    3. Einsteigerfragen
    4. Admininterface Docker
    • Glasfaser
      Glasfaser @Marc73 last edited by
      @marc73 sagte in Admininterface Docker:
      Netzwerk im bridgemodus
      Wäre dann in der Docker Port Config 8081 : 8081
      Adminportal auf Port 8081 HTTP
      Was ist mit meinen Frage oben ....
        Marc73 @Glasfaser last edited by
        @glasfaser ja anderen Browser habe ich auch schon probiert. Wie kann ich denn hier eine Logdatei hochladen?
        • Glasfaser
          @marc73
          siehe hier :
            @glasfaser
            Log:
            buanet-iobroker1
            date stream content
            2022-10-19T16:21:22.903018723Z stdout host.buanet-iobroker1 check instance "system.adapter.backitup.0" for host "buanet-iobroker1"
            2022-10-19T16:21:22.901268306Z stdout host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "buanet-iobroker1"
            2022-10-19T16:21:22.894945040Z stdout host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "buanet-iobroker1"
            2022-10-19T16:21:20.445825187Z stdout
            2022-10-19T16:21:20.445755448Z stdout Starting ioBroker...
            2022-10-19T16:21:20.445700060Z stdout
            2022-10-19T16:21:20.445622458Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:20.444599979Z stdout ----- Step 5 of 5: ioBroker startup -----
            2022-10-19T16:21:20.444424251Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:20.434887331Z stdout
            2022-10-19T16:21:20.434510363Z stdout For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
            2022-10-19T16:21:20.433665986Z stdout Some adapters have special requirements/ settings which can be activated by the use of environment variables.
            2022-10-19T16:21:20.433344531Z stdout
            2022-10-19T16:21:20.432834210Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:20.431786805Z stdout ----- Step 4 of 5: Applying special settings -----
            2022-10-19T16:21:20.431089719Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:06.785453511Z stdout
            2022-10-19T16:21:06.785193094Z stdout Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
            2022-10-19T16:21:06.776460663Z stdout
            2022-10-19T16:21:06.775926979Z stdout (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
            2022-10-19T16:21:06.469377553Z stdout
            2022-10-19T16:21:06.469256826Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:06.467731226Z stdout ----- Step 3 of 5: Checking ioBroker installation -----
            2022-10-19T16:21:06.467563798Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:06.465775419Z stdout
            2022-10-19T16:21:06.465170421Z stdout Existing installation of ioBroker detected in /opt/iobroker.
            2022-10-19T16:21:06.334266189Z stdout
            2022-10-19T16:21:06.334161688Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:06.333247535Z stdout ----- Step 2 of 5: Detecting ioBroker installation -----
            2022-10-19T16:21:06.333017406Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:21:06.320835218Z stdout
            2022-10-19T16:21:06.320591164Z stdout Done.
            2022-10-19T16:21:06.274109073Z stdout 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            2022-10-19T16:21:05.199453717Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T16:21:05.196586807Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 96% Building dependency tree... Done
            2022-10-19T16:21:04.766574597Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 42% Reading package lists... 83% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T16:21:02.769668770Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T16:21:02.768041305Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 74% Building dependency tree... Done
            2022-10-19T16:21:02.323147488Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 42% Reading package lists... 77% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T16:20:53.511935447Z stdout Checking the following Packages: ...
            2022-10-19T16:20:53.511849146Z stdout Installing additional packages is set by ENV.
            2022-10-19T16:20:53.511757019Z stdout
            2022-10-19T16:20:53.511666405Z stdout This is not the first run of this container. Skipping first run preparation.
            2022-10-19T16:20:53.511476577Z stdout
            2022-10-19T16:20:53.511163685Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:53.510181418Z stdout ----- Step 1 of 5: Preparing container -----
            2022-10-19T16:20:53.509988578Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:53.509001749Z stdout
            2022-10-19T16:20:53.508822346Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:53.506968153Z stdout ----- SETUID: 1000 -----
            2022-10-19T16:20:53.505851510Z stdout ----- SETGID: 1000 -----
            2022-10-19T16:20:53.504627964Z stdout ----- ENV -----
            2022-10-19T16:20:53.504551538Z stdout ----- -----
            2022-10-19T16:20:53.504219058Z stdout ----- npm: 8.19.2 -----
            2022-10-19T16:20:52.307943810Z stdout ----- node: v16.18.0 -----
            2022-10-19T16:20:52.298215112Z stdout ----- Versions -----
            2022-10-19T16:20:52.298140298Z stdout ----- -----
            2022-10-19T16:20:52.297887832Z stdout ----- build: 2022-10-13T23:57:48+00:00 -----
            2022-10-19T16:20:52.296938103Z stdout ----- image: v7.0.1 -----
            2022-10-19T16:20:52.296404707Z stdout ----- Docker-Image -----
            2022-10-19T16:20:52.296332456Z stdout ----- -----
            2022-10-19T16:20:52.296021301Z stdout ----- hostname: buanet-iobroker1 -----
            2022-10-19T16:20:52.292953400Z stdout ----- arch: x86_64 -----
            2022-10-19T16:20:52.290150979Z stdout ----- System -----
            2022-10-19T16:20:52.289949763Z stdout ----- -----
            2022-10-19T16:20:52.289886262Z stdout ----- Debugging information -----
            2022-10-19T16:20:52.289815386Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:52.289470718Z stdout
            2022-10-19T16:20:52.289413442Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:52.289343066Z stdout ----- Please be patient! -----
            2022-10-19T16:20:52.289277427Z stdout ----- Startupscript is now running. -----
            2022-10-19T16:20:52.289192738Z stdout ----- Welcome to your ioBroker-container! -----
            2022-10-19T16:20:52.289126287Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:52.289009798Z stdout
            2022-10-19T16:20:52.288880196Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:52.284909730Z stdout ------------------------- 2022-10-19 18:20:52 -------------------------
            2022-10-19T16:20:52.282347101Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:20:52.279265562Z stdout
            2022-10-19T16:20:49.254714953Z stdout Done. Have a nice day!
            2022-10-19T16:20:49.254514325Z stdout .
            2022-10-19T16:20:48.111749409Z stdout ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
            2022-10-19T16:20:47.939675861Z stdout .================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
            2022-10-19T16:20:47.228552494Z stdout Shutting down ioBroker...
            2022-10-19T16:20:47.228402404Z stdout Recived termination signal (SIGTERM).
            2022-10-19T16:20:47.223317996Z stdout
            2022-10-19T16:05:45.724334551Z stdout host.buanet-iobroker1 check instance "system.adapter.backitup.0" for host "buanet-iobroker1"
            2022-10-19T16:05:45.722555010Z stdout host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "buanet-iobroker1"
            2022-10-19T16:05:45.717806057Z stdout host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "buanet-iobroker1"
            2022-10-19T16:05:43.124138056Z stdout
            2022-10-19T16:05:43.124037404Z stdout Starting ioBroker...
            2022-10-19T16:05:43.123883227Z stdout
            2022-10-19T16:05:43.123792988Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:43.122557505Z stdout ----- Step 5 of 5: ioBroker startup -----
            2022-10-19T16:05:43.122234350Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:43.112978547Z stdout
            2022-10-19T16:05:43.112850145Z stdout For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
            2022-10-19T16:05:43.112590678Z stdout Some adapters have special requirements/ settings which can be activated by the use of environment variables.
            2022-10-19T16:05:43.112181859Z stdout
            2022-10-19T16:05:43.111685388Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:43.111168655Z stdout ----- Step 4 of 5: Applying special settings -----
            2022-10-19T16:05:43.110235365Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:29.607927011Z stdout
            2022-10-19T16:05:29.607724796Z stdout Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
            2022-10-19T16:05:29.598647059Z stdout
            2022-10-19T16:05:29.598353754Z stdout (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
            2022-10-19T16:05:29.262281010Z stdout
            2022-10-19T16:05:29.262158146Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:29.261084441Z stdout ----- Step 3 of 5: Checking ioBroker installation -----
            2022-10-19T16:05:29.260897100Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:29.259029207Z stdout
            2022-10-19T16:05:29.258486823Z stdout Existing installation of ioBroker detected in /opt/iobroker.
            2022-10-19T16:05:29.144278893Z stdout
            2022-10-19T16:05:29.144092840Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:29.141728814Z stdout ----- Step 2 of 5: Detecting ioBroker installation -----
            2022-10-19T16:05:29.140972964Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:29.129981408Z stdout
            2022-10-19T16:05:29.129754504Z stdout Done.
            2022-10-19T16:05:29.075976569Z stdout 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            2022-10-19T16:05:28.107654119Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T16:05:28.007205604Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 97% Building dependency tree... Done
            2022-10-19T16:05:27.588859968Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 44% Reading package lists... 83% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T16:05:25.457310111Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T16:05:25.454667580Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 92% Building dependency tree... Done
            2022-10-19T16:05:25.031215436Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 44% Reading package lists... 84% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T16:05:16.305354560Z stdout Checking the following Packages: ...
            2022-10-19T16:05:16.305248533Z stdout Installing additional packages is set by ENV.
            2022-10-19T16:05:16.305172020Z stdout
            2022-10-19T16:05:16.305034067Z stdout This is not the first run of this container. Skipping first run preparation.
            2022-10-19T16:05:16.304919028Z stdout
            2022-10-19T16:05:16.304470283Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:16.303391053Z stdout ----- Step 1 of 5: Preparing container -----
            2022-10-19T16:05:16.303224788Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:16.302039906Z stdout
            2022-10-19T16:05:16.301879603Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:16.300647733Z stdout ----- SETUID: 1000 -----
            2022-10-19T16:05:16.298612012Z stdout ----- SETGID: 1000 -----
            2022-10-19T16:05:16.297105374Z stdout ----- ENV -----
            2022-10-19T16:05:16.296964497Z stdout ----- -----
            2022-10-19T16:05:16.296181384Z stdout ----- npm: 8.19.2 -----
            2022-10-19T16:05:14.344610177Z stdout ----- node: v16.18.0 -----
            2022-10-19T16:05:14.336708097Z stdout ----- Versions -----
            2022-10-19T16:05:14.336628621Z stdout ----- -----
            2022-10-19T16:05:14.335845495Z stdout ----- build: 2022-10-13T23:57:48+00:00 -----
            2022-10-19T16:05:14.333994840Z stdout ----- image: v7.0.1 -----
            2022-10-19T16:05:14.333264965Z stdout ----- Docker-Image -----
            2022-10-19T16:05:14.333154676Z stdout ----- -----
            2022-10-19T16:05:14.332815820Z stdout ----- hostname: buanet-iobroker1 -----
            2022-10-19T16:05:14.330700411Z stdout ----- arch: x86_64 -----
            2022-10-19T16:05:14.330605784Z stdout ----- System -----
            2022-10-19T16:05:14.330527995Z stdout ----- -----
            2022-10-19T16:05:14.330424469Z stdout ----- Debugging information -----
            2022-10-19T16:05:14.330341717Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:14.330265429Z stdout
            2022-10-19T16:05:14.330152664Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:14.328712953Z stdout ----- Please be patient! -----
            2022-10-19T16:05:14.328611226Z stdout ----- Startupscript is now running. -----
            2022-10-19T16:05:14.328450486Z stdout ----- Welcome to your ioBroker-container! -----
            2022-10-19T16:05:14.328368497Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:14.328212057Z stdout
            2022-10-19T16:05:14.326743446Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:14.323124286Z stdout ------------------------- 2022-10-19 18:05:14 -------------------------
            2022-10-19T16:05:14.315554136Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:05:14.313258111Z stdout
            2022-10-19T16:03:08.588964463Z stdout Done. Have a nice day!
            2022-10-19T16:03:08.587928859Z stdout ..
            2022-10-19T16:03:06.219106862Z stdout ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
            2022-10-19T16:03:06.203713509Z stdout .================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
            2022-10-19T16:03:05.535453437Z stdout Shutting down ioBroker...
            2022-10-19T16:03:05.535293409Z stdout Recived termination signal (SIGTERM).
            2022-10-19T16:03:05.531902166Z stdout
            2022-10-19T16:02:20.108115804Z stdout host.buanet-iobroker1 check instance "system.adapter.backitup.0" for host "buanet-iobroker1"
            2022-10-19T16:02:20.106518415Z stdout host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "buanet-iobroker1"
            2022-10-19T16:02:20.102048204Z stdout host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "buanet-iobroker1"
            2022-10-19T16:02:17.480091056Z stdout
            2022-10-19T16:02:17.479997542Z stdout Starting ioBroker...
            2022-10-19T16:02:17.479937804Z stdout
            2022-10-19T16:02:17.479714925Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:17.477954196Z stdout ----- Step 5 of 5: ioBroker startup -----
            2022-10-19T16:02:17.477460663Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:17.470863042Z stdout
            2022-10-19T16:02:17.470771715Z stdout For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
            2022-10-19T16:02:17.470674889Z stdout Some adapters have special requirements/ settings which can be activated by the use of environment variables.
            2022-10-19T16:02:17.470619150Z stdout
            2022-10-19T16:02:17.470459198Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:17.468953073Z stdout ----- Step 4 of 5: Applying special settings -----
            2022-10-19T16:02:17.468234099Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:04.475244357Z stdout
            2022-10-19T16:02:04.475130905Z stdout Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
            2022-10-19T16:02:04.474610322Z stdout
            2022-10-19T16:02:04.052207120Z stdout (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
            2022-10-19T16:02:03.628289069Z stdout
            2022-10-19T16:02:03.627872500Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:03.626221498Z stdout ----- Step 3 of 5: Checking ioBroker installation -----
            2022-10-19T16:02:03.626032620Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:03.624950914Z stdout
            2022-10-19T16:02:03.624681922Z stdout Existing installation of ioBroker detected in /opt/iobroker.
            2022-10-19T16:02:03.492896141Z stdout
            2022-10-19T16:02:03.492550211Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:03.491238051Z stdout ----- Step 2 of 5: Detecting ioBroker installation -----
            2022-10-19T16:02:03.491046886Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:02:03.477012292Z stdout
            2022-10-19T16:02:03.476828002Z stdout Done.
            2022-10-19T16:02:03.431184038Z stdout 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            2022-10-19T16:02:02.319951826Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T16:02:02.318032682Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 67% Building dependency tree... Done
            2022-10-19T16:02:01.866223585Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 43% Reading package lists... 84% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T16:01:59.699893623Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T16:01:59.698113906Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 96% Building dependency tree... Done
            2022-10-19T16:01:59.278565902Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 43% Reading package lists... 83% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T16:01:50.433252330Z stdout Checking the following Packages: ...
            2022-10-19T16:01:50.433167178Z stdout Installing additional packages is set by ENV.
            2022-10-19T16:01:50.433096977Z stdout
            2022-10-19T16:01:50.432964750Z stdout This is not the first run of this container. Skipping first run preparation.
            2022-10-19T16:01:50.432831973Z stdout
            2022-10-19T16:01:50.432453891Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:50.430462284Z stdout ----- Step 1 of 5: Preparing container -----
            2022-10-19T16:01:50.430267868Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:50.428939759Z stdout
            2022-10-19T16:01:50.428770181Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:50.427296569Z stdout ----- SETUID: 1000 -----
            2022-10-19T16:01:50.426384604Z stdout ----- SETGID: 1000 -----
            2022-10-19T16:01:50.423716698Z stdout ----- ENV -----
            2022-10-19T16:01:50.423317741Z stdout ----- -----
            2022-10-19T16:01:50.421887168Z stdout ----- npm: 8.19.2 -----
            2022-10-19T16:01:48.343911772Z stdout ----- node: v16.18.0 -----
            2022-10-19T16:01:48.334222500Z stdout ----- Versions -----
            2022-10-19T16:01:48.334143549Z stdout ----- -----
            2022-10-19T16:01:48.333920620Z stdout ----- build: 2022-10-13T23:57:48+00:00 -----
            2022-10-19T16:01:48.332855165Z stdout ----- image: v7.0.1 -----
            2022-10-19T16:01:48.332259993Z stdout ----- Docker-Image -----
            2022-10-19T16:01:48.332040602Z stdout ----- -----
            2022-10-19T16:01:48.331848249Z stdout ----- hostname: buanet-iobroker1 -----
            2022-10-19T16:01:48.328395642Z stdout ----- arch: x86_64 -----
            2022-10-19T16:01:48.304325933Z stdout ----- System -----
            2022-10-19T16:01:48.304268332Z stdout ----- -----
            2022-10-19T16:01:48.304194631Z stdout ----- Debugging information -----
            2022-10-19T16:01:48.303971015Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:48.303756974Z stdout
            2022-10-19T16:01:48.303676110Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:48.303558508Z stdout ----- Please be patient! -----
            2022-10-19T16:01:48.303422918Z stdout ----- Startupscript is now running. -----
            2022-10-19T16:01:48.302936423Z stdout ----- Welcome to your ioBroker-container! -----
            2022-10-19T16:01:48.302774195Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:48.300359343Z stdout
            2022-10-19T16:01:48.300189853Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:48.298125856Z stdout ------------------------- 2022-10-19 18:01:48 -------------------------
            2022-10-19T16:01:48.297116277Z stdout --------------------------------------------------------------------------------
            2022-10-19T16:01:48.293007760Z stdout
            2022-10-19T15:57:42.574677332Z stdout Done. Have a nice day!
            2022-10-19T15:57:42.572704599Z stdout ..
            2022-10-19T15:57:40.183491602Z stdout ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
            2022-10-19T15:57:40.171969175Z stdout .================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
            2022-10-19T15:57:39.473846013Z stdout Shutting down ioBroker...
            2022-10-19T15:57:39.473705536Z stdout Recived termination signal (SIGTERM).
            2022-10-19T15:57:39.470297942Z stdout
            2022-10-19T15:49:30.730238823Z stdout object system.meta.uuid created: aaee033c-655b-48a6-95a5-316efcdd06c9
            2022-10-19T15:49:30.427813161Z stdout host.buanet-iobroker1 check instance "system.adapter.backitup.0" for host "buanet-iobroker1"
            2022-10-19T15:49:30.426116608Z stdout host.buanet-iobroker1 check instance "system.adapter.discovery.0" for host "buanet-iobroker1"
            2022-10-19T15:49:30.420822521Z stdout host.buanet-iobroker1 check instance "system.adapter.admin.0" for host "buanet-iobroker1"
            2022-10-19T15:49:27.764978203Z stdout
            2022-10-19T15:49:27.764892776Z stdout Starting ioBroker...
            2022-10-19T15:49:27.764813625Z stdout
            2022-10-19T15:49:27.764691036Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:49:27.763615705Z stdout ----- Step 5 of 5: ioBroker startup -----
            2022-10-19T15:49:27.763419240Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:49:27.727441573Z stdout
            2022-10-19T15:49:27.727339296Z stdout For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
            2022-10-19T15:49:27.727206632Z stdout Some adapters have special requirements/ settings which can be activated by the use of environment variables.
            2022-10-19T15:49:27.727128868Z stdout
            2022-10-19T15:49:27.727002053Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:49:27.725784233Z stdout ----- Step 4 of 5: Applying special settings -----
            2022-10-19T15:49:27.725635106Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:49:27.724836718Z stdout
            2022-10-19T15:49:27.723831176Z stdout Done.
            2022-10-19T15:49:26.499369825Z stdout The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "buanet-iobroker1".
            2022-10-19T15:49:26.491022050Z stdout The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "buanet-iobroker1".
            2022-10-19T15:49:26.482118016Z stdout Updating hostname to buanet-iobroker1... The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "buanet-iobroker1".
            2022-10-19T15:49:01.253085577Z stdout Hostname in ioBroker does not match the hostname of this container.
            2022-10-19T15:48:46.716924844Z stdout
            2022-10-19T15:48:46.716552101Z stdout Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
            2022-10-19T15:48:46.708656633Z stdout
            2022-10-19T15:48:46.708437730Z stdout (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
            2022-10-19T15:48:46.112022483Z stdout
            2022-10-19T15:48:46.111922294Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:48:46.110862577Z stdout ----- Step 3 of 5: Checking ioBroker installation -----
            2022-10-19T15:48:46.110763287Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:48:46.109621306Z stdout
            2022-10-19T15:48:46.109275325Z stdout Existing installation of ioBroker detected in /opt/iobroker.
            2022-10-19T15:48:45.879875465Z stdout
            2022-10-19T15:48:45.879796714Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:48:45.878789685Z stdout ----- Step 2 of 5: Detecting ioBroker installation -----
            2022-10-19T15:48:45.878614594Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:48:45.858804594Z stdout
            2022-10-19T15:48:45.858523577Z stdout Done.
            2022-10-19T15:48:45.812146814Z stdout 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            2022-10-19T15:48:44.674999849Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T15:48:44.673305571Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 73% Building dependency tree... Done
            2022-10-19T15:48:44.239316546Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 43% Reading package lists... 77% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T15:48:42.096355140Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T15:48:42.091425434Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 97% Building dependency tree... Done
            2022-10-19T15:48:41.659487042Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 44% Reading package lists... 84% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T15:48:33.429262785Z stdout Checking the following Packages: ...
            2022-10-19T15:48:33.429173896Z stdout Installing additional packages is set by ENV.
            2022-10-19T15:48:33.429103845Z stdout
            2022-10-19T15:48:33.428995543Z stdout Registering maintenance script as command... Done.
            2022-10-19T15:48:33.428920204Z stdout
            2022-10-19T15:48:33.428763639Z stdout Done.
            2022-10-19T15:48:33.257486122Z stdout 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            2022-10-19T15:48:32.190812804Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T15:48:32.188839459Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 78% Building dependency tree... Done
            2022-10-19T15:48:31.638971979Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 44% Reading package lists... 84% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T15:48:29.658202752Z stdout Reading state information... 0% Reading state information... 0% Reading state information... Done
            2022-10-19T15:48:29.656153056Z stdout Building dependency tree... 0% Building dependency tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency tree... 97% Building dependency tree... Done
            2022-10-19T15:48:29.236742396Z stdout Reading package lists... 0% Reading package lists... 0% Reading package lists... 0% Reading package lists... 42% Reading package lists... 83% Reading package lists... 96% Reading package lists... 96% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... 99% Reading package lists... Done
            2022-10-19T15:48:25.678655928Z stdout Processing triggers for libc-bin (2.31-13+deb11u4) ...
            2022-10-19T15:48:25.134507829Z stdout
            2022-10-19T15:48:25.134438078Z stdout Run 'dpkg-reconfigure tzdata' if you wish to change it.
            2022-10-19T15:48:25.134363414Z stdout Universal Time is now: Wed Oct 19 15:48:25 UTC 2022.
            2022-10-19T15:48:25.134147598Z stdout Local time is now: Wed Oct 19 15:48:25 UTC 2022.
            2022-10-19T15:48:25.129490984Z stdout Current default time zone: 'Etc/UTC'
            2022-10-19T15:48:25.129307019Z stdout
            2022-10-19T15:48:24.485140975Z stdout Setting up tzdata (2021a-1+deb11u7) ...
            2022-10-19T15:48:24.118296879Z stdout Setting up nodejs (16.18.0-deb-1nodesource1) ...
            2022-10-19T15:48:23.776597522Z stdout Setting up linux-libc-dev:amd64 (5.10.149-1) ...
            2022-10-19T15:48:23.324414985Z stdout Setting up libksba8:amd64 (1.5.0-3+deb11u1) ...
            2022-10-19T15:48:14.965689879Z stdout Unpacking nodejs (16.18.0-deb-1nodesource1) over (16.17.1-deb-1nodesource1) ...
            2022-10-19T15:48:14.552721775Z stdout Preparing to unpack .../nodejs_16.18.0-deb-1nodesource1_amd64.deb ...
            2022-10-19T15:48:11.939945767Z stdout Unpacking linux-libc-dev:amd64 (5.10.149-1) over (5.10.140-1) ...
            2022-10-19T15:48:11.514965603Z stdout Preparing to unpack .../linux-libc-dev_5.10.149-1_amd64.deb ...
            2022-10-19T15:48:10.531195486Z stdout Unpacking libksba8:amd64 (1.5.0-3+deb11u1) over (1.5.0-3) ...
            2022-10-19T15:48:10.007809729Z stdout Preparing to unpack .../libksba8_1.5.0-3+deb11u1_amd64.deb ...
            2022-10-19T15:48:07.046867746Z stdout Unpacking tzdata (2021a-1+deb11u7) over (2021a-1+deb11u6) ...
            2022-10-19T15:48:06.446950629Z stdout Preparing to unpack .../tzdata_2021a-1+deb11u7_all.deb ...
            2022-10-19T15:48:06.440464248Z stdout (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 29350 files and directories currently installed.)
            2022-10-19T15:48:05.333800948Z stdout Preconfiguring packages ...
            2022-10-19T15:47:45.537128563Z stdout Updating Linux packages on first run...
            2022-10-19T15:47:45.536963622Z stdout
            2022-10-19T15:47:45.536678305Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:45.535315983Z stdout ----- Step 1 of 5: Preparing container -----
            2022-10-19T15:47:45.535207856Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:45.533739144Z stdout
            2022-10-19T15:47:45.533555504Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:45.531943765Z stdout ----- SETUID: 1000 -----
            2022-10-19T15:47:45.530600668Z stdout ----- SETGID: 1000 -----
            2022-10-19T15:47:45.529013729Z stdout ----- ENV -----
            2022-10-19T15:47:45.528929440Z stdout ----- -----
            2022-10-19T15:47:45.528193141Z stdout ----- npm: 8.15.0 -----
            2022-10-19T15:47:42.709820403Z stdout ----- node: v16.17.1 -----
            2022-10-19T15:47:42.242041660Z stdout ----- Versions -----
            2022-10-19T15:47:42.241724755Z stdout ----- -----
            2022-10-19T15:47:42.241182796Z stdout ----- build: 2022-10-13T23:57:48+00:00 -----
            2022-10-19T15:47:42.239246989Z stdout ----- image: v7.0.1 -----
            2022-10-19T15:47:42.237508723Z stdout ----- Docker-Image -----
            2022-10-19T15:47:42.237146405Z stdout ----- -----
            2022-10-19T15:47:42.236607921Z stdout ----- hostname: buanet-iobroker1 -----
            2022-10-19T15:47:42.232258524Z stdout ----- arch: x86_64 -----
            2022-10-19T15:47:42.218319820Z stdout ----- System -----
            2022-10-19T15:47:42.217976789Z stdout ----- -----
            2022-10-19T15:47:42.217649484Z stdout ----- Debugging information -----
            2022-10-19T15:47:42.217132376Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:42.215630413Z stdout
            2022-10-19T15:47:42.215159468Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:42.213641681Z stdout ----- Please be patient! -----
            2022-10-19T15:47:42.213328988Z stdout ----- Startupscript is now running. -----
            2022-10-19T15:47:42.212935269Z stdout ----- Welcome to your ioBroker-container! -----
            2022-10-19T15:47:42.212428223Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:42.210818147Z stdout
            2022-10-19T15:47:42.210337689Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:42.208660161Z stdout ------------------------- 2022-10-19 17:47:42 -------------------------
            2022-10-19T15:47:42.205796289Z stdout --------------------------------------------------------------------------------
            2022-10-19T15:47:42.202350020Z stdout
            • Glasfaser
              @marc73
              Das ist der Container Log .... alles gut
              Log dich in der Docker-Konsole ein und poste die Ausgabe von
              iobroker logs --watch
              M 3 Replies Last reply Reply Quote 0
                @glasfaser versuche ich gerade bin im Terminal aber das lässt sich nicht kopieren muss ich das mit dem Putty machen oder geht das auch aus dem Terminal?
                • Glasfaser
                  Der gleiche Lade Screen mit dem Logo .
                  Versuche mal im "inkognito Modus" im Browser.
                    @glasfaser gleiches spiel
                      @glasfaser
                      so jetzt habe ich es:
                      root@buanet-iobroker1:/opt/iobroker# iobroker logs --watch
                      2022-10-19 17:49:29.412 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                      2022-10-19 17:49:29.419 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                      2022-10-19 17:49:29.420 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                      2022-10-19 17:49:29.422 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                      2022-10-19 17:49:29.932 - info: host.buanet-iobroker1 connected to Objects and States
                      2022-10-19 17:49:30.002 - info: host.buanet-iobroker1 Node.js version has changed from unknown to 16.18.0
                      2022-10-19 17:49:30.104 - info: host.buanet-iobroker1 added notifications configuration of host
                      2022-10-19 17:49:30.378 - info: host.buanet-iobroker1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                      2022-10-19 17:49:30.415 - info: host.buanet-iobroker1 3 instances found
                      2022-10-19 17:49:30.429 - info: host.buanet-iobroker1 starting 3 instances
                      2022-10-19 17:49:30.512 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 892
                      2022-10-19 17:49:30.730 - info: host.buanet-iobroker1 Created UUID: aaee033c-655b-48a6-95a5-316efcdd06c9
                      2022-10-19 17:49:33.284 - info: admin.0 (892) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 17:49:33.406 - info: admin.0 (892) requesting all states
                      2022-10-19 17:49:33.408 - info: admin.0 (892) requesting all objects
                      2022-10-19 17:49:33.537 - info: admin.0 (892) received all objects
                      2022-10-19 17:49:33.584 - info: admin.0 (892) Request actual repository...
                      2022-10-19 17:49:33.599 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2022-10-19 17:49:33.648 - info: admin.0 (892) http server listening on port 8081
                      2022-10-19 17:49:33.649 - info: admin.0 (892) Use link "http://localhost:8081" to configure.
                      2022-10-19 17:49:33.660 - info: admin.0 (892) socket.io server listening on port 8081
                      2022-10-19 17:49:33.831 - warn: admin.0 (892) Repository cannot be read: Active repo - stable
                      2022-10-19 17:49:33.834 - warn: admin.0 (892) Active repository "stable" cannot be read
                      2022-10-19 17:49:34.502 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 915
                      2022-10-19 17:49:38.083 - info: admin.0 (892) Repository received successfully.
                      2022-10-19 17:49:38.525 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 930
                      2022-10-19 17:49:38.649 - info: discovery.0 (915) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 17:49:40.652 - info: backitup.0 (930) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 17:49:40.738 - info: backitup.0 (930) [iobroker] backup was activated at 02:40 every 1 day(s)
                      2022-10-19 17:57:39.509 - info: host.buanet-iobroker1 received SIGTERM
                      2022-10-19 17:57:39.513 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                      2022-10-19 17:57:39.514 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                      2022-10-19 17:57:39.515 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                      2022-10-19 17:57:39.523 - info: discovery.0 (915) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 17:57:39.523 - info: admin.0 (892) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 17:57:39.530 - info: backitup.0 (930) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 17:57:39.525 - info: discovery.0 (915) terminating
                      2022-10-19 17:57:39.529 - info: discovery.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 17:57:39.534 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                      2022-10-19 17:57:39.532 - info: backitup.0 (930) cleaned everything up...
                      2022-10-19 17:57:39.534 - info: backitup.0 (930) terminating
                      2022-10-19 17:57:39.536 - info: backitup.0 (930) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 17:57:39.537 - info: admin.0 (892) terminating http server on port 8081
                      2022-10-19 17:57:39.540 - info: admin.0 (892) terminating
                      2022-10-19 17:57:39.547 - info: admin.0 (892) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 17:57:39.573 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                      2022-10-19 17:57:39.573 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                      2022-10-19 17:57:40.126 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 17:57:40.162 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 17:57:40.172 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 17:57:40.173 - info: host.buanet-iobroker1 All instances are stopped.
                      2022-10-19 17:57:40.407 - info: host.buanet-iobroker1 terminated
                      2022-10-19 18:02:18.785 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                      2022-10-19 18:02:18.793 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                      2022-10-19 18:02:18.794 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                      2022-10-19 18:02:18.795 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                      2022-10-19 18:02:19.479 - info: host.buanet-iobroker1 connected to Objects and States
                      2022-10-19 18:02:19.579 - info: host.buanet-iobroker1 added notifications configuration of host
                      2022-10-19 18:02:20.088 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                      2022-10-19 18:02:20.096 - info: host.buanet-iobroker1 3 instances found
                      2022-10-19 18:02:20.110 - info: host.buanet-iobroker1 starting 3 instances
                      2022-10-19 18:02:20.163 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 423
                      2022-10-19 18:02:20.184 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                      2022-10-19 18:02:20.198 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                      2022-10-19 18:02:20.210 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                      2022-10-19 18:02:20.222 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                      2022-10-19 18:02:20.236 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                      2022-10-19 18:02:20.249 - info: host.buanet-iobroker1 Some obsolete host states deleted.
                      2022-10-19 18:02:22.494 - info: admin.0 (423) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:02:22.553 - info: admin.0 (423) requesting all states
                      2022-10-19 18:02:22.555 - info: admin.0 (423) requesting all objects
                      2022-10-19 18:02:22.995 - info: admin.0 (423) received all objects
                      2022-10-19 18:02:23.160 - info: admin.0 (423) Request actual repository...
                      2022-10-19 18:02:23.305 - info: admin.0 (423) http server listening on port 8081
                      2022-10-19 18:02:23.305 - info: admin.0 (423) Use link "http://localhost:8081" to configure.
                      2022-10-19 18:02:23.328 - info: admin.0 (423) socket.io server listening on port 8081
                      2022-10-19 18:02:23.371 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2022-10-19 18:02:24.183 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 450
                      2022-10-19 18:02:25.857 - info: admin.0 (423) Repository received successfully.
                      2022-10-19 18:02:30.146 - info: backitup.0 (465) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:02:30.220 - info: backitup.0 (465) [iobroker] backup was activated at 02:40 every 1 day(s)
                      2022-10-19 18:03:05.539 - info: host.buanet-iobroker1 received SIGTERM
                      2022-10-19 18:03:05.543 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                      2022-10-19 18:03:05.545 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                      2022-10-19 18:03:05.548 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                      2022-10-19 18:03:05.567 - info: admin.0 (423) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 18:03:05.568 - info: discovery.0 (450) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 18:03:05.571 - info: discovery.0 (450) terminating
                      2022-10-19 18:03:05.573 - info: discovery.0 (450) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 18:03:05.579 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                      2022-10-19 18:03:05.578 - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 18:03:05.574 - info: admin.0 (423) terminating http server on port 8081
                      2022-10-19 18:03:05.583 - info: admin.0 (423) terminating
                      2022-10-19 18:03:05.585 - info: admin.0 (423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 18:03:05.584 - info: backitup.0 (465) cleaned everything up...
                      2022-10-19 18:03:05.588 - info: backitup.0 (465) terminating
                      2022-10-19 18:03:05.597 - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 18:03:05.619 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                      2022-10-19 18:03:05.620 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                      2022-10-19 18:03:06.190 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 18:03:06.204 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 18:03:06.237 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 18:03:06.238 - info: host.buanet-iobroker1 All instances are stopped.
                      2022-10-19 18:03:06.490 - info: host.buanet-iobroker1 terminated
                      2022-10-19 18:05:44.520 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                      2022-10-19 18:05:44.529 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                      2022-10-19 18:05:44.530 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                      2022-10-19 18:05:44.531 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                      2022-10-19 18:05:45.283 - info: host.buanet-iobroker1 connected to Objects and States
                      2022-10-19 18:05:45.314 - info: host.buanet-iobroker1 added notifications configuration of host
                      2022-10-19 18:05:45.704 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                      2022-10-19 18:05:45.712 - info: host.buanet-iobroker1 3 instances found
                      2022-10-19 18:05:45.726 - info: host.buanet-iobroker1 starting 3 instances
                      2022-10-19 18:05:45.779 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 424
                      2022-10-19 18:05:45.799 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                      2022-10-19 18:05:45.813 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                      2022-10-19 18:05:45.827 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                      2022-10-19 18:05:45.839 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                      2022-10-19 18:05:45.852 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                      2022-10-19 18:05:45.866 - info: host.buanet-iobroker1 Some obsolete host states deleted.
                      2022-10-19 18:05:48.102 - info: admin.0 (424) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:05:48.186 - info: admin.0 (424) requesting all states
                      2022-10-19 18:05:48.187 - info: admin.0 (424) requesting all objects
                      2022-10-19 18:05:48.624 - info: admin.0 (424) received all objects
                      2022-10-19 18:05:48.766 - info: admin.0 (424) Request actual repository...
                      2022-10-19 18:05:48.806 - info: admin.0 (424) http server listening on port 8081
                      2022-10-19 18:05:48.809 - info: admin.0 (424) Use link "http://localhost:8081" to configure.
                      2022-10-19 18:05:48.849 - info: admin.0 (424) socket.io server listening on port 8081
                      2022-10-19 18:05:49.047 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2022-10-19 18:05:49.891 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 451
                      2022-10-19 18:05:51.277 - info: admin.0 (424) Repository received successfully.
                      2022-10-19 18:05:52.117 - info: discovery.0 (451) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:05:53.769 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 466
                      2022-10-19 18:05:55.931 - info: backitup.0 (466) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:05:56.012 - info: backitup.0 (466) [iobroker] backup was activated at 02:40 every 1 day(s)
                      2022-10-19 18:20:47.231 - info: host.buanet-iobroker1 received SIGTERM
                      2022-10-19 18:20:47.235 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                      2022-10-19 18:20:47.239 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                      2022-10-19 18:20:47.239 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                      2022-10-19 18:20:47.260 - info: discovery.0 (451) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 18:20:47.251 - info: admin.0 (424) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 18:20:47.269 - info: backitup.0 (466) Got terminate signal TERMINATE_YOURSELF
                      2022-10-19 18:20:47.263 - info: discovery.0 (451) terminating
                      2022-10-19 18:20:47.265 - info: discovery.0 (451) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 18:20:47.277 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                      2022-10-19 18:20:47.271 - info: backitup.0 (466) cleaned everything up...
                      2022-10-19 18:20:47.273 - info: backitup.0 (466) terminating
                      2022-10-19 18:20:47.275 - info: backitup.0 (466) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 18:20:47.277 - info: admin.0 (424) terminating http server on port 8081
                      2022-10-19 18:20:47.279 - info: admin.0 (424) terminating
                      2022-10-19 18:20:47.281 - info: admin.0 (424) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-10-19 18:20:47.317 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                      2022-10-19 18:20:47.318 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                      2022-10-19 18:20:47.898 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 18:20:47.939 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 18:20:47.941 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-10-19 18:20:47.941 - info: host.buanet-iobroker1 All instances are stopped.
                      2022-10-19 18:20:48.071 - info: host.buanet-iobroker1 terminated
                      2022-10-19 18:21:21.726 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                      2022-10-19 18:21:21.733 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                      2022-10-19 18:21:21.734 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                      2022-10-19 18:21:21.735 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                      2022-10-19 18:21:22.466 - info: host.buanet-iobroker1 connected to Objects and States
                      2022-10-19 18:21:22.493 - info: host.buanet-iobroker1 added notifications configuration of host
                      2022-10-19 18:21:22.879 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                      2022-10-19 18:21:22.888 - info: host.buanet-iobroker1 3 instances found
                      2022-10-19 18:21:22.905 - info: host.buanet-iobroker1 starting 3 instances
                      2022-10-19 18:21:22.960 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 411
                      2022-10-19 18:21:23.001 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                      2022-10-19 18:21:23.018 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                      2022-10-19 18:21:23.044 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                      2022-10-19 18:21:23.074 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                      2022-10-19 18:21:23.087 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                      2022-10-19 18:21:23.101 - info: host.buanet-iobroker1 Some obsolete host states deleted.
                      2022-10-19 18:21:25.330 - info: admin.0 (411) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:21:25.394 - info: admin.0 (411) requesting all states
                      2022-10-19 18:21:25.396 - info: admin.0 (411) requesting all objects
                      2022-10-19 18:21:25.954 - info: admin.0 (411) received all objects
                      2022-10-19 18:21:26.139 - info: admin.0 (411) Request actual repository...
                      2022-10-19 18:21:26.200 - info: admin.0 (411) http server listening on port 8081
                      2022-10-19 18:21:26.201 - info: admin.0 (411) Use link "http://localhost:8081" to configure.
                      2022-10-19 18:21:26.228 - info: admin.0 (411) socket.io server listening on port 8081
                      2022-10-19 18:21:26.472 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2022-10-19 18:21:26.983 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 446
                      2022-10-19 18:21:29.010 - info: admin.0 (411) Repository received successfully.
                      2022-10-19 18:21:29.323 - info: discovery.0 (446) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:21:30.942 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 465
                      2022-10-19 18:21:33.135 - info: backitup.0 (465) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                      2022-10-19 18:21:33.204 - info: backitup.0 (465) [iobroker] backup was activated at 02:40 every 1 day(s)
                        @glasfaser
                        was mir hier aufgefallen ist:
                        was ist das das ist nicht meine externe Adresse und auch keine aus meinem Netz..
                        grüße Und danke
                        Marco
                        • Glasfaser
                          @marc73
                          Sehe keinen Fehler .... warum er in Schleife mit dem Logo hängt.
                          Erstelle zum Test einen neuen Container , aber im Host (nicht bridgemodus)
                          • Glasfaser
                            172.17.0.3
                            die kommt vom bridgemodus
                              @glasfaser
                              habe ich gemacht neuer Container macht genau das gleiche.
                              Ich muss jetzt erstmal Feierabend machen werden da noch weiter suchen.
                              Ich habe auch andere Geräte probiert und auch schon eine ältere Version überall das gleiche.
                              Danke erstmal ich bleibe drann.
                              Grüße Marco
                              • Glasfaser
                                Entwickler-Konsole im Browser mit F12 aufrufen und in der Konsole schauen / posten was dort an Inhalt / Fehler / oder Warn enthalten ist .
                                • Glasfaser
                                  Glasfaser @Glasfaser last edited by Glasfaser
                                  @marc73
                                  @glasfaser sagte in Admininterface Docker:
                                  Popup Blocker aktiv
                                  Firewall aktiv
                                  Was war hiermit !?
                                    Marc73 @Glasfaser last edited by Homoran
                                    @glasfaser
                                    @glasfaser
                                    Moin Popup Blocker oder Firewall sind nicht dran schuld.
                                    Auf dem Synology läuft noch Grafana, influxDB und mein Controller für Unify alle ohne Probleme.
                                    Jetzt habe ich den Firefox mit Konsole (F12 --> Konsole) aufgemacht und da sind folgende Meldungen:
                                    [2022-10-21T08:54:28.284Z] No READY flag received in 3 seconds. Re-init instrument.ts:123:32
                                    [2022-10-21T08:54:28.284Z] Start reconnect 5 instrument.ts:123:32
                                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.254.200:8081/?sid=1666342465275&name=admin aufbauen. socket.io.js:140:21
                                    Die Verbindung zu ws://192.168.254.200:8081/?sid=1666342465275&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                                    [2022-10-21T08:54:28.287Z] Reconnect is already running 5 instrument.ts:123:32
                                    Beim genauen hin schauen wird dieses hier abgebrochen mit einer Ladezeit von 186 Sec:
                                    https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.12.1
                                    Eine eine Idee wo es da klemmen kann??
                                    Grüße Marco
                                    • Glasfaser
                                      Glasfaser @Marc73 last edited by Glasfaser
                                      @marc73
                                      ich habe was gefunden :
                                      Er kann nichts von der URL lesen / erreichen .
                                      zeige mal
                                      iobroker repo list
                                      und in der Dockerkonsole ... geht ein
                                      wget http://download.iobroker.net/sources-dist.json
                                      wird dann etwas runtergeladen !?
                                      EDIT :
                                      Und eine große Bitte ...
                                      pack die Ausgabe in Code-Tags >/< wie schon oben angegeben , so kann man es besser lesen und übersieht es nicht wenn doch Fehler vorhanden sind !!
                                        @glasfaser
                                        root@buanet-iobroker1:/opt/iobroker# iobroker repo list
                                        Active repo(s): stable
                                        root@buanet-iobroker1:/opt/iobroker# wget http://download.iobroker.net/sources-dist.json
                                        --2022-10-22 08:31:18--  http://download.iobroker.net/sources-dist.json
                                        Resolving download.iobroker.net (download.iobroker.net)... 79.143.182.215, 2a02:c205:0:855::1
                                        Connecting to download.iobroker.net (download.iobroker.net)|79.143.182.215|:80... connected.
                                        HTTP request sent, awaiting response... 301 Moved Permanently
                                        Location: http://repo.iobroker.live/sources-dist.json [following]
                                        --2022-10-22 08:31:18--  http://repo.iobroker.live/sources-dist.json
                                        Resolving repo.iobroker.live (repo.iobroker.live)... 172.67.180.22, 104.21.88.137, 2606:4700:3031::6815:5889, ...
                                        Connecting to repo.iobroker.live (repo.iobroker.live)|172.67.180.22|:80... connected.
                                        HTTP request sent, awaiting response... 200 OK
                                        Length: 2876934 (2,7M) [application/json]
                                        Saving to: ‘sources-dist.json.1’
                                        sources-dist.json.1                                100%[================================================================================================================>]   2,74M  2,37MB/s    in 1,2s
                                        2022-10-22 08:31:20 (2,37 MB/s) - ‘sources-dist.json.1’ saved [2876934/2876934]
                                        moin ja läd was runter.
                                        Grüße marco
                                        • Glasfaser
                                          @marc73
                                          Füge eine weitere Repo URL dazu :
                                          iobroker repo add live-stable http://iobroker.live/repo/sources-dist.json
                                          iobroker repo unset stable
                                          iobroker repo set live-stable
                                          iobroker update
                                          Danach mal den Container neu starten
                                            @glasfaser
                                            2022-10-22 13:08:23.653  - info: admin.0 (425) received all objects
                                            2022-10-22 13:08:23.675  - warn: admin.0 (425) Repository cannot be read: Active repo - live-stable
                                            2022-10-22 13:08:23.676  - warn: admin.0 (425) Active repository "live-stable" cannot be read
                                            2022-10-22 13:08:23.880  - info: admin.0 (425) http server listening on port 8081
                                            2022-10-22 13:08:23.881  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                                            2022-10-22 13:08:23.891  - info: admin.0 (425) socket.io server listening on port 8081
                                            2022-10-22 13:08:24.655  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 452
                                            2022-10-22 13:08:26.670  - info: discovery.0 (452) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                                            2022-10-22 13:08:28.639  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                                            2022-10-22 13:08:30.631  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                                            2022-10-22 13:08:30.705  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                                            habe ich gemacht leider siehe
                                            Zeile 3:
                                            Admin ist nicht zu laden 😞
                                            Glasfaser 2 Replies Last reply Reply Quote 0
                                            1488
