    4. [gelöst] VIS: funktioniert nicht
      Guckstu:
        toste last edited by
        Nein, noch nicht. Aber jetzt:
        pi@raspberrypi:/opt/iobroker $ iobroker upgrade vis --debug
        Adapter "vis"            is not installed.
        pi@raspberrypi:/opt/iobroker $ iobroker install vis --debug
        NPM version: 8.19.2
        Installing iobroker.vis@1.4.15... (System call)
        npm ERR! code 6
        npm ERR! path /opt/iobroker/node_modules/iobroker.vis
        npm ERR! command failed
        npm ERR! command sh -c -- node main.js --install
        npm ERR!     /home/iobroker/.npm/_logs/2022-10-21T12_51_30_565Z-debug-0.log
        host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@8.19.2
        2 info using node@v16.18.0
        3 timing npm:load:whichnode Completed in 1ms
        4 timing config:load:defaults Completed in 5ms
        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
        6 timing config:load:builtin Completed in 4ms
        7 timing config:load:cli Completed in 6ms
        8 timing config:load:env Completed in 0ms
        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
        10 timing config:load:project Completed in 6ms
        11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
        12 timing config:load:user Completed in 1ms
        13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
        14 timing config:load:global Completed in 1ms
        15 timing config:load:validate Completed in 1ms
        16 timing config:load:credentials Completed in 3ms
        17 timing config:load:setEnvs Completed in 3ms
        18 timing config:load Completed in 34ms
        19 timing npm:load:configload Completed in 35ms
        20 timing npm:load:mkdirpcache Completed in 3ms
        21 timing npm:load:mkdirplogs Completed in 1ms
        22 verbose title npm install iobroker.vis@1.4.15
        23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.15"
        24 timing npm:load:setTitle Completed in 4ms
        25 timing config:load:flatten Completed in 9ms
        26 timing npm:load:display Completed in 13ms
        27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
        28 verbose logfile /home/iobroker/.npm/_logs/2022-10-21T12_51_30_565Z-debug-0.log
        29 timing npm:load:logFile Completed in 17ms
        30 timing npm:load:timers Completed in 0ms
        31 timing npm:load:configScope Completed in 0ms
        32 timing npm:load Completed in 76ms
        33 timing arborist:ctor Completed in 2ms
        34 silly logfile start cleaning logs, removing 2 files
        35 silly logfile done cleaning log files
        36 timing idealTree:init Completed in 2313ms
        37 timing idealTree:userRequests Completed in 17ms
        38 silly idealTree buildDeps
        39 silly fetch manifest iobroker.vis@1.4.15
        40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
        41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 2484ms (cache revalidated)
        42 silly placeDep ROOT iobroker.vis@1.4.15 OK for: iobroker.inst@3.0.0 want: 1.4.15
        43 timing idealTree:#root Completed in 2530ms
        44 timing idealTree:node_modules/iobroker.vis Completed in 0ms
        45 timing idealTree:buildDeps Completed in 2537ms
        46 timing idealTree:fixDepFlags Completed in 19ms
        47 timing idealTree Completed in 4920ms
        48 timing reify:loadTrees Completed in 4924ms
        49 timing reify:diffTrees Completed in 56ms
        50 silly reify moves {}
        51 timing reify:retireShallow Completed in 3ms
        52 timing reify:createSparse Completed in 18ms
        53 timing reify:loadBundles Completed in 0ms
        54 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
        55 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
        56 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto
        57 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto' ]
        58 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/nan
        59 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/nan' ]
        60 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install
        61 silly reify mark deleted [
        61 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install',
        61 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/prebuild-install'
        61 silly reify ]
        62 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc
        63 silly reify mark deleted [
        63 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc',
        63 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/detect-libc'
        63 silly reify ]
        64 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi
        65 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi' ]
        66 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog
        67 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog' ]
        68 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/semver
        69 silly reify mark deleted [
        69 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/semver',
        69 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/semver'
        69 silly reify ]
        70 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet
        71 silly reify mark deleted [
        71 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet'
        71 silly reify ]
        72 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge
        73 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge' ]
        74 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream
        75 silly reify mark deleted [
        75 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream'
        75 silly reify ]
        76 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba
        77 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba' ]
        78 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width
        79 silly reify mark deleted [
        79 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width'
        79 silly reify ]
        80 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi
        81 silly reify mark deleted [
        81 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi'
        81 silly reify ]
        82 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray
        83 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray' ]
        84 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder
        85 silly reify mark deleted [
        85 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder'
        85 silly reify ]
        86 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
        87 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
        88 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point
        89 silly reify mark deleted [
        89 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point'
        89 silly reify ]
        90 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex
        91 silly reify mark deleted [
        91 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex'
        91 silly reify ]
        92 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
        93 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
        94 timing reifyNode:node_modules/osx-temperature-sensor Completed in 32ms
        95 timing reifyNode:node_modules/node-aead-crypto Completed in 31ms
        96 timing reifyNode:node_modules/code-point-at Completed in 498ms
        97 timing reifyNode:node_modules/number-is-nan Completed in 504ms
        98 timing reifyNode:node_modules/node-aead-crypto/node_modules/strip-ansi Completed in 503ms
        99 timing reifyNode:node_modules/node-aead-crypto/node_modules/string-width Completed in 504ms
        100 timing reifyNode:node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point Completed in 505ms
        101 timing reifyNode:node_modules/node-aead-crypto/node_modules/aproba Completed in 508ms
        102 timing reifyNode:node_modules/node-aead-crypto/node_modules/ansi-regex Completed in 507ms
        103 timing reifyNode:node_modules/node-aead-crypto/node_modules/string_decoder Completed in 522ms
        104 timing reifyNode:node_modules/node-aead-crypto/node_modules/npmlog Completed in 524ms
        105 timing reifyNode:node_modules/node-aead-crypto/node_modules/isarray Completed in 528ms
        106 timing reifyNode:node_modules/node-aead-crypto/node_modules/detect-libc Completed in 537ms
        107 timing reifyNode:node_modules/node-aead-crypto/node_modules/are-we-there-yet Completed in 538ms
        108 timing reifyNode:node_modules/node-aead-crypto/node_modules/semver Completed in 541ms
        109 timing reifyNode:node_modules/node-aead-crypto/node_modules/prebuild-install Completed in 560ms
        110 timing reifyNode:node_modules/node-aead-crypto/node_modules/node-abi Completed in 560ms
        111 timing reifyNode:node_modules/node-aead-crypto/node_modules/gauge Completed in 577ms
        112 timing reifyNode:node_modules/node-aead-crypto/node_modules/readable-stream Completed in 594ms
        113 timing reifyNode:node_modules/node-aead-crypto/node_modules/nan Completed in 634ms
        114 timing reifyNode:node_modules/iobroker.vis Completed in 1026ms
        115 timing reify:unpack Completed in 1026ms
        116 timing reify:unretire Completed in 0ms
        117 timing build:queue Completed in 6ms
        118 timing build:link Completed in 0ms
        119 info run iobroker.vis@1.4.15 install node_modules/iobroker.vis node main.js --install
        120 info run iobroker.vis@1.4.15 install { code: 6, signal: null }
        121 timing reify:rollback:createSparse Completed in 153ms
        122 timing reify:rollback:retireShallow Completed in 0ms
        123 timing command:install Completed in 9270ms
        124 verbose stack Error: command failed
        124 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
        124 verbose stack     at ChildProcess.emit (node:events:513:28)
        124 verbose stack     at maybeClose (node:internal/child_process:1100:16)
        124 verbose stack     at Socket.<anonymous> (node:internal/child_process:458:11)
        124 verbose stack     at Socket.emit (node:events:513:28)
        124 verbose stack     at Pipe.<anonymous> (node:net:301:12)
        125 verbose pkgid iobroker.vis@1.4.15
        126 verbose cwd /opt/iobroker
        127 verbose Linux 5.10.103-v7l+
        128 verbose node v16.18.0
        129 verbose npm  v8.19.2
        130 error code 6
        131 error path /opt/iobroker/node_modules/iobroker.vis
        132 error command failed
        133 error command sh -c -- node main.js --install
        134 verbose exit 6
        135 timing npm Completed in 9653ms
        136 verbose unfinished npm timer reify 1666356690932
        137 verbose unfinished npm timer reify:build 1666356696982
        138 verbose unfinished npm timer build 1666356696984
        139 verbose unfinished npm timer build:deps 1666356696985
        140 verbose unfinished npm timer build:run:install 1666356696993
        141 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1666356696994
        142 verbose code 6
        143 error A complete log of this run can be found in:
        143 error     /home/iobroker/.npm/_logs/2022-10-21T12_51_30_565Z-debug-0.log
          Thomas Braun Most Active @toste last edited by
          @toste Versuch mal eine der Vorversionen zu installieren. vis 1.4.10 oder so.
            @thomas-braun sieht aber wirklich anders aus.
            nicht dass da doch das neue npm da in die Suppe spuckt
              toste @Thomas Braun last edited by
              Hab ich doch?
              pi@raspberrypi:/home/iobroker/.npm/_logs $ npm -v
              8.19.2
              pi@raspberrypi:/home/iobroker/.npm/_logs $ node -v
              v16.18.0
                Homoran Global Moderator Administrators @toste last edited by
                @toste sagte in VIS: funktioniert nicht:
                Hab ich doch?
                nee
                @thomas-braun sagte in VIS: funktioniert nicht:
                vis 1.4.10 oder so.
                also
                iobroker upgrade vis@1.4.10 --debug
                  @homoran sagte in VIS: funktioniert nicht:
                  Nöö, zufällig hab ich gerade gestern auf meinem 'bleeding-edge'-System mit nodejs@19 und npm@8.19.2 vis installiert. Ging ohne Probleme auch damit.
                    Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                    joa, mit node 19!
                    es gab früher auch npm Versionen die mit node 18, aber nicht mit 16 liefen.
                    Gensu so was hab ich im Verdacht
                      Mal abwarten was
                      bringt.
                        toste @Homoran last edited by
                        pi@raspberrypi:/home/iobroker $ iobroker upgrade vis@1.4.10 --debug
                        This upgrade of "vis" will at least introduce the following changes:
                        -> 1.4.8:
                        Added support for js-controller 4.x
                        -> 1.4.7:
                        Fixed subscribeOidAtRuntime if called with invalid IDs
                        Added support of license manager
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                        Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: y
                        Update vis from @0.0.0 to @1.4.10
                        NPM version: 8.19.2
                        Installing iobroker.vis@1.4.10... (System call)
                        npm ERR! code 6
                        npm ERR!     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
                        host.raspberrypi Cannot install iobroker.vis@1.4.10: 6
                          Was steht da drin?
                          less -R /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
                            6 timing config:load:builtin Completed in 3ms
                            11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                            18 timing config:load Completed in 31ms
                            19 timing npm:load:configload Completed in 32ms
                            22 verbose title npm install iobroker.vis@1.4.10
                            23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
                            26 timing npm:load:display Completed in 12ms
                            28 verbose logfile /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
                            29 timing npm:load:logFile Completed in 15ms
                            30 timing npm:load:timers Completed in 1ms
                            32 timing npm:load Completed in 70ms
                            36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                            37 timing idealTree:init Completed in 2113ms
                            38 timing idealTree:userRequests Completed in 15ms
                            39 silly idealTree buildDeps
                            40 silly fetch manifest iobroker.vis@1.4.10
                            41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1804ms (cache hit)
                            42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
                            43 silly fetch manifest axios@^0.24.0
                            44 http fetch GET 200 https://registry.npmjs.org/axios 701ms (cache revalidated)
                            45 timing idealTree:#root Completed in 2547ms
                            46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
                            47 timing idealTree:node_modules/iobroker.vis Completed in 7ms
                            48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
                            49 timing idealTree:buildDeps Completed in 2556ms
                            50 timing idealTree:fixDepFlags Completed in 19ms
                            51 timing idealTree Completed in 4736ms
                            52 timing reify:loadTrees Completed in 4739ms
                            53 timing reify:diffTrees Completed in 55ms
                            54 silly reify moves {}
                            55 timing reify:retireShallow Completed in 3ms
                            56 timing reify:createSparse Completed in 25ms
                            57 timing reify:loadBundles Completed in 0ms
                            58 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                            59 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                            61 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto' ]
                            62 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/nan
                            63 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/nan' ]
                            64 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install
                            65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install',
                            65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/prebuild-install'
                            65 silly reify ]
                            66 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc
                            67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc',
                            67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/detect-libc'
                            67 silly reify ]
                            68 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi
                            69 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi' ]
                            70 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog
                            71 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog' ]
                            72 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/semver
                            73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/semver',
                            73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/semver'
                            73 silly reify ]
                            74 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet
                            75 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet'
                            75 silly reify ]
                            76 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge
                            77 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge' ]
                            78 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream
                            79 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream'
                            79 silly reify ]
                            80 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba
                            81 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba' ]
                            82 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width
                            83 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width'
                            83 silly reify ]
                            84 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi
                            85 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi'
                            85 silly reify ]
                            86 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray
                            87 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray' ]
                            88 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder
                            89 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder'
                            89 silly reify ]
                            90 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
                            91 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
                            92 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point
                            93 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point'
                            93 silly reify ]
                            94 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex
                            95 silly reify mark deleted [
                            95 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex'
                            95 silly reify ]
                            96 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
                            97 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
                            98 timing reifyNode:node_modules/osx-temperature-sensor Completed in 30ms
                            99 timing reifyNode:node_modules/node-aead-crypto Completed in 30ms
                            100 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
                            101 timing reifyNode:node_modules/number-is-nan Completed in 296ms
                            102 timing reifyNode:node_modules/code-point-at Completed in 291ms
                            103 timing reifyNode:node_modules/node-aead-crypto/node_modules/strip-ansi Completed in 296ms
                            104 timing reifyNode:node_modules/node-aead-crypto/node_modules/string-width Completed in 297ms
                            105 timing reifyNode:node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point Completed in 297ms
                            106 timing reifyNode:node_modules/node-aead-crypto/node_modules/aproba Completed in 299ms
                            107 timing reifyNode:node_modules/node-aead-crypto/node_modules/ansi-regex Completed in 300ms
                            108 timing reifyNode:node_modules/node-aead-crypto/node_modules/string_decoder Completed in 313ms
                            109 timing reifyNode:node_modules/node-aead-crypto/node_modules/npmlog Completed in 314ms
                            110 timing reifyNode:node_modules/node-aead-crypto/node_modules/isarray Completed in 318ms
                            111 timing reifyNode:node_modules/node-aead-crypto/node_modules/detect-libc Completed in 324ms
                            112 timing reifyNode:node_modules/node-aead-crypto/node_modules/are-we-there-yet Completed in 325ms
                            113 timing reifyNode:node_modules/node-aead-crypto/node_modules/semver Completed in 327ms
                            114 timing reifyNode:node_modules/node-aead-crypto/node_modules/prebuild-install Completed in 344ms
                            115 timing reifyNode:node_modules/node-aead-crypto/node_modules/node-abi Completed in 344ms
                            116 timing reifyNode:node_modules/node-aead-crypto/node_modules/gauge Completed in 361ms
                            117 timing reifyNode:node_modules/node-aead-crypto/node_modules/readable-stream Completed in 379ms
                            118 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 420ms
                            119 timing reifyNode:node_modules/node-aead-crypto/node_modules/nan Completed in 418ms
                            120 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 2386ms (cache miss)
                            121 timing reifyNode:node_modules/iobroker.vis Completed in 2461ms
                            122 timing reify:unpack Completed in 2462ms
                            123 timing reify:unretire Completed in 0ms
                            124 timing build:queue Completed in 5ms
                            125 timing build:link Completed in 0ms
                            126 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
                            127 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
                            128 timing reify:rollback:createSparse Completed in 212ms
                            129 timing reify:rollback:retireShallow Completed in 0ms
                            130 timing command:install Completed in 10629ms
                            131 verbose stack Error: command failed
                            131 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
                            131 verbose stack     at ChildProcess.emit (node:events:513:28)
                            131 verbose stack     at maybeClose (node:internal/child_process:1100:16)
                            131 verbose stack     at Socket.<anonymous> (node:internal/child_process:458:11)
                            131 verbose stack     at Socket.emit (node:events:513:28)
                            131 verbose stack     at Pipe.<anonymous> (node:net:301:12)
                            132 verbose pkgid iobroker.vis@1.4.10
                            133 verbose cwd /opt/iobroker
                            134 verbose Linux 5.10.103-v7l+
                            135 verbose node v16.18.0
                            136 verbose npm  v8.19.2
                            137 error code 6
                            138 error path /opt/iobroker/node_modules/iobroker.vis
                            139 error command failed
                            140 error command sh -c -- node main.js --install
                            141 verbose exit 6
                            142 timing npm Completed in 10985ms
                            143 verbose unfinished npm timer reify 1666357655886
                            144 verbose unfinished npm timer reify:build 1666357663196
                            145 verbose unfinished npm timer build 1666357663198
                            146 verbose unfinished npm timer build:deps 1666357663198
                            147 verbose unfinished npm timer build:run:install 1666357663205
                            148 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1666357663206
                            149 verbose code 6
                            150 error A complete log of this run can be found in:
                            150 error     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
                              iob install vis@1.4.5
                              T metaxa 2 Replies Last reply Reply Quote 2
                                OK, das sieht anders aus und läuft wieder:
                                pi@raspberrypi:/home/iobroker $ iob install vis@1.4.5
                                NPM version: 8.19.2
                                Installing iobroker.vis@1.4.5... (System call)
                                added 1 package in 22s
                                60 packages are looking for funding
                                  run `npm fund` for details
                                host.raspberrypi install adapter vis@1.4.5
                                upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                Adapter "system.adapter.vis.0" restarted.
                                upload [322] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png
                                upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png
                                upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png
                                upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png
                                upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_BulbOnOffCtrl.png widgets/basic/img/Prev_BulbOnOffCtrl.png image/png
                                upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ScreenResolution.png widgets/basic/img/Prev_ScreenResolution.png image/png
                                upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrl.png widgets/basic/img/Prev_ValueBoolCtrl.png image/png
                                upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueListHtml8.png widgets/basic/img/Prev_ValueListHtml8.png image/png
                                upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml
                                upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/info/js/info.js widgets/info/js/info.js application/javascript
                                upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
                                upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
                                upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
                                upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
                                upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                                upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                                upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                                upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                                upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                                upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                                upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                                upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                                upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                                upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                                upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                                upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                                upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                                upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                                upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                                upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                                upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                                upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                                host.raspberrypi object system.adapter.vis created/updated
                                Update "system.adapter.vis.0"
                                Jetzt bietet er mir wieder das Update auf 1.4.15 an. Soll ich das probieren?
                                  @toste
                                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  iob update
                                  sagt? Wenn das sauber ist kannst du das upgrade auf die aktuelle vis wagen.
                                    pi@raspberrypi:/home/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                    pi@raspberrypi:/home/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.18.0
                                    v16.18.0
                                    8.19.2
                                    4.0.23
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                    /home/iobroker
                                    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                    Hit:4 https://www.pivccu.de/piVCCU stable InRelease
                                    Reading package lists... Done
                                    Building dependency tree
                                    All packages are up to date.
                                    nodejs:
                                      Installed: 16.18.0-deb-1nodesource1
                                      Candidate: 16.18.0-deb-1nodesource1
                                      Version table:
                                     *** 16.18.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                            100 /var/lib/dpkg/status
                                         10.24.0~dfsg-1~deb10u2 500
                                    pi@raspberrypi:/home/iobroker $ iob update
                                    Used repository: Stable (default)
                                    Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                                    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                                    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                                    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                    Adapter    "history"      : 2.2.0    , installed 2.2.0
                                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "iot"          : 1.11.9   , installed 1.11.9
                                    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                                    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                                    Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                    Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
                                    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                                    Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                                    Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                                      @toste
                                      Das sieht gut aus. Bring das mal auf die aktuelle vis.
                                        Prima, auch das hat funktioniert. Vielen lieben Dank !!
                                        Aber warum das jetzt nicht direkt ging, wissen wir nicht?
                                          Ich vermute, das hat mit der Lizenz zu tun. Bei den alten Versionen wurde das anders gehandhabt, soweit ich weiß.
                                            Schmunzi57 last edited by
                                            Guten Morgen, auch ich hatte genau dieses Problem und es konnte, wie hier auch gelöst werden.
                                            Nun bin ich wieder HAPPY 😋
                                            Recht herzlichen Dank an alle die hier helfen und für uns "weniger wissende" da sind.
                                            Mein besonderer Dank gilt in diesem Fall @Thomas-Braun, denn ohne dieses spezifische Wissen ist man halt aufgeschmissen.
                                            In diesem Sinne nochmal mein Danke und macht bitte weiter so.
                                            Tschüs
                                            2300
