    4. [gelöst] VIS: funktioniert nicht
      Mal abwarten was
      iobroker upgrade vis@1.4.10 --debug
      bringt.
        toste @Homoran last edited by
        pi@raspberrypi:/home/iobroker $ iobroker upgrade vis@1.4.10 --debug
        This upgrade of "vis" will at least introduce the following changes:
        -> 1.4.8:
        Added support for js-controller 4.x
        -> 1.4.7:
        Fixed subscribeOidAtRuntime if called with invalid IDs
        Added support of license manager
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: y
        Update vis from @0.0.0 to @1.4.10
        NPM version: 8.19.2
        Installing iobroker.vis@1.4.10... (System call)
        npm ERR! code 6
        npm ERR! path /opt/iobroker/node_modules/iobroker.vis
        npm ERR! command failed
        npm ERR! command sh -c -- node main.js --install
        npm ERR!     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
        host.raspberrypi Cannot install iobroker.vis@1.4.10: 6
          Thomas Braun Most Active @toste last edited by
          @toste sagte in VIS: funktioniert nicht:
          Was steht da drin?
          less -R /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
            toste @Thomas Braun last edited by
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@8.19.2
            2 info using node@v16.18.0
            3 timing npm:load:whichnode Completed in 1ms
            4 timing config:load:defaults Completed in 5ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
            6 timing config:load:builtin Completed in 3ms
            7 timing config:load:cli Completed in 6ms
            8 timing config:load:env Completed in 0ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
            10 timing config:load:project Completed in 6ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 1ms
            15 timing config:load:validate Completed in 1ms
            16 timing config:load:credentials Completed in 3ms
            17 timing config:load:setEnvs Completed in 3ms
            18 timing config:load Completed in 31ms
            19 timing npm:load:configload Completed in 32ms
            20 timing npm:load:mkdirpcache Completed in 3ms
            21 timing npm:load:mkdirplogs Completed in 1ms
            22 verbose title npm install iobroker.vis@1.4.10
            23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
            24 timing npm:load:setTitle Completed in 4ms
            25 timing config:load:flatten Completed in 9ms
            26 timing npm:load:display Completed in 12ms
            27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
            28 verbose logfile /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
            29 timing npm:load:logFile Completed in 15ms
            30 timing npm:load:timers Completed in 1ms
            31 timing npm:load:configScope Completed in 0ms
            32 timing npm:load Completed in 70ms
            33 timing arborist:ctor Completed in 2ms
            34 silly logfile start cleaning logs, removing 2 files
            35 silly logfile done cleaning log files
            36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            37 timing idealTree:init Completed in 2113ms
            38 timing idealTree:userRequests Completed in 15ms
            39 silly idealTree buildDeps
            40 silly fetch manifest iobroker.vis@1.4.10
            41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1804ms (cache hit)
            42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
            43 silly fetch manifest axios@^0.24.0
            44 http fetch GET 200 https://registry.npmjs.org/axios 701ms (cache revalidated)
            45 timing idealTree:#root Completed in 2547ms
            46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
            47 timing idealTree:node_modules/iobroker.vis Completed in 7ms
            48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
            49 timing idealTree:buildDeps Completed in 2556ms
            50 timing idealTree:fixDepFlags Completed in 19ms
            51 timing idealTree Completed in 4736ms
            52 timing reify:loadTrees Completed in 4739ms
            53 timing reify:diffTrees Completed in 55ms
            54 silly reify moves {}
            55 timing reify:retireShallow Completed in 3ms
            56 timing reify:createSparse Completed in 25ms
            57 timing reify:loadBundles Completed in 0ms
            58 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
            59 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
            60 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto
            61 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto' ]
            62 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/nan
            63 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/nan' ]
            64 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install
            65 silly reify mark deleted [
            65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install',
            65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/prebuild-install'
            65 silly reify ]
            66 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc
            67 silly reify mark deleted [
            67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc',
            67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/detect-libc'
            67 silly reify ]
            68 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi
            69 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi' ]
            70 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog
            71 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog' ]
            72 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/semver
            73 silly reify mark deleted [
            73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/semver',
            73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/semver'
            73 silly reify ]
            74 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet
            75 silly reify mark deleted [
            75 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet'
            75 silly reify ]
            76 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge
            77 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge' ]
            78 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream
            79 silly reify mark deleted [
            79 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream'
            79 silly reify ]
            80 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba
            81 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba' ]
            82 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width
            83 silly reify mark deleted [
            83 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width'
            83 silly reify ]
            84 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi
            85 silly reify mark deleted [
            85 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi'
            85 silly reify ]
            86 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray
            87 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray' ]
            88 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder
            89 silly reify mark deleted [
            89 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder'
            89 silly reify ]
            90 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
            91 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
            92 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point
            93 silly reify mark deleted [
            93 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point'
            93 silly reify ]
            94 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex
            95 silly reify mark deleted [
            95 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex'
            95 silly reify ]
            96 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
            97 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
            98 timing reifyNode:node_modules/osx-temperature-sensor Completed in 30ms
            99 timing reifyNode:node_modules/node-aead-crypto Completed in 30ms
            100 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
            101 timing reifyNode:node_modules/number-is-nan Completed in 296ms
            102 timing reifyNode:node_modules/code-point-at Completed in 291ms
            103 timing reifyNode:node_modules/node-aead-crypto/node_modules/strip-ansi Completed in 296ms
            104 timing reifyNode:node_modules/node-aead-crypto/node_modules/string-width Completed in 297ms
            105 timing reifyNode:node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point Completed in 297ms
            106 timing reifyNode:node_modules/node-aead-crypto/node_modules/aproba Completed in 299ms
            107 timing reifyNode:node_modules/node-aead-crypto/node_modules/ansi-regex Completed in 300ms
            108 timing reifyNode:node_modules/node-aead-crypto/node_modules/string_decoder Completed in 313ms
            109 timing reifyNode:node_modules/node-aead-crypto/node_modules/npmlog Completed in 314ms
            110 timing reifyNode:node_modules/node-aead-crypto/node_modules/isarray Completed in 318ms
            111 timing reifyNode:node_modules/node-aead-crypto/node_modules/detect-libc Completed in 324ms
            112 timing reifyNode:node_modules/node-aead-crypto/node_modules/are-we-there-yet Completed in 325ms
            113 timing reifyNode:node_modules/node-aead-crypto/node_modules/semver Completed in 327ms
            114 timing reifyNode:node_modules/node-aead-crypto/node_modules/prebuild-install Completed in 344ms
            115 timing reifyNode:node_modules/node-aead-crypto/node_modules/node-abi Completed in 344ms
            116 timing reifyNode:node_modules/node-aead-crypto/node_modules/gauge Completed in 361ms
            117 timing reifyNode:node_modules/node-aead-crypto/node_modules/readable-stream Completed in 379ms
            118 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 420ms
            119 timing reifyNode:node_modules/node-aead-crypto/node_modules/nan Completed in 418ms
            120 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 2386ms (cache miss)
            121 timing reifyNode:node_modules/iobroker.vis Completed in 2461ms
            122 timing reify:unpack Completed in 2462ms
            123 timing reify:unretire Completed in 0ms
            124 timing build:queue Completed in 5ms
            125 timing build:link Completed in 0ms
            126 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
            127 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
            128 timing reify:rollback:createSparse Completed in 212ms
            129 timing reify:rollback:retireShallow Completed in 0ms
            130 timing command:install Completed in 10629ms
            131 verbose stack Error: command failed
            131 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
            131 verbose stack     at ChildProcess.emit (node:events:513:28)
            131 verbose stack     at maybeClose (node:internal/child_process:1100:16)
            131 verbose stack     at Socket.<anonymous> (node:internal/child_process:458:11)
            131 verbose stack     at Socket.emit (node:events:513:28)
            131 verbose stack     at Pipe.<anonymous> (node:net:301:12)
            132 verbose pkgid iobroker.vis@1.4.10
            133 verbose cwd /opt/iobroker
            134 verbose Linux 5.10.103-v7l+
            135 verbose node v16.18.0
            136 verbose npm  v8.19.2
            137 error code 6
            138 error path /opt/iobroker/node_modules/iobroker.vis
            139 error command failed
            140 error command sh -c -- node main.js --install
            141 verbose exit 6
            142 timing npm Completed in 10985ms
            143 verbose unfinished npm timer reify 1666357655886
            144 verbose unfinished npm timer reify:build 1666357663196
            145 verbose unfinished npm timer build 1666357663198
            146 verbose unfinished npm timer build:deps 1666357663198
            147 verbose unfinished npm timer build:run:install 1666357663205
            148 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1666357663206
            149 verbose code 6
            150 error A complete log of this run can be found in:
            150 error     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
              iob install vis@1.4.5
              T metaxa 2 Replies Last reply Reply Quote 2
                OK, das sieht anders aus und läuft wieder:
                pi@raspberrypi:/home/iobroker $ iob install vis@1.4.5
                NPM version: 8.19.2
                Installing iobroker.vis@1.4.5... (System call)
                added 1 package in 22s
                60 packages are looking for funding
                  run `npm fund` for details
                host.raspberrypi install adapter vis@1.4.5
                upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                Adapter "system.adapter.vis.0" restarted.
                upload [322] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png
                upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png
                upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png
                upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png
                upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_BulbOnOffCtrl.png widgets/basic/img/Prev_BulbOnOffCtrl.png image/png
                upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ScreenResolution.png widgets/basic/img/Prev_ScreenResolution.png image/png
                upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrl.png widgets/basic/img/Prev_ValueBoolCtrl.png image/png
                upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueListHtml8.png widgets/basic/img/Prev_ValueListHtml8.png image/png
                upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml
                upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/info/js/info.js widgets/info/js/info.js application/javascript
                upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
                upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
                upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
                upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
                upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                host.raspberrypi object system.adapter.vis created/updated
                Update "system.adapter.vis.0"
                Jetzt bietet er mir wieder das Update auf 1.4.15 an. Soll ich das probieren?
                  @toste
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  iob update
                  sagt? Wenn das sauber ist kannst du das upgrade auf die aktuelle vis wagen.
                    pi@raspberrypi:/home/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                    pi@raspberrypi:/home/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.18.0
                    v16.18.0
                    8.19.2
                    4.0.23
                    pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                    /home/iobroker
                    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                    Hit:4 https://www.pivccu.de/piVCCU stable InRelease
                    Reading package lists... Done
                    Building dependency tree
                    All packages are up to date.
                    nodejs:
                      Installed: 16.18.0-deb-1nodesource1
                      Candidate: 16.18.0-deb-1nodesource1
                      Version table:
                     *** 16.18.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u2 500
                    pi@raspberrypi:/home/iobroker $ iob update
                    Used repository: Stable (default)
                    Adapter    "admin"        : 6.2.22   , installed 6.2.22
                    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                    Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                    Adapter    "history"      : 2.2.0    , installed 2.2.0
                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                    Adapter    "iot"          : 1.11.9   , installed 1.11.9
                    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                    Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                    Adapter    "ping"         : 1.5.3    , installed 1.5.3
                    Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
                    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                    Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                    Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                      @toste
                      Das sieht gut aus. Bring das mal auf die aktuelle vis.
                        Prima, auch das hat funktioniert. Vielen lieben Dank !!
                        Aber warum das jetzt nicht direkt ging, wissen wir nicht?
                          Ich vermute, das hat mit der Lizenz zu tun. Bei den alten Versionen wurde das anders gehandhabt, soweit ich weiß.
                            Schmunzi57 last edited by
                            Guten Morgen, auch ich hatte genau dieses Problem und es konnte, wie hier auch gelöst werden.
                            Nun bin ich wieder HAPPY 😋
                            Recht herzlichen Dank an alle die hier helfen und für uns "weniger wissende" da sind.
                            Mein besonderer Dank gilt in diesem Fall @Thomas-Braun, denn ohne dieses spezifische Wissen ist man halt aufgeschmissen.
                            In diesem Sinne nochmal mein Danke und macht bitte weiter so.
                            Tschüs
                            • metaxa
                              metaxa @Thomas Braun last edited by
                              @thomas-braun sagte in [gelöst] VIS: funktioniert nicht:
                              Auch von meiner Seite, danke!
                              2300
