    3. Einsteigerfragen
    4. Installation
    5. Node npm - Infos zum (tats.) Versionsstand
      Thomas Braun Most Active @qwerty1896 last edited by
      @qwerty1896
      Vollständig zeigen.
      iobroker update -i
      • Q
        qwerty1896 last edited by qwerty1896
        Sorry, würde es auch gern im schwarzen Kasten anzeigen lassen. Hier das Resultat:
        Used repository: default
        hash unchanged, use cached sources
        Cannot get any information of "_repoInfo". Ignored.
        update done
        Adapter "accuweather" : 1.2.1 , installed 1.2.1
        Adapter "admin" : 6.2.22 , installed 6.2.22
        Adapter "backitup" : 2.4.12 , installed 2.4.12
        Adapter "daswetter" : 3.1.3 , installed 3.1.3
        Adapter "discovery" : 3.0.5 , installed 3.0.5
        Adapter "dwd" : 2.8.3 , installed 2.8.3
        Adapter "echarts" : 1.0.12 , installed 1.0.12
        Adapter "fahrplan" : 1.2.2 , installed 1.2.2
        Adapter "flot" : 1.11.0 , installed 1.11.0
        Adapter "history" : 2.2.0 , installed 2.2.0
        Adapter "hue" : 3.7.1 , installed 3.7.1
        Adapter "ical" : 1.13.1 , installed 1.13.1
        Adapter "icons-mfd-svg" : 1.1.0 , installed 1.1.0
        Adapter "javascript" : 6.0.3 , installed 6.0.3
        Controller "js-controller" : 4.0.23 , installed 3.3.22 [Updateable]
        Adapter "pushover" : 3.0.3 , installed 3.0.3
        Adapter "pvforecast" : 2.3.0 , installed 2.3.0
        Adapter "simple-api" : 2.7.0 , installed 2.7.0
        Adapter "socketio" : 4.2.0 , installed 4.2.0
        Adapter "sonoff" : 2.5.1 , installed 2.5.1
        Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
        Adapter "telegram" : 1.14.1 , installed 1.14.1
        Adapter "vis" : 1.4.15 , installed 1.4.15
        Adapter "vis-hqwidgets" : 1.3.0 , installed 1.3.0
        Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
        Adapter "vis-material-advanced": 1.7.2 , installed 1.7.2
        Adapter "vis-timeandweather": 1.2.2 , installed 1.2.2
        Adapter "web" : 4.3.0 , installed 4.3.0
        Adapter "ws" : 1.3.0 , installed 1.3.0
        Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @qwerty1896 last edited by
          @qwerty1896 sagte in Node npm - Infos zum (tats.) Versionsstand:
          wäre nett!
            @qwerty1896
            Schwarzer Kasten
            Bring den js-controller auf Stand. Der Rest ist es ja auch.
              Änderungen und Erweiterungen in älteren Posts bitte mit EDIT: kennzeichnen!
              • Q
                qwerty1896 @Homoran last edited by
                pi@raspberrypi:~ $ iob update
                Used repository: stable
                Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                pi@raspberrypi:~ $ iob repo list
                Active repo(s): stable
                  @qwerty1896
                  Sollte passen.
                  Nächstes Projekt: nodejs auf die empfohlene Version 16 bringen.
                  • Q
                    qwerty1896 @Thomas Braun last edited by
                    Vielen Dank. Erst mal mache ich ein Backup.
                    Erst dann traue ich mich an nodsjs 16.
                      @qwerty1896
                      Backitup läuft ja hoffentlich ohnehin täglich?
                      • Q
                        Tja. Am sichersten ist mir eine 1:1-Kopie des SD-Karte.
                        • Q
                          qwerty1896 @qwerty1896 last edited by
                          Hallol Thomas,
                          ich will die "Sache" jetzt mal angehen auf:
                          node.js 16.18.0 und npm 8.19.2
                          Ist das so richtig?
                          a)
                          curl -sL https://deb.nodesource.com/setup_16.18 | sudo -E bash
                          sudo apt install nodejs
                          sudo ln -s /usr/bin/node /usr/bin/nodejs
                          b)
                          sudo apt install nodejs=16.18-deb-1nodesource1
                          oder
                          sudo apt install nodejs=16.18.0-deb-1nodesource1
                            Thomas Braun Most Active @qwerty1896 last edited by Thomas Braun
                            Ist das so richtig?
                            Eher nicht. Hängt davon an welche Grundvoraussetzungen da bei dir gegeben sind.
                            Wie sieht das bei dir aus?
                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              @qwerty1896
                              Wenn der Stand von oben noch aktuell ist:
                              Einfach per (Editor von Hand)
                              sudo nano /etc/apt/sources.list.d/nodesource.list
                              aus node_14.x ein node_16.x machen,
                              Dann
                              iob stop
                              sudo apt update
                              sudo apt full-upgrade
                              iob start
                              abwarten, bis alles wieder läuft. Kann etwas dauern.
                              • Q
                                Ich habe nicht verändert. Wie mehr nicht?
                                  @qwerty1896
                                  Nö, das ist so simpel.
                                  • Q
                                    Das schaffe auch ich. Erst noch das Backup. Ich gebe eine Rückmeldung.
                                    Das hat aber nicht lange gedauert... (max. 3 Min)...
                                      @qwerty1896
                                      • Q
                                        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        armv7l
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.18.0
                                        v16.18.0
                                        8.19.2
                                        4.0.23
                                        pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                        /home/pi
                                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Paketlisten werden gelesen… Fertig
                                        Abhängigkeitsbaum wird aufgebaut… Fertig
                                        Statusinformationen werden eingelesen… Fertig
                                        Alle Pakete sind aktuell.
                                        nodejs:
                                          Installiert:           16.18.0-deb-1nodesource1
                                          Installationskandidat: 16.18.0-deb-1nodesource1
                                          Versionstabelle:
                                         *** 16.18.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                                100 /var/lib/dpkg/status
                                             12.22.12~dfsg-1~deb11u1 500
                                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                        Sieht das gut aus? Ich denke ja... Der ioBroker startet schon mal...
                                          @qwerty1896
                                          Ja, passt. Und so simpel ist ein Wechsel der nodeJS-Installation.
                                          • Q
                                            VIELEN DANK.
                                            Die Anleitung zur aktuellen Version hat mich schon ein wenig abgeschreckt!
                                            Es passt nicht ganz:
                                            Gibt es "irgendwo" eine gute Anleitung für die influxdb und Grafana-Installation?
                                            1.2k
                                            node npm versionsstand
                                            1882
