das hauptscript aus 25000 Zeilen besteht und durch webpack durchgenudelt wurde.
                              Gott sei dank nicht minifiziert und alles in javascript und html.
                              lustigerweise sind da portraitbilder mit enthalten. wahrscheinlich die entwickler oder die mitarbeiter der firma
                              was für ein schrott die heute alles in die apps mit reinpacken
                              nochmal nachtrag. die obige app ist eine app für eine profilösung
                              ein weiterer durchgang mit dieser app
                              https://play.google.com/store/apps/details?id=com.marantec.maveoapp2&hl=de&gl=US
                              lief leider nicht so gut. die ist technisch anders umgesetzt und daher nicht wirklich einsehbar. ich gehe aber davon aus, das die funktionsweise nicht viel anders ist wie die obige
                              • Gerudom 0
                                Gerudom 0 @OliverIO last edited by Gerudom 0
                                @oliverio auf mich wirkt das ganze Thema so als war da Mal ein Student der sich irgendeine Lösung gesucht hat und hat Mal angefangen. Dann war er weg 😂 seither versuchen mehrere Künstler ihr Glück.... Diese Inkonsistenzen in mehreren Apps Schnittstellen etc. nichts neues. Einer vom Support sagte vor Jahren Mal zu mir die müssen Reverse Engineering betreiben für die Funktionsweise der App. Das sagt alles. So falsch ist mein Eindruck glaub nicht...
                                • OliverIO
                                  @gerudom-0
                                  ja zumindest für die tcp schnittstelle gilt das.
                                  die app sieht ganz gut aus.
                                  evtl fällt dir ja eine regel ein, wie man aus den sich wiederholenden "openings" den status ableiten kann (evtl wenn das mehr wie x sekunden gemeldet wird, dann wird der in between status angenommen.
                                  das lässt sich schon einbauen.
                                  nur ich kann nix testen ich bin auf leute angewiesen, die das gerät haben
                                    TomTom24 @OliverIO last edited by TomTom24
                                    gelöst: der Name vom Torantrieb war gemeint..., den musste ich umbenennen oder benutzen. War nur durch die Rückmeldung irritiert.
                                    @oliverio Leider bekomme ich immer die Meldung:
                                    client received: R;Error;Unknown garage for device: TomsGarage
                                    wenn ich das über iobroker trigger.
                                    Nutze ich die Zapf-App kommt die Meldung:
                                    client received: S;Garagentorantrieb;lightOn for device: TomsGarage
                                    Devicename stimmt also...irgendeine Idee, was ich noch machen könnte?
                                    Danke Tom
                                    • OliverIO
                                      OliverIO @TomTom24 last edited by
                                      @TomTom24
                                      Puh das ist schon eine Weile her.
                                      Da es keine gute Hersteller Beschreibung gibt haben wir das sozusagen Reverse engineerd
                                      Da ich selbst das Gerät nicht besitze war das dann alles per Ferndiagnose
                                      Wenn der Hersteller irgendeine Kleinigkeit ändert dann passt es schon nicht mehr.
                                      communication javascript monitoring
                                      4751
