    4. [gelöst] VIS: funktioniert nicht
      toste @Homoran last edited by
      pi@raspberrypi:/home/iobroker $ iobroker upgrade vis@1.4.10 --debug
      This upgrade of "vis" will at least introduce the following changes:
      -> 1.4.8:
      Added support for js-controller 4.x
      -> 1.4.7:
      Fixed subscribeOidAtRuntime if called with invalid IDs
      Added support of license manager
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade vis from @0.0.0 to @1.4.10 now? [(y)es, (n)o]: y
      Update vis from @0.0.0 to @1.4.10
      NPM version: 8.19.2
      Installing iobroker.vis@1.4.10... (System call)
      npm ERR! code 6
      npm ERR! path /opt/iobroker/node_modules/iobroker.vis
      npm ERR! command failed
      npm ERR! command sh -c -- node main.js --install
      npm ERR!     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
      host.raspberrypi Cannot install iobroker.vis@1.4.10: 6
        Thomas Braun Most Active @toste last edited by
        @toste sagte in VIS: funktioniert nicht:
        Was steht da drin?
        less -R /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
          toste @Thomas Braun last edited by
          0 verbose cli /usr/bin/node /usr/bin/npm
          1 info using npm@8.19.2
          2 info using node@v16.18.0
          3 timing npm:load:whichnode Completed in 1ms
          4 timing config:load:defaults Completed in 5ms
          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
          6 timing config:load:builtin Completed in 3ms
          7 timing config:load:cli Completed in 6ms
          8 timing config:load:env Completed in 0ms
          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
          10 timing config:load:project Completed in 6ms
          11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
          12 timing config:load:user Completed in 1ms
          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
          14 timing config:load:global Completed in 1ms
          15 timing config:load:validate Completed in 1ms
          16 timing config:load:credentials Completed in 3ms
          17 timing config:load:setEnvs Completed in 3ms
          18 timing config:load Completed in 31ms
          19 timing npm:load:configload Completed in 32ms
          20 timing npm:load:mkdirpcache Completed in 3ms
          21 timing npm:load:mkdirplogs Completed in 1ms
          22 verbose title npm install iobroker.vis@1.4.10
          23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
          24 timing npm:load:setTitle Completed in 4ms
          25 timing config:load:flatten Completed in 9ms
          26 timing npm:load:display Completed in 12ms
          27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
          28 verbose logfile /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
          29 timing npm:load:logFile Completed in 15ms
          30 timing npm:load:timers Completed in 1ms
          31 timing npm:load:configScope Completed in 0ms
          32 timing npm:load Completed in 70ms
          33 timing arborist:ctor Completed in 2ms
          34 silly logfile start cleaning logs, removing 2 files
          35 silly logfile done cleaning log files
          36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
          37 timing idealTree:init Completed in 2113ms
          38 timing idealTree:userRequests Completed in 15ms
          39 silly idealTree buildDeps
          40 silly fetch manifest iobroker.vis@1.4.10
          41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1804ms (cache hit)
          42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
          43 silly fetch manifest axios@^0.24.0
          44 http fetch GET 200 https://registry.npmjs.org/axios 701ms (cache revalidated)
          45 timing idealTree:#root Completed in 2547ms
          46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
          47 timing idealTree:node_modules/iobroker.vis Completed in 7ms
          48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
          49 timing idealTree:buildDeps Completed in 2556ms
          50 timing idealTree:fixDepFlags Completed in 19ms
          51 timing idealTree Completed in 4736ms
          52 timing reify:loadTrees Completed in 4739ms
          53 timing reify:diffTrees Completed in 55ms
          54 silly reify moves {}
          55 timing reify:retireShallow Completed in 3ms
          56 timing reify:createSparse Completed in 25ms
          57 timing reify:loadBundles Completed in 0ms
          58 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
          59 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
          60 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto
          61 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto' ]
          62 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/nan
          63 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/nan' ]
          64 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install
          65 silly reify mark deleted [
          65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install',
          65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/prebuild-install'
          65 silly reify ]
          66 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc
          67 silly reify mark deleted [
          67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc',
          67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/detect-libc'
          67 silly reify ]
          68 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi
          69 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi' ]
          70 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog
          71 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog' ]
          72 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/semver
          73 silly reify mark deleted [
          73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/semver',
          73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/semver'
          73 silly reify ]
          74 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet
          75 silly reify mark deleted [
          75 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet'
          75 silly reify ]
          76 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge
          77 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge' ]
          78 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream
          79 silly reify mark deleted [
          79 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream'
          79 silly reify ]
          80 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba
          81 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba' ]
          82 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width
          83 silly reify mark deleted [
          83 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width'
          83 silly reify ]
          84 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi
          85 silly reify mark deleted [
          85 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi'
          85 silly reify ]
          86 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray
          87 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray' ]
          88 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder
          89 silly reify mark deleted [
          89 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder'
          89 silly reify ]
          90 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
          91 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
          92 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point
          93 silly reify mark deleted [
          93 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point'
          93 silly reify ]
          94 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex
          95 silly reify mark deleted [
          95 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex'
          95 silly reify ]
          96 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
          97 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
          98 timing reifyNode:node_modules/osx-temperature-sensor Completed in 30ms
          99 timing reifyNode:node_modules/node-aead-crypto Completed in 30ms
          100 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
          101 timing reifyNode:node_modules/number-is-nan Completed in 296ms
          102 timing reifyNode:node_modules/code-point-at Completed in 291ms
          103 timing reifyNode:node_modules/node-aead-crypto/node_modules/strip-ansi Completed in 296ms
          104 timing reifyNode:node_modules/node-aead-crypto/node_modules/string-width Completed in 297ms
          105 timing reifyNode:node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point Completed in 297ms
          106 timing reifyNode:node_modules/node-aead-crypto/node_modules/aproba Completed in 299ms
          107 timing reifyNode:node_modules/node-aead-crypto/node_modules/ansi-regex Completed in 300ms
          108 timing reifyNode:node_modules/node-aead-crypto/node_modules/string_decoder Completed in 313ms
          109 timing reifyNode:node_modules/node-aead-crypto/node_modules/npmlog Completed in 314ms
          110 timing reifyNode:node_modules/node-aead-crypto/node_modules/isarray Completed in 318ms
          111 timing reifyNode:node_modules/node-aead-crypto/node_modules/detect-libc Completed in 324ms
          112 timing reifyNode:node_modules/node-aead-crypto/node_modules/are-we-there-yet Completed in 325ms
          113 timing reifyNode:node_modules/node-aead-crypto/node_modules/semver Completed in 327ms
          114 timing reifyNode:node_modules/node-aead-crypto/node_modules/prebuild-install Completed in 344ms
          115 timing reifyNode:node_modules/node-aead-crypto/node_modules/node-abi Completed in 344ms
          116 timing reifyNode:node_modules/node-aead-crypto/node_modules/gauge Completed in 361ms
          117 timing reifyNode:node_modules/node-aead-crypto/node_modules/readable-stream Completed in 379ms
          118 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 420ms
          119 timing reifyNode:node_modules/node-aead-crypto/node_modules/nan Completed in 418ms
          120 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 2386ms (cache miss)
          121 timing reifyNode:node_modules/iobroker.vis Completed in 2461ms
          122 timing reify:unpack Completed in 2462ms
          123 timing reify:unretire Completed in 0ms
          124 timing build:queue Completed in 5ms
          125 timing build:link Completed in 0ms
          126 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
          127 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
          128 timing reify:rollback:createSparse Completed in 212ms
          129 timing reify:rollback:retireShallow Completed in 0ms
          130 timing command:install Completed in 10629ms
          131 verbose stack Error: command failed
          131 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
          131 verbose stack     at ChildProcess.emit (node:events:513:28)
          131 verbose stack     at maybeClose (node:internal/child_process:1100:16)
          131 verbose stack     at Socket.<anonymous> (node:internal/child_process:458:11)
          131 verbose stack     at Socket.emit (node:events:513:28)
          131 verbose stack     at Pipe.<anonymous> (node:net:301:12)
          132 verbose pkgid iobroker.vis@1.4.10
          133 verbose cwd /opt/iobroker
          134 verbose Linux 5.10.103-v7l+
          135 verbose node v16.18.0
          136 verbose npm  v8.19.2
          137 error code 6
          138 error path /opt/iobroker/node_modules/iobroker.vis
          139 error command failed
          140 error command sh -c -- node main.js --install
          141 verbose exit 6
          142 timing npm Completed in 10985ms
          143 verbose unfinished npm timer reify 1666357655886
          144 verbose unfinished npm timer reify:build 1666357663196
          145 verbose unfinished npm timer build 1666357663198
          146 verbose unfinished npm timer build:deps 1666357663198
          147 verbose unfinished npm timer build:run:install 1666357663205
          148 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1666357663206
          149 verbose code 6
          150 error A complete log of this run can be found in:
          150 error     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
            iob install vis@1.4.5
            T metaxa 2 Replies Last reply Reply Quote 2
              OK, das sieht anders aus und läuft wieder:
              pi@raspberrypi:/home/iobroker $ iob install vis@1.4.5
              NPM version: 8.19.2
              Installing iobroker.vis@1.4.5... (System call)
              added 1 package in 22s
              60 packages are looking for funding
                run `npm fund` for details
              host.raspberrypi install adapter vis@1.4.5
              upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
              upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
              upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
              upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
              Adapter "system.adapter.vis.0" restarted.
              upload [322] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
              upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png
              upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png
              upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png
              upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
              upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png
              upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_BulbOnOffCtrl.png widgets/basic/img/Prev_BulbOnOffCtrl.png image/png
              upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ScreenResolution.png widgets/basic/img/Prev_ScreenResolution.png image/png
              upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrl.png widgets/basic/img/Prev_ValueBoolCtrl.png image/png
              upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueListHtml8.png widgets/basic/img/Prev_ValueListHtml8.png image/png
              upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml
              upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/info/js/info.js widgets/info/js/info.js application/javascript
              upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
              upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
              upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
              upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
              upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
              upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
              upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
              upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
              upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
              upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
              upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
              upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
              upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
              upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
              upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
              upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
              upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
              upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
              upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
              upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
              upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
              upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
              host.raspberrypi object system.adapter.vis created/updated
              Update "system.adapter.vis.0"
              Jetzt bietet er mir wieder das Update auf 1.4.15 an. Soll ich das probieren?
                @toste
                sudo ln -s /usr/bin/node /usr/bin/nodejs
                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                iob update
                sagt? Wenn das sauber ist kannst du das upgrade auf die aktuelle vis wagen.
                  pi@raspberrypi:/home/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                  pi@raspberrypi:/home/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.18.0
                  v16.18.0
                  8.19.2
                  4.0.23
                  pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  /home/iobroker
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Hit:4 https://www.pivccu.de/piVCCU stable InRelease
                  Reading package lists... Done
                  Building dependency tree
                  All packages are up to date.
                  nodejs:
                    Installed: 16.18.0-deb-1nodesource1
                    Candidate: 16.18.0-deb-1nodesource1
                    Version table:
                   *** 16.18.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                          100 /var/lib/dpkg/status
                       10.24.0~dfsg-1~deb10u2 500
                  pi@raspberrypi:/home/iobroker $ iob update
                  Used repository: Stable (default)
                  Adapter    "admin"        : 6.2.22   , installed 6.2.22
                  Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
                  Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                  Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                  Adapter    "history"      : 2.2.0    , installed 2.2.0
                  Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                  Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                  Adapter    "iot"          : 1.11.9   , installed 1.11.9
                  Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                  Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                  Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                  Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                  Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                  Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                  Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                    @toste
                    Das sieht gut aus. Bring das mal auf die aktuelle vis.
                      Prima, auch das hat funktioniert. Vielen lieben Dank !!
                      Aber warum das jetzt nicht direkt ging, wissen wir nicht?
                        Ich vermute, das hat mit der Lizenz zu tun. Bei den alten Versionen wurde das anders gehandhabt, soweit ich weiß.
                          Schmunzi57 last edited by
                          Guten Morgen, auch ich hatte genau dieses Problem und es konnte, wie hier auch gelöst werden.
                          Nun bin ich wieder HAPPY 😋
                          Recht herzlichen Dank an alle die hier helfen und für uns "weniger wissende" da sind.
                          Mein besonderer Dank gilt in diesem Fall @Thomas-Braun, denn ohne dieses spezifische Wissen ist man halt aufgeschmissen.
                          In diesem Sinne nochmal mein Danke und macht bitte weiter so.
                          Tschüs
                          • metaxa
                            metaxa @Thomas Braun last edited by
                            @thomas-braun sagte in [gelöst] VIS: funktioniert nicht:
                            Auch von meiner Seite, danke!
                            2300
