    3. Einsteigerfragen
    4. Installation
    5. Node npm - Infos zum (tats.) Versionsstand
      Thomas Braun Most Active @qwerty1896 last edited by
      @qwerty1896
      iobroker update -i
      Halte das Ding auf Stand, da ist mindestens der js-controller schon lange nicht mehr angepackt worden. Tu das!
      • Q
        qwerty1896 @Thomas Braun last edited by
        Used repository: default
        hash unchanged, use cached sources
        Cannot get any information of "_repoInfo". Ignored.
        update done
        Controller "js-controller" : 4.0.23 , installed 3.3.22 [Updateable]
        Alle anderen sind up-to-date.
          @qwerty1896
          Vollständig zeigen.
          iobroker update -i
          • Q
            qwerty1896 last edited by qwerty1896
            Sorry, würde es auch gern im schwarzen Kasten anzeigen lassen. Hier das Resultat:
            update done
            Adapter "accuweather" : 1.2.1 , installed 1.2.1
            Adapter "admin" : 6.2.22 , installed 6.2.22
            Adapter "backitup" : 2.4.12 , installed 2.4.12
            Adapter "daswetter" : 3.1.3 , installed 3.1.3
            Adapter "discovery" : 3.0.5 , installed 3.0.5
            Adapter "dwd" : 2.8.3 , installed 2.8.3
            Adapter "echarts" : 1.0.12 , installed 1.0.12
            Adapter "fahrplan" : 1.2.2 , installed 1.2.2
            Adapter "flot" : 1.11.0 , installed 1.11.0
            Adapter "history" : 2.2.0 , installed 2.2.0
            Adapter "hue" : 3.7.1 , installed 3.7.1
            Adapter "ical" : 1.13.1 , installed 1.13.1
            Adapter "icons-mfd-svg" : 1.1.0 , installed 1.1.0
            Adapter "javascript" : 6.0.3 , installed 6.0.3
            Adapter "pushover" : 3.0.3 , installed 3.0.3
            Adapter "pvforecast" : 2.3.0 , installed 2.3.0
            Adapter "simple-api" : 2.7.0 , installed 2.7.0
            Adapter "socketio" : 4.2.0 , installed 4.2.0
            Adapter "sonoff" : 2.5.1 , installed 2.5.1
            Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
            Adapter "telegram" : 1.14.1 , installed 1.14.1
            Adapter "vis" : 1.4.15 , installed 1.4.15
            Adapter "vis-hqwidgets" : 1.3.0 , installed 1.3.0
            Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
            Adapter "vis-material-advanced": 1.7.2 , installed 1.7.2
            Adapter "vis-timeandweather": 1.2.2 , installed 1.2.2
            Adapter "web" : 4.3.0 , installed 4.3.0
            Adapter "ws" : 1.3.0 , installed 1.3.0
            Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @qwerty1896 last edited by
              @qwerty1896 sagte in Node npm - Infos zum (tats.) Versionsstand:
              wäre nett!
                @qwerty1896
                Schwarzer Kasten
                Bring den js-controller auf Stand. Der Rest ist es ja auch.
                  Änderungen und Erweiterungen in älteren Posts bitte mit EDIT: kennzeichnen!
                  • Q
                    qwerty1896 @Homoran last edited by
                    pi@raspberrypi:~ $ iob update
                    Used repository: stable
                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                    pi@raspberrypi:~ $ iob repo list
                    Active repo(s): stable
                      @qwerty1896
                      Sollte passen.
                      Nächstes Projekt: nodejs auf die empfohlene Version 16 bringen.
                      • Q
                        Vielen Dank. Erst mal mache ich ein Backup.
                        Erst dann traue ich mich an nodsjs 16.
                          @qwerty1896
                          Backitup läuft ja hoffentlich ohnehin täglich?
                          • Q
                            Tja. Am sichersten ist mir eine 1:1-Kopie des SD-Karte.
                            • Q
                              qwerty1896 @qwerty1896 last edited by
                              Hallol Thomas,
                              ich will die "Sache" jetzt mal angehen auf:
                              node.js 16.18.0 und npm 8.19.2
                              Ist das so richtig?
                              a)
                              curl -sL https://deb.nodesource.com/setup_16.18 | sudo -E bash
                              sudo apt install nodejs
                              sudo ln -s /usr/bin/node /usr/bin/nodejs
                              b)
                              sudo apt install nodejs=16.18-deb-1nodesource1
                              oder
                              sudo apt install nodejs=16.18.0-deb-1nodesource1
                                Thomas Braun Most Active @qwerty1896 last edited by Thomas Braun
                                Ist das so richtig?
                                Eher nicht. Hängt davon an welche Grundvoraussetzungen da bei dir gegeben sind.
                                Wie sieht das bei dir aus?
                                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  @qwerty1896
                                  Wenn der Stand von oben noch aktuell ist:
                                  Einfach per (Editor von Hand)
                                  sudo nano /etc/apt/sources.list.d/nodesource.list
                                  aus node_14.x ein node_16.x machen,
                                  Dann
                                  iob stop
                                  sudo apt update
                                  sudo apt full-upgrade
                                  iob start
                                  abwarten, bis alles wieder läuft. Kann etwas dauern.
                                  • Q
                                    Ich habe nicht verändert. Wie mehr nicht?
                                      @qwerty1896
                                      Nö, das ist so simpel.
                                      • Q
                                        Das schaffe auch ich. Erst noch das Backup. Ich gebe eine Rückmeldung.
                                        Das hat aber nicht lange gedauert... (max. 3 Min)...
                                          @qwerty1896
                                          • Q
                                            pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                            armv7l
                                            /usr/bin/nodejs
                                            /usr/bin/node
                                            /usr/bin/npm
                                            v16.18.0
                                            v16.18.0
                                            8.19.2
                                            4.0.23
                                            pi
                                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                            /home/pi
                                            OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                            OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            Paketlisten werden gelesen… Fertig
                                            Abhängigkeitsbaum wird aufgebaut… Fertig
                                            Statusinformationen werden eingelesen… Fertig
                                            Alle Pakete sind aktuell.
                                            nodejs:
                                              Installiert:           16.18.0-deb-1nodesource1
                                              Installationskandidat: 16.18.0-deb-1nodesource1
                                              Versionstabelle:
                                             *** 16.18.0-deb-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                                    100 /var/lib/dpkg/status
                                                 12.22.12~dfsg-1~deb11u1 500
                                                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                            Sieht das gut aus? Ich denke ja... Der ioBroker startet schon mal...
                                            node npm versionsstand
                                            1882
