    5. Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.
      WilliKlein @paul53 last edited by Homoran
        <variables>
          <variable id="%f2p3[xiEK;T;hxSX|t5">shelly</variable>
        </variables>
        <block type="variables_set" id="k)@FiWDGHXsZ,SHM}1zS" x="300" y="-111">
          <field name="VAR" id="%f2p3[xiEK;T;hxSX|t5">shelly</field>
            <block type="get_value" id="MfV3iIf5#Fx*F#SPbAd`">
              <field name="OID">shelly.0.shellyplus1#7c87ce63d85c#1.Relay0.Switch</field>
            <block type="on_ext" id="_f?n?9+^x32}4r=j(lF0">
              <value name="OID0">
                <shadow type="field_oid" id="Bbh1E/},e./{_Yf3_;px">
                  <field name="oid">growatt.0.1030054.devices.DFK0BKD00C.historyLast.ppv</field>
                <block type="controls_if" id="5^_]~A*IAxXr.+z+,O|g">
                    <block type="logic_compare" id="9@jz$j=TVGPXYwK_N1tl">
                      <field name="OP">LT</field>
                        <block type="on_source" id="3O1($TjuU2zLP#.u6(]l">
                        <block type="math_number" id=")G`AERK`8@25wu`}x;HJ">
                          <field name="NUM">3000</field>
                    <block type="variables_set" id="eb+o#xx@Yv#zEjH3[c8,">
                        <block type="logic_boolean" id="^9S9/{$K~z:7}vXy+vXd">
                  <value name="IF1">
                    <block type="logic_compare" id="Hk1ghg;eIF}mNq~qg2$N">
                      <field name="OP">GT</field>
                        <block type="on_source" id=";GgYm,hYSX3/.3FCVqb^">
                        <block type="math_number" id="`=4-0(|xgYJ{WIg_dctO">
                          <field name="NUM">3500</field>
                  <statement name="DO1">
                    <block type="variables_set" id="SDx9dFe8-XqT~?PP,265">
                        <block type="logic_boolean" id="^aFhyq!(ta2DJm$2qCtt">
                    <block type="controls_if" id="9q!Zk#Vc?c9EX$:Z9zUK">
                        <block type="logic_compare" id="43Vu=|/wYh`tM*c*dc-J">
                          <field name="OP">NEQ</field>
                            <block type="variables_get" id="*xID|?TLTij`-[+2G4K[">
                            <block type="get_value" id="}|Y8Zi|6j(ivB?Z+tt}8">
                        <block type="control" id="12N5$JSuj7~#-O,zt39W">
                          <field name="DELAY_MS">1000</field>
                          <field name="UNIT">ms</field>
                            <block type="variables_get" id="P@N|PbiTOZ:Bo}3[.)SG">
        WilliKlein @WilliKlein last edited by
        @williklein said in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
        ich weiss nicht wie ich das zurückschicken kann
        DJMarc75 paul53 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @WilliKlein last edited by
          @williklein @paul53 hat Dir ein Blockly geschickt.... was willst Du denn warum zurückschicken ??
            paul53 @WilliKlein last edited by
            @williklein sagte: ich weiss nicht wie ich das zurückschicken kann
            Als Bild.
            Was soll das?
              ich wollte meine Änderung exportieren. Ich bin nicht gut in der Bedienung. Du hast mir das geschickt, ich habe es importiert, dann geändert und wollte es zurückschicken, ob ich es richtig gemacht habe. Das ist wohl daneben gegangen.
                @williklein sagte: Das ist wohl daneben gegangen.
                Nein, aber die Bedingungen lauten jetzt bei dir: Bei hohem Solarertrag Shelly ausschalten und bei niedrigem Solarertrag Shelly einschalten.
                  ja ich möchte das natürlich testen und im Moment ist der Ertrag 0.
                  Ich habe an demshelly eine Lampe und möchte die zum Leuchten bringen.
                  Ich habe im Leitfaden gelesen, habs aber auch nicht verstanden
                  If Then variable <10
                  Schalter ein
                  else
                  Schalter aus
                  endif
                  Das ist für mich logisch. In Blockly kriege ich das nicht hin.
                  crunchip Homoran 2 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @WilliKlein last edited by
                      WilliKlein @crunchip last edited by
                      @crunchip
                      OK, der shelly spinet von false auf true um, aber das Licht geht nicht an.
                      Ist das dann der falsch é Datenpunkt ?
                      DJMarc75 crunchip W 3 Replies Last reply Reply Quote 0
                      • DJMarc75
                        DJMarc75 @WilliKlein last edited by DJMarc75
                        @williklein Wenn Du uns das Blockly zeigen würdest dann kann man bestimmt auch helfen.
                          Homoran Global Moderator Administrators @WilliKlein last edited by Homoran
                          @williklein sagte in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
                          wenn das dein Kriterium sein soll muss das hier der Trigger sein.
                          und die anschließende Logik machst du genau so wie dort.
                            crunchip Forum Testing Most Active @WilliKlein last edited by crunchip
                            @williklein das musst du im shelly einstellen, ob schalter, steckdose, taster, ob`s relais geschaltet werden soll....
                            hier als Beispiel
                              @crunchip
                              Warum schaltet der shelly nicht, steht immer noch auf false
                                wie sollte er?
                                @homoran sagte in Mit Blockly das Shelly 1 ein/aus über Solar Ertrag.:
                                die Zeit muss in die Logik.
                                der Auslöser soll doch die Solareinspeisung/produktion sein
                                bei dir löst die Uhrzeit (heute 0:01 -0:59) aus
                                  WilliKlein @Homoran last edited by
                                  OK ich hatte nicht alle Stunden eingestellt. Jetzt schaltet der ein. Ich wollte erst mal sehen ob der überhaupt schaltet.
                                  Unten steht jetzt die Version wie ich sie gerne erstmal zum Schalten bringen möchte. Das geht jetzt noch nicht.
                                  Homoran paul53 crunchip 3 Replies Last reply Reply Quote 0
                                    ist trotzdem Blödsinn.
                                    dann lass lieben den Trigger weg, dann passiertvder Rest einmalig beim Skriptstart/abspeichern.
                                    ich denke das letzte falls gehört unter das andere falls/sonstfalls und nich in das sonstfalls
                                      des erste war nur ein Test, weil ich den shelly überhaupt nicht zum schalten bekommen habe, das lösche ich natürlich.
                                        Tests sind wichtig. Muss man aber richtig machen!
                                        ein Zeitraum als Trigger nutzt gar nichts bei diesem Skript. er ist nur gestartet, weil du es innerhalb des Zeitraums gespeichert hast
                                          @williklein sagte: Unten steht jetzt die Version wie ich sie gerne erstmal zum Schalten bringen möchte. Das geht jetzt noch nicht.
                                          Ist auch falsch. Richtig:
                                            einfach den Datenpunkt in den Objekten umschalten, dann weisst du ob er schaltet, aber wie gesagt, du musst den shelly erstmal einstellen
                                            220
                                            19012
