    3. Einsteigerfragen
    4. Admininterface Docker
      Marc73 @Glasfaser last edited by
      @glasfaser
      so jetzt habe ich es:
      root@buanet-iobroker1:/opt/iobroker# iobroker logs --watch
      2022-10-19 17:49:29.412 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
      2022-10-19 17:49:29.419 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-10-19 17:49:29.420 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
      2022-10-19 17:49:29.422 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
      2022-10-19 17:49:29.932 - info: host.buanet-iobroker1 connected to Objects and States
      2022-10-19 17:49:30.002 - info: host.buanet-iobroker1 Node.js version has changed from unknown to 16.18.0
      2022-10-19 17:49:30.104 - info: host.buanet-iobroker1 added notifications configuration of host
      2022-10-19 17:49:30.378 - info: host.buanet-iobroker1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-10-19 17:49:30.415 - info: host.buanet-iobroker1 3 instances found
      2022-10-19 17:49:30.429 - info: host.buanet-iobroker1 starting 3 instances
      2022-10-19 17:49:30.512 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 892
      2022-10-19 17:49:30.730 - info: host.buanet-iobroker1 Created UUID: aaee033c-655b-48a6-95a5-316efcdd06c9
      2022-10-19 17:49:33.284 - info: admin.0 (892) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 17:49:33.406 - info: admin.0 (892) requesting all states
      2022-10-19 17:49:33.408 - info: admin.0 (892) requesting all objects
      2022-10-19 17:49:33.537 - info: admin.0 (892) received all objects
      2022-10-19 17:49:33.584 - info: admin.0 (892) Request actual repository...
      2022-10-19 17:49:33.599 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-10-19 17:49:33.648 - info: admin.0 (892) http server listening on port 8081
      2022-10-19 17:49:33.649 - info: admin.0 (892) Use link "http://localhost:8081" to configure.
      2022-10-19 17:49:33.660 - info: admin.0 (892) socket.io server listening on port 8081
      2022-10-19 17:49:33.831 - warn: admin.0 (892) Repository cannot be read: Active repo - stable
      2022-10-19 17:49:33.834 - warn: admin.0 (892) Active repository "stable" cannot be read
      2022-10-19 17:49:34.502 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 915
      2022-10-19 17:49:38.083 - info: admin.0 (892) Repository received successfully.
      2022-10-19 17:49:38.525 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 930
      2022-10-19 17:49:38.649 - info: discovery.0 (915) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 17:49:40.652 - info: backitup.0 (930) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 17:49:40.738 - info: backitup.0 (930) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-10-19 17:57:39.509 - info: host.buanet-iobroker1 received SIGTERM
      2022-10-19 17:57:39.513 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-10-19 17:57:39.514 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-10-19 17:57:39.515 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-10-19 17:57:39.523 - info: discovery.0 (915) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 17:57:39.523 - info: admin.0 (892) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 17:57:39.530 - info: backitup.0 (930) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 17:57:39.525 - info: discovery.0 (915) terminating
      2022-10-19 17:57:39.529 - info: discovery.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 17:57:39.534 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
      2022-10-19 17:57:39.532 - info: backitup.0 (930) cleaned everything up...
      2022-10-19 17:57:39.534 - info: backitup.0 (930) terminating
      2022-10-19 17:57:39.536 - info: backitup.0 (930) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 17:57:39.537 - info: admin.0 (892) terminating http server on port 8081
      2022-10-19 17:57:39.540 - info: admin.0 (892) terminating
      2022-10-19 17:57:39.547 - info: admin.0 (892) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 17:57:39.573 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
      2022-10-19 17:57:39.573 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
      2022-10-19 17:57:40.126 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 17:57:40.162 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 17:57:40.172 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 17:57:40.173 - info: host.buanet-iobroker1 All instances are stopped.
      2022-10-19 17:57:40.407 - info: host.buanet-iobroker1 terminated
      2022-10-19 18:02:18.785 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
      2022-10-19 18:02:18.793 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-10-19 18:02:18.794 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
      2022-10-19 18:02:18.795 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
      2022-10-19 18:02:19.479 - info: host.buanet-iobroker1 connected to Objects and States
      2022-10-19 18:02:19.579 - info: host.buanet-iobroker1 added notifications configuration of host
      2022-10-19 18:02:20.088 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
      2022-10-19 18:02:20.096 - info: host.buanet-iobroker1 3 instances found
      2022-10-19 18:02:20.110 - info: host.buanet-iobroker1 starting 3 instances
      2022-10-19 18:02:20.163 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 423
      2022-10-19 18:02:20.184 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
      2022-10-19 18:02:20.198 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
      2022-10-19 18:02:20.210 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
      2022-10-19 18:02:20.222 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
      2022-10-19 18:02:20.236 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
      2022-10-19 18:02:20.249 - info: host.buanet-iobroker1 Some obsolete host states deleted.
      2022-10-19 18:02:22.494 - info: admin.0 (423) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:02:22.553 - info: admin.0 (423) requesting all states
      2022-10-19 18:02:22.555 - info: admin.0 (423) requesting all objects
      2022-10-19 18:02:22.995 - info: admin.0 (423) received all objects
      2022-10-19 18:02:23.160 - info: admin.0 (423) Request actual repository...
      2022-10-19 18:02:23.305 - info: admin.0 (423) http server listening on port 8081
      2022-10-19 18:02:23.305 - info: admin.0 (423) Use link "http://localhost:8081" to configure.
      2022-10-19 18:02:23.328 - info: admin.0 (423) socket.io server listening on port 8081
      2022-10-19 18:02:23.371 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-10-19 18:02:24.183 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 450
      2022-10-19 18:02:25.857 - info: admin.0 (423) Repository received successfully.
      2022-10-19 18:02:30.146 - info: backitup.0 (465) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:02:30.220 - info: backitup.0 (465) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-10-19 18:03:05.539 - info: host.buanet-iobroker1 received SIGTERM
      2022-10-19 18:03:05.543 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-10-19 18:03:05.545 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-10-19 18:03:05.548 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-10-19 18:03:05.567 - info: admin.0 (423) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 18:03:05.568 - info: discovery.0 (450) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 18:03:05.571 - info: discovery.0 (450) terminating
      2022-10-19 18:03:05.573 - info: discovery.0 (450) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 18:03:05.579 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
      2022-10-19 18:03:05.578 - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 18:03:05.574 - info: admin.0 (423) terminating http server on port 8081
      2022-10-19 18:03:05.583 - info: admin.0 (423) terminating
      2022-10-19 18:03:05.585 - info: admin.0 (423) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 18:03:05.584 - info: backitup.0 (465) cleaned everything up...
      2022-10-19 18:03:05.588 - info: backitup.0 (465) terminating
      2022-10-19 18:03:05.597 - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 18:03:05.619 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
      2022-10-19 18:03:05.620 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
      2022-10-19 18:03:06.190 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 18:03:06.204 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 18:03:06.237 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 18:03:06.238 - info: host.buanet-iobroker1 All instances are stopped.
      2022-10-19 18:03:06.490 - info: host.buanet-iobroker1 terminated
      2022-10-19 18:05:44.520 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
      2022-10-19 18:05:44.529 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-10-19 18:05:44.530 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
      2022-10-19 18:05:44.531 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
      2022-10-19 18:05:45.283 - info: host.buanet-iobroker1 connected to Objects and States
      2022-10-19 18:05:45.314 - info: host.buanet-iobroker1 added notifications configuration of host
      2022-10-19 18:05:45.704 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
      2022-10-19 18:05:45.712 - info: host.buanet-iobroker1 3 instances found
      2022-10-19 18:05:45.726 - info: host.buanet-iobroker1 starting 3 instances
      2022-10-19 18:05:45.779 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 424
      2022-10-19 18:05:45.799 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
      2022-10-19 18:05:45.813 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
      2022-10-19 18:05:45.827 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
      2022-10-19 18:05:45.839 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
      2022-10-19 18:05:45.852 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
      2022-10-19 18:05:45.866 - info: host.buanet-iobroker1 Some obsolete host states deleted.
      2022-10-19 18:05:48.102 - info: admin.0 (424) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:05:48.186 - info: admin.0 (424) requesting all states
      2022-10-19 18:05:48.187 - info: admin.0 (424) requesting all objects
      2022-10-19 18:05:48.624 - info: admin.0 (424) received all objects
      2022-10-19 18:05:48.766 - info: admin.0 (424) Request actual repository...
      2022-10-19 18:05:48.806 - info: admin.0 (424) http server listening on port 8081
      2022-10-19 18:05:48.809 - info: admin.0 (424) Use link "http://localhost:8081" to configure.
      2022-10-19 18:05:48.849 - info: admin.0 (424) socket.io server listening on port 8081
      2022-10-19 18:05:49.047 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-10-19 18:05:49.891 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 451
      2022-10-19 18:05:51.277 - info: admin.0 (424) Repository received successfully.
      2022-10-19 18:05:52.117 - info: discovery.0 (451) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:05:53.769 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 466
      2022-10-19 18:05:55.931 - info: backitup.0 (466) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:05:56.012 - info: backitup.0 (466) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-10-19 18:20:47.231 - info: host.buanet-iobroker1 received SIGTERM
      2022-10-19 18:20:47.235 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-10-19 18:20:47.239 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-10-19 18:20:47.239 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-10-19 18:20:47.260 - info: discovery.0 (451) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 18:20:47.251 - info: admin.0 (424) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 18:20:47.269 - info: backitup.0 (466) Got terminate signal TERMINATE_YOURSELF
      2022-10-19 18:20:47.263 - info: discovery.0 (451) terminating
      2022-10-19 18:20:47.265 - info: discovery.0 (451) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 18:20:47.277 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
      2022-10-19 18:20:47.271 - info: backitup.0 (466) cleaned everything up...
      2022-10-19 18:20:47.273 - info: backitup.0 (466) terminating
      2022-10-19 18:20:47.275 - info: backitup.0 (466) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 18:20:47.277 - info: admin.0 (424) terminating http server on port 8081
      2022-10-19 18:20:47.279 - info: admin.0 (424) terminating
      2022-10-19 18:20:47.281 - info: admin.0 (424) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-10-19 18:20:47.317 - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
      2022-10-19 18:20:47.318 - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
      2022-10-19 18:20:47.898 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 18:20:47.939 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 18:20:47.941 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-10-19 18:20:47.941 - info: host.buanet-iobroker1 All instances are stopped.
      2022-10-19 18:20:48.071 - info: host.buanet-iobroker1 terminated
      2022-10-19 18:21:21.726 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
      2022-10-19 18:21:21.733 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-10-19 18:21:21.734 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
      2022-10-19 18:21:21.735 - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
      2022-10-19 18:21:22.466 - info: host.buanet-iobroker1 connected to Objects and States
      2022-10-19 18:21:22.493 - info: host.buanet-iobroker1 added notifications configuration of host
      2022-10-19 18:21:22.879 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
      2022-10-19 18:21:22.888 - info: host.buanet-iobroker1 3 instances found
      2022-10-19 18:21:22.905 - info: host.buanet-iobroker1 starting 3 instances
      2022-10-19 18:21:22.960 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 411
      2022-10-19 18:21:23.001 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
      2022-10-19 18:21:23.018 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
      2022-10-19 18:21:23.044 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
      2022-10-19 18:21:23.074 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
      2022-10-19 18:21:23.087 - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
      2022-10-19 18:21:23.101 - info: host.buanet-iobroker1 Some obsolete host states deleted.
      2022-10-19 18:21:25.330 - info: admin.0 (411) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:21:25.394 - info: admin.0 (411) requesting all states
      2022-10-19 18:21:25.396 - info: admin.0 (411) requesting all objects
      2022-10-19 18:21:25.954 - info: admin.0 (411) received all objects
      2022-10-19 18:21:26.139 - info: admin.0 (411) Request actual repository...
      2022-10-19 18:21:26.200 - info: admin.0 (411) http server listening on port 8081
      2022-10-19 18:21:26.201 - info: admin.0 (411) Use link "http://localhost:8081" to configure.
      2022-10-19 18:21:26.228 - info: admin.0 (411) socket.io server listening on port 8081
      2022-10-19 18:21:26.472 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-10-19 18:21:26.983 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 446
      2022-10-19 18:21:29.010 - info: admin.0 (411) Repository received successfully.
      2022-10-19 18:21:29.323 - info: discovery.0 (446) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:21:30.942 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 465
      2022-10-19 18:21:33.135 - info: backitup.0 (465) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
      2022-10-19 18:21:33.204 - info: backitup.0 (465) [iobroker] backup was activated at 02:40 every 1 day(s)
        @glasfaser
        was mir hier aufgefallen ist:
        was ist das das ist nicht meine externe Adresse und auch keine aus meinem Netz..
        grüße Und danke
        Marco
        • Glasfaser
          Glasfaser @Marc73 last edited by
          @marc73
          Sehe keinen Fehler .... warum er in Schleife mit dem Logo hängt.
          Erstelle zum Test einen neuen Container , aber im Host (nicht bridgemodus)
          • Glasfaser
            @marc73 sagte in Admininterface Docker:
            172.17.0.3
            die kommt vom bridgemodus
              @glasfaser
              habe ich gemacht neuer Container macht genau das gleiche.
              Ich muss jetzt erstmal Feierabend machen werden da noch weiter suchen.
              Ich habe auch andere Geräte probiert und auch schon eine ältere Version überall das gleiche.
              Danke erstmal ich bleibe drann.
              Grüße Marco
              • Glasfaser
                Entwickler-Konsole im Browser mit F12 aufrufen und in der Konsole schauen / posten was dort an Inhalt / Fehler / oder Warn enthalten ist .
                • Glasfaser
                  Glasfaser @Glasfaser last edited by Glasfaser
                  @marc73
                  @glasfaser sagte in Admininterface Docker:
                  Popup Blocker aktiv
                  Firewall aktiv
                  Was war hiermit !?
                    Marc73 @Glasfaser last edited by Homoran
                    @glasfaser
                    @glasfaser
                    Moin Popup Blocker oder Firewall sind nicht dran schuld.
                    Auf dem Synology läuft noch Grafana, influxDB und mein Controller für Unify alle ohne Probleme.
                    Jetzt habe ich den Firefox mit Konsole (F12 --> Konsole) aufgemacht und da sind folgende Meldungen:
                    [2022-10-21T08:54:28.284Z] No READY flag received in 3 seconds. Re-init instrument.ts:123:32
                    [2022-10-21T08:54:28.284Z] Start reconnect 5 instrument.ts:123:32
                    Firefox kann keine Verbindung zu dem Server unter ws://192.168.254.200:8081/?sid=1666342465275&name=admin aufbauen. socket.io.js:140:21
                    Die Verbindung zu ws://192.168.254.200:8081/?sid=1666342465275&name=admin wurde unterbrochen, während die Seite geladen wurde. socket.io.js:140:21
                    [2022-10-21T08:54:28.287Z] Reconnect is already running 5 instrument.ts:123:32
                    Beim genauen hin schauen wird dieses hier abgebrochen mit einer Ladezeit von 186 Sec:
                    https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F7.12.1
                    Eine eine Idee wo es da klemmen kann??
                    Grüße Marco
                    • Glasfaser
                      Glasfaser @Marc73 last edited by Glasfaser
                      @marc73
                      ich habe was gefunden :
                      Er kann nichts von der URL lesen / erreichen .
                      zeige mal
                      iobroker repo list
                      und in der Dockerkonsole ... geht ein
                      wget http://download.iobroker.net/sources-dist.json
                      wird dann etwas runtergeladen !?
                      EDIT :
                      Und eine große Bitte ...
                      pack die Ausgabe in Code-Tags >/< wie schon oben angegeben , so kann man es besser lesen und übersieht es nicht wenn doch Fehler vorhanden sind !!
                        @glasfaser
                        root@buanet-iobroker1:/opt/iobroker# iobroker repo list
                        Active repo(s): stable
                        root@buanet-iobroker1:/opt/iobroker# wget http://download.iobroker.net/sources-dist.json
                        --2022-10-22 08:31:18--  http://download.iobroker.net/sources-dist.json
                        Resolving download.iobroker.net (download.iobroker.net)... 79.143.182.215, 2a02:c205:0:855::1
                        Connecting to download.iobroker.net (download.iobroker.net)|79.143.182.215|:80... connected.
                        HTTP request sent, awaiting response... 301 Moved Permanently
                        Location: http://repo.iobroker.live/sources-dist.json [following]
                        --2022-10-22 08:31:18--  http://repo.iobroker.live/sources-dist.json
                        Resolving repo.iobroker.live (repo.iobroker.live)... 172.67.180.22, 104.21.88.137, 2606:4700:3031::6815:5889, ...
                        Connecting to repo.iobroker.live (repo.iobroker.live)|172.67.180.22|:80... connected.
                        HTTP request sent, awaiting response... 200 OK
                        Length: 2876934 (2,7M) [application/json]
                        Saving to: ‘sources-dist.json.1’
                        sources-dist.json.1                                100%[================================================================================================================>]   2,74M  2,37MB/s    in 1,2s
                        2022-10-22 08:31:20 (2,37 MB/s) - ‘sources-dist.json.1’ saved [2876934/2876934]
                        moin ja läd was runter.
                        Grüße marco
                        • Glasfaser
                          @marc73
                          Füge eine weitere Repo URL dazu :
                          iobroker repo add live-stable http://iobroker.live/repo/sources-dist.json
                          iobroker repo unset stable
                          iobroker repo set live-stable
                          iobroker update
                          Danach mal den Container neu starten
                            @glasfaser
                            2022-10-22 13:08:23.653  - info: admin.0 (425) received all objects
                            2022-10-22 13:08:23.675  - warn: admin.0 (425) Repository cannot be read: Active repo - live-stable
                            2022-10-22 13:08:23.676  - warn: admin.0 (425) Active repository "live-stable" cannot be read
                            2022-10-22 13:08:23.880  - info: admin.0 (425) http server listening on port 8081
                            2022-10-22 13:08:23.881  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                            2022-10-22 13:08:23.891  - info: admin.0 (425) socket.io server listening on port 8081
                            2022-10-22 13:08:24.655  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 452
                            2022-10-22 13:08:26.670  - info: discovery.0 (452) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                            2022-10-22 13:08:28.639  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                            2022-10-22 13:08:30.631  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                            2022-10-22 13:08:30.705  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                            habe ich gemacht leider siehe
                            Zeile 3:
                            Admin ist nicht zu laden 😞
                            Glasfaser 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              @marc73
                              dann ... nur zum TEST auf Beta
                              iobroker repo unset live-stable
                              iobroker repo set beta
                              • Glasfaser
                                Also der ioBroker Logo Ladekreis ... im Browser !?
                                • Glasfaser
                                  Da ich ein Synology
                                  im Docker.
                                  Es ist schon merkwürdig, das es per wget im Container funktioniert ,
                                  aber ....
                                  schau mal in der Firewall in der Syn eventuell Blockt da etwas !?
                                    @glasfaser @glasfaser
                                    so ich habe jetzt nocheinmal die Firewall in er SYN aus gemacht und im Router hatte ich noch ein Portforwarding auf port 8081 auf einen Controller.
                                    Auf meinem Ubunutserver läuft das es allerdings alles.
                                    hier jetzt noch einmal das Protokoll dauert immer etwas muss ich leider zusammensetzen man kann nicht alles aus dem Terminal kopieren.
                                    2022-10-22 08:34:40.902  - info: host.buanet-iobroker1 received SIGTERM
                                    2022-10-22 08:34:40.924  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2022-10-22 08:34:40.966  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                                    2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                                    2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                                    2022-10-22 08:34:40.940  - info: admin.0 (411) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 08:34:41.009  - info: admin.0 (411) terminating http server on port 8081
                                    2022-10-22 08:34:41.017  - info: admin.0 (411) terminating
                                    2022-10-22 08:34:41.019  - info: admin.0 (411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 08:34:40.957  - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 08:34:41.028  - info: backitup.0 (465) cleaned everything up...
                                    2022-10-22 08:34:41.031  - info: backitup.0 (465) terminating
                                    2022-10-22 08:34:41.044  - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 08:34:40.951  - info: discovery.0 (446) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 08:34:41.037  - info: discovery.0 (446) terminating
                                    2022-10-22 08:34:41.044  - info: discovery.0 (446) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 08:34:41.638  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 08:34:41.668  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 08:34:41.682  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 08:34:41.683  - info: host.buanet-iobroker1 All instances are stopped.
                                    2022-10-22 08:34:41.761  - info: host.buanet-iobroker1 terminated
                                    2022-10-22 08:35:21.399  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-10-22 08:35:21.406  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-10-22 08:35:21.407  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                                    2022-10-22 08:35:21.408  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                                    2022-10-22 08:35:22.436  - info: host.buanet-iobroker1 connected to Objects and States
                                    2022-10-22 08:35:22.471  - info: host.buanet-iobroker1 added notifications configuration of host
                                    2022-10-22 08:35:22.901  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                                    2022-10-22 08:35:22.909  - info: host.buanet-iobroker1 3 instances found
                                    2022-10-22 08:35:22.923  - info: host.buanet-iobroker1 starting 3 instances
                                    2022-10-22 08:35:23.027  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 421
                                    2022-10-22 08:35:23.046  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                                    2022-10-22 08:35:23.107  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                                    2022-10-22 08:35:23.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                                    2022-10-22 08:35:23.155  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                                    2022-10-22 08:35:23.188  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                                    2022-10-22 08:35:23.201  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                                    2022-10-22 08:35:26.039  - info: admin.0 (421) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 08:35:26.096  - info: admin.0 (421) requesting all states
                                    2022-10-22 08:35:26.097  - info: admin.0 (421) requesting all objects
                                    2022-10-22 08:35:26.648  - info: admin.0 (421) received all objects
                                    2022-10-22 08:35:26.814  - info: admin.0 (421) Request actual repository...
                                    2022-10-22 08:35:26.929  - info: admin.0 (421) http server listening on port 8081
                                    2022-10-22 08:35:26.933  - info: admin.0 (421) Use link "http://localhost:8081" to configure.
                                    2022-10-22 08:35:26.968  - info: admin.0 (421) socket.io server listening on port 8081
                                    2022-10-22 08:35:27.249  - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                    2022-10-22 08:35:27.435  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 444
                                    2022-10-22 08:35:31.110  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 459
                                    2022-10-22 08:35:31.476  - info: admin.0 (421) Repository received successfully.
                                    2022-10-22 08:35:32.085  - info: discovery.0 (444) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 08:35:33.912  - info: backitup.0 (459) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 08:35:33.984  - info: backitup.0 (459) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2022-10-22 13:07:43.210  - info: host.buanet-iobroker1 received SIGTERM
                                    2022-10-22 13:07:43.216  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2022-10-22 13:07:43.230  - info: admin.0 (421) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:07:43.238  - info: admin.0 (421) terminating http server on port 8081
                                    2022-10-22 13:07:43.241  - info: admin.0 (421) terminating
                                    2022-10-22 13:07:43.243  - info: admin.0 (421) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:07:43.239  - info: discovery.0 (444) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:07:43.247  - info: backitup.0 (459) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:07:43.249  - info: discovery.0 (444) terminating
                                    2022-10-22 13:07:43.251  - info: discovery.0 (444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:07:43.256  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                                    2022-10-22 13:07:43.257  - info: backitup.0 (459) cleaned everything up...
                                    2022-10-22 13:07:43.259  - info: backitup.0 (459) terminating
                                    2022-10-22 13:07:43.261  - info: backitup.0 (459) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:07:43.294  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                                    2022-10-22 13:07:43.295  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                                    2022-10-22 13:07:43.873  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:07:43.884  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:07:43.924  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:07:43.925  - info: host.buanet-iobroker1 All instances are stopped.
                                    2022-10-22 13:07:44.064  - info: host.buanet-iobroker1 terminated
                                    2022-10-22 13:08:18.617  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-10-22 13:08:18.625  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-10-22 13:08:18.626  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                                    2022-10-22 13:08:18.627  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                                    2022-10-22 13:08:20.102  - info: host.buanet-iobroker1 connected to Objects and States
                                    2022-10-22 13:08:20.130  - info: host.buanet-iobroker1 added notifications configuration of host
                                    2022-10-22 13:08:20.580  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                                    2022-10-22 13:08:20.589  - info: host.buanet-iobroker1 3 instances found
                                    2022-10-22 13:08:20.603  - info: host.buanet-iobroker1 starting 3 instances
                                    2022-10-22 13:08:20.670  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                                    2022-10-22 13:08:20.715  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                                    2022-10-22 13:08:20.802  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                                    2022-10-22 13:08:20.838  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                                    2022-10-22 13:08:20.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                                    2022-10-22 13:08:20.903  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                                    2022-10-22 13:08:20.929  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                                    2022-10-22 13:08:23.129  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:08:23.206  - info: admin.0 (425) requesting all states
                                    2022-10-22 13:08:23.208  - info: admin.0 (425) requesting all objects
                                    2022-10-22 13:23:36.922  - info: host.buanet-iobroker1 received SIGTERM
                                    2022-10-22 13:23:36.927  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2022-10-22 13:23:36.941  - info: discovery.0 (452) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:23:36.940  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:23:36.948  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:23:36.948  - info: admin.0 (425) terminating http server on port 8081
                                    2022-10-22 13:23:36.950  - info: admin.0 (425) terminating
                                    2022-10-22 13:23:36.952  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:23:36.944  - info: discovery.0 (452) terminating
                                    2022-10-22 13:23:36.946  - info: discovery.0 (452) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:23:36.951  - info: backitup.0 (467) cleaned everything up...
                                    2022-10-22 13:23:36.952  - info: backitup.0 (467) terminating
                                    2022-10-22 13:23:36.954  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:23:36.959  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                                    2022-10-22 13:23:36.999  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                                    2022-10-22 13:23:37.000  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                                    2022-10-22 13:23:37.576  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:23:37.607  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 All instances are stopped.
                                    2022-10-22 13:23:37.929  - info: host.buanet-iobroker1 terminated
                                    2022-10-22 13:24:13.013  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-10-22 13:24:13.020  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-10-22 13:24:13.022  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                                    2022-10-22 13:24:13.023  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                                    2022-10-22 13:24:14.441  - info: host.buanet-iobroker1 connected to Objects and States
                                    2022-10-22 13:24:14.475  - info: host.buanet-iobroker1 added notifications configuration of host
                                    2022-10-22 13:24:14.914  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                                    2022-10-22 13:24:14.923  - info: host.buanet-iobroker1 3 instances found
                                    2022-10-22 13:24:14.937  - info: host.buanet-iobroker1 starting 3 instances
                                    2022-10-22 13:24:14.999  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                                    2022-10-22 13:24:15.026  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                                    2022-10-22 13:24:15.083  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                                    2022-10-22 13:24:15.096  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                                    2022-10-22 13:24:15.109  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                                    2022-10-22 13:24:15.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                                    2022-10-22 13:24:15.154  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                                    2022-10-22 13:24:17.368  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:24:17.459  - info: admin.0 (426) requesting all states
                                    2022-10-22 13:24:17.461  - info: admin.0 (426) requesting all objects
                                    2022-10-22 13:24:18.173  - info: admin.0 (426) received all objects
                                    2022-10-22 13:24:18.197  - warn: admin.0 (426) No repository source configured
                                    2022-10-22 13:24:18.649  - info: admin.0 (426) Request actual repository...
                                    2022-10-22 13:24:18.686  - info: admin.0 (426) http server listening on port 8081
                                    2022-10-22 13:24:18.688  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                                    2022-10-22 13:24:18.712  - info: admin.0 (426) socket.io server listening on port 8081
                                    2022-10-22 13:24:19.201  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                                    2022-10-22 13:24:19.331  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 453
                                    2022-10-22 13:24:20.196  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                                    2022-10-22 13:24:27.708  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 464
                                    2022-10-22 13:24:27.963  - info: admin.0 (426) Repository received successfully.
                                    2022-10-22 13:24:28.336  - info: discovery.0 (453) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:24:30.424  - info: backitup.0 (464) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:24:30.514  - info: backitup.0 (464) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2022-10-22 13:28:42.223  - info: host.buanet-iobroker1 received SIGTERM
                                    2022-10-22 13:28:42.227  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2022-10-22 13:28:42.235  - info: admin.0 (426) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:28:42.245  - info: discovery.0 (453) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:28:42.246  - info: backitup.0 (464) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:28:42.248  - info: discovery.0 (453) terminating
                                    2022-10-22 13:28:42.250  - info: discovery.0 (453) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:28:42.238  - info: admin.0 (426) terminating http server on port 8081
                                    2022-10-22 13:28:42.240  - info: admin.0 (426) terminating
                                    2022-10-22 13:28:42.253  - info: admin.0 (426) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:28:42.248  - info: backitup.0 (464) cleaned everything up...
                                    2022-10-22 13:28:42.250  - info: backitup.0 (464) terminating
                                    2022-10-22 13:28:42.255  - info: backitup.0 (464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:28:42.260  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                                    2022-10-22 13:28:42.299  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                                    2022-10-22 13:28:42.300  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                                    2022-10-22 13:28:42.875  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:28:42.915  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:28:42.920  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:28:42.921  - info: host.buanet-iobroker1 All instances are stopped.
                                    2022-10-22 13:28:43.071  - info: host.buanet-iobroker1 terminated
                                    2022-10-22 13:29:17.425  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-10-22 13:29:17.432  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-10-22 13:29:17.433  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                                    2022-10-22 13:29:17.434  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                                    2022-10-22 13:29:19.096  - info: host.buanet-iobroker1 connected to Objects and States
                                    2022-10-22 13:29:19.128  - info: host.buanet-iobroker1 added notifications configuration of host
                                    2022-10-22 13:29:19.516  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                                    2022-10-22 13:29:19.524  - info: host.buanet-iobroker1 3 instances found
                                    2022-10-22 13:29:19.537  - info: host.buanet-iobroker1 starting 3 instances
                                    2022-10-22 13:29:19.604  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                                    2022-10-22 13:29:19.630  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                                    2022-10-22 13:29:19.739  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                                    2022-10-22 13:29:19.752  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                                    2022-10-22 13:29:19.769  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                                    2022-10-22 13:29:19.829  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                                    2022-10-22 13:29:19.842  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                                    2022-10-22 13:29:21.954  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:29:22.059  - info: admin.0 (425) requesting all states
                                    2022-10-22 13:29:22.060  - info: admin.0 (425) requesting all objects
                                    2022-10-22 13:29:23.568  - info: admin.0 (425) received all objects
                                    2022-10-22 13:29:23.634  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 448
                                    2022-10-22 13:29:24.016  - info: admin.0 (425) Request actual repository...
                                    2022-10-22 13:29:24.058  - info: admin.0 (425) http server listening on port 8081
                                    2022-10-22 13:29:24.061  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                                    2022-10-22 13:29:24.085  - info: admin.0 (425) socket.io server listening on port 8081
                                    2022-10-22 13:29:24.850  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                                    2022-10-22 13:29:25.885  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                                    2022-10-22 13:29:26.136  - info: discovery.0 (448) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:29:27.813  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                                    2022-10-22 13:29:28.189  - info: admin.0 (425) Repository received successfully.
                                    2022-10-22 13:29:29.895  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:29:29.984  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2022-10-22 13:35:35.192  - info: host.buanet-iobroker1 received SIGTERM
                                    2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2022-10-22 13:35:35.201  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2022-10-22 13:35:35.211  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:35:35.209  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:35:35.211  - info: discovery.0 (448) Got terminate signal TERMINATE_YOURSELF
                                    2022-10-22 13:35:35.212  - info: backitup.0 (467) cleaned everything up...
                                    2022-10-22 13:35:35.214  - info: backitup.0 (467) terminating
                                    2022-10-22 13:35:35.216  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:35:35.221  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                                    2022-10-22 13:35:35.217  - info: discovery.0 (448) terminating
                                    2022-10-22 13:35:35.221  - info: discovery.0 (448) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:35:35.214  - info: admin.0 (425) terminating http server on port 8081
                                    2022-10-22 13:35:35.220  - info: admin.0 (425) terminating
                                    2022-10-22 13:35:35.224  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-10-22 13:35:35.258  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                                    2022-10-22 13:35:35.259  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                                    2022-10-22 13:35:35.829  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:35:35.855  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:35:35.887  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2022-10-22 13:35:35.888  - info: host.buanet-iobroker1 All instances are stopped.
                                    2022-10-22 13:35:36.149  - info: host.buanet-iobroker1 terminated
                                    2022-10-22 13:36:13.277  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-10-22 13:36:13.285  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-10-22 13:36:13.288  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                                    2022-10-22 13:36:15.271  - info: host.buanet-iobroker1 connected to Objects and States
                                    2022-10-22 13:36:15.303  - info: host.buanet-iobroker1 added notifications configuration of host
                                    2022-10-22 13:36:15.689  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                                    2022-10-22 13:36:15.697  - info: host.buanet-iobroker1 3 instances found
                                    2022-10-22 13:36:15.710  - info: host.buanet-iobroker1 starting 3 instances
                                    2022-10-22 13:36:15.779  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                                    2022-10-22 13:36:15.800  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                                    2022-10-22 13:36:15.855  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                                    2022-10-22 13:36:15.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                                    2022-10-22 13:36:15.882  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                                    2022-10-22 13:36:15.896  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                                    2022-10-22 13:36:15.910  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                                    2022-10-22 13:36:18.138  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:36:18.201  - info: admin.0 (426) requesting all states
                                    2022-10-22 13:36:18.202  - info: admin.0 (426) requesting all objects
                                    2022-10-22 13:36:19.653  - info: admin.0 (426) received all objects
                                    2022-10-22 13:36:19.881  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 449
                                    2022-10-22 13:36:20.384  - info: admin.0 (426) http server listening on port 8081
                                    2022-10-22 13:36:20.385  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                                    2022-10-22 13:36:20.396  - info: admin.0 (426) socket.io server listening on port 8081
                                    2022-10-22 13:36:21.894  - info: discovery.0 (449) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:36:23.752  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 468
                                    2022-10-22 13:36:25.918  - info: backitup.0 (468) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                                    2022-10-22 13:36:25.997  - info: backitup.0 (468) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    ^C
                                    • Glasfaser
                                      Ist OK ...
                                      Und immer noch :
                                      Gehe mal beim Browser im inkognito Modus , was ist dann
                                        @glasfaser
                                        ja ist leider immer noch passiert nix.
                                        immer noch startlogo und nix passiert
                                        • Glasfaser
                                          @marc73
                                          Ich habe keine Idee mehr .... 😞
                                          bzw. ist es sehr merkwürdig das " nichts " funktioniert und immer der gleiche Fehler ist .
                                          Laut Log hast du bridgemodus , was ist im Host ?
                                          die Syn mal neu gestartet ... glaube aber nicht das es daran liegt
                                          , obwohl es gab mal einen User wo das Docker Paket einen Schuß weg hatte.
                                          Er hat das Docker zusatzpaket gelöscht , neu installiert und den ioBroker Docker neu angelegt , danach lief es
                                            Homoran Global Moderator Administrators @Glasfaser last edited by
                                            @glasfaser hab ich's nur übersehen oder gibt es noch kein Browserlog?
                                            1488
