    3. Off Topic
    4. Magic Mirror zusammen mit IOBroker
      mrjeschke last edited by
      So sieht die mm.sh dann aus
      cd MagicMirror
      npm run server
      Und crontab
      # Edit this file to introduce tasks to be run by cron.
      # Each task to run has to be defined through a single line
      # indicating with different fields when the task will be run
      # and what command to run for the task
      # To define the time you can provide concrete values for
      # minute (m), hour (h), day of month (dom), month (mon),
      # and day of week (dow) or use '*' in these fields (for 'any').
      # Notice that tasks will be started based on the cron's system
      # daemon's notion of time and timezones.
      # Output of the crontab jobs (including errors) is sent through
      # email to the user the crontab file belongs to (unless redirected).
      # For example, you can run a backup of all your user accounts
      # at 5 a.m every week with:
      # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
      # For more information see the manual pages of crontab(5) and cron(8)
      # m h  dom mon dow   command
      @reboot /home/pi/mm.sh
      Kusselin 1 Reply Last reply Reply Quote 0
      • Kusselin
        Kusselin @mrjeschke last edited by Kusselin
        @mrjeschke ok danke Dir.. ja Nano der interne Editor bei Linux.. ich probier’s mal danke Dir 🙂
        Ähhm das kommt wenn ich crontab -e eingebe! Was wähle ichda?
        pi@MagicMirror-live:~$ crontab -e
        no crontab for pi - using an empty one
        Select an editor.  To change later, run 'select-editor'.
          1. /bin/nano        <---- easiest
          2. /usr/bin/vim.tiny
          3. /bin/ed
        Choose 1-3 [1]:
          mrjeschke @Kusselin last edited by
          @kusselin
          Da will er wissen mit welchem Editor du es bearbeiten möchtest.
          Nimm 1 für nano.
          Kusselin 1 Reply Last reply Reply Quote 1
          • Kusselin
            @mrjeschke klappt net 😞
            wenn ich 192.168.200.74:8080 eingebe keine Verbindung...
            da liegt mein MagicMirror
            /home/pi/MagicMirror
            Wasn das jetzt noch nachdem ich crontab beendet habe??
            No modification made
              @kusselin
              Was sagt
              crontab -l
              • Kusselin
                @mrjeschke sagte in Magic Mirror zusammen mit IOBroker:
                crontab -l
                pi@MagicMirror-live:~$ crontab -l
                Homoran M 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @Kusselin last edited by
                  @kusselin sagte in Magic Mirror zusammen mit IOBroker:
                  und auch rebooted?
                    @kusselin
                    Seltsam
                    Zur Sicherheit mal
                    ls -la ~/mm.sh
                    und
                    cat ~/mm.sh
                    • Kusselin
                      Kusselin @Homoran last edited by
                      @homoran hab den ganzen container rebootet ...ist das nicht o.k.?
                      • Kusselin
                        cat ~/mm.sh
                        pi@MagicMirror-live:~$ ls -la ~/mm.sh
                        -rw-rw-r-- 1 pi pi 32 Oct 18 19:26 /home/pi/mm.sh
                        pi@MagicMirror-live:~$ cat ~/mm.sh
                        cd ~/MagicMirror
                        npm run server
                        ich muss dazusagen das ich beid der Eingabe vorhin wo du sagtest ich solle 1 auswählen ein [c] davor hatte und keine Zahl mehr eintragen konnte..kam wahrscheinlich vom Strg+C immer machen....hab dann putty zugemacht udn neu aufgemacht....dann crontab -e eingegeben udn dann dachte ich das ich wieder zu der Auswahl kommen würde - war aber nicht so...dann hat sich gleich der Editor geöffnet..
                        weiss net ob es daran liegt?
                        kann man das nochmal rückgängig machen?
                        Anscheimed ist da was verlorengegangen...so kann ichs mir nur vorstellen....sorry
                          @kusselin
                          Du hast die Datei nicht ausführbar gemacht
                          chmod +r ~/mm.sh
                          • Kusselin
                            @mrjeschke scheisse...auf was man bei Linux alles achten muss...voll krass...
                            jetzt läufts... 🙂
                            und jetzt macht der crontab bzw die datei merkt jetzt...achtuung ein reboot war jetzt weider starten...also ist jetzt wenn ich einen reboot mache immer MM verfügbar..richtig?
                            Frage noch....was hat das ausführen jetzt gebracht.....chmod +r ?
                            was bedeutet das +r?
                            vorher das verstehe ich so konnte man nicht auf die mm.sh zugreifen richtig?
                              mrjeschke @Kusselin last edited by mrjeschke
                              @kusselin
                              Das +r bedeutet das man die Datei ausführen darf, also das es ein Programm ist das man starten darf. Wie eine exe unter WIndows (ok nur in etwa)
                              Für crontab kannst du mal eingeben
                              rm ~/.selected_editor
                              Dann sollte beim nächten mal die Abfrage wieder kommen.
                              Edit: Ja richtig, bei jedem booten wird jetzt der MM gestartet.
                              • Kusselin
                                @mrjeschke perfekt.. danke 🙏 Dir
                                • Kusselin
                                  @kusselin
                                  Auf keinen Fall Windows Notepad. Da kommt nur Unfug raus.
                                  Die Befehle sind im Terminal / ssh einzugeben.
                                  Mit cd ~
                                  geht es ins home-Verzeichnis
                                  Dann startest du dort mit
                                  nano mm.sh
                                  den Editor und gibst die beiden Zeilen
                                  cd ~/MagicMirror
                                  npm run server
                                  ein. Mit Steuerung s speichern, Mit Steuerung x beenden.
                                  Dann gibst du ein
                                  crontab -e
                                  Es öffnet sich so etwas wie ein Editor, dort kommt nur eine Zeile rein (am Ende)
                                  Wieder mit Steueruns s speichern, mit Steuerung x beenden.
                                  sudo reboot
                                  Fertig
                                  Hi, ich musste ein Update/Upgrade meines LXC Containers machen udn habe jetzt das Problem das ich keine Verbindung mehr aufbauen kann zu meinem MM wenn ich IP:8080 in den Browser eingebe.
                                  ich hatte durch deine Hilfe damals mit Cron den MM so ausführbar machen können damit dieser auch bei einem Neustart wieder startet. -> Nun startet er nicht mehr...die cron ist noch vorhanden udn auch die mm.sh unter /home..
                                  Weisst du eventuell was ich mir zerschossen habe beim Update/upgrade?
                                  Über ne Info herzlichen Dank
                                    @kusselin
                                    Ist die Datei mm.sh ausführbar?
                                    In einem meiner Posts ist mir ein dummer Tippfehler passiert.
                                    Es muss heißen
                                    chmod +x ~/mm.sh
                                    Thomas Braun Kusselin 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @mrjeschke last edited by
                                      Ich hab es jetzt nur überflogen, aber genau sowas steuert man über systemd und entsprechende units.
                                      • Kusselin
                                        @mrjeschke hi, ich habe zumindest gestern unter benutzer "pi" in der Console den Befehl "chmod +x ~/mm.sh" abgesetzt...dann den LXC Container neu gestartet udn die IP:8080 im Browser eingegeben... Seite ging aber nicht auf 😞
                                        Frage: Was kann man sich bei einem Update zerschiessen bzw. was kann da überschrieben werden? Der cron und die mm.sh ist ja noch vorhanden udn der Inhalt auch (geprüft mit nano)
                                          @kusselin
                                          Keine Ahnung was da passiert sein könnte.
                                          Ich würde aber mal testen ob die MM-Software läuft oder Fehler bringt.
                                          Dazu mal die mm.sh umbenennen.
                                          mv mm.sh mm2.sh
                                          Nach einem Neustart des LXC-Containers
                                          cd ~/MagicMirror
                                          npm run server
                                          und schauen ob irgendwelche Fehler kommen.
                                          • Kusselin
                                            @mrjeschke Hi schau...ich bin ins Verzeichnis MagicMirror dann das hier:
                                            pi@MagicMirror-live:~/MagicMirror$ npm run server
                                            > magicmirror@2.27.0 server
                                            > node ./serveronly
                                            node:internal/modules/cjs/loader:1031
                                              throw err;
                                            Error: Cannot find module 'envsub'
                                            Require stack:
                                            - /home/pi/MagicMirror/js/app.js
                                            - /home/pi/MagicMirror/serveronly/index.js
                                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
                                                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                                at Function.Module._load (node:internal/modules/cjs/loader:873:27)
                                                at Module.require (node:internal/modules/cjs/loader:1100:19)
                                                at require (node:internal/modules/cjs/helpers:119:18)
                                                at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:6:16)
                                                at Module._compile (node:internal/modules/cjs/loader:1198:14)
                                                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
                                                at Module.load (node:internal/modules/cjs/loader:1076:32)
                                                at Function.Module._load (node:internal/modules/cjs/loader:911:12) {
                                              code: 'MODULE_NOT_FOUND',
                                              requireStack: [
                                                '/home/pi/MagicMirror/js/app.js',
                                                '/home/pi/MagicMirror/serveronly/index.js'
                                            Kannst du da sagen was da net geht?
                                            EDIT: Keiner ne Idee was die Meldungen bedeuten? Ich kann nur lesen was mit "Cannot find modul"
                                            Was ist hier zu machen?
                                            magic mirror
                                            24
                                            224
                                            41943
