    3. Einsteigerfragen
    4. Admininterface Docker
    • Glasfaser
      Glasfaser @Marc73 last edited by Glasfaser
      @marc73
      ich habe was gefunden :
      2022-10-19 17:49:33.599 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-10-19 17:49:33.648 - info: admin.0 (892) http server listening on port 8081
      2022-10-19 17:49:33.649 - info: admin.0 (892) Use link "http://localhost:8081" to configure.
      2022-10-19 17:49:33.660 - info: admin.0 (892) socket.io server listening on port 8081
      2022-10-19 17:49:33.831 - warn: admin.0 (892) Repository cannot be read: Active repo - stable
      2022-10-19 17:49:33.834 - warn: admin.0 (892) Active repository "stable" cannot be read
      Er kann nichts von der URL lesen / erreichen .
      zeige mal
      iobroker repo list
      und in der Dockerkonsole ... geht ein
      wget http://download.iobroker.net/sources-dist.json
      wird dann etwas runtergeladen !?
      EDIT :
      Und eine große Bitte ...
      pack die Ausgabe in Code-Tags >/< wie schon oben angegeben , so kann man es besser lesen und übersieht es nicht wenn doch Fehler vorhanden sind !!
        Marc73 @Glasfaser last edited by
        @glasfaser
        root@buanet-iobroker1:/opt/iobroker# iobroker repo list
        Active repo(s): stable
        root@buanet-iobroker1:/opt/iobroker# wget http://download.iobroker.net/sources-dist.json
        --2022-10-22 08:31:18--  http://download.iobroker.net/sources-dist.json
        Resolving download.iobroker.net (download.iobroker.net)... 79.143.182.215, 2a02:c205:0:855::1
        Connecting to download.iobroker.net (download.iobroker.net)|79.143.182.215|:80... connected.
        HTTP request sent, awaiting response... 301 Moved Permanently
        Location: http://repo.iobroker.live/sources-dist.json [following]
        --2022-10-22 08:31:18--  http://repo.iobroker.live/sources-dist.json
        Resolving repo.iobroker.live (repo.iobroker.live)... 172.67.180.22, 104.21.88.137, 2606:4700:3031::6815:5889, ...
        Connecting to repo.iobroker.live (repo.iobroker.live)|172.67.180.22|:80... connected.
        HTTP request sent, awaiting response... 200 OK
        Length: 2876934 (2,7M) [application/json]
        Saving to: ‘sources-dist.json.1’
        sources-dist.json.1                                100%[================================================================================================================>]   2,74M  2,37MB/s    in 1,2s
        2022-10-22 08:31:20 (2,37 MB/s) - ‘sources-dist.json.1’ saved [2876934/2876934]
        moin ja läd was runter.
        Grüße marco
        • Glasfaser
          @marc73
          Füge eine weitere Repo URL dazu :
          iobroker repo add live-stable http://iobroker.live/repo/sources-dist.json
          iobroker repo unset stable
          iobroker repo set live-stable
          iobroker update
          Danach mal den Container neu starten
            @glasfaser
            2022-10-22 13:08:23.653  - info: admin.0 (425) received all objects
            2022-10-22 13:08:23.675  - warn: admin.0 (425) Repository cannot be read: Active repo - live-stable
            2022-10-22 13:08:23.676  - warn: admin.0 (425) Active repository "live-stable" cannot be read
            2022-10-22 13:08:23.880  - info: admin.0 (425) http server listening on port 8081
            2022-10-22 13:08:23.881  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
            2022-10-22 13:08:23.891  - info: admin.0 (425) socket.io server listening on port 8081
            2022-10-22 13:08:24.655  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 452
            2022-10-22 13:08:26.670  - info: discovery.0 (452) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
            2022-10-22 13:08:28.639  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
            2022-10-22 13:08:30.631  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
            2022-10-22 13:08:30.705  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
            habe ich gemacht leider siehe
            Zeile 3:
            Admin ist nicht zu laden 😞
            Glasfaser 2 Replies Last reply Reply Quote 0
            • Glasfaser
              @marc73
              dann ... nur zum TEST auf Beta
              iobroker repo unset live-stable
              iobroker repo set beta
              • Glasfaser
                @marc73 sagte in Admininterface Docker:
                Also der ioBroker Logo Ladekreis ... im Browser !?
                • Glasfaser
                  Da ich ein Synology
                  im Docker.
                  Es ist schon merkwürdig, das es per wget im Container funktioniert ,
                  aber ....
                  schau mal in der Firewall in der Syn eventuell Blockt da etwas !?
                    @glasfaser @glasfaser
                    so ich habe jetzt nocheinmal die Firewall in er SYN aus gemacht und im Router hatte ich noch ein Portforwarding auf port 8081 auf einen Controller.
                    Auf meinem Ubunutserver läuft das es allerdings alles.
                    hier jetzt noch einmal das Protokoll dauert immer etwas muss ich leider zusammensetzen man kann nicht alles aus dem Terminal kopieren.
                    root@buanet-iobroker1:/opt/iobroker# iobroker logs --watch
                    2022-10-22 08:34:40.902  - info: host.buanet-iobroker1 received SIGTERM
                    2022-10-22 08:34:40.924  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                    2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                    2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2022-10-22 08:34:40.966  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                    2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                    2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                    2022-10-22 08:34:40.940  - info: admin.0 (411) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 08:34:41.009  - info: admin.0 (411) terminating http server on port 8081
                    2022-10-22 08:34:41.017  - info: admin.0 (411) terminating
                    2022-10-22 08:34:41.019  - info: admin.0 (411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 08:34:40.957  - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 08:34:41.028  - info: backitup.0 (465) cleaned everything up...
                    2022-10-22 08:34:41.031  - info: backitup.0 (465) terminating
                    2022-10-22 08:34:41.044  - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 08:34:40.951  - info: discovery.0 (446) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 08:34:41.037  - info: discovery.0 (446) terminating
                    2022-10-22 08:34:41.044  - info: discovery.0 (446) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 08:34:41.638  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 08:34:41.668  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 08:34:41.682  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 08:34:41.683  - info: host.buanet-iobroker1 All instances are stopped.
                    2022-10-22 08:34:41.761  - info: host.buanet-iobroker1 terminated
                    2022-10-22 08:35:21.399  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                    2022-10-22 08:35:21.406  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-10-22 08:35:21.407  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                    2022-10-22 08:35:21.408  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                    2022-10-22 08:35:22.436  - info: host.buanet-iobroker1 connected to Objects and States
                    2022-10-22 08:35:22.471  - info: host.buanet-iobroker1 added notifications configuration of host
                    2022-10-22 08:35:22.901  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                    2022-10-22 08:35:22.909  - info: host.buanet-iobroker1 3 instances found
                    2022-10-22 08:35:22.923  - info: host.buanet-iobroker1 starting 3 instances
                    2022-10-22 08:35:23.027  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 421
                    2022-10-22 08:35:23.046  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                    2022-10-22 08:35:23.107  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                    2022-10-22 08:35:23.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                    2022-10-22 08:35:23.155  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                    2022-10-22 08:35:23.188  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                    2022-10-22 08:35:23.201  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                    2022-10-22 08:35:26.039  - info: admin.0 (421) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 08:35:26.096  - info: admin.0 (421) requesting all states
                    2022-10-22 08:35:26.097  - info: admin.0 (421) requesting all objects
                    2022-10-22 08:35:26.648  - info: admin.0 (421) received all objects
                    2022-10-22 08:35:26.814  - info: admin.0 (421) Request actual repository...
                    2022-10-22 08:35:26.929  - info: admin.0 (421) http server listening on port 8081
                    2022-10-22 08:35:26.933  - info: admin.0 (421) Use link "http://localhost:8081" to configure.
                    2022-10-22 08:35:26.968  - info: admin.0 (421) socket.io server listening on port 8081
                    2022-10-22 08:35:27.249  - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2022-10-22 08:35:27.435  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 444
                    2022-10-22 08:35:31.110  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 459
                    2022-10-22 08:35:31.476  - info: admin.0 (421) Repository received successfully.
                    2022-10-22 08:35:32.085  - info: discovery.0 (444) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 08:35:33.912  - info: backitup.0 (459) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 08:35:33.984  - info: backitup.0 (459) [iobroker] backup was activated at 02:40 every 1 day(s)
                    2022-10-22 13:07:43.210  - info: host.buanet-iobroker1 received SIGTERM
                    2022-10-22 13:07:43.216  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                    2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                    2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2022-10-22 13:07:43.230  - info: admin.0 (421) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:07:43.238  - info: admin.0 (421) terminating http server on port 8081
                    2022-10-22 13:07:43.241  - info: admin.0 (421) terminating
                    2022-10-22 13:07:43.243  - info: admin.0 (421) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:07:43.239  - info: discovery.0 (444) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:07:43.247  - info: backitup.0 (459) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:07:43.249  - info: discovery.0 (444) terminating
                    2022-10-22 13:07:43.251  - info: discovery.0 (444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:07:43.256  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                    2022-10-22 13:07:43.257  - info: backitup.0 (459) cleaned everything up...
                    2022-10-22 13:07:43.259  - info: backitup.0 (459) terminating
                    2022-10-22 13:07:43.261  - info: backitup.0 (459) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:07:43.294  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                    2022-10-22 13:07:43.295  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                    2022-10-22 13:07:43.873  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:07:43.884  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:07:43.924  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:07:43.925  - info: host.buanet-iobroker1 All instances are stopped.
                    2022-10-22 13:07:44.064  - info: host.buanet-iobroker1 terminated
                    2022-10-22 13:08:18.617  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                    2022-10-22 13:08:18.625  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-10-22 13:08:18.626  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                    2022-10-22 13:08:18.627  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                    2022-10-22 13:08:20.102  - info: host.buanet-iobroker1 connected to Objects and States
                    2022-10-22 13:08:20.130  - info: host.buanet-iobroker1 added notifications configuration of host
                    2022-10-22 13:08:20.580  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                    2022-10-22 13:08:20.589  - info: host.buanet-iobroker1 3 instances found
                    2022-10-22 13:08:20.603  - info: host.buanet-iobroker1 starting 3 instances
                    2022-10-22 13:08:20.670  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                    2022-10-22 13:08:20.715  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                    2022-10-22 13:08:20.802  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                    2022-10-22 13:08:20.838  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                    2022-10-22 13:08:20.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                    2022-10-22 13:08:20.903  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                    2022-10-22 13:08:20.929  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                    2022-10-22 13:08:23.129  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:08:23.206  - info: admin.0 (425) requesting all states
                    2022-10-22 13:08:23.208  - info: admin.0 (425) requesting all objects
                    2022-10-22 13:23:36.922  - info: host.buanet-iobroker1 received SIGTERM
                    2022-10-22 13:23:36.927  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                    2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                    2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2022-10-22 13:23:36.941  - info: discovery.0 (452) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:23:36.940  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:23:36.948  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:23:36.948  - info: admin.0 (425) terminating http server on port 8081
                    2022-10-22 13:23:36.950  - info: admin.0 (425) terminating
                    2022-10-22 13:23:36.952  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:23:36.944  - info: discovery.0 (452) terminating
                    2022-10-22 13:23:36.946  - info: discovery.0 (452) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:23:36.951  - info: backitup.0 (467) cleaned everything up...
                    2022-10-22 13:23:36.952  - info: backitup.0 (467) terminating
                    2022-10-22 13:23:36.954  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:23:36.959  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                    2022-10-22 13:23:36.999  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                    2022-10-22 13:23:37.000  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                    2022-10-22 13:23:37.576  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:23:37.607  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 All instances are stopped.
                    2022-10-22 13:23:37.929  - info: host.buanet-iobroker1 terminated
                    2022-10-22 13:24:13.013  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                    2022-10-22 13:24:13.020  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-10-22 13:24:13.022  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                    2022-10-22 13:24:13.023  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                    2022-10-22 13:24:14.441  - info: host.buanet-iobroker1 connected to Objects and States
                    2022-10-22 13:24:14.475  - info: host.buanet-iobroker1 added notifications configuration of host
                    2022-10-22 13:24:14.914  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                    2022-10-22 13:24:14.923  - info: host.buanet-iobroker1 3 instances found
                    2022-10-22 13:24:14.937  - info: host.buanet-iobroker1 starting 3 instances
                    2022-10-22 13:24:14.999  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                    2022-10-22 13:24:15.026  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                    2022-10-22 13:24:15.083  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                    2022-10-22 13:24:15.096  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                    2022-10-22 13:24:15.109  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                    2022-10-22 13:24:15.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                    2022-10-22 13:24:15.154  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                    2022-10-22 13:24:17.368  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:24:17.459  - info: admin.0 (426) requesting all states
                    2022-10-22 13:24:17.461  - info: admin.0 (426) requesting all objects
                    2022-10-22 13:24:18.173  - info: admin.0 (426) received all objects
                    2022-10-22 13:24:18.197  - warn: admin.0 (426) No repository source configured
                    2022-10-22 13:24:18.649  - info: admin.0 (426) Request actual repository...
                    2022-10-22 13:24:18.686  - info: admin.0 (426) http server listening on port 8081
                    2022-10-22 13:24:18.688  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                    2022-10-22 13:24:18.712  - info: admin.0 (426) socket.io server listening on port 8081
                    2022-10-22 13:24:19.201  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                    2022-10-22 13:24:19.331  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 453
                    2022-10-22 13:24:20.196  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                    2022-10-22 13:24:27.708  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 464
                    2022-10-22 13:24:27.963  - info: admin.0 (426) Repository received successfully.
                    2022-10-22 13:24:28.336  - info: discovery.0 (453) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:24:30.424  - info: backitup.0 (464) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:24:30.514  - info: backitup.0 (464) [iobroker] backup was activated at 02:40 every 1 day(s)
                    2022-10-22 13:28:42.223  - info: host.buanet-iobroker1 received SIGTERM
                    2022-10-22 13:28:42.227  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                    2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                    2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2022-10-22 13:28:42.235  - info: admin.0 (426) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:28:42.245  - info: discovery.0 (453) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:28:42.246  - info: backitup.0 (464) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:28:42.248  - info: discovery.0 (453) terminating
                    2022-10-22 13:28:42.250  - info: discovery.0 (453) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:28:42.238  - info: admin.0 (426) terminating http server on port 8081
                    2022-10-22 13:28:42.240  - info: admin.0 (426) terminating
                    2022-10-22 13:28:42.253  - info: admin.0 (426) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:28:42.248  - info: backitup.0 (464) cleaned everything up...
                    2022-10-22 13:28:42.250  - info: backitup.0 (464) terminating
                    2022-10-22 13:28:42.255  - info: backitup.0 (464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:28:42.260  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                    2022-10-22 13:28:42.299  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                    2022-10-22 13:28:42.300  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                    2022-10-22 13:28:42.875  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:28:42.915  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:28:42.920  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:28:42.921  - info: host.buanet-iobroker1 All instances are stopped.
                    2022-10-22 13:28:43.071  - info: host.buanet-iobroker1 terminated
                    2022-10-22 13:29:17.425  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                    2022-10-22 13:29:17.432  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-10-22 13:29:17.433  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                    2022-10-22 13:29:17.434  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                    2022-10-22 13:29:19.096  - info: host.buanet-iobroker1 connected to Objects and States
                    2022-10-22 13:29:19.128  - info: host.buanet-iobroker1 added notifications configuration of host
                    2022-10-22 13:29:19.516  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                    2022-10-22 13:29:19.524  - info: host.buanet-iobroker1 3 instances found
                    2022-10-22 13:29:19.537  - info: host.buanet-iobroker1 starting 3 instances
                    2022-10-22 13:29:19.604  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                    2022-10-22 13:29:19.630  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                    2022-10-22 13:29:19.739  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                    2022-10-22 13:29:19.752  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                    2022-10-22 13:29:19.769  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                    2022-10-22 13:29:19.829  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                    2022-10-22 13:29:19.842  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                    2022-10-22 13:29:21.954  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:29:22.059  - info: admin.0 (425) requesting all states
                    2022-10-22 13:29:22.060  - info: admin.0 (425) requesting all objects
                    2022-10-22 13:29:23.568  - info: admin.0 (425) received all objects
                    2022-10-22 13:29:23.634  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 448
                    2022-10-22 13:29:24.016  - info: admin.0 (425) Request actual repository...
                    2022-10-22 13:29:24.058  - info: admin.0 (425) http server listening on port 8081
                    2022-10-22 13:29:24.061  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                    2022-10-22 13:29:24.085  - info: admin.0 (425) socket.io server listening on port 8081
                    2022-10-22 13:29:24.850  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                    2022-10-22 13:29:25.885  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                    2022-10-22 13:29:26.136  - info: discovery.0 (448) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:29:27.813  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                    2022-10-22 13:29:28.189  - info: admin.0 (425) Repository received successfully.
                    2022-10-22 13:29:29.895  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:29:29.984  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                    2022-10-22 13:35:35.192  - info: host.buanet-iobroker1 received SIGTERM
                    2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                    2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                    2022-10-22 13:35:35.201  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                    2022-10-22 13:35:35.211  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:35:35.209  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:35:35.211  - info: discovery.0 (448) Got terminate signal TERMINATE_YOURSELF
                    2022-10-22 13:35:35.212  - info: backitup.0 (467) cleaned everything up...
                    2022-10-22 13:35:35.214  - info: backitup.0 (467) terminating
                    2022-10-22 13:35:35.216  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:35:35.221  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                    2022-10-22 13:35:35.217  - info: discovery.0 (448) terminating
                    2022-10-22 13:35:35.221  - info: discovery.0 (448) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:35:35.214  - info: admin.0 (425) terminating http server on port 8081
                    2022-10-22 13:35:35.220  - info: admin.0 (425) terminating
                    2022-10-22 13:35:35.224  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-10-22 13:35:35.258  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                    2022-10-22 13:35:35.259  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                    2022-10-22 13:35:35.829  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:35:35.855  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:35:35.887  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-10-22 13:35:35.888  - info: host.buanet-iobroker1 All instances are stopped.
                    2022-10-22 13:35:36.149  - info: host.buanet-iobroker1 terminated
                    2022-10-22 13:36:13.277  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                    2022-10-22 13:36:13.285  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2022-10-22 13:36:13.288  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                    2022-10-22 13:36:15.271  - info: host.buanet-iobroker1 connected to Objects and States
                    2022-10-22 13:36:15.303  - info: host.buanet-iobroker1 added notifications configuration of host
                    2022-10-22 13:36:15.689  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                    2022-10-22 13:36:15.697  - info: host.buanet-iobroker1 3 instances found
                    2022-10-22 13:36:15.710  - info: host.buanet-iobroker1 starting 3 instances
                    2022-10-22 13:36:15.779  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                    2022-10-22 13:36:15.800  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                    2022-10-22 13:36:15.855  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                    2022-10-22 13:36:15.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                    2022-10-22 13:36:15.882  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                    2022-10-22 13:36:15.896  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                    2022-10-22 13:36:15.910  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                    2022-10-22 13:36:18.138  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:36:18.201  - info: admin.0 (426) requesting all states
                    2022-10-22 13:36:18.202  - info: admin.0 (426) requesting all objects
                    2022-10-22 13:36:19.653  - info: admin.0 (426) received all objects
                    2022-10-22 13:36:19.881  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 449
                    2022-10-22 13:36:20.384  - info: admin.0 (426) http server listening on port 8081
                    2022-10-22 13:36:20.385  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                    2022-10-22 13:36:20.396  - info: admin.0 (426) socket.io server listening on port 8081
                    2022-10-22 13:36:21.894  - info: discovery.0 (449) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:36:23.752  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 468
                    2022-10-22 13:36:25.918  - info: backitup.0 (468) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                    2022-10-22 13:36:25.997  - info: backitup.0 (468) [iobroker] backup was activated at 02:40 every 1 day(s)
                    ^C
                    • Glasfaser
                      Ist OK ...
                      Und immer noch :
                      @glasfaser sagte in Admininterface Docker:
                      Gehe mal beim Browser im inkognito Modus , was ist dann
                        @glasfaser
                        ja ist leider immer noch passiert nix.
                        immer noch startlogo und nix passiert
                        • Glasfaser
                          @marc73
                          Ich habe keine Idee mehr .... 😞
                          bzw. ist es sehr merkwürdig das " nichts " funktioniert und immer der gleiche Fehler ist .
                          Laut Log hast du bridgemodus , was ist im Host ?
                          die Syn mal neu gestartet ... glaube aber nicht das es daran liegt
                          , obwohl es gab mal einen User wo das Docker Paket einen Schuß weg hatte.
                          Er hat das Docker zusatzpaket gelöscht , neu installiert und den ioBroker Docker neu angelegt , danach lief es
                            Homoran Global Moderator Administrators @Glasfaser last edited by
                            @glasfaser hab ich's nur übersehen oder gibt es noch kein Browserlog?
                            • Glasfaser
                              Glasfaser @Homoran last edited by
                              https://forum.iobroker.net/post/877149
                                ich hatte ja auch schonmal alles gelöscht.
                                Ist ja glücklicherweise noch nicht´s drann aber ich verstehe es auch nicht.
                                Ich werde mal genau das machen alles weg und neu + Neustart vom SYN.
                                Ich hatte ja auch schonmal eine ältere Version probiert V6.(weiß ich nicht mehr) da war das gleiche Problem.
                                Alles andere läuft:
                                Unifi-controller, influxdb, grafana.
                                Ich werfe mal alles raus und mache mal neu melde mich dann wieder kurzfristig.
                                Danke euch allen erstmal.
                                  @glasfaser Danke!
                                  ich hab's mal in code-tags gesetzt.
                                  • Glasfaser
                                    Ich auch nicht .... bzw. keine Idee / Lösung mehr dazu !
                                    • Marc Berg
                                      Marc Berg Most Active @Marc73 last edited by
                                      @marc73
                                      Kein Ahnung, ob ich jetzt komplett danebenliege, aber für mich sieht es so aus, als ob der Websockets-Support der Knackpunkt ist. Nutzt Du den Reverseproxy der Synology?
                                      https://mariushosting.com/synology-some-docker-containers-need-websocket/
                                        So ich habe jetzt einmal alles raus geworfen und dann einen anderen Container genommen und zwar den offiziellen iobroker/ioboker
                                        Dann habe ich alles so eingerichtet wie immer im mit Netzwerk im HOSTmodus.
                                        Leider funktionierte es am Anfang leider auch nicht.
                                        Nach einem Blick in den Log war sichtbar das es wohl einen Konflikt mit der Webstation und dem Dockercontainer gibt.
                                        Ich habe dann das benutzerdefinierte Portal gelöscht und den iobroker neu gestartet und was soll ich sagen
                                        ER LÄUFT!!!
                                        Danke @Glasfaser für die Unterstützung.
                                        Ich hoffe es kann später jemand damit was anfangen.
                                        • Glasfaser
                                          ER LÄUFT!!!
                                          Puhh ...
                                          freut mich das es jetzt funktioniert 🙂
                                            Homoran Global Moderator Administrators @Marc Berg last edited by
                                            @marc-berg sagte in Admininterface Docker:
                                            trifft auf mich auch zu.
                                            in der Browserkonsole steht zum einen etwas von ws und trotzdem etwas von socket.io
                                            7ch hab viel zu wenig Ahnung davon um zu wissen ob das ok ist
                                            1488
