    3. Einsteigerfragen
    4. Admininterface Docker
    • Glasfaser
      Glasfaser @Marc73 last edited by
      @marc73
      Füge eine weitere Repo URL dazu :
      iobroker repo add live-stable http://iobroker.live/repo/sources-dist.json
      iobroker repo unset stable
      iobroker repo set live-stable
      iobroker update
      Danach mal den Container neu starten
        Marc73 @Glasfaser last edited by
        @glasfaser
        2022-10-22 13:08:23.653  - info: admin.0 (425) received all objects
        2022-10-22 13:08:23.675  - warn: admin.0 (425) Repository cannot be read: Active repo - live-stable
        2022-10-22 13:08:23.676  - warn: admin.0 (425) Active repository "live-stable" cannot be read
        2022-10-22 13:08:23.880  - info: admin.0 (425) http server listening on port 8081
        2022-10-22 13:08:23.881  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
        2022-10-22 13:08:23.891  - info: admin.0 (425) socket.io server listening on port 8081
        2022-10-22 13:08:24.655  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 452
        2022-10-22 13:08:26.670  - info: discovery.0 (452) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
        2022-10-22 13:08:28.639  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
        2022-10-22 13:08:30.631  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
        2022-10-22 13:08:30.705  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
        habe ich gemacht leider siehe
        Zeile 3:
        Admin ist nicht zu laden 😞
        Glasfaser 2 Replies Last reply Reply Quote 0
        • Glasfaser
          @marc73
          dann ... nur zum TEST auf Beta
          iobroker repo unset live-stable
          iobroker repo set beta
          • Glasfaser
            @marc73 sagte in Admininterface Docker:
            Also der ioBroker Logo Ladekreis ... im Browser !?
            • Glasfaser
              Da ich ein Synology
              im Docker.
              Es ist schon merkwürdig, das es per wget im Container funktioniert ,
              aber ....
              schau mal in der Firewall in der Syn eventuell Blockt da etwas !?
                @glasfaser @glasfaser
                so ich habe jetzt nocheinmal die Firewall in er SYN aus gemacht und im Router hatte ich noch ein Portforwarding auf port 8081 auf einen Controller.
                Auf meinem Ubunutserver läuft das es allerdings alles.
                hier jetzt noch einmal das Protokoll dauert immer etwas muss ich leider zusammensetzen man kann nicht alles aus dem Terminal kopieren.
                root@buanet-iobroker1:/opt/iobroker# iobroker logs --watch
                2022-10-22 08:34:40.902  - info: host.buanet-iobroker1 received SIGTERM
                2022-10-22 08:34:40.924  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                2022-10-22 08:34:40.926  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-10-22 08:34:40.966  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                2022-10-22 08:34:41.006  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                2022-10-22 08:34:40.940  - info: admin.0 (411) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 08:34:41.009  - info: admin.0 (411) terminating http server on port 8081
                2022-10-22 08:34:41.017  - info: admin.0 (411) terminating
                2022-10-22 08:34:41.019  - info: admin.0 (411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 08:34:40.957  - info: backitup.0 (465) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 08:34:41.028  - info: backitup.0 (465) cleaned everything up...
                2022-10-22 08:34:41.031  - info: backitup.0 (465) terminating
                2022-10-22 08:34:41.044  - info: backitup.0 (465) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 08:34:40.951  - info: discovery.0 (446) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 08:34:41.037  - info: discovery.0 (446) terminating
                2022-10-22 08:34:41.044  - info: discovery.0 (446) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 08:34:41.638  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 08:34:41.668  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 08:34:41.682  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 08:34:41.683  - info: host.buanet-iobroker1 All instances are stopped.
                2022-10-22 08:34:41.761  - info: host.buanet-iobroker1 terminated
                2022-10-22 08:35:21.399  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                2022-10-22 08:35:21.406  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-10-22 08:35:21.407  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                2022-10-22 08:35:21.408  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                2022-10-22 08:35:22.436  - info: host.buanet-iobroker1 connected to Objects and States
                2022-10-22 08:35:22.471  - info: host.buanet-iobroker1 added notifications configuration of host
                2022-10-22 08:35:22.901  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                2022-10-22 08:35:22.909  - info: host.buanet-iobroker1 3 instances found
                2022-10-22 08:35:22.923  - info: host.buanet-iobroker1 starting 3 instances
                2022-10-22 08:35:23.027  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 421
                2022-10-22 08:35:23.046  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                2022-10-22 08:35:23.107  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                2022-10-22 08:35:23.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                2022-10-22 08:35:23.155  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                2022-10-22 08:35:23.188  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                2022-10-22 08:35:23.201  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                2022-10-22 08:35:26.039  - info: admin.0 (421) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 08:35:26.096  - info: admin.0 (421) requesting all states
                2022-10-22 08:35:26.097  - info: admin.0 (421) requesting all objects
                2022-10-22 08:35:26.648  - info: admin.0 (421) received all objects
                2022-10-22 08:35:26.814  - info: admin.0 (421) Request actual repository...
                2022-10-22 08:35:26.929  - info: admin.0 (421) http server listening on port 8081
                2022-10-22 08:35:26.933  - info: admin.0 (421) Use link "http://localhost:8081" to configure.
                2022-10-22 08:35:26.968  - info: admin.0 (421) socket.io server listening on port 8081
                2022-10-22 08:35:27.249  - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2022-10-22 08:35:27.435  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 444
                2022-10-22 08:35:31.110  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 459
                2022-10-22 08:35:31.476  - info: admin.0 (421) Repository received successfully.
                2022-10-22 08:35:32.085  - info: discovery.0 (444) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 08:35:33.912  - info: backitup.0 (459) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 08:35:33.984  - info: backitup.0 (459) [iobroker] backup was activated at 02:40 every 1 day(s)
                2022-10-22 13:07:43.210  - info: host.buanet-iobroker1 received SIGTERM
                2022-10-22 13:07:43.216  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                2022-10-22 13:07:43.217  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-10-22 13:07:43.230  - info: admin.0 (421) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:07:43.238  - info: admin.0 (421) terminating http server on port 8081
                2022-10-22 13:07:43.241  - info: admin.0 (421) terminating
                2022-10-22 13:07:43.243  - info: admin.0 (421) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:07:43.239  - info: discovery.0 (444) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:07:43.247  - info: backitup.0 (459) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:07:43.249  - info: discovery.0 (444) terminating
                2022-10-22 13:07:43.251  - info: discovery.0 (444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:07:43.256  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                2022-10-22 13:07:43.257  - info: backitup.0 (459) cleaned everything up...
                2022-10-22 13:07:43.259  - info: backitup.0 (459) terminating
                2022-10-22 13:07:43.261  - info: backitup.0 (459) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:07:43.294  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                2022-10-22 13:07:43.295  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                2022-10-22 13:07:43.873  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:07:43.884  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:07:43.924  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:07:43.925  - info: host.buanet-iobroker1 All instances are stopped.
                2022-10-22 13:07:44.064  - info: host.buanet-iobroker1 terminated
                2022-10-22 13:08:18.617  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                2022-10-22 13:08:18.625  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-10-22 13:08:18.626  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                2022-10-22 13:08:18.627  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                2022-10-22 13:08:20.102  - info: host.buanet-iobroker1 connected to Objects and States
                2022-10-22 13:08:20.130  - info: host.buanet-iobroker1 added notifications configuration of host
                2022-10-22 13:08:20.580  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                2022-10-22 13:08:20.589  - info: host.buanet-iobroker1 3 instances found
                2022-10-22 13:08:20.603  - info: host.buanet-iobroker1 starting 3 instances
                2022-10-22 13:08:20.670  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                2022-10-22 13:08:20.715  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                2022-10-22 13:08:20.802  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                2022-10-22 13:08:20.838  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                2022-10-22 13:08:20.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                2022-10-22 13:08:20.903  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                2022-10-22 13:08:20.929  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                2022-10-22 13:08:23.129  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:08:23.206  - info: admin.0 (425) requesting all states
                2022-10-22 13:08:23.208  - info: admin.0 (425) requesting all objects
                2022-10-22 13:23:36.922  - info: host.buanet-iobroker1 received SIGTERM
                2022-10-22 13:23:36.927  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                2022-10-22 13:23:36.929  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-10-22 13:23:36.941  - info: discovery.0 (452) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:23:36.940  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:23:36.948  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:23:36.948  - info: admin.0 (425) terminating http server on port 8081
                2022-10-22 13:23:36.950  - info: admin.0 (425) terminating
                2022-10-22 13:23:36.952  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:23:36.944  - info: discovery.0 (452) terminating
                2022-10-22 13:23:36.946  - info: discovery.0 (452) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:23:36.951  - info: backitup.0 (467) cleaned everything up...
                2022-10-22 13:23:36.952  - info: backitup.0 (467) terminating
                2022-10-22 13:23:36.954  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:23:36.959  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                2022-10-22 13:23:36.999  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                2022-10-22 13:23:37.000  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                2022-10-22 13:23:37.576  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:23:37.607  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:23:37.608  - info: host.buanet-iobroker1 All instances are stopped.
                2022-10-22 13:23:37.929  - info: host.buanet-iobroker1 terminated
                2022-10-22 13:24:13.013  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                2022-10-22 13:24:13.020  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-10-22 13:24:13.022  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                2022-10-22 13:24:13.023  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                2022-10-22 13:24:14.441  - info: host.buanet-iobroker1 connected to Objects and States
                2022-10-22 13:24:14.475  - info: host.buanet-iobroker1 added notifications configuration of host
                2022-10-22 13:24:14.914  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                2022-10-22 13:24:14.923  - info: host.buanet-iobroker1 3 instances found
                2022-10-22 13:24:14.937  - info: host.buanet-iobroker1 starting 3 instances
                2022-10-22 13:24:14.999  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                2022-10-22 13:24:15.026  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                2022-10-22 13:24:15.083  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                2022-10-22 13:24:15.096  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                2022-10-22 13:24:15.109  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                2022-10-22 13:24:15.123  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                2022-10-22 13:24:15.154  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                2022-10-22 13:24:17.368  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:24:17.459  - info: admin.0 (426) requesting all states
                2022-10-22 13:24:17.461  - info: admin.0 (426) requesting all objects
                2022-10-22 13:24:18.173  - info: admin.0 (426) received all objects
                2022-10-22 13:24:18.197  - warn: admin.0 (426) No repository source configured
                2022-10-22 13:24:18.649  - info: admin.0 (426) Request actual repository...
                2022-10-22 13:24:18.686  - info: admin.0 (426) http server listening on port 8081
                2022-10-22 13:24:18.688  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                2022-10-22 13:24:18.712  - info: admin.0 (426) socket.io server listening on port 8081
                2022-10-22 13:24:19.201  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                2022-10-22 13:24:19.331  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 453
                2022-10-22 13:24:20.196  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                2022-10-22 13:24:27.708  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 464
                2022-10-22 13:24:27.963  - info: admin.0 (426) Repository received successfully.
                2022-10-22 13:24:28.336  - info: discovery.0 (453) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:24:30.424  - info: backitup.0 (464) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:24:30.514  - info: backitup.0 (464) [iobroker] backup was activated at 02:40 every 1 day(s)
                2022-10-22 13:28:42.223  - info: host.buanet-iobroker1 received SIGTERM
                2022-10-22 13:28:42.227  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                2022-10-22 13:28:42.228  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-10-22 13:28:42.235  - info: admin.0 (426) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:28:42.245  - info: discovery.0 (453) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:28:42.246  - info: backitup.0 (464) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:28:42.248  - info: discovery.0 (453) terminating
                2022-10-22 13:28:42.250  - info: discovery.0 (453) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:28:42.238  - info: admin.0 (426) terminating http server on port 8081
                2022-10-22 13:28:42.240  - info: admin.0 (426) terminating
                2022-10-22 13:28:42.253  - info: admin.0 (426) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:28:42.248  - info: backitup.0 (464) cleaned everything up...
                2022-10-22 13:28:42.250  - info: backitup.0 (464) terminating
                2022-10-22 13:28:42.255  - info: backitup.0 (464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:28:42.260  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                2022-10-22 13:28:42.299  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                2022-10-22 13:28:42.300  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                2022-10-22 13:28:42.875  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:28:42.915  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:28:42.920  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:28:42.921  - info: host.buanet-iobroker1 All instances are stopped.
                2022-10-22 13:28:43.071  - info: host.buanet-iobroker1 terminated
                2022-10-22 13:29:17.425  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                2022-10-22 13:29:17.432  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-10-22 13:29:17.433  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.18.0
                2022-10-22 13:29:17.434  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                2022-10-22 13:29:19.096  - info: host.buanet-iobroker1 connected to Objects and States
                2022-10-22 13:29:19.128  - info: host.buanet-iobroker1 added notifications configuration of host
                2022-10-22 13:29:19.516  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                2022-10-22 13:29:19.524  - info: host.buanet-iobroker1 3 instances found
                2022-10-22 13:29:19.537  - info: host.buanet-iobroker1 starting 3 instances
                2022-10-22 13:29:19.604  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 425
                2022-10-22 13:29:19.630  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                2022-10-22 13:29:19.739  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                2022-10-22 13:29:19.752  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                2022-10-22 13:29:19.769  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                2022-10-22 13:29:19.829  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                2022-10-22 13:29:19.842  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                2022-10-22 13:29:21.954  - info: admin.0 (425) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:29:22.059  - info: admin.0 (425) requesting all states
                2022-10-22 13:29:22.060  - info: admin.0 (425) requesting all objects
                2022-10-22 13:29:23.568  - info: admin.0 (425) received all objects
                2022-10-22 13:29:23.634  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 448
                2022-10-22 13:29:24.016  - info: admin.0 (425) Request actual repository...
                2022-10-22 13:29:24.058  - info: admin.0 (425) http server listening on port 8081
                2022-10-22 13:29:24.061  - info: admin.0 (425) Use link "http://localhost:8081" to configure.
                2022-10-22 13:29:24.085  - info: admin.0 (425) socket.io server listening on port 8081
                2022-10-22 13:29:24.850  - info: host.buanet-iobroker1 Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                2022-10-22 13:29:25.885  - info: host.buanet-iobroker1 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                2022-10-22 13:29:26.136  - info: discovery.0 (448) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:29:27.813  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 467
                2022-10-22 13:29:28.189  - info: admin.0 (425) Repository received successfully.
                2022-10-22 13:29:29.895  - info: backitup.0 (467) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:29:29.984  - info: backitup.0 (467) [iobroker] backup was activated at 02:40 every 1 day(s)
                2022-10-22 13:35:35.192  - info: host.buanet-iobroker1 received SIGTERM
                2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
                2022-10-22 13:35:35.198  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 (force=false, process=true)
                2022-10-22 13:35:35.201  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 (force=false, process=true)
                2022-10-22 13:35:35.211  - info: backitup.0 (467) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:35:35.209  - info: admin.0 (425) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:35:35.211  - info: discovery.0 (448) Got terminate signal TERMINATE_YOURSELF
                2022-10-22 13:35:35.212  - info: backitup.0 (467) cleaned everything up...
                2022-10-22 13:35:35.214  - info: backitup.0 (467) terminating
                2022-10-22 13:35:35.216  - info: backitup.0 (467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:35:35.221  - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
                2022-10-22 13:35:35.217  - info: discovery.0 (448) terminating
                2022-10-22 13:35:35.221  - info: discovery.0 (448) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:35:35.214  - info: admin.0 (425) terminating http server on port 8081
                2022-10-22 13:35:35.220  - info: admin.0 (425) terminating
                2022-10-22 13:35:35.224  - info: admin.0 (425) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-10-22 13:35:35.258  - info: host.buanet-iobroker1 stopInstance system.adapter.discovery.0 send kill signal
                2022-10-22 13:35:35.259  - info: host.buanet-iobroker1 stopInstance system.adapter.backitup.0 send kill signal
                2022-10-22 13:35:35.829  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:35:35.855  - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:35:35.887  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-10-22 13:35:35.888  - info: host.buanet-iobroker1 All instances are stopped.
                2022-10-22 13:35:36.149  - info: host.buanet-iobroker1 terminated
                2022-10-22 13:36:13.277  - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
                2022-10-22 13:36:13.285  - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2022-10-22 13:36:13.288  - info: host.buanet-iobroker1 ip addresses: 172.17.0.3
                2022-10-22 13:36:15.271  - info: host.buanet-iobroker1 connected to Objects and States
                2022-10-22 13:36:15.303  - info: host.buanet-iobroker1 added notifications configuration of host
                2022-10-22 13:36:15.689  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeCurrent"
                2022-10-22 13:36:15.697  - info: host.buanet-iobroker1 3 instances found
                2022-10-22 13:36:15.710  - info: host.buanet-iobroker1 starting 3 instances
                2022-10-22 13:36:15.779  - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 426
                2022-10-22 13:36:15.800  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewest"
                2022-10-22 13:36:15.855  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.nodeNewestNext"
                2022-10-22 13:36:15.868  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmCurrent"
                2022-10-22 13:36:15.882  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewest"
                2022-10-22 13:36:15.896  - info: host.buanet-iobroker1 Delete state "system.host.buanet-iobroker1.versions.npmNewestNext"
                2022-10-22 13:36:15.910  - info: host.buanet-iobroker1 Some obsolete host states deleted.
                2022-10-22 13:36:18.138  - info: admin.0 (426) starting. Version 6.2.22 in /opt/iobroker/node_modules/iobroker.admin, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:36:18.201  - info: admin.0 (426) requesting all states
                2022-10-22 13:36:18.202  - info: admin.0 (426) requesting all objects
                2022-10-22 13:36:19.653  - info: admin.0 (426) received all objects
                2022-10-22 13:36:19.881  - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 449
                2022-10-22 13:36:20.384  - info: admin.0 (426) http server listening on port 8081
                2022-10-22 13:36:20.385  - info: admin.0 (426) Use link "http://localhost:8081" to configure.
                2022-10-22 13:36:20.396  - info: admin.0 (426) socket.io server listening on port 8081
                2022-10-22 13:36:21.894  - info: discovery.0 (449) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:36:23.752  - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 468
                2022-10-22 13:36:25.918  - info: backitup.0 (468) starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.18.0, js-controller: 4.0.23
                2022-10-22 13:36:25.997  - info: backitup.0 (468) [iobroker] backup was activated at 02:40 every 1 day(s)
                ^C
                • Glasfaser
                  Glasfaser @Marc73 last edited by Glasfaser
                  Ist OK ...
                  Und immer noch :
                  @glasfaser sagte in Admininterface Docker:
                  Gehe mal beim Browser im inkognito Modus , was ist dann
                    @glasfaser
                    ja ist leider immer noch passiert nix.
                    immer noch startlogo und nix passiert
                    • Glasfaser
                      @marc73
                      Ich habe keine Idee mehr .... 😞
                      bzw. ist es sehr merkwürdig das " nichts " funktioniert und immer der gleiche Fehler ist .
                      Laut Log hast du bridgemodus , was ist im Host ?
                      die Syn mal neu gestartet ... glaube aber nicht das es daran liegt
                      , obwohl es gab mal einen User wo das Docker Paket einen Schuß weg hatte.
                      Er hat das Docker zusatzpaket gelöscht , neu installiert und den ioBroker Docker neu angelegt , danach lief es
                        Homoran Global Moderator Administrators @Glasfaser last edited by
                        @glasfaser hab ich's nur übersehen oder gibt es noch kein Browserlog?
                        • Glasfaser
                          Glasfaser @Homoran last edited by
                          https://forum.iobroker.net/post/877149
                            ich hatte ja auch schonmal alles gelöscht.
                            Ist ja glücklicherweise noch nicht´s drann aber ich verstehe es auch nicht.
                            Ich werde mal genau das machen alles weg und neu + Neustart vom SYN.
                            Ich hatte ja auch schonmal eine ältere Version probiert V6.(weiß ich nicht mehr) da war das gleiche Problem.
                            Alles andere läuft:
                            Unifi-controller, influxdb, grafana.
                            Ich werfe mal alles raus und mache mal neu melde mich dann wieder kurzfristig.
                            Danke euch allen erstmal.
                              @glasfaser Danke!
                              ich hab's mal in code-tags gesetzt.
                              • Glasfaser
                                Ich auch nicht .... bzw. keine Idee / Lösung mehr dazu !
                                • Marc Berg
                                  Marc Berg Most Active @Marc73 last edited by
                                  @marc73
                                  Kein Ahnung, ob ich jetzt komplett danebenliege, aber für mich sieht es so aus, als ob der Websockets-Support der Knackpunkt ist. Nutzt Du den Reverseproxy der Synology?
                                  https://mariushosting.com/synology-some-docker-containers-need-websocket/
                                    So ich habe jetzt einmal alles raus geworfen und dann einen anderen Container genommen und zwar den offiziellen iobroker/ioboker
                                    Dann habe ich alles so eingerichtet wie immer im mit Netzwerk im HOSTmodus.
                                    Leider funktionierte es am Anfang leider auch nicht.
                                    Nach einem Blick in den Log war sichtbar das es wohl einen Konflikt mit der Webstation und dem Dockercontainer gibt.
                                    Ich habe dann das benutzerdefinierte Portal gelöscht und den iobroker neu gestartet und was soll ich sagen
                                    ER LÄUFT!!!
                                    Danke @Glasfaser für die Unterstützung.
                                    Ich hoffe es kann später jemand damit was anfangen.
                                    • Glasfaser
                                      ER LÄUFT!!!
                                      Puhh ...
                                      freut mich das es jetzt funktioniert 🙂
                                        Homoran Global Moderator Administrators @Marc Berg last edited by
                                        @marc-berg sagte in Admininterface Docker:
                                        trifft auf mich auch zu.
                                        in der Browserkonsole steht zum einen etwas von ws und trotzdem etwas von socket.io
                                        7ch hab viel zu wenig Ahnung davon um zu wissen ob das ok ist
                                          Marc73 @Homoran last edited by
                                          Dank euch nochmal !!!
                                          Schönes Rest WE Marco
                                          1488
