    5. Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.
      paul53 @WilliKlein last edited by paul53
      @williklein sagte:
      Wenn der Wert (ppv) vom Growatt > 3000 ist
      dann Shelly (switch) on.
      wenn < 2800 dann switch off
      Damit beträgt die Hysterese 200 W (3000 - 2800).
      Ich exportiere mal das Blockly. Du musst nach dem Import nur noch die Datenpunkte austauschen.
       <variables>
         <variable id="E,j@%LJR_SW?ayCR!]L,">shelly</variable>
       </variables>
       <block type="variables_set" id="k)@FiWDGHXsZ,SHM}1zS" x="300" y="-111">
         <field name="VAR" id="E,j@%LJR_SW?ayCR!]L,">shelly</field>
           <block type="get_value" id="MfV3iIf5#Fx*F#SPbAd`">
             <field name="OID">shelly.0.dev2.Relay0.Switch</field>
           <block type="on_ext" id="_f?n?9+^x32}4r=j(lF0">
             <value name="OID0">
               <shadow type="field_oid" id="Bbh1E/},e./{_Yf3_;px">
                 <field name="oid">0_userdata.0.Blockly.PV-Leistung</field>
               <block type="controls_if" id="5^_]~A*IAxXr.+z+,O|g">
                   <block type="logic_compare" id="9@jz$j=TVGPXYwK_N1tl">
                     <field name="OP">GT</field>
                       <block type="on_source" id="3O1($TjuU2zLP#.u6(]l">
                       <block type="math_number" id=")G`AERK`8@25wu`}x;HJ">
                         <field name="NUM">3000</field>
                   <block type="variables_set" id="eb+o#xx@Yv#zEjH3[c8,">
                       <block type="logic_boolean" id="^9S9/{$K~z:7}vXy+vXd">
                 <value name="IF1">
                   <block type="logic_compare" id="Hk1ghg;eIF}mNq~qg2$N">
                     <field name="OP">LT</field>
                       <block type="on_source" id=";GgYm,hYSX3/.3FCVqb^">
                       <block type="math_number" id="`=4-0(|xgYJ{WIg_dctO">
                         <field name="NUM">2800</field>
                 <statement name="DO1">
                   <block type="variables_set" id="SDx9dFe8-XqT~?PP,265">
                       <block type="logic_boolean" id="^aFhyq!(ta2DJm$2qCtt">
                   <block type="controls_if" id="9q!Zk#Vc?c9EX$:Z9zUK">
                       <block type="logic_compare" id="43Vu=|/wYh`tM*c*dc-J">
                         <field name="OP">NEQ</field>
                           <block type="variables_get" id="*xID|?TLTij`-[+2G4K[">
                           <block type="get_value" id="}|Y8Zi|6j(ivB?Z+tt}8">
                       <block type="control" id="12N5$JSuj7~#-O,zt39W">
                           <block type="variables_get" id="P@N|PbiTOZ:Bo}3[.)SG">
        WilliKlein @paul53 last edited by Homoran
          <variables>
            <variable id="%f2p3[xiEK;T;hxSX|t5">shelly</variable>
          </variables>
            <field name="VAR" id="%f2p3[xiEK;T;hxSX|t5">shelly</field>
                <field name="OID">shelly.0.shellyplus1#7c87ce63d85c#1.Relay0.Switch</field>
                <value name="OID0">
                    <field name="oid">growatt.0.1030054.devices.DFK0BKD00C.historyLast.ppv</field>
                    <value name="IF1">
                            <field name="NUM">3500</field>
                            <field name="DELAY_MS">1000</field>
                            <field name="UNIT">ms</field>
          WilliKlein @WilliKlein last edited by
          @williklein said in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
          ich weiss nicht wie ich das zurückschicken kann
          DJMarc75 paul53 2 Replies Last reply Reply Quote 0
          • DJMarc75
            DJMarc75 @WilliKlein last edited by
            @williklein @paul53 hat Dir ein Blockly geschickt.... was willst Du denn warum zurückschicken ??
              @williklein sagte: ich weiss nicht wie ich das zurückschicken kann
              Als Bild.
              Was soll das?
                ich wollte meine Änderung exportieren. Ich bin nicht gut in der Bedienung. Du hast mir das geschickt, ich habe es importiert, dann geändert und wollte es zurückschicken, ob ich es richtig gemacht habe. Das ist wohl daneben gegangen.
                  @williklein sagte: Das ist wohl daneben gegangen.
                  Nein, aber die Bedingungen lauten jetzt bei dir: Bei hohem Solarertrag Shelly ausschalten und bei niedrigem Solarertrag Shelly einschalten.
                    ja ich möchte das natürlich testen und im Moment ist der Ertrag 0.
                    Ich habe an demshelly eine Lampe und möchte die zum Leuchten bringen.
                    Ich habe im Leitfaden gelesen, habs aber auch nicht verstanden
                    If Then variable <10
                    Schalter ein
                    else
                    Schalter aus
                    endif
                    Das ist für mich logisch. In Blockly kriege ich das nicht hin.
                    crunchip Homoran 2 Replies Last reply Reply Quote 0
                      crunchip Forum Testing Most Active @WilliKlein last edited by
                        WilliKlein @crunchip last edited by
                        @crunchip
                        OK, der shelly spinet von false auf true um, aber das Licht geht nicht an.
                        Ist das dann der falsch é Datenpunkt ?
                        DJMarc75 crunchip W 3 Replies Last reply Reply Quote 0
                        • DJMarc75
                          DJMarc75 @WilliKlein last edited by DJMarc75
                          @williklein Wenn Du uns das Blockly zeigen würdest dann kann man bestimmt auch helfen.
                            Homoran Global Moderator Administrators @WilliKlein last edited by Homoran
                            @williklein sagte in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
                            wenn das dein Kriterium sein soll muss das hier der Trigger sein.
                            und die anschließende Logik machst du genau so wie dort.
                              crunchip Forum Testing Most Active @WilliKlein last edited by crunchip
                              @williklein das musst du im shelly einstellen, ob schalter, steckdose, taster, ob`s relais geschaltet werden soll....
                              hier als Beispiel
                                @crunchip
                                Warum schaltet der shelly nicht, steht immer noch auf false
                                  wie sollte er?
                                  @homoran sagte in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
                                  die Zeit muss in die Logik.
                                  der Auslöser soll doch die Solareinspeisung/produktion sein
                                  bei dir löst die Uhrzeit (heute 0:01 -0:59) aus
                                    WilliKlein @Homoran last edited by
                                    OK ich hatte nicht alle Stunden eingestellt. Jetzt schaltet der ein. Ich wollte erst mal sehen ob der überhaupt schaltet.
                                    Unten steht jetzt die Version wie ich sie gerne erstmal zum Schalten bringen möchte. Das geht jetzt noch nicht.
                                    Homoran paul53 crunchip 3 Replies Last reply Reply Quote 0
                                      ist trotzdem Blödsinn.
                                      dann lass lieben den Trigger weg, dann passiertvder Rest einmalig beim Skriptstart/abspeichern.
                                      ich denke das letzte falls gehört unter das andere falls/sonstfalls und nich in das sonstfalls
                                        des erste war nur ein Test, weil ich den shelly überhaupt nicht zum schalten bekommen habe, das lösche ich natürlich.
                                          Tests sind wichtig. Muss man aber richtig machen!
                                          ein Zeitraum als Trigger nutzt gar nichts bei diesem Skript. er ist nur gestartet, weil du es innerhalb des Zeitraums gespeichert hast
                                            @williklein sagte: Unten steht jetzt die Version wie ich sie gerne erstmal zum Schalten bringen möchte. Das geht jetzt noch nicht.
                                            Ist auch falsch. Richtig:
                                            220
                                            19027
